[geos-commits] r2961 - in trunk/include/geos: algorithm geom
geom/prep geomgraph index/chain index/strtree noding
noding/snapround operation/predicate planargraph simplify
svn_geos at osgeo.org
Mon Mar 29 08:17:38 EDT 2010
Author: mloskot
Date: 2010-03-29 08:17:37 -0400 (Mon, 29 Mar 2010)
New Revision: 2961
trunk/include/geos/algorithm/CentralEndpointIntersector.h
trunk/include/geos/geom/CoordinateArraySequence.h
trunk/include/geos/geom/CoordinateArraySequenceFactory.h
trunk/include/geos/geom/CoordinateArraySequenceFactory.inl
trunk/include/geos/geom/CoordinateSequence.h
trunk/include/geos/geom/CoordinateSequenceFactory.h
trunk/include/geos/geom/CoordinateSequenceFilter.h
trunk/include/geos/geom/Geometry.h
trunk/include/geos/geom/GeometryCollection.h
trunk/include/geos/geom/LineSegment.h
trunk/include/geos/geom/LineSegment.inl
trunk/include/geos/geom/LineString.h
trunk/include/geos/geom/Polygon.h
trunk/include/geos/geom/prep/PreparedLineStringIntersects.h
trunk/include/geos/geomgraph/EdgeEndStar.h
trunk/include/geos/geomgraph/TopologyLocation.h
trunk/include/geos/index/chain/MonotoneChain.h
trunk/include/geos/index/chain/MonotoneChainBuilder.h
trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
trunk/include/geos/index/strtree/AbstractSTRtree.h
trunk/include/geos/index/strtree/SIRtree.h
trunk/include/geos/index/strtree/STRtree.h
trunk/include/geos/noding/MCIndexNoder.h
trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
trunk/include/geos/noding/SegmentNodeList.h
trunk/include/geos/noding/SegmentStringUtil.h
trunk/include/geos/noding/snapround/HotPixel.h
trunk/include/geos/operation/predicate/RectangleIntersects.h
trunk/include/geos/planargraph/DirectedEdgeStar.h
trunk/include/geos/planargraph/PlanarGraph.h
trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h
trunk/include/geos/simplify/TaggedLineString.h
Qualify size_t with std namespace in headers.
Modified: trunk/include/geos/algorithm/CentralEndpointIntersector.h
--- trunk/include/geos/algorithm/CentralEndpointIntersector.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/algorithm/CentralEndpointIntersector.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -106,7 +106,7 @@
geom::Coordinate avg(0, 0);
size_t n = pts.size();
if ( ! n ) return avg;
- for (size_t i=0; i<n; ++i)
+ for (std::size_t i=0; i<n; ++i)
avg.x += pts[i].x;
avg.y += pts[i].y;
@@ -131,7 +131,7 @@
double minDist = std::numeric_limits<double>::max();
geom::Coordinate result = geom::Coordinate::getNull();
- for (size_t i = 0, n=pts.size(); i < n; ++i) {
+ for (std::size_t i = 0, n=pts.size(); i < n; ++i) {
double dist = p.distance(pts[i]);
if (dist < minDist) {
minDist = dist;
Modified: trunk/include/geos/geom/CoordinateArraySequence.h
--- trunk/include/geos/geom/CoordinateArraySequence.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateArraySequence.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -44,10 +44,10 @@
CoordinateSequence *clone() const;
//const Coordinate& getCoordinate(int pos) const;
- const Coordinate& getAt(size_t pos) const;
+ const Coordinate& getAt(std::size_t pos) const;
/// Copy Coordinate at position i to Coordinate c
- virtual void getAt(size_t i, Coordinate& c) const;
+ virtual void getAt(std::size_t i, Coordinate& c) const;
//int size() const;
size_t getSize() const;
@@ -65,7 +65,7 @@
CoordinateArraySequence(std::vector<Coordinate> *coords);
/// Construct sequence allocating space for n coordinates
- CoordinateArraySequence(size_t n);
+ CoordinateArraySequence(std::size_t n);
~CoordinateArraySequence();
@@ -86,20 +86,20 @@
* NOTE: this is a CoordinateList interface in JTS
- virtual void add(size_t i, const Coordinate& coord, bool allowRepeated);
+ virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated);
