[geos-commits] r3057 - in trunk/php: . test
svn_geos at osgeo.org
Sun Jun 20 22:02:05 EDT 2010
Author: strk
Date: 2010-06-21 02:02:05 +0000 (Mon, 21 Jun 2010)
New Revision: 3057
trunk/php/geos.c
trunk/php/test/test.php
startPoint, endPoint
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-21 01:58:23 UTC (rev 3056)
+++ trunk/php/geos.c 2010-06-21 02:02:05 UTC (rev 3057)
@@ -216,6 +216,8 @@
PHP_METHOD(Geometry, dimension);
PHP_METHOD(Geometry, coordinateDimension);
PHP_METHOD(Geometry, pointN);
+PHP_METHOD(Geometry, startPoint);
+PHP_METHOD(Geometry, endPoint);
static function_entry Geometry_methods[] = {
PHP_ME(Geometry, __construct, NULL, 0)
@@ -266,6 +268,8 @@
PHP_ME(Geometry, dimension, NULL, 0)
PHP_ME(Geometry, coordinateDimension, NULL, 0)
PHP_ME(Geometry, pointN, NULL, 0)
+ PHP_ME(Geometry, startPoint, NULL, 0)
+ PHP_ME(Geometry, endPoint, NULL, 0)
{NULL, NULL, NULL}
@@ -1792,7 +1796,46 @@
setRelay(return_value, cc);
+ * GEOSGeometry GEOSGeometry::startPoint()
+ GEOSGeometry *geom;
+ const GEOSGeometry *c;
+ GEOSGeometry *cc;
+ geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ c = GEOSGeomGetStartPoint(geom);
+ if ( ! c ) RETURN_NULL(); /* should get an exception first */
+ cc = GEOSGeom_clone(c);
+ if ( ! cc ) RETURN_NULL(); /* should get an exception first */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, cc);
+ * GEOSGeometry GEOSGeometry::endPoint()
+ GEOSGeometry *cc;
+ c = GEOSGeomGetEndPoint(geom);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-06-21 01:58:23 UTC (rev 3056)
+++ trunk/php/test/test.php 2010-06-21 02:02:05 UTC (rev 3057)
@@ -1606,4 +1606,29 @@
+ public function testGeometry_startendPoint()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ $g = $reader->read('LINESTRING (10 10, 10 14, 14 14, 14 10)');
+ $this->assertEquals('POINT (10 10)', $writer->write($g->startPoint()) );
+ $this->assertEquals('POINT (14 10)', $writer->write($g->endPoint()) );
+ $this->assertNull( $g->pointN(4) );
+ $g = $reader->read('LINEARRING (11 11, 11 12, 12 11, 11 11)');
+ $this->assertEquals('POINT (11 11)', $writer->write($g->startPoint()) );
+ $this->assertEquals('POINT (11 11)', $writer->write($g->endPoint()) );
+ $g = $reader->read('POINT (0 0)');
+ try {
+ $g->pointN(0);
+ $this->assertTrue( FALSE );
+ } catch (Exception $e) {
+ $this->assertContains( 'LineString', $e->getMessage() );
More information about the geos-commits
