[geos-commits] r2932 - in trunk: . include/geos/operation/valid
src/operation/valid tests/xmltester/tests/general
svn_geos at osgeo.org
Tue Mar 2 16:04:03 EST 2010
Author: strk
Date: 2010-03-02 16:04:02 -0500 (Tue, 02 Mar 2010)
New Revision: 2932
trunk/NEWS
trunk/include/geos/operation/valid/IsValidOp.h
trunk/src/operation/valid/IsValidOp.cpp
trunk/tests/xmltester/tests/general/TestValid.xml
Fix false positive return from IsValidOp (#333)
Modified: trunk/NEWS
--- trunk/NEWS 2010-02-28 19:01:20 UTC (rev 2931)
+++ trunk/NEWS 2010-03-02 21:04:02 UTC (rev 2932)
@@ -14,6 +14,8 @@
- Polygonizer::getDangles returns by const ref
- Polygonizer::getInvalidRingLines returns by const ref and retains
ownership of vector elements
+- Bug fixes:
+ - Invalid compound geometries reported as valid (#333)
Changes in 3.2.0
Modified: trunk/include/geos/operation/valid/IsValidOp.h
--- trunk/include/geos/operation/valid/IsValidOp.h 2010-02-28 19:01:20 UTC (rev 2931)
+++ trunk/include/geos/operation/valid/IsValidOp.h 2010-03-02 21:04:02 UTC (rev 2932)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2005-2006 Refractions Research Inc.
* Copyright (C) 2001-2002 Vivid Solutions Inc.
Modified: trunk/src/operation/valid/IsValidOp.cpp
--- trunk/src/operation/valid/IsValidOp.cpp 2010-02-28 19:01:20 UTC (rev 2931)
+++ trunk/src/operation/valid/IsValidOp.cpp 2010-03-02 21:04:02 UTC (rev 2932)
@@ -4,6 +4,7 @@
* Copyright (C) 2005 Refractions Research Inc.
@@ -116,7 +117,7 @@
if (isChecked) return;
- assert( validErr == NULL );
+ //assert( validErr == NULL );
validErr=NULL;
// empty geometries are always valid!
@@ -132,7 +133,7 @@
else if (0 != (gc=dynamic_cast<const GeometryCollection *>(g)))
checkValid(gc);
else throw util::UnsupportedOperationException();
- isChecked=true;
+ //isChecked=true;
Modified: trunk/tests/xmltester/tests/general/TestValid.xml
--- trunk/tests/xmltester/tests/general/TestValid.xml 2010-02-28 19:01:20 UTC (rev 2931)
+++ trunk/tests/xmltester/tests/general/TestValid.xml 2010-03-02 21:04:02 UTC (rev 2932)
@@ -78,6 +78,14 @@
</case>
<case>
+ <desc>L - linestring with two identical points </desc>
+ <a>MULTILINESTRING((1 1, 0 0), (0 0, 0 0))</a>
+ <test>
+ <op name="isValid" arg1="A"> false </op>
+ </test>
+ </case>
+ <case>
<desc>A - zero-area polygon </desc>
<a>POLYGON ((0 0, 0 0, 0 0, 0 0, 0 0))</a>
<test>
More information about the geos-commits