- void setAt(const Coordinate& c, size_t pos);
+ void setAt(const Coordinate& c, std::size_t pos);
- void deleteAt(size_t pos);
+ void deleteAt(std::size_t pos);
std::string toString() const;
void setPoints(const std::vector<Coordinate> &v);
- double getOrdinate(size_t index,
+ double getOrdinate(std::size_t index,
size_t ordinateIndex) const;
- void setOrdinate(size_t index, size_t ordinateIndex,
+ void setOrdinate(std::size_t index, std::size_t ordinateIndex,
double value);
void expandEnvelope(Envelope &env) const;
Modified: trunk/include/geos/geom/CoordinateArraySequenceFactory.h
--- trunk/include/geos/geom/CoordinateArraySequenceFactory.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateArraySequenceFactory.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -51,10 +51,10 @@
CoordinateSequence *create(std::vector<Coordinate> *coords) const;
- CoordinateSequence *create(std::vector<Coordinate> *coords, size_t dims) const;
+ CoordinateSequence *create(std::vector<Coordinate> *coords, std::size_t dims) const;
- /** @see CoordinateSequenceFactory::create(size_t, int) */
- CoordinateSequence *create(size_t size, size_t dimension=3) const;
+ /** @see CoordinateSequenceFactory::create(std::size_t, int) */
+ CoordinateSequence *create(std::size_t size, std::size_t dimension=3) const;
/** \brief
* Returns the singleton instance of CoordinateArraySequenceFactory
Modified: trunk/include/geos/geom/CoordinateArraySequenceFactory.inl
--- trunk/include/geos/geom/CoordinateArraySequenceFactory.inl 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateArraySequenceFactory.inl 2010-03-29 12:17:37 UTC (rev 2961)
@@ -37,7 +37,7 @@
INLINE CoordinateSequence *
-CoordinateArraySequenceFactory::create(size_t size, size_t /* dimension */)
+CoordinateArraySequenceFactory::create(std::size_t size, std::size_t /* dimension */)
const
/* CoordinateArraySequence only accepts 3d Coordinates */
Modified: trunk/include/geos/geom/CoordinateSequence.h
--- trunk/include/geos/geom/CoordinateSequence.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateSequence.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -95,7 +95,7 @@
* Coordinate or merely a copy depends on the implementation.
//virtual const Coordinate& getCoordinate(int i) const=0;
- virtual const Coordinate& getAt(size_t i) const=0;
+ virtual const Coordinate& getAt(std::size_t i) const=0;
/// Return last Coordinate in the sequence
const Coordinate& back() const {
@@ -107,21 +107,21 @@
return getAt(0);
- const Coordinate& operator[] (size_t i) const {
+ const Coordinate& operator[] (std::size_t i) const {
return getAt(i);
/** \brief
* Write Coordinate at position i to given Coordinate.
- virtual void getAt(size_t i, Coordinate& c) const=0;
+ virtual void getAt(std::size_t i, Coordinate& c) const=0;
/** \brief
* Returns the number of Coordinates (actual or otherwise, as
* this implementation may not store its data in Coordinate objects).
//virtual int size() const=0;
- virtual size_t getSize() const=0;
+ virtual std::size_t getSize() const=0;
size_t size() const { return getSize(); }
@@ -200,7 +200,7 @@
- virtual void add(size_t i, const Coordinate& coord, bool allowRepeated)=0;
+ virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated)=0;
/// Returns <code>true</code> it list contains no coordinates.
virtual bool isEmpty() const=0;
@@ -212,13 +212,13 @@
//virtual int getSize() const=0;
/// Get a reference to Coordinate at position pos
- //virtual const Coordinate& getAt(size_t pos) const=0;
+ //virtual const Coordinate& getAt(std::size_t pos) const=0;
/// Copy Coordinate c to position pos
- virtual void setAt(const Coordinate& c, size_t pos)=0;
+ virtual void setAt(const Coordinate& c, std::size_t pos)=0;
/// Delete Coordinate at position pos (list will shrink).
