[geos-commits] r2868 - in trunk: include/geos src/algorithm
src/algorithm/locate src/noding/snapround
src/operation/buffer src/operation/overlay/snap
src/operation/overlay/validate
svn_geos at osgeo.org
Sun Jan 17 19:59:23 EST 2010
Author: mloskot
Date: 2010-01-17 19:59:21 -0500 (Sun, 17 Jan 2010)
New Revision: 2868
trunk/include/geos/platform.h.cmake
trunk/src/algorithm/CGAlgorithms.cpp
trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
trunk/src/noding/snapround/HotPixel.cpp
trunk/src/operation/buffer/BufferOp.cpp
trunk/src/operation/overlay/snap/GeometrySnapper.cpp
trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
* Successfully tested CMake configuration with Visual Studio 2010 (#317).
* Disable argument dependant lookup (Koenig) for min/max functions to make sure GEOS compiles in the presence of the min/max macros.
* Some platform headers define min() and max() macros which cause some common C++ constructs to fail to compile.
Modified: trunk/include/geos/platform.h.cmake
--- trunk/include/geos/platform.h.cmake 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/include/geos/platform.h.cmake 2010-01-18 00:59:21 UTC (rev 2868)
@@ -151,13 +151,12 @@
# error "Could not find finite or isfinite function or macro!"
#endif
+#include <limits>
+#define DoubleNegInfinity (-(std::numeric_limits<double>::infinity)())
+#define DoubleMax (std::numeric_limits<double>::max)()
+// Defines NaN for Intel platforms
+#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
+// Don't forget to define infinities
+#define DoubleInfinity (std::numeric_limits<double>::infinity)()
-#include <limits>
-#define DoubleNegInfinity -std::numeric_limits<double>::infinity()
-#define DoubleMax std::numeric_limits<double>::max()
-// Defines NaN for Intel platforms
-#define DoubleNotANumber std::numeric_limits<double>::quiet_NaN()
-// Don't forget to define infinities
-#define DoubleInfinity std::numeric_limits<double>::infinity()
#endif // GEOS_PLATFORM_H_INCLUDED
Modified: trunk/src/algorithm/CGAlgorithms.cpp
--- trunk/src/algorithm/CGAlgorithms.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/algorithm/CGAlgorithms.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -284,17 +284,17 @@
double s_top=(A.y-C.y)*(B.x-A.x)-(A.x-C.x)*(B.y-A.y);
double s_bot=(B.x-A.x)*(D.y-C.y)-(B.y-A.y)*(D.x-C.x);
if ((r_bot==0)||(s_bot==0)) {
- return std::min(distancePointLine(A,C,D),
- std::min(distancePointLine(B,C,D),
- std::min(distancePointLine(C,A,B), distancePointLine(D,A,B))));
+ return (std::min)(distancePointLine(A,C,D),
+ (std::min)(distancePointLine(B,C,D),
+ (std::min)(distancePointLine(C,A,B), distancePointLine(D,A,B))));
double s=s_top/s_bot;
double r=r_top/r_bot;
if ((r<0)||( r>1)||(s<0)||(s>1)) {
//no intersection
return 0.0; //intersection exists
Modified: trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp
--- trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/algorithm/locate/IndexedPointInAreaLocator.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -75,8 +75,8 @@
for ( size_t i = 1, ni = pts->size(); i < ni; i++ )
geom::LineSegment * seg = new geom::LineSegment( (*pts)[ i - 1 ], (*pts)[ i ]);
- double min = std::min( seg->p0.y, seg->p1.y);
- double max = std::max( seg->p0.y, seg->p1.y);
+ double const min = (std::min)( seg->p0.y, seg->p1.y);
+ double const max = (std::max)( seg->p0.y, seg->p1.y);
// NOTE: seg ownership still ours
allocatedSegments.push_back(seg);
Modified: trunk/src/noding/snapround/HotPixel.cpp
--- trunk/src/noding/snapround/HotPixel.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/noding/snapround/HotPixel.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -101,10 +101,10 @@
const Coordinate& p1) const
- double segMinx = std::min(p0.x, p1.x);
- double segMaxx = std::max(p0.x, p1.x);
- double segMiny = std::min(p0.y, p1.y);
- double segMaxy = std::max(p0.y, p1.y);
+ double const segMinx = (std::min)(p0.x, p1.x);
+ double const segMaxx = (std::max)(p0.x, p1.x);
+ double const segMiny = (std::min)(p0.y, p1.y);
+ double const segMaxy = (std::max)(p0.y, p1.y);
bool isOutsidePixelEnv = maxx < segMinx
|| minx > segMaxx
Modified: trunk/src/operation/buffer/BufferOp.cpp
--- trunk/src/operation/buffer/BufferOp.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/operation/buffer/BufferOp.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -67,7 +67,7 @@
int maxPrecisionDigits)
const Envelope *env=g->getEnvelopeInternal();
- double envSize=std::max(env->getHeight(), env->getWidth());
+ double envSize=(std::max)(env->getHeight(), env->getWidth());
double expandByDistance=distance > 0.0 ? distance : 0.0;
double bufEnvSize=envSize + 2 * expandByDistance;
// the smallest power of 10 greater than the buffer envelope
Modified: trunk/src/operation/overlay/snap/GeometrySnapper.cpp
--- trunk/src/operation/overlay/snap/GeometrySnapper.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/operation/overlay/snap/GeometrySnapper.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -120,7 +120,7 @@
GeometrySnapper::computeSizeBasedSnapTolerance(const geom::Geometry& g)
const Envelope* env = g.getEnvelopeInternal();
- double minDimension = std::min(env->getHeight(), env->getWidth());
+ double minDimension = (std::min)(env->getHeight(), env->getWidth());
double snapTol = minDimension * snapPrecisionFactor;
return snapTol;
@@ -156,7 +156,7 @@
GeometrySnapper::computeOverlaySnapTolerance(const geom::Geometry& g1,
const geom::Geometry& g2)
- return std::min(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
+ return (std::min)(computeOverlaySnapTolerance(g1), computeOverlaySnapTolerance(g2));
/* public static */
Modified: trunk/src/operation/overlay/validate/OverlayResultValidator.cpp
--- trunk/src/operation/overlay/validate/OverlayResultValidator.cpp 2010-01-17 23:54:32 UTC (rev 2867)
+++ trunk/src/operation/overlay/validate/OverlayResultValidator.cpp 2010-01-18 00:59:21 UTC (rev 2868)
@@ -235,12 +235,12 @@
/*private static*/
double
OverlayResultValidator::computeBoundaryDistanceTolerance(
- const geom::Geometry& g0, const geom::Geometry& g1)
+ const geom::Geometry& g0, const geom::Geometry& g1)
- using geos::operation::overlay::snap::GeometrySnapper;
+ using geos::operation::overlay::snap::GeometrySnapper;
- return std::min(GeometrySnapper::computeSizeBasedSnapTolerance(g0),
- GeometrySnapper::computeSizeBasedSnapTolerance(g1));
+ return (std::min)(GeometrySnapper::computeSizeBasedSnapTolerance(g0),
+ GeometrySnapper::computeSizeBasedSnapTolerance(g1));
} // namespace geos.operation.overlay.validate
More information about the geos-commits
