[geos-commits] r2854 - in trunk/include/geos: . util
svn_geos at osgeo.org
Sat Jan 16 15:12:23 EST 2010
Author: mloskot
Date: 2010-01-16 15:12:23 -0500 (Sat, 16 Jan 2010)
New Revision: 2854
trunk/include/geos/platform.h.in
trunk/include/geos/util/math.h
Unified detection of math features to define FINITE and ISNAN macros
Modified: trunk/include/geos/platform.h.in
--- trunk/include/geos/platform.h.in 2010-01-16 18:14:41 UTC (rev 2853)
+++ trunk/include/geos/platform.h.in 2010-01-16 20:12:23 UTC (rev 2854)
@@ -45,7 +45,6 @@
#include <float.h>
#endif
-#include <cmath> // for finite()/isfinite() and isnan()
#include <limits> // for std::numeric_limits
@@ -59,28 +58,6 @@
#define DoubleMax std::numeric_limits<double>::max()
-inline bool
-isFinite(double d)
-#if defined(HAVE_FINITE) && !defined(HAVE_ISFINITE) && !defined(__MINGW32__)
- return (finite(d));
-#else
- // Put using namespace std; here if you have to
- // put it anywhere.
- using namespace std;
- return (isfinite(d));
-#endif
-#define FINITE(x) ( isFinite(x) )
-#ifdef HAVE_ISNAN
-#define ISNAN(x) ( isnan(x) )
-#else
-// Hack for OS/X <cmath> incorrectly re-defining isnan() into
-// oblivion. It does leave a version in std.
-#define ISNAN(x) ( std::isnan(x) )
-#endif
#ifdef HAVE_INT64_T_64
typedef int64_t int64;
#else
@@ -95,4 +72,35 @@
# endif
#endif
+#if defined(HAVE_FINITE) && !defined(HAVE_ISFINITE)
+# define FINITE(x) (finite(x))
+#else
+# if defined(_MSC_VER)
+# define FINITE(x) _finite(static_cast<double>(x))
+# else
+# define FINITE(x) (isfinite(x))
+# endif
#endif
+#if defined(HAVE_ISNAN)
+# define ISNAN(x) (isnan(x))
+#else
+# define ISNAN(x) _isnan(x)
+# elif defined(__OSX__)
+ // Hack for OS/X <cmath> incorrectly re-defining isnan() into oblivion.
+ // It does leave a version in std.
+# define ISNAN(x) (std::isnan(x))
+# endif
+#endif
+#ifndef FINITE
+#error "Can not compile without finite or isfinite function or macro"
+#endif
+#ifndef ISNAN
+#error "Can not compile without isnan function or macro"
+#endif
+#endif
Modified: trunk/include/geos/util/math.h
--- trunk/include/geos/util/math.h 2010-01-16 18:14:41 UTC (rev 2853)
+++ trunk/include/geos/util/math.h 2010-01-16 20:12:23 UTC (rev 2854)
@@ -17,8 +17,7 @@
#ifndef GEOS_UTIL_MATH_H
#define GEOS_UTIL_MATH_H
-namespace geos {
-namespace util { // geos::util
+namespace geos { namespace util {
/// Symmetric Rounding Algorithm
double sym_round(double val);
@@ -30,18 +29,16 @@
double rint_vc(double val);
/// Default rounding method for GEOS
-/// Always use this rounding method, to easy
-/// easy switching between different rounding
-/// method for the whole codebase
-inline double round(double val) {
+/// @note Always use this rounding method, to easy easy switching
+/// between different rounding method for the whole codebase.
+inline double round(double val)
return java_math_round(val);
-} // namespace geos.util
+}} // namespace geos::util
#endif // GEOS_UTIL_MATH_H
More information about the geos-commits
