[geos-commits] r3062 - in trunk: capi php
svn_geos at osgeo.org
Wed Jun 23 05:31:32 EDT 2010
Author: strk
Date: 2010-06-23 09:31:32 +0000 (Wed, 23 Jun 2010)
New Revision: 3062
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/php/geos.c
There's no point for GEOSisValidDetail to take output parameter as const pointer
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2010-06-23 09:23:29 UTC (rev 3061)
+++ trunk/capi/geos_c.cpp 2010-06-23 09:31:32 UTC (rev 3062)
@@ -203,7 +203,7 @@
char
GEOSisValidDetail(const Geometry *g,
- char** reason, const Geometry ** location)
+ char** reason, Geometry ** location)
return GEOSisValidDetail_r( handle, g, reason, location );
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-06-23 09:23:29 UTC (rev 3061)
+++ trunk/capi/geos_c.h.in 2010-06-23 09:31:32 UTC (rev 3062)
@@ -752,7 +752,7 @@
/* caller has the responsibility to destroy 'reason' (GEOSFree)
* and 'location' (GEOSGeom_destroy) Sparams */
extern char GEOS_DLL GEOSisValidDetail(const GEOSGeometry* g, char** reason,
- const GEOSGeometry** location);
+ GEOSGeometry** location);
extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g1);
extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g1);
extern char GEOS_DLL GEOSHasZ(const GEOSGeometry* g1);
@@ -768,7 +768,7 @@
* and 'location' (GEOSGeom_destroy_r) Sparams */
extern char GEOS_DLL GEOSisValidDetail_r(GEOSContextHandle_t handle,
extern char GEOS_DLL GEOSisSimple_r(GEOSContextHandle_t handle,
extern char GEOS_DLL GEOSisRing_r(GEOSContextHandle_t handle,
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-06-23 09:23:29 UTC (rev 3061)
+++ trunk/capi/geos_ts_c.cpp 2010-06-23 09:31:32 UTC (rev 3062)
@@ -668,7 +668,7 @@
char
GEOSisValidDetail_r(GEOSContextHandle_t extHandle, const Geometry *g,
if ( 0 == extHandle )
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-06-23 09:23:29 UTC (rev 3061)
+++ trunk/php/geos.c 2010-06-23 09:31:32 UTC (rev 3062)
@@ -1063,7 +1063,7 @@
this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
- ret = GEOSisValidDetail(this, &reason, (const GEOSGeometry**)&location);
+ ret = GEOSisValidDetail(this, &reason, &location);
if ( ret == 2 ) RETURN_NULL(); /* should get an exception first */
if ( reason ) {
More information about the geos-commits
