[geos-commits] r2922 - in trunk: capi
	include/geos/operation/polygonize src/operation/polygonize
    svn_geos at osgeo.org
    Mon Feb 22 16:41:15 EST 2010
Author: strk
Date: 2010-02-22 16:41:13 -0500 (Mon, 22 Feb 2010)
New Revision: 2922
   trunk/capi/geos_ts_c.cpp
   trunk/include/geos/operation/polygonize/PolygonizeEdge.h
   trunk/include/geos/operation/polygonize/Polygonizer.h
   trunk/src/operation/polygonize/Polygonizer.cpp
Avoid heap allocation of a vector for cut edges, bits of additional documentation
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2010-02-22 21:29:55 UTC (rev 2921)
+++ trunk/capi/geos_ts_c.cpp	2010-02-22 21:41:13 UTC (rev 2922)
@@ -2429,8 +2429,7 @@
         handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
 #endif
-        std::vector<const LineString *>* lines = plgnzr.getCutEdges();
-        assert(0 != lines);
+        const std::vector<const LineString *>& lines = plgnzr.getCutEdges();
 #if GEOS_DEBUG
         handle->NOTICE_MESSAGE("output polygons got");
@@ -2441,13 +2440,12 @@
         // nature, so we explicitly convert.
         // (it's just a waste of processor and memory, btw)
         // XXX mloskot: See comment for GEOSPolygonize_r
-        std::vector<Geometry*> *linevec = new std::vector<Geometry *>(lines->size());
+        std::vector<Geometry*> *linevec = new std::vector<Geometry *>(lines.size());
-        for (std::size_t i = 0; i < lines->size(); ++i)
+        for (std::size_t i = 0, n=lines.size(); i < n; ++i)
-            (*linevec)[i] = (*lines)[i]->clone();
+            (*linevec)[i] = lines[i]->clone();
-        // FIXME mloskot: Who deallocates vector pointed by lines* ?
         const GeometryFactory *gf = handle->geomFactory;
Modified: trunk/include/geos/operation/polygonize/PolygonizeEdge.h
--- trunk/include/geos/operation/polygonize/PolygonizeEdge.h	2010-02-22 21:29:55 UTC (rev 2921)
+++ trunk/include/geos/operation/polygonize/PolygonizeEdge.h	2010-02-22 21:41:13 UTC (rev 2922)
@@ -44,9 +44,14 @@
 class GEOS_DLL PolygonizeEdge: public planargraph::Edge {
 private:
+	// Externally owned
 	const geom::LineString *line;
 public:
+	// Keep the given pointer (won't do anything to it)
 	PolygonizeEdge(const geom::LineString *newLine);
+	// Just return what it was given initially
 	const geom::LineString* getLine();
Modified: trunk/include/geos/operation/polygonize/Polygonizer.h
--- trunk/include/geos/operation/polygonize/Polygonizer.h	2010-02-22 21:29:55 UTC (rev 2921)
+++ trunk/include/geos/operation/polygonize/Polygonizer.h	2010-02-22 21:41:13 UTC (rev 2922)
@@ -114,7 +114,7 @@
 	// initialize with empty collections, in case nothing is computed
 	std::vector<const geom::LineString*> *dangles;
-	std::vector<const geom::LineString*> *cutEdges;
+	std::vector<const geom::LineString*> cutEdges;
 	std::vector<geom::LineString*> *invalidRingLines;
 	std::vector<EdgeRing*> *holeList;
@@ -202,7 +202,7 @@
 	 * TODO: return by const vector reference instead !
-	std::vector<const geom::LineString*>* getCutEdges();
+	const std::vector<const geom::LineString*>& getCutEdges();
 	/** \brief
 	 * Get the list of lines forming invalid rings found during
Modified: trunk/src/operation/polygonize/Polygonizer.cpp
--- trunk/src/operation/polygonize/Polygonizer.cpp	2010-02-22 21:29:55 UTC (rev 2921)
+++ trunk/src/operation/polygonize/Polygonizer.cpp	2010-02-22 21:41:13 UTC (rev 2922)
@@ -63,7 +63,7 @@
 	lineStringAdder(new Polygonizer::LineStringAdder(this)),
 	graph(NULL),
 	dangles(NULL),
-	cutEdges(NULL),
+	cutEdges(),
 	invalidRingLines(NULL),
 	holeList(NULL),
 	shellList(NULL),
@@ -75,7 +75,6 @@
 	delete lineStringAdder;
 	delete dangles;
-	delete cutEdges;
 	delete graph;
 	delete holeList;
@@ -200,7 +199,7 @@
  * Get the list of cut edges found during polygonization.
  * @return a collection of the input {@LineStrings} which are cut edges
-vector<const LineString*>*
+const vector<const LineString*>&
 Polygonizer::getCutEdges()
 	polygonize();
@@ -238,9 +237,7 @@
 	dangles = new std::vector<const LineString*>();
 	graph->deleteDangles(*dangles);
-	// TODO: drop this heap allocation
-	cutEdges = new std::vector<const LineString*>();
-	graph->deleteCutEdges(*cutEdges);
+	graph->deleteCutEdges(cutEdges);
 	vector<EdgeRing*> edgeRingList;
 	graph->getEdgeRings(edgeRingList);
More information about the geos-commits
