[geos-commits] r3068 - in trunk: capi include/geos/io src/io
svn_geos at osgeo.org
Thu Jun 24 05:01:54 EDT 2010
Author: strk
Date: 2010-06-24 09:01:54 +0000 (Thu, 24 Jun 2010)
New Revision: 3068
trunk/capi/geos_ts_c.cpp
trunk/include/geos/io/WKBWriter.h
trunk/src/io/WKBWriter.cpp
Make WKBWriter::setByteOrder check for argument and throw IllegalArgumentException when appropriate. Make sure C-API wrapper catches those.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-06-24 08:28:41 UTC (rev 3067)
+++ trunk/capi/geos_ts_c.cpp 2010-06-24 09:01:54 UTC (rev 3068)
@@ -4576,6 +4576,10 @@
writer->setByteOrder(newByteOrder);
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
catch (...)
handle->ERROR_MESSAGE("Unknown exception thrown");
Modified: trunk/include/geos/io/WKBWriter.h
--- trunk/include/geos/io/WKBWriter.h 2010-06-24 08:28:41 UTC (rev 3067)
+++ trunk/include/geos/io/WKBWriter.h 2010-06-24 09:01:54 UTC (rev 3068)
@@ -102,9 +102,10 @@
* Sets the output dimension used by the <code>WKBWriter</code>.
- * @param newOutputDimension Supported values are 2 or 3. Note that 3 indicates
- * up to 3 dimensions will be written but 2D WKB is still produced for 2D geometries.
+ * @param newOutputDimension Supported values are 2 or 3.
+ * Note that 3 indicates up to 3 dimensions will be written but
+ * 2D WKB is still produced for 2D geometries.
virtual void setOutputDimension(int newOutputDimension);
@@ -119,7 +120,7 @@
* Sets the byte order used by the
* <code>WKBWriter</code>.
- virtual void setByteOrder(int newByteOrder) { byteOrder=newByteOrder; }
+ virtual void setByteOrder(int newByteOrder);
* \brief
Modified: trunk/src/io/WKBWriter.cpp
--- trunk/src/io/WKBWriter.cpp 2010-06-24 08:28:41 UTC (rev 3067)
+++ trunk/src/io/WKBWriter.cpp 2010-06-24 09:01:54 UTC (rev 3068)
@@ -206,7 +206,7 @@
buf[0] = WKBConstants::wkbNDR;
- else
+ else
buf[0] = WKBConstants::wkbXDR;
@@ -215,7 +215,24 @@
outStream->write(reinterpret_cast<char*>(buf), 1);
+/* public */
void
+WKBWriter::setByteOrder(int bo)
+ if (bo != ByteOrderValues::ENDIAN_LITTLE &&
+ bo != ByteOrderValues::ENDIAN_BIG )
+ std::ostringstream os;
+ os << "WKB output dimension must be LITTLE ("
+ << ByteOrderValues::ENDIAN_LITTLE
+ << ") or BIG (" << ByteOrderValues::ENDIAN_BIG << ")";
+ throw util::IllegalArgumentException(os.str());
+ byteOrder = bo;
+void
WKBWriter::writeGeometryType(int typeId, int SRID)
int flag3D = (outputDimension == 3) ? 0x80000000 : 0;
More information about the geos-commits
