[geos-commits] r2925 - in trunk: .
include/geos/operation/polygonize src/operation/polygonize
svn_geos at osgeo.org
Mon Feb 22 17:17:14 EST 2010
Author: strk
Date: 2010-02-22 17:17:13 -0500 (Mon, 22 Feb 2010)
New Revision: 2925
trunk/NEWS
trunk/include/geos/operation/polygonize/Polygonizer.h
trunk/src/operation/polygonize/Polygonizer.cpp
Drop heap allocation of invalidRingLines vector
Modified: trunk/NEWS
--- trunk/NEWS 2010-02-22 22:06:33 UTC (rev 2924)
+++ trunk/NEWS 2010-02-22 22:17:13 UTC (rev 2925)
@@ -8,8 +8,10 @@
- CAPI: GEOSGeom_extractUniquePoints_r
- CAPI: GEOSGetGeometryN support for single geometries
- C++ API changes:
- - Polygonizer::getCutEdges returns a const reference
- - Polygonizer::getDangles returns a const reference
+ - Polygonizer::getCutEdges returns by const ref
+ - Polygonizer::getDangles returns by const ref
+ - Polygonizer::getInvalidRingLines returns by const ref and retains
+ ownership of vector elements
Changes in 3.2.0
Modified: trunk/include/geos/operation/polygonize/Polygonizer.h
--- trunk/include/geos/operation/polygonize/Polygonizer.h 2010-02-22 22:06:33 UTC (rev 2924)
+++ trunk/include/geos/operation/polygonize/Polygonizer.h 2010-02-22 22:17:13 UTC (rev 2925)
@@ -95,10 +95,9 @@
void polygonize();
- /// @todo : take all args by ref
- void findValidRings(std::vector<EdgeRing*>& edgeRingList,
- std::vector<EdgeRing*> *validEdgeRingList,
- std::vector<geom::LineString*> *invalidRingList);
+ void findValidRings(const std::vector<EdgeRing*>& edgeRingList,
+ std::vector<EdgeRing*>& validEdgeRingList,
+ std::vector<geom::LineString*>& invalidRingList);
void findShellsAndHoles(const std::vector<EdgeRing*>& edgeRingList);
@@ -115,7 +114,7 @@
// initialize with empty collections, in case nothing is computed
std::vector<const geom::LineString*> dangles;
std::vector<const geom::LineString*> cutEdges;
- std::vector<geom::LineString*> *invalidRingLines;
+ std::vector<geom::LineString*> invalidRingLines;
std::vector<EdgeRing*> holeList;
std::vector<EdgeRing*> shellList;
@@ -203,15 +202,11 @@
* Get the list of lines forming invalid rings found during
* polygonization.
- * @return a collection of LineStrings which form invalid rings
- * Ownership of vector is tranferred to caller.
- * On second call will return NULL (unless polygonize is called again).
- * Elements of vector will need be released by caller (or will be
- * released by this class if nobody ever called this method).
+ * @return a (possibly empty) collection of pointers to
+ * the input LineStrings which form invalid rings
- * TODO: always retain ownership of vector and elements, return by const ref !
- std::vector<geom::LineString*>* getInvalidRingLines();
+ const std::vector<geom::LineString*>& getInvalidRingLines();
// This seems to be needed by GCC 2.95.4
friend class Polygonizer::LineStringAdder;
Modified: trunk/src/operation/polygonize/Polygonizer.cpp
--- trunk/src/operation/polygonize/Polygonizer.cpp 2010-02-22 22:06:33 UTC (rev 2924)
+++ trunk/src/operation/polygonize/Polygonizer.cpp 2010-02-22 22:17:13 UTC (rev 2925)
@@ -64,7 +64,7 @@
graph(NULL),
dangles(),
cutEdges(),
- invalidRingLines(NULL),
+ invalidRingLines(),
holeList(),
shellList(),
polyList(NULL)
@@ -76,12 +76,9 @@
delete lineStringAdder;
delete graph;
- if ( invalidRingLines )
- for (unsigned int i=0, n=invalidRingLines->size(); i<n; ++i)
- delete (*invalidRingLines)[i];
- delete invalidRingLines;
+ for (unsigned int i=0, n=invalidRingLines.size(); i<n; ++i)
+ delete invalidRingLines[i];
if ( polyList )
for (unsigned int i=0, n=polyList->size(); i<n; ++i)
@@ -197,17 +194,12 @@
return cutEdges;
- * Get the list of lines forming invalid rings found during polygonization.
- * @return a collection of the input {@LineStrings} which form invalid rings
-vector<LineString*>*
+/* public */
+const vector<LineString*>&
Polygonizer::getInvalidRingLines()
polygonize();
- vector<LineString*> *ret = invalidRingLines;
- invalidRingLines = NULL;
- return ret;
+ return invalidRingLines;
/* public */
@@ -232,8 +224,8 @@
cerr<<"Polygonizer::polygonize(): "<<edgeRingList.size()<<" edgeRings in graph"<<endl;
#endif
vector<EdgeRing*> validEdgeRingList;
- invalidRingLines=new vector<LineString*>();
- findValidRings(edgeRingList, &validEdgeRingList, invalidRingLines);
+ invalidRingLines.clear(); /* what if it was populated already ? we should clean ! */
+ findValidRings(edgeRingList, validEdgeRingList, invalidRingLines);
#if GEOS_DEBUG
cerr<<" "<<validEdgeRingList.size()<<" valid"<<endl;
cerr<<" "<<invalidRingLines.size()<<" invalid"<<endl;
@@ -256,9 +248,9 @@
/* private */
void
-Polygonizer::findValidRings(vector<EdgeRing*>& edgeRingList,
- vector<EdgeRing*> *validEdgeRingList,
- vector<LineString*> *invalidRingList)
+Polygonizer::findValidRings(const vector<EdgeRing*>& edgeRingList,
+ vector<EdgeRing*>& validEdgeRingList,
+ vector<LineString*>& invalidRingList)
typedef vector<EdgeRing*> EdgeRingList;
@@ -266,10 +258,14 @@
EdgeRing *er = edgeRingList[i];
if (er->isValid())
- validEdgeRingList->push_back(er);
+ validEdgeRingList.push_back(er);
else
- invalidRingList->push_back(er->getLineString());
+ // NOTE: polygonize::EdgeRing::getLineString
+ // returned LineString ownership is transferred.
+ invalidRingList.push_back(er->getLineString());
More information about the geos-commits
