[geos-commits] r2942 - in branches/3.2:
source/headers/geos/operation/valid source/operation/valid
tests/xmltester/tests/general
svn_geos at osgeo.org
Thu Mar 18 14:26:05 EDT 2010
Author: strk
Date: 2010-03-18 14:26:02 -0400 (Thu, 18 Mar 2010)
New Revision: 2942
branches/3.2/source/headers/geos/operation/valid/IsValidOp.h
branches/3.2/source/operation/valid/IsValidOp.cpp
branches/3.2/tests/xmltester/tests/general/TestValid.xml
Fix false-positive return from IsValidOp. This is done better than in trunk, so will backport later.
Modified: branches/3.2/source/headers/geos/operation/valid/IsValidOp.h
--- branches/3.2/source/headers/geos/operation/valid/IsValidOp.h 2010-03-16 13:13:37 UTC (rev 2941)
+++ branches/3.2/source/headers/geos/operation/valid/IsValidOp.h 2010-03-18 18:26:02 UTC (rev 2942)
@@ -69,6 +69,7 @@
// CHECKME: should this really be a pointer ?
TopologyValidationError* validErr;
+ void checkValid();
void checkValid(const geom::Geometry *g);
void checkValid(const geom::Point *g);
void checkValid(const geom::LinearRing *g);
Modified: branches/3.2/source/operation/valid/IsValidOp.cpp
--- branches/3.2/source/operation/valid/IsValidOp.cpp 2010-03-16 13:13:37 UTC (rev 2941)
+++ branches/3.2/source/operation/valid/IsValidOp.cpp 2010-03-18 18:26:02 UTC (rev 2942)
@@ -82,7 +82,7 @@
bool
IsValidOp::isValid()
- checkValid(parentGeometry);
+ checkValid();
return validErr==NULL;
@@ -105,17 +105,22 @@
TopologyValidationError *
IsValidOp::getValidationError()
+ checkValid();
return validErr;
void
-IsValidOp::checkValid(const Geometry *g)
+IsValidOp::checkValid()
if (isChecked) return;
+ checkValid(parentGeometry);
+ isChecked=true;
+void
+IsValidOp::checkValid(const Geometry *g)
assert( validErr == NULL );
- validErr=NULL;
// empty geometries are always valid!
if (g->isEmpty()) return;
@@ -130,7 +135,6 @@
else if (0 != (gc=dynamic_cast<const GeometryCollection *>(g)))
checkValid(gc);
else throw util::UnsupportedOperationException();
- isChecked=true;
Modified: branches/3.2/tests/xmltester/tests/general/TestValid.xml
--- branches/3.2/tests/xmltester/tests/general/TestValid.xml 2010-03-16 13:13:37 UTC (rev 2941)
+++ branches/3.2/tests/xmltester/tests/general/TestValid.xml 2010-03-18 18:26:02 UTC (rev 2942)
@@ -78,6 +78,14 @@
</case>
<case>
+ <desc>mL - MultiLinestring with two identical points in second component</desc>
+ <a>MULTILINESTRING((1 1, 0 0), (0 0, 0 0))</a>
+ <test>
+ <op name="isValid" arg1="A"> false </op>
+ </test>
+ </case>
+ <case>
<desc>A - zero-area polygon </desc>
<a>POLYGON ((0 0, 0 0, 0 0, 0 0, 0 0))</a>
<test>
More information about the geos-commits
