[geos-commits] r2940 - trunk/capi
svn_geos at osgeo.org
Tue Mar 16 08:32:25 EDT 2010
Author: strk
Date: 2010-03-16 08:32:24 -0400 (Tue, 16 Mar 2010)
New Revision: 2940
trunk/capi/geos_ts_c.cpp
Now that IsValidOp doesn't cache the 'checked' status it is better to trigger a single check rather than two (also fix leaks)
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-03-14 10:13:43 UTC (rev 2939)
+++ trunk/capi/geos_ts_c.cpp 2010-03-16 12:32:24 UTC (rev 2940)
@@ -589,16 +589,16 @@
using geos::operation::valid::TopologyValidationError;
IsValidOp ivo(g1);
- bool valid = ivo.isValid();
- if (!valid)
+ TopologyValidationError *err = ivo.getValidationError();
+ if ( err )
- TopologyValidationError *err = ivo.getValidationError();
- if ( err )
- handle->NOTICE_MESSAGE("%s", err->toString().c_str());
+ handle->NOTICE_MESSAGE("%s", err->toString().c_str());
+ return 0;
- return valid;
+ else
+ return 1;
catch (const std::exception &e)
@@ -636,17 +636,13 @@
char const* const validstr = "Valid Geometry";
IsValidOp ivo(g1);
- bool isvalid = ivo.isValid();
- if ( ! isvalid )
+ if (0 != err)
- if (0 != err)
- const std::string errloc = err->getCoordinate().toString();
- std::string errmsg(err->getMessage());
- errmsg += "[" + errloc + "]";
- result = gstrdup(errmsg);
+ const std::string errloc = err->getCoordinate().toString();
+ std::string errmsg(err->getMessage());
+ errmsg += "[" + errloc + "]";
+ result = gstrdup(errmsg);
else
@@ -689,19 +685,15 @@
IsValidOp ivo(g);
- if ( ! isvalid )
+ if (0 != err)
- if (0 != err)
- *location = handle->geomFactory->createPoint(err->getCoordinate());
- *reason = gstrdup(errmsg);
- else {
- /* is it ever possible for getValidationError to be 0 ? */
+ *location = handle->geomFactory->createPoint(err->getCoordinate());
+ *reason = gstrdup(errmsg);
+ else
return 0; /* invalid */
More information about the geos-commits
