[geos-commits] r3017 - in trunk/php: . test
svn_geos at osgeo.org
Sat Jun 19 07:34:09 EDT 2010
Author: strk
Date: 2010-06-19 11:34:09 +0000 (Sat, 19 Jun 2010)
New Revision: 3017
trunk/php/TODO
trunk/php/geos.c
trunk/php/test/Makefile.am
trunk/php/test/test.php
Complete implementation of WKTWriter interfaces, add phpunit-based testing, add .project interface to Geometry
Modified: trunk/php/TODO
--- trunk/php/TODO 2010-06-19 11:32:49 UTC (rev 3016)
+++ trunk/php/TODO 2010-06-19 11:34:09 UTC (rev 3017)
@@ -1,7 +1,5 @@
In order of priority
-- Complete all interfaces for WKTReader/WKTWriter/Geometry
-- Doxygen based documentation
-- Proper automated testing (phpunit2?)
+- Complete interfaces of Geometry
- Add interfaces for WKBReader/WKBWriter ?
+- Doxygen based documentation ?
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-19 11:32:49 UTC (rev 3016)
+++ trunk/php/geos.c 2010-06-19 11:34:09 UTC (rev 3017)
@@ -38,7 +38,6 @@
PHP_RSHUTDOWN_FUNCTION(geos);
PHP_MINFO_FUNCTION(geos);
PHP_FUNCTION(GEOSVersion);
-/*PHP_METHOD(WKTReader, write);*/
static function_entry geos_functions[] = {
PHP_FE(GEOSVersion, NULL)
@@ -150,10 +149,13 @@
/* -- class GEOSGeometry -------------------- */
PHP_METHOD(Geometry, __construct);
+PHP_METHOD(Geometry, project);
PHP_METHOD(Geometry, numGeometries);
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
+ PHP_ME(Geometry, project, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -201,6 +203,27 @@
RETURN_LONG(ret);
+ GEOSGeometry *this;
+ GEOSGeometry *other;
+ zval *zobj;
+ double ret;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
+ == FAILURE) {
+ RETURN_NULL();
+ other = getRelay(zobj, Geometry_ce_ptr);
+ ret = GEOSProject(this, other);
+ if ( ret < 0 ) RETURN_NULL(); /* should get an exception first */
+ RETURN_DOUBLE(ret);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
@@ -279,11 +302,17 @@
PHP_METHOD(WKTWriter, __construct);
PHP_METHOD(WKTWriter, write);
PHP_METHOD(WKTWriter, setTrim);
+PHP_METHOD(WKTWriter, setRoundingPrecision);
+PHP_METHOD(WKTWriter, setOutputDimension);
+PHP_METHOD(WKTWriter, setOld3D);
static function_entry WKTWriter_methods[] = {
PHP_ME(WKTWriter, __construct, NULL, 0)
PHP_ME(WKTWriter, write, NULL, 0)
PHP_ME(WKTWriter, setTrim, NULL, 0)
+ PHP_ME(WKTWriter, setRoundingPrecision, NULL, 0)
+ PHP_ME(WKTWriter, setOutputDimension, NULL, 0)
+ PHP_ME(WKTWriter, setOld3D, NULL, 0)
{NULL, NULL, NULL}
@@ -374,6 +403,56 @@
GEOSWKTWriter_setTrim(writer, trim);
+ GEOSWKTWriter *writer;
+ long int prec;
+ writer = (GEOSWKTWriter*)getRelay(getThis(), WKTWriter_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l", &prec)
+ == FAILURE)
+ RETURN_NULL();
+ GEOSWKTWriter_setRoundingPrecision(writer, prec);
+ long int dim;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "l", &dim)
+ == FAILURE)
+ RETURN_NULL();
+ GEOSWKTWriter_setOutputDimension(writer, dim);
+ zend_bool bval;
+ int val;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "b", &bval)
+ == FAILURE)
+ RETURN_NULL();
+ val = bval;
+ GEOSWKTWriter_setOld3D(writer, val);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/Makefile.am