- virtual void deleteAt(size_t pos)=0;
+ virtual void deleteAt(std::size_t pos)=0;
/// Get a string rapresentation of CoordinateSequence
virtual std::string toString() const=0;
@@ -260,7 +260,7 @@
* Returns either the given CoordinateSequence if its length
* is greater than the given amount, or an empty CoordinateSequence.
- static CoordinateSequence* atLeastNCoordinatesOrNothing(size_t n,
+ static CoordinateSequence* atLeastNCoordinatesOrNothing(std::size_t n,
CoordinateSequence *c);
/** \brief
@@ -272,7 +272,7 @@
/// Return position of a Coordinate, or -1 if not found
- /// FIXME: return size_t, using numeric_limits<size_t>::max
+ /// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
/// as 'not found' value.
static int indexOf(const Coordinate *coordinate,
@@ -320,7 +320,7 @@
* @return the dimension of the sequence.
- virtual size_t getDimension() const=0;
+ virtual std::size_t getDimension() const=0;
* Returns the ordinate of a coordinate in this sequence.
@@ -332,7 +332,7 @@
* @param ordinateIndex the ordinate index in the coordinate
* (in range [0, dimension-1])
- virtual double getOrdinate(size_t index, size_t ordinateIndex) const=0;
+ virtual double getOrdinate(std::size_t index, std::size_t ordinateIndex) const=0;
* Returns ordinate X (0) of the specified coordinate.
@@ -340,7 +340,7 @@
* @param index
* @return the value of the X ordinate in the index'th coordinate
- virtual double getX(size_t index) const { return getOrdinate(index, X); }
+ virtual double getX(std::size_t index) const { return getOrdinate(index, X); }
* Returns ordinate Y (1) of the specified coordinate.
@@ -348,7 +348,7 @@
* @param index
* @return the value of the Y ordinate in the index'th coordinate
- virtual double getY(size_t index) const { return getOrdinate(index, Y); }
+ virtual double getY(std::size_t index) const { return getOrdinate(index, Y); }
@@ -359,7 +359,7 @@
* @param value the new ordinate value
- virtual void setOrdinate(size_t index, size_t ordinateIndex, double value)=0;
+ virtual void setOrdinate(std::size_t index, std::size_t ordinateIndex, double value)=0;
* Expands the given Envelope to include the coordinates in the
@@ -385,7 +385,7 @@
void applyCoordinateFilter(T& f)
Coordinate c;
- for(size_t i=0, n=size(); i<n; ++i)
+ for(std::size_t i=0, n=size(); i<n; ++i)
getAt(i, c);
f.filter(c);
Modified: trunk/include/geos/geom/CoordinateSequenceFactory.h
--- trunk/include/geos/geom/CoordinateSequenceFactory.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateSequenceFactory.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -75,7 +75,7 @@
* @param dimension the dimension of the coordinates in the sequence
* (if user-specifiable, otherwise ignored)
- virtual CoordinateSequence *create(size_t size,
+ virtual CoordinateSequence *create(std::size_t size,
size_t dimension) const=0;
virtual ~CoordinateSequenceFactory();
Modified: trunk/include/geos/geom/CoordinateSequenceFilter.h
--- trunk/include/geos/geom/CoordinateSequenceFilter.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/CoordinateSequenceFilter.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -68,7 +68,7 @@
* is applied
* @param i the index of the coordinate to apply the filter to
- virtual void filter_rw(CoordinateSequence& /*seq*/, size_t /*i*/)
+ virtual void filter_rw(CoordinateSequence& /*seq*/, std::size_t /*i*/)
{ assert(0); }
@@ -78,7 +78,7 @@
* is applied
- virtual void filter_ro(const CoordinateSequence& /*seq*/, size_t /*i*/)
+ virtual void filter_ro(const CoordinateSequence& /*seq*/, std::size_t /*i*/)
{ assert(0); }
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/Geometry.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -264,7 +264,7 @@
virtual CoordinateSequence* getCoordinates() const=0; //Abstract
/// Returns the count of this Geometrys vertices.
