[geos-commits] r2848 - trunk/include/geos/noding
svn_geos at osgeo.org
Wed Jan 13 16:35:51 EST 2010
Author: mloskot
Date: 2010-01-13 16:35:51 -0500 (Wed, 13 Jan 2010)
New Revision: 2848
trunk/include/geos/noding/NodedSegmentString.h
* Successfully compiled with Visual C++ 8.0 after restructuring source tree.
** NodedSegmentString class;
** Use explicit self-describing two-step casts to indicate what's really happening - C-cast is evil and hides serious interface issues.
** Added missing <cstddef> and qualify size_t with std namespace.
Modified: trunk/include/geos/noding/NodedSegmentString.h
--- trunk/include/geos/noding/NodedSegmentString.h 2010-01-13 21:25:46 UTC (rev 2847)
+++ trunk/include/geos/noding/NodedSegmentString.h 2010-01-13 21:35:51 UTC (rev 2848)
@@ -30,6 +30,8 @@
//#include <geos/noding/Octant.h>
#include <geos/geom/Coordinate.h>
+#include <cstddef>
#ifdef _MSC_VER
#pragma warning(push)
#pragma warning(disable: 4355) // warning C4355: 'this' : used in base member initializer list
@@ -54,18 +56,19 @@
public:
- static void getNodedSubstrings(SegmentString::ConstVect* segStrings,
- SegmentString::NonConstVect* resultEdgelist)
- for (size_t i=0, n=segStrings->size(); i<n; i++)
- NodedSegmentString * nss = (NodedSegmentString *)((*segStrings)[i]);
- nss->getNodeList().addSplitEdges( resultEdgelist);
+ static void getNodedSubstrings(SegmentString::ConstVect* segStrings,
+ SegmentString::NonConstVect* resultEdgelist)
+ for (ConstVect::size_type i=0, n=segStrings->size(); i<n; i++)
+ NodedSegmentString const* nss =
+ static_cast<NodedSegmentString const*>((*segStrings)[i]);
- const SegmentString::NonConstVect& segStrings,
+ const_cast<NodedSegmentString*>(nss)->getNodeList().addSplitEdges( resultEdgelist);
+ static void getNodedSubstrings(const SegmentString::NonConstVect& segStrings,
SegmentString::NonConstVect* resultEdgeList);
/// Returns allocated object
@@ -82,16 +85,14 @@
* @param data the user-defined data of this segment string
* (may be null)
- NodedSegmentString(geom::CoordinateSequence *newPts,
- const void* newContext)
- NodableSegmentString(newContext),
- nodeList(this),
- pts(newPts)
+ NodedSegmentString(geom::CoordinateSequence *newPts, const void* newContext)
+ : NodableSegmentString(newContext)
+ , nodeList(this)
+ , pts(newPts)
~NodedSegmentString()
* Adds an intersection node for a given point and segment to this segment string.
@@ -102,15 +103,16 @@
* @param segmentIndex the index of the segment containing the intersection
* @return the intersection node for the point
- SegmentNode * addIntersectionNode( geom::Coordinate * intPt, size_t segmentIndex)
+ SegmentNode* addIntersectionNode( geom::Coordinate * intPt, std::size_t segmentIndex)
- size_t normalizedSegmentIndex = segmentIndex;
+ std::size_t normalizedSegmentIndex = segmentIndex;
// normalize the intersection point location
- size_t nextSegIndex = normalizedSegmentIndex + 1;
+ std::size_t nextSegIndex = normalizedSegmentIndex + 1;
if (nextSegIndex < size())
- const geom::Coordinate &nextPt = getCoordinate( nextSegIndex);
+ geom::Coordinate const& nextPt =
+ getCoordinate(static_cast<unsigned int>(nextSegIndex));
// Normalize segment index if intPt falls on vertex
// The check for point equality is 2D only - Z values are ignored
@@ -131,7 +133,7 @@
virtual unsigned int size() const
- return pts->size();
+ return static_cast<unsigned int>(pts->size());
virtual const geom::Coordinate& getCoordinate(unsigned int i) const;
More information about the geos-commits