--- trunk/php/test/Makefile.am 2010-06-19 11:32:49 UTC (rev 3016)
+++ trunk/php/test/Makefile.am 2010-06-19 11:34:09 UTC (rev 3017)
@@ -24,12 +24,15 @@
EXTRA_DIST = test.php crashme.php
-if ENABLE_PHP
+if ENABLE_PHP_TESTS
+PHPOPTS = -n -d enable_dl=On -d extension_dir=../.libs
check:
- php -n -d enable_dl=On -d extension_dir=../.libs test.php
+ $(PHP) $(PHPOPTS) $(PHPUNIT) test.php
crashtest:
- php -n -d enable_dl=On -d extension_dir=../.libs crashme.php
+ $(PHP) $(PHPOPTS) crashme.php
endif
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-19 11:32:49 UTC (rev 3016)
+++ trunk/php/test/test.php 2010-06-19 11:34:09 UTC (rev 3017)
@@ -5,39 +5,241 @@
dl("geos.so");
-echo "\n";
-echo "Geos version is: " . GEOSVersion() . "\n";
-echo "\n";
+require_once 'PHPUnit/Framework.php';
-$reader = new GEOSWKTReader();
-$writer = new GEOSWKTWriter();
+class test extends PHPUnit_Framework_TestCase
+ public function testGEOSVersion()
+ $this->assertContains('-CAPI-', GEOSVersion());
-/* BOGUS WKT */
-try {
- $geom = $reader->read("ciao");
-} catch (Exception $e) {
- echo 'EXPECTED [WKTReader::read("ciao")]: ' . $e->getMessage() . "\n";
+ public function testWKTReader__construct()
+ $reader = new GEOSWKTReader();
+ $this->assertNotNull($reader);
-$geom = $reader->read("POINT(0 0)");
-$num = $geom->numGeometries();
-echo 'Geom has ' . $num . " geometries, WKT follows:\n";
-echo "[DEFAULT UNTRIMMED]: ".$writer->write($geom) . "\n";
-$writer->setTrim(TRUE);
-echo "[TRIMMED]: ".$writer->write($geom) . "\n";
-$writer->setTrim(FALSE);
-echo "[UNTRIMMED]: ".$writer->write($geom) . "\n";
+ public function testWKTReader_read()
+ /* Good WKT */
+ $geom = $reader->read('POINT(0 0)');
+ $this->assertNotNull($geom);
+ $geom = $reader->read('MULTIPOINT(0 0 1, 2 3 4)');
+ $geom = $reader->read('MULTIPOINT((0 0), (2 3))');
+ $geom = $reader->read('LINESTRING(0 0 1, 2 3 4)');
+ $geom = $reader->read('MULTILINESTRING((0 0 1, 2 3 4),
+ (10 10 2, 3 4 5))');
+ $geom = $reader->read('POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))');
+ $geom = $reader->read('MULTIPOLYGON(
+ ((0 0, 1 0, 1 1, 0 1, 0 0)),
+ ((10 10, 10 14, 14 14, 14 10, 10 10),
+ (11 11, 11 12, 12 12, 12 11, 11 11))
+ $geom = $reader->read('GEOMETRYCOLLECTION(
+ MULTIPOLYGON(
+ POLYGON((0 0, 1 0, 1 1, 0 1, 0 0)),
+ MULTILINESTRING((0 0, 2 3), (10 10, 3 4)),
+ LINESTRING(0 0, 2 3),
+ MULTIPOINT(0 0, 2 3),
+ POINT(9 0)
-echo "We'll do trimmed WKT from now on";
+ /* BOGUS WKT */
+ try {
+ $reader->read("MULTIDOT(0 1 2 3)");
+ $this->assertTrue(FALSE); # this is just to fail if we get here
+ } catch (Exception $e) {
+ $this->assertContains('ParseException', $e->getMessage());
-$geom = $reader->read("MULTIPOINT(0 0, 1 1)");
-echo 'Geom has ' . $num . " geometries. WKT follows:\n";
-echo $writer->write($geom) . "\n";
+ public function testWKTWriter__construct()
+ $writer = new GEOSWKTWriter();
+ $this->assertNotNull($writer);
-echo "\n";
-echo "\n";
+ public function testWKTWriter_write()
+ try {
+ $writer->write(1);
+ $this->assertContains('expects parameter 1', $e->getMessage());
+ $g = $reader->read('POINT(6 7)');