- virtual size_t getNumPoints() const=0; //Abstract
+ virtual std::size_t getNumPoints() const=0; //Abstract
/// Returns false if the Geometry not simple.
virtual bool isSimple() const;
@@ -277,11 +277,11 @@
/// Returns the number of geometries in this collection
/// (or 1 if this is not a collection)
- virtual size_t getNumGeometries() const { return 1; }
+ virtual std::size_t getNumGeometries() const { return 1; }
/// Returns a pointer to the nth Geometry int this collection
/// (or self if this is not a collection)
- virtual const Geometry* getGeometryN(size_t /*n*/) const { return this; }
+ virtual const Geometry* getGeometryN(std::size_t /*n*/) const { return this; }
* \brief Tests the validity of this <code>Geometry</code>.
@@ -664,7 +664,7 @@
template <class T>
void applyComponentFilter(T& f) const
- for(size_t i=0, n=getNumGeometries(); i<n; ++i)
+ for(std::size_t i=0, n=getNumGeometries(); i<n; ++i)
f.filter(getGeometryN(i));
Modified: trunk/include/geos/geom/GeometryCollection.h
--- trunk/include/geos/geom/GeometryCollection.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/GeometryCollection.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -114,7 +114,7 @@
virtual int getBoundaryDimension() const;
- virtual size_t getNumPoints() const;
+ virtual std::size_t getNumPoints() const;
virtual std::string getGeometryType() const;
@@ -150,10 +150,10 @@
virtual double getLength() const;
- virtual size_t getNumGeometries() const;
+ virtual std::size_t getNumGeometries() const;
- virtual const Geometry* getGeometryN(size_t n) const;
+ virtual const Geometry* getGeometryN(std::size_t n) const;
protected:
Modified: trunk/include/geos/geom/LineSegment.h
--- trunk/include/geos/geom/LineSegment.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/LineSegment.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -77,10 +77,10 @@
void setCoordinates(const Coordinate& c0, const Coordinate& c1);
// obsoleted, use operator[] instead
- //const Coordinate& getCoordinate(size_t i) const;
+ //const Coordinate& getCoordinate(std::size_t i) const;
- const Coordinate& operator[](size_t i) const;
- Coordinate& operator[](size_t i);
+ const Coordinate& operator[](std::size_t i) const;
+ Coordinate& operator[](std::size_t i);
void setCoordinates(const LineSegment& ls);
Modified: trunk/include/geos/geom/LineSegment.inl
--- trunk/include/geos/geom/LineSegment.inl 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/LineSegment.inl 2010-03-29 12:17:37 UTC (rev 2961)
@@ -105,7 +105,7 @@
INLINE const Coordinate&
-LineSegment::operator[](size_t i) const
+LineSegment::operator[](std::size_t i) const
if (i==0) return p0;
assert(i==1);
@@ -113,7 +113,7 @@
INLINE Coordinate&
assert(i==1);
Modified: trunk/include/geos/geom/LineString.h
--- trunk/include/geos/geom/LineString.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/LineString.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -99,9 +99,9 @@
virtual bool isEmpty() const;
- virtual Point* getPointN(size_t n) const;
