[geos-commits] r2865 - in trunk: . include src
svn_geos at osgeo.org
Sun Jan 17 18:06:27 EST 2010
Author: mloskot
Date: 2010-01-17 18:06:26 -0500 (Sun, 17 Jan 2010)
New Revision: 2865
Added:
trunk/include/CMakeLists.txt
trunk/CMakeLists.txt
trunk/src/CMakeLists.txt
Configured 'make install' target for GEOS C++ static library archive and headers (#317)
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2010-01-17 03:21:21 UTC (rev 2864)
+++ trunk/CMakeLists.txt 2010-01-17 23:06:26 UTC (rev 2865)
@@ -136,7 +136,7 @@
# Configure subdirectories
+add_subdirectory(include)
add_subdirectory(src)
add_subdirectory(capi)
add_subdirectory(tests)
Added: trunk/include/CMakeLists.txt
--- trunk/include/CMakeLists.txt (rev 0)
+++ trunk/include/CMakeLists.txt 2010-01-17 23:06:26 UTC (rev 2865)
@@ -0,0 +1,22 @@
+# $Id$
+# GEOS C++ library build configuration for CMake build system
+# Copyright (C) 2009 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+install(FILES geos.h DESTINATION include/geos)
+install(DIRECTORY geos/
+ DESTINATION include/geos
+ FILES_MATCHING
+ PATTERN "*.h"
+ PATTERN "*.inl"
+ PATTERN ".svn" EXCLUDE)
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt 2010-01-17 03:21:21 UTC (rev 2864)
+++ trunk/src/CMakeLists.txt 2010-01-17 23:06:26 UTC (rev 2865)
@@ -15,3 +15,8 @@
file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
add_library(geos STATIC ${geos_SOURCES})
+install(TARGETS geos
+ RUNTIME DESTINATION bin
+ LIBRARY DESTINATION lib
+ ARCHIVE DESTINATION lib)
More information about the geos-commits
