[geos-commits] r3011 - in trunk/php: . test
svn_geos at osgeo.org
Fri Jun 18 12:15:08 EDT 2010
Author: strk
Date: 2010-06-18 16:15:08 +0000 (Fri, 18 Jun 2010)
New Revision: 3011
trunk/php/geos.c
trunk/php/test/test.php
WKTWriter::setTrim
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-18 16:12:21 UTC (rev 3010)
+++ trunk/php/geos.c 2010-06-18 16:15:08 UTC (rev 3011)
@@ -28,7 +28,7 @@
#include "Zend/zend_exceptions.h" /* for zend_throw_exception_object */
/* GEOS stuff */
-#include <geos_c.h>
+#include "geos_c.h"
/* Own stuff */
#include "php_geos.h"
@@ -278,10 +278,12 @@
PHP_METHOD(WKTWriter, __construct);
PHP_METHOD(WKTWriter, write);
+PHP_METHOD(WKTWriter, setTrim);
static function_entry WKTWriter_methods[] = {
PHP_ME(WKTWriter, __construct, NULL, 0)
PHP_ME(WKTWriter, write, NULL, 0)
+ PHP_ME(WKTWriter, setTrim, NULL, 0)
{NULL, NULL, NULL}
@@ -307,7 +309,6 @@
return Gen_create_obj(type, WKTWriter_dtor, &WKTWriter_object_handlers);
GEOSWKTWriter* obj;
@@ -355,6 +356,24 @@
+ GEOSWKTWriter *writer;
+ zend_bool trimval;
+ char trim;
+ writer = (GEOSWKTWriter*)getRelay(getThis(), WKTWriter_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "b", &trimval)
+ == FAILURE)
+ RETURN_NULL();
+ trim = trimval;
+ GEOSWKTWriter_setTrim(writer, trim);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-18 16:12:21 UTC (rev 3010)
+++ trunk/php/test/test.php 2010-06-18 16:15:08 UTC (rev 3011)
@@ -23,8 +23,16 @@
$geom = $reader->read("POINT(0 0)");
$num = $geom->numGeometries();
echo 'Geom has ' . $num . " geometries, WKT follows:\n";
-echo $writer->write($geom) . "\n";
+echo "[DEFAULT UNTRIMMED]: ".$writer->write($geom) . "\n";
+$writer->setTrim(TRUE);
+echo "[TRIMMED]: ".$writer->write($geom) . "\n";
+$writer->setTrim(FALSE);
+echo "[UNTRIMMED]: ".$writer->write($geom) . "\n";
+echo "We'll do trimmed WKT from now on";
$geom = $reader->read("MULTIPOINT(0 0, 1 1)");
echo 'Geom has ' . $num . " geometries. WKT follows:\n";
More information about the geos-commits