+ virtual Point* getPointN(std::size_t n) const;
/// \brief
/// Return the start point of the LineString
Modified: trunk/include/geos/geom/Polygon.h
--- trunk/include/geos/geom/Polygon.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/Polygon.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -116,7 +116,7 @@
size_t getNumInteriorRing() const;
/// Get nth interior ring (hole)
- const LineString* getInteriorRingN(size_t n) const;
+ const LineString* getInteriorRingN(std::size_t n) const;
virtual GeometryTypeId getGeometryTypeId() const;
Modified: trunk/include/geos/geom/prep/PreparedLineStringIntersects.h
--- trunk/include/geos/geom/prep/PreparedLineStringIntersects.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geom/prep/PreparedLineStringIntersects.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -101,7 +101,7 @@
// geom::Coordinate::ConstVect coords;
// ComponentCoordinateExtracter::getCoordinates( *testGeom, coords);
- // for (size_t i=0, n=coords.size(); i<n; i++)
+ // for (std::size_t i=0, n=coords.size(); i<n; i++)
// geom::Coordinate c = *(coords[i]);
// if ( locator->intersects( c, &(prepLine->getGeometry()) ))
Modified: trunk/include/geos/geomgraph/EdgeEndStar.h
--- trunk/include/geos/geomgraph/EdgeEndStar.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geomgraph/EdgeEndStar.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -86,7 +86,7 @@
virtual geom::Coordinate& getCoordinate();
- virtual size_t getDegree();
+ virtual std::size_t getDegree();
virtual iterator begin();
@@ -145,7 +145,7 @@
-inline size_t
+inline std::size_t
EdgeEndStar::getDegree()
return edgeMap.size();
Modified: trunk/include/geos/geomgraph/TopologyLocation.h
--- trunk/include/geos/geomgraph/TopologyLocation.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/geomgraph/TopologyLocation.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -80,7 +80,7 @@
TopologyLocation(const TopologyLocation &gl);
- int get(size_t posIndex) const;
+ int get(std::size_t posIndex) const;
* @return true if all locations are Location::UNDEF
@@ -104,7 +104,7 @@
void setAllLocationsIfNull(int locValue);
- void setLocation(size_t locIndex, int locValue);
+ void setLocation(std::size_t locIndex, int locValue);
void setLocation(int locValue);
Modified: trunk/include/geos/index/chain/MonotoneChain.h
--- trunk/include/geos/index/chain/MonotoneChain.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/chain/MonotoneChain.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -98,7 +98,7 @@
/// Ownership left to caller, this class holds a reference.
MonotoneChain(const geom::CoordinateSequence& pts,
- size_t start, size_t end, void* context);
+ std::size_t start, std::size_t end, void* context);
~MonotoneChain();
@@ -113,7 +113,7 @@
* Set given LineSegment with points of the segment starting
* at the given index.
- void getLineSegment(size_t index, geom::LineSegment& ls) const;
+ void getLineSegment(std::size_t index, geom::LineSegment& ls) const;
* Return the subsequence of coordinates forming this chain.
