[geos-commits] r3034 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 05:13:13 EDT 2010
Author: strk
Date: 2010-06-20 09:13:13 +0000 (Sun, 20 Jun 2010)
New Revision: 3034
trunk/php/geos.c
trunk/php/test/test.php
Make GEOSPolygonize a free function rather than a method on GEOSGeometry. This is to allow extending it to accept differnet kind of args, like arrays of GEOSGeometry for example..
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-20 09:02:22 UTC (rev 3033)
+++ trunk/php/geos.c 2010-06-20 09:13:13 UTC (rev 3034)
@@ -38,9 +38,11 @@
PHP_RSHUTDOWN_FUNCTION(geos);
PHP_MINFO_FUNCTION(geos);
PHP_FUNCTION(GEOSVersion);
+PHP_FUNCTION(GEOSPolygonize);
static function_entry geos_functions[] = {
PHP_FE(GEOSVersion, NULL)
+ PHP_FE(GEOSPolygonize, NULL)
{NULL, NULL, NULL}
@@ -162,16 +164,6 @@
-/* -- Free functions ------------------------- */
-PHP_FUNCTION(GEOSVersion)
- char *str;
- str = estrdup(GEOSversion());
- RETURN_STRING(str, 0);
/* -- class GEOSGeometry -------------------- */
PHP_METHOD(Geometry, __construct);
@@ -189,7 +181,6 @@
PHP_METHOD(Geometry, pointOnSurface);
PHP_METHOD(Geometry, centroid);
PHP_METHOD(Geometry, relate);
-PHP_METHOD(Geometry, polygonize);
PHP_METHOD(Geometry, numGeometries);
@@ -209,7 +200,6 @@
PHP_ME(Geometry, pointOnSurface, NULL, 0)
PHP_ME(Geometry, centroid, NULL, 0)
PHP_ME(Geometry, relate, NULL, 0)
- PHP_ME(Geometry, polygonize, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -682,65 +672,6 @@
- * array GEOSGeometry::polygonize()
- * The returned array contains the following elements:
- * - 'rings'
- * Type: array of GEOSGeometry
- * Rings that can be formed by the costituent
- * linework of geometry.
- * - 'cut_edges' (optional)
- * Edges which are connected at both ends but
- * which do not form part of polygon.
- * - 'dangles'
- * Edges which have one or both ends which are
- * not incident on another edge endpoint
- * - 'invalid_rings'
- * Edges which form rings which are invalid
- * (e.g. the component lines contain a self-intersection)
- GEOSGeometry *this;
- GEOSGeometry *rings;
- GEOSGeometry *cut_edges;
- GEOSGeometry *dangles;
- GEOSGeometry *invalid_rings;
- zval *rings_array;
- zval *cut_edges_array;
- zval *dangles_array;
- zval *invalid_rings_array;
- this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
- rings = GEOSPolygonize_full(this, &cut_edges, &dangles, &invalid_rings);
- if ( ! rings ) RETURN_NULL(); /* should get an exception first */
- /* return value should be an array */
- array_init(return_value);
- rings_array = dumpGeometry(rings);
- GEOSGeom_destroy(rings);
- cut_edges_array = dumpGeometry(cut_edges);
- GEOSGeom_destroy(cut_edges);
- dangles_array = dumpGeometry(dangles);
- GEOSGeom_destroy(dangles);
- invalid_rings_array = dumpGeometry(invalid_rings);
- GEOSGeom_destroy(invalid_rings);
- add_assoc_zval(return_value, "rings", rings_array);
- add_assoc_zval(return_value, "cut_edges", cut_edges_array);
- add_assoc_zval(return_value, "dangles", dangles_array);
- add_assoc_zval(return_value, "invalid_rings", invalid_rings_array);
/* -- class GEOSWKTReader -------------------- */
PHP_METHOD(WKTReader, __construct);
@@ -970,6 +901,86 @@
GEOSWKTWriter_setOld3D(writer, val);
+/* -- Free functions ------------------------- */
+ * string GEOSVersion()
+PHP_FUNCTION(GEOSVersion)
+ char *str;
+ str = estrdup(GEOSversion());
+ RETURN_STRING(str, 0);
+ * array GEOSPolygonize(GEOSGeometry $geom)
+ * The returned array contains the following elements:
+ * - 'rings'
+ * Type: array of GEOSGeometry
+ * Rings that can be formed by the costituent
+ * linework of geometry.
+ * - 'cut_edges' (optional)
+ * Edges which are connected at both ends but
+ * which do not form part of polygon.
+ * - 'dangles'
+ * Edges which have one or both ends which are
+ * not incident on another edge endpoint
+ * - 'invalid_rings'
+ * Edges which form rings which are invalid
+ * (e.g. the component lines contain a self-intersection)
+ GEOSGeometry *this;
+ GEOSGeometry *rings;
+ GEOSGeometry *cut_edges;
+ GEOSGeometry *dangles;
+ GEOSGeometry *invalid_rings;
+ zval *rings_array;
+ zval *cut_edges_array;
+ zval *dangles_array;
+ zval *invalid_rings_array;
+ zval *zobj;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
+ == FAILURE)
+ RETURN_NULL();
+ this = getRelay(zobj, Geometry_ce_ptr);
+ rings = GEOSPolygonize_full(this, &cut_edges, &dangles, &invalid_rings);
+ if ( ! rings ) RETURN_NULL(); /* should get an exception first */
+ /* return value should be an array */
+ array_init(return_value);
+ rings_array = dumpGeometry(rings);
+ GEOSGeom_destroy(rings);
+ cut_edges_array = dumpGeometry(cut_edges);
+ GEOSGeom_destroy(cut_edges);
+ dangles_array = dumpGeometry(dangles);
+ GEOSGeom_destroy(dangles);
+ invalid_rings_array = dumpGeometry(invalid_rings);
+ GEOSGeom_destroy(invalid_rings);
+ add_assoc_zval(return_value, "rings", rings_array);
+ add_assoc_zval(return_value, "cut_edges", cut_edges_array);
+ add_assoc_zval(return_value, "dangles", dangles_array);
+ add_assoc_zval(return_value, "invalid_rings", invalid_rings_array);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-20 09:02:22 UTC (rev 3033)
+++ trunk/php/test/test.php 2010-06-20 09:13:13 UTC (rev 3034)
@@ -913,7 +913,7 @@
$g2 = $reader->read('POINT(0 0)');
$g = $g->union($g2); /* Make sure linestrings are noded */
- $ret = $g->polygonize();
+ $ret = GEOSPolygonize($g);
* NOTE: the following expected results are suspicious
More information about the geos-commits
