[geos-commits] r2910 - in trunk: capi tests/unit/capi
svn_geos at osgeo.org
Thu Feb 11 03:33:32 EST 2010
Author: strk
Date: 2010-02-11 03:33:30 -0500 (Thu, 11 Feb 2010)
New Revision: 2910
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/capi/GEOSGeom_create.cpp
Complete set of typed-empty constructors and tests for them [RT-SIGTA]
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-02-11 08:18:44 UTC (rev 2909)
+++ trunk/capi/geos_c.h.in 2010-02-11 08:33:30 UTC (rev 2910)
@@ -4,6 +4,7 @@
* C-Wrapper for GEOS library
+ * Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -418,12 +419,16 @@
extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint_r(
GEOSContextHandle_t handle,
GEOSCoordSequence* s);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyPoint_r(
+ GEOSContextHandle_t handle);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing_r(
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString_r(
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyLineString_r(
* Second argument is an array of GEOSGeometry* objects.
@@ -446,6 +451,8 @@
GEOSContextHandle_t handle, int type,
GEOSGeometry* *geoms,
unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createEmptyCollection_r(
+ GEOSContextHandle_t handle, int type);
extern GEOSGeometry GEOS_DLL *GEOSGeom_clone(const GEOSGeometry* g);
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-02-11 08:18:44 UTC (rev 2909)
+++ trunk/capi/geos_ts_c.cpp 2010-02-11 08:33:30 UTC (rev 2910)
@@ -4,6 +4,7 @@
* Copyright (C) 2005-2006 Refractions Research Inc.
@@ -2207,6 +2208,67 @@
Geometry *
+GEOSGeom_createEmptyCollection_r(GEOSContextHandle_t extHandle, int type)
+ if ( 0 == extHandle )
+ return NULL;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return NULL;
+#ifdef GEOS_DEBUG
+ char buf[256];
+ sprintf(buf, "createCollection: requested type %d, ngeoms: %d",
+ type, ngeoms);
+ handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
+#endif
+ try
+ const GeometryFactory* gf = handle->geomFactory;
+ Geometry *g = 0;
+ switch (type)
+ case GEOS_GEOMETRYCOLLECTION:
+ g = gf->createGeometryCollection();
+ break;
+ case GEOS_MULTIPOINT:
+ g = gf->createMultiPoint();
+ break;
+ case GEOS_MULTILINESTRING:
+ g = gf->createMultiLineString();
+ break;
+ case GEOS_MULTIPOLYGON:
+ g = gf->createMultiPolygon();
+ break;
+ default:
+ handle->ERROR_MESSAGE("Unsupported type request for GEOSGeom_createEmptyCollection_r");
+ g = 0;
+ return g;
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 0;
+Geometry *
GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type, Geometry **geoms, unsigned int ngeoms)
@@ -2958,6 +3020,38 @@
Geometry *
+GEOSGeom_createEmptyPoint_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ try
+ const GeometryFactory *gf = handle->geomFactory;
+ return gf->createPoint();
+ catch (...)
+ return NULL;
+Geometry *
GEOSGeom_createPoint_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
@@ -3023,6 +3117,39 @@
Geometry *
+GEOSGeom_createEmptyLineString_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ try
+ return gf->createLineString();
+ catch (...)
+ return NULL;
+Geometry *
GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
Modified: trunk/tests/unit/capi/GEOSGeom_create.cpp
--- trunk/tests/unit/capi/GEOSGeom_create.cpp 2010-02-11 08:18:44 UTC (rev 2909)
+++ trunk/tests/unit/capi/GEOSGeom_create.cpp 2010-02-11 08:33:30 UTC (rev 2910)
@@ -58,17 +58,84 @@
// Test Cases
- // EMPTY polygon
+ // EMPTY point
template<>
template<>
void object::test<1>()
+ geom1_ = GEOSGeom_createEmptyPoint_r(handle_);
+ ensure(GEOSisEmpty_r(handle_, geom1_));
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POINT);
+ GEOSGeom_destroy(geom1_); geom1_=0;
+ // EMPTY linestring
+ template<>
+ template<>
+ void object::test<2>()
+ geom1_ = GEOSGeom_createEmptyLineString_r(handle_);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_LINESTRING);
+ // EMPTY polygon
+ template<>
+ template<>
+ void object::test<3>()
geom1_ = GEOSGeom_createEmptyPolygon_r(handle_);
ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_POLYGON);
+ // EMPTY multipoint
+ template<>
+ template<>
+ void object::test<4>()
+ geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOINT);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOINT);
+ // EMPTY multilinestring
+ template<>
+ template<>
+ void object::test<5>()
+ geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTILINESTRING);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTILINESTRING);
+ // EMPTY multipolygon
+ template<>
+ template<>
+ void object::test<6>()
+ geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_MULTIPOLYGON);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_MULTIPOLYGON);
+ // EMPTY collection
+ template<>
+ template<>
+ void object::test<7>()
+ geom1_ = GEOSGeom_createEmptyCollection_r(handle_, GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(GEOSGeomTypeId_r(handle_, geom1_), GEOS_GEOMETRYCOLLECTION);
} // namespace tut
More information about the geos-commits