@@ -145,8 +145,8 @@
size_t end0,
MonotoneChainSelectAction& mcs);
- void computeOverlaps(size_t start0, size_t end0, MonotoneChain& mc,
- size_t start1, size_t end1,
+ void computeOverlaps(std::size_t start0, std::size_t end0, MonotoneChain& mc,
+ std::size_t start1, std::size_t end1,
MonotoneChainOverlapAction& mco);
/// Externally owned
Modified: trunk/include/geos/index/chain/MonotoneChainBuilder.h
--- trunk/include/geos/index/chain/MonotoneChainBuilder.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/chain/MonotoneChainBuilder.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -97,8 +97,8 @@
* NOTE: aborts if 'start' is >= pts.getSize()
- static size_t findChainEnd(const geom::CoordinateSequence& pts,
- size_t start);
+ static std::size_t findChainEnd(const geom::CoordinateSequence& pts,
+ std::size_t start);
} // namespace geos::index::chain
Modified: trunk/include/geos/index/chain/MonotoneChainOverlapAction.h
--- trunk/include/geos/index/chain/MonotoneChainOverlapAction.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/chain/MonotoneChainOverlapAction.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -64,8 +64,8 @@
* @param start2 the index of the start of the overlapping segment
* from mc2
- virtual void overlap(MonotoneChain& mc1, size_t start1,
- MonotoneChain& mc2, size_t start2);
+ virtual void overlap(MonotoneChain& mc1, std::size_t start1,
+ MonotoneChain& mc2, std::size_t start2);
* This is a convenience function which can be overridden to
Modified: trunk/include/geos/index/strtree/AbstractSTRtree.h
--- trunk/include/geos/index/strtree/AbstractSTRtree.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/strtree/AbstractSTRtree.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -231,7 +231,7 @@
std::auto_ptr<BoundableList> boundablesAtLevel(int level);
// @@ should be size_t, probably
- size_t nodeCapacity;
+ std::size_t nodeCapacity;
* @return a test for intersection between two bounds,
@@ -248,7 +248,7 @@
* Constructs an AbstractSTRtree with the specified maximum number of child
* nodes that a node may have
- AbstractSTRtree(size_t newNodeCapacity)
+ AbstractSTRtree(std::size_t newNodeCapacity)
built(false),
itemBoundables(new BoundableList()),
@@ -279,7 +279,7 @@
* Returns the maximum number of child nodes that a node may have
- virtual size_t getNodeCapacity() { return nodeCapacity; }
+ virtual std::size_t getNodeCapacity() { return nodeCapacity; }
virtual void query(const void* searchBounds, const AbstractNode* node, std::vector<void*>* matches);
Modified: trunk/include/geos/index/strtree/SIRtree.h
--- trunk/include/geos/index/strtree/SIRtree.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/strtree/SIRtree.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -54,7 +54,7 @@
* Constructs an SIRtree with the given maximum number of child nodes
* that a node may have
- SIRtree(size_t nodeCapacity);
+ SIRtree(std::size_t nodeCapacity);
virtual ~SIRtree();
Modified: trunk/include/geos/index/strtree/STRtree.h
--- trunk/include/geos/index/strtree/STRtree.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/index/strtree/STRtree.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -118,7 +118,7 @@
* Constructs an STRtree with the given maximum number of child nodes that
* a node may have
- STRtree(size_t nodeCapacity=10);
+ STRtree(std::size_t nodeCapacity=10);
void insert(const geom::Envelope *itemEnv,void* item);
Modified: trunk/include/geos/noding/MCIndexNoder.h
--- trunk/include/geos/noding/MCIndexNoder.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/noding/MCIndexNoder.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -99,8 +99,8 @@
si(newSi)
- void overlap(index::chain::MonotoneChain& mc1, size_t start1,
- index::chain::MonotoneChain& mc2, size_t start2);
+ void overlap(index::chain::MonotoneChain& mc1, std::size_t start1,
+ index::chain::MonotoneChain& mc2, std::size_t start2);
private:
SegmentIntersector& si;
Modified: trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -84,8 +84,8 @@
index::chain::MonotoneChainOverlapAction(), si(si)
private:
Modified: trunk/include/geos/noding/SegmentNodeList.h
--- trunk/include/geos/noding/SegmentNodeList.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/noding/SegmentNodeList.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -93,7 +93,7 @@
* which are pre-existing in the vertex list.
void findCollapsesFromExistingVertices(
- std::vector<size_t>& collapsedVertexIndexes);
+ std::vector<std::size_t>& collapsedVertexIndexes);
* Adds nodes for any collapsed edge pairs caused by inserted nodes
@@ -103,7 +103,7 @@
* the vertex must be added as a node as well.
