[geos-commits] r3026 - in trunk/php: . test
svn_geos at osgeo.org
Sat Jun 19 13:14:08 EDT 2010
Author: strk
Date: 2010-06-19 17:14:08 +0000 (Sat, 19 Jun 2010)
New Revision: 3026
trunk/php/geos.c
trunk/php/test/test.php
Export buffer costants and method
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-19 13:27:10 UTC (rev 3025)
+++ trunk/php/geos.c 2010-06-19 17:14:08 UTC (rev 3026)
@@ -113,6 +113,32 @@
return proxy->relay;
+static long getZvalAsLong(zval* val)
+ long ret;
+ zval tmp;
+ tmp = *val;
+ zval_copy_ctor(&tmp);
+ convert_to_long(&tmp);
+ ret = Z_LVAL(tmp);
+ zval_dtor(&tmp);
+ return ret;
+static long getZvalAsDouble(zval* val)
+ double ret;
+ zval tmp;
+ tmp = *val;
+ convert_to_double(&tmp);
+ ret = Z_DVAL(tmp);
+ zval_dtor(&tmp);
+ return ret;
static zend_object_value
Gen_create_obj (zend_class_entry *type TSRMLS_DC,
zend_objects_free_object_storage_t st, zend_object_handlers* handlers)
@@ -151,6 +177,7 @@
PHP_METHOD(Geometry, __construct);
PHP_METHOD(Geometry, project);
PHP_METHOD(Geometry, interpolate);
+PHP_METHOD(Geometry, buffer);
PHP_METHOD(Geometry, numGeometries);
@@ -158,6 +185,7 @@
PHP_ME(Geometry, __construct, NULL, 0)
PHP_ME(Geometry, project, NULL, 0)
PHP_ME(Geometry, interpolate, NULL, 0)
+ PHP_ME(Geometry, buffer, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -257,6 +285,91 @@
setRelay(return_value, ret);
+ * GEOSGeometry::buffer(dist, [<styleArray>])
+ * styleArray keys supported:
+ * 'quad_segs'
+ * Type: int
+ * Number of segments used to approximate
+ * a quarter circle (defaults to 8).
+ * 'endcap'
+ * Type: long
+ * Endcap style (defaults to GEOSBUF_CAP_ROUND)
+ * 'join'
+ * Type: long
+ * Join style (defaults to GEOSBUF_JOIN_ROUND)
+ * 'mitre_limit'
+ * Type: double
+ * mitre ratio limit (only affects joins with GEOSBUF_JOIN_MITRE style)
+ * 'miter_limit' is also accepted as a synonym for 'mitre_limit'.
+ GEOSGeometry *this;
+ double dist;
+ GEOSGeometry *ret;
+ static const double default_mitreLimit = 5.0;
+ static const int default_endCapStyle = GEOSBUF_CAP_ROUND;
+ static const int default_joinStyle = GEOSBUF_JOIN_ROUND;
+ static const int default_quadSegs = 8;
+ long int quadSegs = default_quadSegs;
+ long int endCapStyle = default_endCapStyle;
+ long int joinStyle = default_joinStyle;
+ double mitreLimit = default_mitreLimit;
+ zval *style_val = NULL;
+ zval **data;
+ HashTable *style;
+ char *key;
+ ulong index;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "d|a",
+ &dist, &style_val) == FAILURE) {
+ RETURN_NULL();
+ if ( style_val )
+ style = HASH_OF(style_val);
+ while(zend_hash_get_current_key(style, &key, &index, 0)
+ == HASH_KEY_IS_STRING)
+ if(!strcmp(key, "quad_segs"))
+ zend_hash_get_current_data(style, (void**)&data);
+ quadSegs = getZvalAsLong(*data);
+ else if(!strcmp(key, "endcap"))
+ endCapStyle = getZvalAsLong(*data);
+ else if(!strcmp(key, "join"))
+ joinStyle = getZvalAsLong(*data);
+ else if(!strcmp(key, "mitre_limit"))
+ mitreLimit = getZvalAsDouble(*data);
+ zend_hash_move_forward(style);
+ ret = GEOSBufferWithStyle(this, dist,
+ quadSegs, endCapStyle, joinStyle, mitreLimit);
+ if ( ! ret ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, ret);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
@@ -517,6 +630,20 @@
zend_get_std_object_handlers(), sizeof(zend_object_handlers));
Geometry_object_handlers.clone_obj = NULL;
+ /* Constants */
+ REGISTER_LONG_CONSTANT("GEOSBUF_CAP_ROUND", GEOSBUF_CAP_ROUND,
