[geos-commits] r3037 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 17:00:29 EDT 2010
Author: strk
Date: 2010-06-20 21:00:29 +0000 (Sun, 20 Jun 2010)
New Revision: 3037
trunk/php/geos.c
trunk/php/test/test.php
Relational operators + equalsExact
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-20 19:05:57 UTC (rev 3036)
+++ trunk/php/geos.c 2010-06-20 21:00:29 UTC (rev 3037)
@@ -185,6 +185,15 @@
PHP_METHOD(Geometry, relate);
PHP_METHOD(Geometry, simplify); /* also does topology-preserving */
PHP_METHOD(Geometry, extractUniquePoints);
+PHP_METHOD(Geometry, disjoint);
+PHP_METHOD(Geometry, touches);
+PHP_METHOD(Geometry, intersects);
+PHP_METHOD(Geometry, crosses);
+PHP_METHOD(Geometry, within);
+PHP_METHOD(Geometry, contains);
+PHP_METHOD(Geometry, overlaps);
+PHP_METHOD(Geometry, equals);
+PHP_METHOD(Geometry, equalsExact);
PHP_METHOD(Geometry, numGeometries);
@@ -206,6 +215,15 @@
PHP_ME(Geometry, relate, NULL, 0)
PHP_ME(Geometry, simplify, NULL, 0)
PHP_ME(Geometry, extractUniquePoints, NULL, 0)
+ PHP_ME(Geometry, disjoint, NULL, 0)
+ PHP_ME(Geometry, touches, NULL, 0)
+ PHP_ME(Geometry, intersects, NULL, 0)
+ PHP_ME(Geometry, crosses, NULL, 0)
+ PHP_ME(Geometry, within, NULL, 0)
+ PHP_ME(Geometry, contains, NULL, 0)
+ PHP_ME(Geometry, overlaps, NULL, 0)
+ PHP_ME(Geometry, equals, NULL, 0)
+ PHP_ME(Geometry, equalsExact, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
{NULL, NULL, NULL}
@@ -1068,8 +1086,252 @@
setRelay(return_value, ret);
+ * bool GEOSGeometry::disjoint(GEOSGeometry)
+ GEOSGeometry *this;
+ GEOSGeometry *other;
+ int ret;
+ zend_bool retBool;
+ zval *zobj;
+ this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o", &zobj)
+ == FAILURE) {
+ RETURN_NULL();
+ other = getRelay(zobj, Geometry_ce_ptr);
+ ret = GEOSDisjoint(this, other);
+ if ( ret == 2 ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ retBool = ret;
+ RETURN_BOOL(retBool);
+ * bool GEOSGeometry::touches(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSTouches(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::intersects(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSIntersects(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::crosses(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSCrosses(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::within(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSWithin(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::contains(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSContains(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::overlaps(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSOverlaps(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::equals(GEOSGeometry)
+ int ret;
+ zval *zobj;
+ &zobj) == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSEquals(this, other);
+ retBool = ret;
+ * bool GEOSGeometry::equalsExact(GEOSGeometry)
+ * bool GEOSGeometry::equalsExact(GEOSGeometry, double tolerance)
+ int ret;
+ double tolerance = 0;
+ zval *zobj;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "o|d",
+ &zobj, &tolerance) == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSEqualsExact(this, other, tolerance);
+ retBool = ret;
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-20 19:05:57 UTC (rev 3036)
+++ trunk/php/test/test.php 2010-06-20 21:00:29 UTC (rev 3037)
@@ -1024,4 +1024,116 @@
'MULTIPOINT (0 0, 1 0, 1 1, 0 1, 10 10, 10 14, 14 14, 14 10, 11 11, 11 12, 12 12, 12 11, 2 3, 3 4, 9 0)'
, $writer->write($gs));
+ public function testGeometry_relationalOps()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g1 = $reader->read('POINT(0 0)');
+ $g2 = $reader->read('POINT(0 0)');
+ $this->assertFalse( $g1->disjoint($g2) );
+ $this->assertFalse( $g1->touches($g2) ); /* no bounds, can't touch */
+ $this->assertTrue( $g1->intersects($g2) );
+ $this->assertFalse( $g1->crosses($g2) );
+ $this->assertTrue( $g1->within($g2) );
+ $this->assertTrue( $g1->contains($g2) );
+ $this->assertFalse( $g1->overlaps($g2) );
+ $this->assertTrue( $g1->equals($g2) );
+ $this->assertTrue( $g1->equalsExact($g2) );
+ $g2 = $reader->read('LINESTRING(0 0, 10 0)');
+ $this->assertTrue( $g1->touches($g2) );
+ $this->assertFalse( $g1->within($g2) );
+ $this->assertFalse( $g1->contains($g2) );
+ $this->assertFalse( $g1->equals($g2) );
+ $this->assertFalse( $g1->equalsExact($g2, 10) );
+ $g1 = $reader->read('POINT(5 0)');
+ $g1 = $reader->read('LINESTRING(5 -5, 5 5)');
+ $this->assertTrue( $g1->crosses($g2) );
+ $this->assertFalse( $g1->equalsExact($g2, 1) );
+ $g1 = $reader->read('LINESTRING(5 0, 15 0)');
+ $this->assertTrue( $g1->overlaps($g2) );
+ $g1 = $reader->read('LINESTRING(0 0, 5 0, 10 0)');
+ $g1 = $reader->read('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))');
+ $g2 = $reader->read('POLYGON((5 -5, 5 5, 15 5, 15 -5, 5 -5))');
+ $g2 = $reader->read('POINT(15 15)');
+ $this->assertTrue( $g1->disjoint($g2) );
+ $this->assertFalse( $g1->intersects($g2) );
More information about the geos-commits
