[geos-commits] r3048 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 21:05:00 EDT 2010
Author: strk
Date: 2010-06-21 01:05:00 +0000 (Mon, 21 Jun 2010)
New Revision: 3048
trunk/php/geos.c
trunk/php/test/test.php
numInteriorRings
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-21 00:56:12 UTC (rev 3047)
+++ trunk/php/geos.c 2010-06-21 01:05:00 UTC (rev 3048)
@@ -206,6 +206,7 @@
PHP_METHOD(Geometry, setSRID);
PHP_METHOD(Geometry, numGeometries);
PHP_METHOD(Geometry, getGeometryN);
+PHP_METHOD(Geometry, numInteriorRings);
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
@@ -246,6 +247,7 @@
PHP_ME(Geometry, setSRID, NULL, 0)
PHP_ME(Geometry, numGeometries, NULL, 0)
PHP_ME(Geometry, getGeometryN, NULL, 0)
+ PHP_ME(Geometry, numInteriorRings, NULL, 0)
{NULL, NULL, NULL}
@@ -1585,8 +1587,24 @@
setRelay(return_value, cc);
+ * long GEOSGeometry::numInteriorRings()
+ GEOSGeometry *geom;
+ long int ret;
+ geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ ret = GEOSGetNumInteriorRings(geom);
+ if ( ret == -1 ) RETURN_NULL(); /* should get an exception first */
+ RETURN_LONG(ret);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-21 00:56:12 UTC (rev 3047)
+++ trunk/php/test/test.php 2010-06-21 01:05:00 UTC (rev 3048)
@@ -1358,4 +1358,32 @@
+ public function testGeometry_numInteriorRings()
+ $reader = new GEOSWKTReader();
+ $g = $reader->read('POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))');
+ $this->assertEquals(0, $g->numInteriorRings());
+ (10 10, 10 14, 14 14, 14 10, 10 10),
+ (11 11, 11 12, 12 12, 12 11, 11 11))');
+ $this->assertEquals(1, $g->numInteriorRings());
+ (11 11, 11 12, 12 12, 12 11, 11 11),
+ (13 11, 13 12, 13.5 12, 13.5 11, 13 11))');
+ $this->assertEquals(2, $g->numInteriorRings());
+ $g = $reader->read('POINT (0 0)');
+ try {
+ $this->assertTrue( FALSE );
+ } catch (Exception $e) {
+ $this->assertContains( 'Polygon', $e->getMessage() );
More information about the geos-commits