+ CONST_CS|CONST_PERSISTENT);
+ REGISTER_LONG_CONSTANT("GEOSBUF_CAP_FLAT", GEOSBUF_CAP_FLAT,
+ REGISTER_LONG_CONSTANT("GEOSBUF_CAP_SQUARE", GEOSBUF_CAP_SQUARE,
+ REGISTER_LONG_CONSTANT("GEOSBUF_JOIN_ROUND", GEOSBUF_JOIN_ROUND,
+ REGISTER_LONG_CONSTANT("GEOSBUF_JOIN_MITRE", GEOSBUF_JOIN_MITRE,
+ REGISTER_LONG_CONSTANT("GEOSBUF_JOIN_BEVEL", GEOSBUF_JOIN_BEVEL,
return SUCCESS;
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-19 13:27:10 UTC (rev 3025)
+++ trunk/php/test/test.php 2010-06-19 17:14:08 UTC (rev 3026)
@@ -15,6 +15,16 @@
$this->assertContains('-CAPI-', GEOSVersion());
+ public function testConstants()
+ $this->assertEquals(1, GEOSBUF_CAP_ROUND);
+ $this->assertEquals(2, GEOSBUF_CAP_FLAT);
+ $this->assertEquals(3, GEOSBUF_CAP_SQUARE);
+ $this->assertEquals(1, GEOSBUF_JOIN_ROUND);
+ $this->assertEquals(2, GEOSBUF_JOIN_MITRE);
+ $this->assertEquals(3, GEOSBUF_JOIN_BEVEL);
public function testWKTReader__construct()
$reader = new GEOSWKTReader();
@@ -312,4 +322,115 @@
$this->assertEquals('POINT (10 0)', $writer->write($prj));
+ public function testGeometry_buffer()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g = $reader->read('POINT(0 0)');
+ $b = $g->buffer(0);
+ $this->assertEquals('POLYGON EMPTY', $writer->write($b));
+ $b = $g->buffer(10);
+'POLYGON ((10 0, 10 -2, 9 -4, 8 -6, 7 -7, 6 -8, 4 -9, 2 -10, 0 -10, -2 -10, -4 -9, -6 -8, -7 -7, -8 -6, -9 -4, -10 -2, -10 -0, -10 2, -9 4, -8 6, -7 7, -6 8, -4 9, -2 10, -0 10, 2 10, 4 9, 6 8, 7 7, 8 6, 9 4, 10 2, 10 0))'
+ , $writer->write($b));
+ # One segment per quadrant
+ $b = $g->buffer(10, array('quad_segs' => 1));
+'POLYGON ((10 0, 0 -10, -10 -0, -0 10, 10 0))'
+ /* End cap styles */
+ $g = $reader->read('LINESTRING(0 0, 100 0)');
+ 'quad_segs' => 1,
+ 'endcap' => GEOSBUF_CAP_ROUND
+'POLYGON ((100 10, 110 0, 100 -10, 0 -10, -10 0, 0 10, 100 10))'
+ 'quad_segs' => 1,
+ 'endcap' => GEOSBUF_CAP_FLAT
+'POLYGON ((100 10, 100 -10, 0 -10, 0 10, 100 10))'
+ 'quad_segs' => 1,
+ 'endcap' => GEOSBUF_CAP_SQUARE
+'POLYGON ((100 10, 110 10, 110 -10, 0 -10, -10 -10, -10 10, 100 10))'
+ /* Join styles */
+ $g = $reader->read('LINESTRING(0 0, 100 0, 100 100)');
+ 'quad_segs' => 2,
+ 'join' => GEOSBUF_JOIN_ROUND
+'POLYGON ((90 10, 90 100, 93 107, 100 110, 107 107, 110 100, 110 0, 107 -7, 100 -10, 0 -10, -7 -7, -10 0, -7 7, 0 10, 90 10))'
+ 'quad_segs' => 2,
+ 'join' => GEOSBUF_JOIN_BEVEL
+'POLYGON ((90 10, 90 100, 93 107, 100 110, 107 107, 110 100, 110 0, 100 -10, 0 -10, -7 -7, -10 0, -7 7, 0 10, 90 10))'
+ 'quad_segs' => 2,
+ 'join' => GEOSBUF_JOIN_MITRE
+'POLYGON ((90 10, 90 100, 93 107, 100 110, 107 107, 110 100, 110 -10, 0 -10, -7 -7, -10 0, -7 7, 0 10, 90 10))'
+ 'quad_segs' => 2,
+ 'join' => GEOSBUF_JOIN_MITRE,
+ 'mitre_limit' => 1.0
+'POLYGON ((90 10, 90 100, 93 107, 100 110, 107 107, 110 100, 109 -5, 105 -9, 0 -10, -7 -7, -10 0, -7 7, 0 10, 90 10))'
+ /* Check that elements of the passed style array are not
+ * type-converted (buffer op will need to type-convert
+ * internally)
+ $ary = array('a' => 1);
+ $myStyle = array(
+ 'quad_segs' => "a string",
+ 'join' => "1",
+ 'endcap' => $ary,
+ 'mitre_limit' => 2 /* an int.. */
+ $this->assertEquals('string', gettype($myStyle['quad_segs']));
+ $this->assertEquals('string', gettype($myStyle['join']));
+ $this->assertEquals('array', gettype($myStyle['endcap']));
+ $this->assertEquals('integer', gettype($myStyle['mitre_limit']));
+ $b = $g->buffer(10, $myStyle);
More information about the geos-commits
