[geos-commits] r2893 - in trunk: . include/geos
svn_geos at osgeo.org
Fri Jan 29 12:42:10 EST 2010
Author: mloskot
Date: 2010-01-29 12:42:07 -0500 (Fri, 29 Jan 2010)
New Revision: 2893
trunk/CMakeLists.txt
trunk/include/geos/platform.h.cmake
Solved problem with repeated definition of getMachineByteOrder (#317). Added check if alternative platform.h is already present in the include/geos directory and deactivate it renaming to platform.h.disable, before generating CMake-specific platform.h. Tested on Windows with Visual C++ but with -DGEOS_ENABLE_INLINE=OFF otherwise DLL linking fails with many redefined symbols - to be checked.
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2010-01-29 01:43:22 UTC (rev 2892)
+++ trunk/CMakeLists.txt 2010-01-29 17:42:07 UTC (rev 2893)
@@ -86,18 +86,20 @@
elseif(MSVC)
# Set pedantic mode by default
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
+ #set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
+ string(REGEX REPLACE "/W[0-9]" "/W4" CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
+ message(STATUS "Z: ${CMAKE_CXX_FLAGS}")
if(MSVC80 OR MSVC90 OR MSVC10)
# Option is to enable the /MP switch for Visual Studio 2005 or later
option(GEOS_MSVC_ENABLE_MP
- "Set to ON to build GEOS with the /MP option (Visual Studio 2005 and above)." OFF)
+ "Set to ON to build GEOS with the /MP option (Visual Studio 2005 and above)." ON)
mark_as_advanced(GEOS_MSVC_ENABLE_MP)
if(GEOS_MSVC_ENABLE_MP)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
endif()
- message(STATUS "Setting Visual Studio 2005+ option /MP to ${ENABLE_MSVC_MP}")
+ message(STATUS "Setting Visual Studio 2005+ option /MP to ${GEOS_MSVC_ENABLE_MP}")
# Disable C4996: 'function': was declared deprecated
add_definitions(-D_SCL_SECURE_NO_WARNINGS)
@@ -198,6 +200,12 @@
# TODO: output to CMAKE_CURRENT_BINARY_DIR instead of CMAKE_SOURCE_DIR
+if(EXISTS ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h)
+ file(RENAME
+ ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h
+ ${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.disabled)
+endif()
configure_file(${CMAKE_CURRENT_SOURCE_DIR}/include/geos/platform.h.cmake
${CMAKE_CURRENT_BINARY_DIR}/include/geos/platform.h)
Modified: trunk/include/geos/platform.h.cmake
--- trunk/include/geos/platform.h.cmake 2010-01-29 01:43:22 UTC (rev 2892)
+++ trunk/include/geos/platform.h.cmake 2010-01-29 17:42:07 UTC (rev 2893)
@@ -20,6 +20,9 @@
#ifndef GEOS_PLATFORM_H_INCLUDED
#define GEOS_PLATFORM_H_INCLUDED
+/* Disable inclusion of platform.h not generated by CMake */
+#define GEOS_PLATFORM_H 1
/* Set to 1 if you have stdint.h */
#cmakedefine HAVE_STDINT_H 1
More information about the geos-commits
