[geos-commits] r2884 - trunk
    svn_geos at osgeo.org
    Fri Jan 22 19:10:59 EST 2010
Author: mloskot
Date: 2010-01-22 19:10:58 -0500 (Fri, 22 Jan 2010)
New Revision: 2884
   trunk/CMakeLists.txt
Tweaked detection isfinite and isnan declared as functions in C++ (#317)
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt	2010-01-22 23:52:24 UTC (rev 2883)
+++ trunk/CMakeLists.txt	2010-01-23 00:10:58 UTC (rev 2884)
@@ -14,7 +14,8 @@
 project(geos)
 cmake_minimum_required(VERSION 2.6)
-#set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake")
+# Location of custom CMake modules with macros used by GEOS
+set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake/modules")
 # Setup GEOS version
@@ -143,28 +144,27 @@
 endif()
 # check functions and macros
+include(CheckPrototypeExists)
 include(CheckSymbolExists)
-include(CheckFunctionExists)
-# TODO: This needs to be improved --mloskot
-check_symbol_exists(std::isnan cmath HAVE_STD_ISNAN)
+check_prototype_exists(isnan cmath HAVE_STD_ISNAN)
 if(NOT HAVE_STD_ISNAN)
   if(MSVC)
-    check_symbol_exists(_isnan float.h HAVE_ISNAN)
+    check_prototype_exists(_isnan float.h HAVE_ISNAN)
   elseif(APPLE)
-    check_symbol_exists(__isnand math.h HAVE_ISNAND_XCODE)
+    check_prototype_exists(__isnand math.h HAVE_ISNAND_XCODE)
     if(NOT HAVE_ISNAND_XCODE)
-      check_symbol_exists(__inline_isnand math.h HAVE_INLINE_ISNAND_XCODE)
+      check_prototype_exists(__inline_isnand math.h HAVE_INLINE_ISNAND_XCODE)
     endif()
   else()
     check_symbol_exists(isnan math.h HAVE_ISNAN)
   endif()
 endif()
-check_symbol_exists(std::isfinite cmath HAVE_STD_ISFINITE)
+check_prototype_exists(isfinite cmath HAVE_STD_ISFINITE)
 if(NOT HAVE_STD_ISFINITE)
   if(MSVC)
-    check_symbol_exists(_finite float.h HAVE_FINITE)
+    check_prototype_exists(_finite float.h HAVE_FINITE)
   else()
     check_symbol_exists(isfinite math.h HAVE_ISFINITE)
   endif()
More information about the geos-commits