void findCollapsesFromInsertedNodes(
bool findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
size_t& collapsedVertexIndex);
@@ -140,9 +140,9 @@
* @param intPt the intersection Coordinate, will be copied
* @param segmentIndex
- SegmentNode* add(const geom::Coordinate& intPt, size_t segmentIndex);
+ SegmentNode* add(const geom::Coordinate& intPt, std::size_t segmentIndex);
- SegmentNode* add(const geom::Coordinate *intPt, size_t segmentIndex) {
+ SegmentNode* add(const geom::Coordinate *intPt, std::size_t segmentIndex) {
return add(*intPt, segmentIndex);
Modified: trunk/include/geos/noding/SegmentStringUtil.h
--- trunk/include/geos/noding/SegmentStringUtil.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/noding/SegmentStringUtil.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -62,7 +62,7 @@
geom::LineString::ConstVect lines;
geom::util::LinearComponentExtracter::getLines(*g, lines);
- for (size_t i=0, n=lines.size(); i<n; i++)
+ for (std::size_t i=0, n=lines.size(); i<n; i++)
geom::LineString* line = (geom::LineString*)(lines[i]);
Modified: trunk/include/geos/noding/snapround/HotPixel.h
--- trunk/include/geos/noding/snapround/HotPixel.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/noding/snapround/HotPixel.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -171,7 +171,7 @@
* @param segIndex
* @return true if a node was added to the segment
- bool addSnappedNode(NodedSegmentString& segStr, size_t segIndex);
+ bool addSnappedNode(NodedSegmentString& segStr, std::size_t segIndex);
Modified: trunk/include/geos/operation/predicate/RectangleIntersects.h
--- trunk/include/geos/operation/predicate/RectangleIntersects.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/operation/predicate/RectangleIntersects.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -66,7 +66,7 @@
* Must be determined empirically. Should err on the
* safe side by making value smaller rather than larger.
- static const size_t MAXIMUM_SCAN_SEGMENT_COUNT;
+ static const std::size_t MAXIMUM_SCAN_SEGMENT_COUNT;
/** \brief
* Create a new intersects computer for a rectangle.
Modified: trunk/include/geos/planargraph/DirectedEdgeStar.h
--- trunk/include/geos/planargraph/DirectedEdgeStar.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/planargraph/DirectedEdgeStar.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -86,7 +86,7 @@
* \brief Returns the number of edges around the Node associated
* with this DirectedEdgeStar.
- size_t getDegree() const { return outEdges.size(); }
+ std::size_t getDegree() const { return outEdges.size(); }
* \brief Returns the coordinate for the node at wich this
Modified: trunk/include/geos/planargraph/PlanarGraph.h
--- trunk/include/geos/planargraph/PlanarGraph.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/planargraph/PlanarGraph.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -230,7 +230,7 @@
* Returns all Nodes with the given number of Edges around it.
* The return value is a newly allocated vector of existing nodes
- std::vector<Node*>* findNodesOfDegree(size_t degree);
+ std::vector<Node*>* findNodesOfDegree(std::size_t degree);
} // namespace geos::planargraph
Modified: trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h
--- trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/simplify/DouglasPeuckerLineSimplifier.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -81,7 +81,7 @@
BoolVectAutoPtr usePt;
double distanceTolerance;
- void simplifySection(size_t i, size_t j);
+ void simplifySection(std::size_t i, std::size_t j);
// Declare type as noncopyable
DouglasPeuckerLineSimplifier(const DouglasPeuckerLineSimplifier& other);
Modified: trunk/include/geos/simplify/TaggedLineString.h
--- trunk/include/geos/simplify/TaggedLineString.h 2010-03-29 12:13:37 UTC (rev 2960)
+++ trunk/include/geos/simplify/TaggedLineString.h 2010-03-29 12:17:37 UTC (rev 2961)
@@ -80,9 +80,9 @@
size_t getResultSize() const;
- TaggedLineSegment* getSegment(size_t);
+ TaggedLineSegment* getSegment(std::size_t);
- const TaggedLineSegment* getSegment(size_t) const;
+ const TaggedLineSegment* getSegment(std::size_t) const;
std::vector<TaggedLineSegment*>& getSegments();
More information about the geos-commits
