[geos-commits] r2999 - in trunk: src/io tests/unit/io
svn_geos at osgeo.org
Tue Jun 1 11:15:04 EDT 2010
Author: warmerdam
Date: 2010-06-01 11:15:03 -0400 (Tue, 01 Jun 2010)
New Revision: 2999
trunk/src/io/WKTReader.cpp
trunk/tests/unit/io/WKTReaderTest.cpp
make WKTReader keywords case insensitive
Modified: trunk/src/io/WKTReader.cpp
--- trunk/src/io/WKTReader.cpp 2010-05-31 16:25:57 UTC (rev 2998)
+++ trunk/src/io/WKTReader.cpp 2010-06-01 15:15:03 UTC (rev 2999)
@@ -199,7 +199,16 @@
case StringTokenizer::TT_NUMBER:
throw ParseException("Expected word but encountered number", tokenizer->getNVal());
case StringTokenizer::TT_WORD:
- return tokenizer->getSVal();
+ string word = tokenizer->getSVal();
+ int i = word.size();
+ while( --i >= 0 )
+ word[i] = toupper(word[i]);
+ return word;
case '(':
return "(";
case ')':
Modified: trunk/tests/unit/io/WKTReaderTest.cpp
--- trunk/tests/unit/io/WKTReaderTest.cpp 2010-05-31 16:25:57 UTC (rev 2998)
+++ trunk/tests/unit/io/WKTReaderTest.cpp 2010-06-01 15:15:03 UTC (rev 2999)
@@ -109,6 +109,16 @@
delete coords;
+ // 5 - Check support for mixed case keywords (and old style 3D)
+ template<>
+ template<>
+ void object::test<5>()
+ GeomPtr geom(wktreader.read("LineString (-117 33 2, -116 34 4)"));
+ ensure_equals( wktwriter.write(geom.get()),
+ std::string("LINESTRING Z (-117.0 33.0 2.0, -116.0 34.0 4.0)") );
} // namespace tut
More information about the geos-commits
