[geos-commits] r3060 - in trunk: php src/geom
svn_geos at osgeo.org
Mon Jun 21 10:31:41 EDT 2010
Author: strk
Date: 2010-06-21 14:31:41 +0000 (Mon, 21 Jun 2010)
New Revision: 3060
trunk/php/TODO
trunk/php/geos.c
trunk/src/geom/GeometryCollection.cpp
trunk/src/geom/LineString.cpp
trunk/src/geom/Polygon.cpp
Switch back to unchecked getGeometryN, getPointN and getInteriorRingN, check them at the PHP level, for performance sake in C-land.
Modified: trunk/php/TODO
--- trunk/php/TODO 2010-06-21 10:30:48 UTC (rev 3059)
+++ trunk/php/TODO 2010-06-21 14:31:41 UTC (rev 3060)
@@ -1,6 +1,5 @@
In order of priority
-- Add GEOSGeometry::Normalize (make non-mutating !)
- Implement serialization/deserialization for Geometry
- Documentation !! (doxygen-based?)
- Find a way to have GEOSGeometry contents shown on var_dump
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-21 10:30:48 UTC (rev 3059)
+++ trunk/php/geos.c 2010-06-21 14:31:41 UTC (rev 3060)
@@ -1269,6 +1269,7 @@
RETURN_NULL();
+ if ( num >= GEOSGetNumGeometries(geom) ) RETURN_NULL();
c = GEOSGetGeometryN(geom, num);
if ( ! c ) RETURN_NULL(); /* should get an exception first */
cc = GEOSGeom_clone(c);
@@ -1361,6 +1362,7 @@
RETURN_NULL();
+ if ( num >= GEOSGetNumInteriorRings(geom) ) RETURN_NULL();
c = GEOSGetInteriorRingN(geom, num);
@@ -1455,6 +1457,7 @@
RETURN_NULL();
+ if ( num >= GEOSGeomGetNumPoints(geom) ) RETURN_NULL();
c = GEOSGeomGetPointN(geom, num);
Modified: trunk/src/geom/GeometryCollection.cpp
--- trunk/src/geom/GeometryCollection.cpp 2010-06-21 10:30:48 UTC (rev 3059)
+++ trunk/src/geom/GeometryCollection.cpp 2010-06-21 14:31:41 UTC (rev 3060)
@@ -148,7 +148,6 @@
const Geometry*
GeometryCollection::getGeometryN(size_t n) const
- if ( n >= geometries->size() ) return 0;
return (*geometries)[n];
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp 2010-06-21 10:30:48 UTC (rev 3059)
+++ trunk/src/geom/LineString.cpp 2010-06-21 14:31:41 UTC (rev 3060)
@@ -169,7 +169,6 @@
assert(getFactory());
assert(points.get());
- if ( n >= points->size() ) return 0;
return getFactory()->createPoint(points->getAt(n));
Modified: trunk/src/geom/Polygon.cpp
--- trunk/src/geom/Polygon.cpp 2010-06-21 10:30:48 UTC (rev 3059)
+++ trunk/src/geom/Polygon.cpp 2010-06-21 14:31:41 UTC (rev 3060)
@@ -194,7 +194,6 @@
const LineString*
Polygon::getInteriorRingN(size_t n) const
- if ( n >= holes->size() ) return 0;
return (LineString *) (*holes)[n];
More information about the geos-commits