+ $this->assertEquals('POINT (6.0000000000000000 7.0000000000000000)',
+ $writer->write($g));
+ public function testWKTWriter_setTrim()
+ $this->assertNotNull($g);
+ $writer->setTrim(TRUE);
+ $this->assertEquals('POINT (6 7)',
+ $writer->setTrim(FALSE);
+ public function testWKT_roundTrip()
+ $r = new GEOSWKTReader();
+ $w = new GEOSWKTWriter();
+ $w->setTrim(TRUE);
+ $in[] = 'POINT (0 0)';
+ $in[] = 'MULTIPOINT (0 1, 2 3)';
+ $in[] = 'LINESTRING (0 0, 2 3)';
+ $in[] = 'MULTILINESTRING ((0 1, 2 3), (10 10, 3 4))';
+ $in[] = 'POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))';
+ $in[] = 'MULTIPOLYGON (((0 0, 1 0, 1 1, 0 1, 0 0)), ((10 10, 10 14, 14 14, 14 10, 10 10), (11 11, 11 12, 12 12, 12 11, 11 11)))';
+ $in[] = 'GEOMETRYCOLLECTION (MULTIPOLYGON (((0 0, 1 0, 1 1, 0 1, 0 0)), ((10 10, 10 14, 14 14, 14 10, 10 10), (11 11, 11 12, 12 12, 12 11, 11 11))), POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0)), MULTILINESTRING ((0 0, 2 3), (10 10, 3 4)), LINESTRING (0 0, 2 3), MULTIPOINT (0 0, 2 3), POINT (9 0))';
+ foreach ($in as $i) {
+ $this->assertEquals($i, $w->write($r->read($i)));
+ public function testWKTWriter_setRoundingPrecision()
+ $g = $reader->read('POINT(6.123456 7.123456)');
+ $this->assertEquals('POINT (6.1234560000000000 7.1234560000000000)',
+ $writer->setRoundingPrecision(2);
+ $this->assertEquals('POINT (6.12 7.12)', $writer->write($g));
+ $writer->setRoundingPrecision(5); /* rounds */
+ $this->assertEquals('POINT (6.12346 7.12346)', $writer->write($g));
+ $writer->setRoundingPrecision(1);
+ $this->assertEquals('POINT (6.1 7.1)', $writer->write($g));
+ $writer->setRoundingPrecision(0);
+ $this->assertEquals('POINT (6 7)', $writer->write($g));
+ public function testWKTWriter_setOutputDimension()
+ $g3d = $reader->read('POINT(1 2 3)');
+ $g2d = $reader->read('POINT(3 2)');
+ # Only 2d by default
+ $this->assertEquals('POINT (1 2)', $writer->write($g3d));
+ # 3d if requested _and_ available
+ $writer->setOutputDimension(3);
+ $this->assertEquals('POINT Z (1 2 3)', $writer->write($g3d));
+ $this->assertEquals('POINT (3 2)', $writer->write($g2d));
+ public function testWKTWriter_setOld3D()
+ # New 3d WKT by default
+ # Switch to old
+ $writer->setOld3D(TRUE);
+ $this->assertEquals('POINT (1 2 3)', $writer->write($g3d));
+ # Old3d flag is not reset when changing dimensions
+ $writer->setOutputDimension(2);
+ # Likewise, dimensions spec is not reset when changing old3d flag
+ $writer->setOld3D(FALSE);
+ public function testGeometry_project()
+ $g = $reader->read('POINT(1 2)');
+ $g2 = $reader->read('POINT(3 4)');
+ /* The method only accept lineal geometries */
+ try {
+ $prj = $g->project($g2);
+ $this->assertContains('lineal', $e->getMessage());
+ $g = $reader->read('LINESTRING(0 0, 10 0)');
+ $g2 = $reader->read('POINT(0 0)');
+ $this->assertEquals(0, $prj);
+ $g2 = $reader->read('POINT(10 0)');
+ $this->assertEquals(10, $prj);
+ $g2 = $reader->read('POINT(5 0)');
+ $this->assertEquals(5, $prj);
+ $g = $reader->read('MULTILINESTRING((0 0, 10 0),(20 10, 20 30))');
+ $g2 = $reader->read('POINT(20 0)');
+ $g2 = $reader->read('POINT(20 5)');
More information about the geos-commits
