[geos-commits] r2905 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Feb 5 16:24:33 EST 2010
Author: mloskot
Date: 2010-02-05 16:24:32 -0500 (Fri, 05 Feb 2010)
New Revision: 2905
   trunk/CMakeLists.txt
Fixed CMake version comparison to disable platform.h (#317)
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2010-02-05 14:54:47 UTC (rev 2904)
+++ trunk/CMakeLists.txt	2010-02-05 21:24:32 UTC (rev 2905)
@@ -14,6 +14,10 @@
 project(geos)
 cmake_minimum_required(VERSION 2.6)
+if(NOT CMAKE_VERSION)
+    set(CMAKE_VERSION "${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
+endif()
 # Location of custom CMake modules with macros used by GEOS
 set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake/modules")
@@ -217,13 +221,19 @@
 # TODO: output to CMAKE_CURRENT_BINARY_DIR instead of CMAKE_SOURCE_DIR
 if(EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
-  if (${CMAKE_VERSION} VERSION_LESS "2.8.0")
+  message(STATUS "Disabling existing ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h")
+  if(${CMAKE_MAJOR_VERSION} EQUAL 2 AND ${CMAKE_MINOR_VERSION} EQUAL 6)
     file(REMOVE ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
+    set(PH_RESULT "removed")
   else()
     file(RENAME
       ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.disabled)
+      set(PH_RESULT "renamed")
   endif()
+  message(STATUS "Disabling existing ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h - ${PH_RESULT}")
 endif()
 configure_file(${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.cmake
@@ -266,6 +276,9 @@
 # DEBUG settings - TODO: make a summary
+message(STATUS "CMake ${CMAKE_VERSION} successfully configured ${PROJECT_NAME} using ${CMAKE_GENERATOR} generator")
 #message(STATUS "XXX: CMAKE_CXX_FLAGS=${CMAKE_CXX_FLAGS}")
 #message(STATUS "XXX: CMAKE_CXX_FLAGS_DEBUG=${CMAKE_CXX_FLAGS_DEBUG}")
 #message(STATUS "XXX: CMAKE_CXX_FLAGS_RELEASE=${CMAKE_CXX_FLAGS_RELEASE}")
More information about the geos-commits mailing list
