[geos-commits] r2995 - in trunk: include/geos/geom include/geos/io src/geom src/io tests/unit tests/unit/geom tests/unit/io
svn_geos at osgeo.org svn_geos at osgeo.org
Fri May 28 16:38:41 EDT 2010
Author: warmerdam
Date: 2010-05-28 16:38:40 -0400 (Fri, 28 May 2010)
New Revision: 2995
   trunk/include/geos/geom/Geometry.h
   trunk/include/geos/geom/GeometryCollection.h
   trunk/include/geos/geom/LineString.h
   trunk/include/geos/geom/Point.h
   trunk/include/geos/geom/Polygon.h
   trunk/include/geos/io/WKBWriter.h
   trunk/include/geos/io/WKTWriter.h
   trunk/src/geom/GeometryCollection.cpp
   trunk/src/geom/LineString.cpp
   trunk/src/geom/Point.cpp
   trunk/src/geom/Polygon.cpp
   trunk/src/io/WKBWriter.cpp
   trunk/src/io/WKTWriter.cpp
   trunk/tests/unit/Makefile.am
   trunk/tests/unit/geom/LineStringTest.cpp
   trunk/tests/unit/geom/PointTest.cpp
   trunk/tests/unit/io/WKTWriterTest.cpp
Implement getCoordinateDimension() for geometries (#331)
WKTWriter now has setOutputDimension() method, and writes 3D geometries (#292)
WKBWriter has fixes for writing 2D geometries from 3D geometry (#346)
Minimal unit tests for the above.
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/geom/Geometry.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -303,6 +303,9 @@
 	/// Returns the dimension of this Geometry (0=point, 1=line, 2=surface)
 	virtual Dimension::DimensionType getDimension() const=0; //Abstract
+	/// Returns the coordinate dimension of this Geometry (2=XY, 3=XYZ, 4=XYZM in future).
+	virtual int getCoordinateDimension() const=0; //Abstract
 	 * \brief
 	 * Returns the boundary, or an empty geometry of appropriate
Modified: trunk/include/geos/geom/GeometryCollection.h
--- trunk/include/geos/geom/GeometryCollection.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/geom/GeometryCollection.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -105,6 +105,9 @@
 	virtual Dimension::DimensionType getDimension() const;
+	/// Returns coordinate dimension.
+	virtual int getCoordinateDimension() const;
 	virtual Geometry* getBoundary() const;
Modified: trunk/include/geos/geom/LineString.h
--- trunk/include/geos/geom/LineString.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/geom/LineString.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -90,6 +90,9 @@
 	virtual int getBoundaryDimension() const;
 	 * \brief
 	 * Returns a MultiPoint.
Modified: trunk/include/geos/geom/Point.h
--- trunk/include/geos/geom/Point.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/geom/Point.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -92,6 +92,9 @@
 	/// Returns point dimension (0)
 	/// Returns Dimension::False (Point has no boundary)
Modified: trunk/include/geos/geom/Polygon.h
--- trunk/include/geos/geom/Polygon.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/geom/Polygon.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -88,6 +88,9 @@
 	/// Returns surface dimension (2)
 	/// Returns 1 (Polygon boundary is a MultiLineString)
Modified: trunk/include/geos/io/WKBWriter.h
--- trunk/include/geos/io/WKBWriter.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/io/WKBWriter.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -75,30 +75,38 @@
 public:
 	 * \brief
-	 * Initializes writer with target coordinate dimention, endianness flag
-     * and SRID value.
-	 * <code>WKBWriter</code>.
+	 * Initializes writer with target coordinate dimension, endianness
+     * flag and SRID value.
+     * @param dims Supported values are 2 or 3.  Note that 3 indicates
+     * up to 3 dimensions will be written but 2D WKB is still produced for 2D geometries.
+     * @param bo output byte order - default to native machine byte order.
+     * Legal values include 0 (big endian/xdr) and 1 (little endian/ndr).
+     * @param incudeSRID true if SRID should be included in WKB (an
+     * extension).
 	WKBWriter(int dims=2, int bo=getMachineByteOrder(), bool includeSRID=false);
-     * \brief
-     * Destructor.
-    virtual ~WKBWriter();
+         * \brief
+         * Destructor.
+	virtual ~WKBWriter();
 	 * \brief
 	 * Returns the output dimension used by the
-	virtual int getOutputDimension() const { return outputDimension; }
+	virtual int getOutputDimension() const { return defaultOutputDimension; }
-	 * Sets the output dimension used by the
+	 * Sets the output dimension used by the <code>WKBWriter</code>.
+     * @param newOutputDimension Supported values are 2 or 3.  Note that 3 indicates
-	virtual void setOutputDimension(int newOutputDimension) { outputDimension=newOutputDimension; }
+	virtual void setOutputDimension(int newOutputDimension) { defaultOutputDimension=newOutputDimension; }
 	 * \brief
@@ -124,7 +132,7 @@
 	 * Sets whether SRID values should be output by the
-    virtual void setIncludeSRID(int newIncludeSRID) { includeSRID = (0 == newIncludeSRID ? false : true); }
+	virtual void setIncludeSRID(int newIncludeSRID) { includeSRID = (0 == newIncludeSRID ? false : true); }
 	 * \brief Write a Geometry to an ostream.
@@ -148,7 +156,8 @@
 private:
-	int outputDimension;
+	int defaultOutputDimension;
+    int outputDimension;
 	int byteOrder;
Modified: trunk/include/geos/io/WKTWriter.h
--- trunk/include/geos/io/WKTWriter.h	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/include/geos/io/WKTWriter.h	2010-05-28 20:38:40 UTC (rev 2995)
@@ -139,6 +139,32 @@
 	void setTrim(bool p0);
+	 * Enable old style 3D/4D WKT generation.
+     * By default the WKBWriter produces new style 3D/4D WKT (ie. "POINT Z (10 20 30)")
+     * but if this method is used to turn on old style WKT production then the WKT will
+     * be formatted in the style "POINT (10 20 30)".
+	 * @param useOld3D true or false
+	void setOld3D(bool useOld3D ) { old3D = useOld3D; }
+	 * \brief
+	 * Returns the output dimension used by the
+	 * <code>WKBWriter</code>.
 protected:
 	std::string formatter;
@@ -229,6 +255,10 @@
 	int level;
+    bool old3D;
 	void writeFormatted(
 			const geom::Geometry *geometry,
 			bool isFormatted, Writer *writer);
Modified: trunk/src/geom/GeometryCollection.cpp
--- trunk/src/geom/GeometryCollection.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/geom/GeometryCollection.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -127,6 +127,18 @@
 	return dimension;
+int
+GeometryCollection::getCoordinateDimension() const
+	int dimension=2;
+	for (size_t i=0, n=geometries->size(); i<n; ++i)
+		dimension=max(dimension,(*geometries)[i]->getCoordinateDimension());
+	return dimension;
 size_t
 GeometryCollection::getNumGeometries() const
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/geom/LineString.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -136,6 +136,12 @@
 int
+LineString::getCoordinateDimension() const
+    return (int) points->getDimension();
+int
 LineString::getBoundaryDimension() const
 	if (isClosed()) {
Modified: trunk/src/geom/Point.cpp
--- trunk/src/geom/Point.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/geom/Point.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -99,6 +99,12 @@
 int
+Point::getCoordinateDimension() const
+    return (int) coordinates->getDimension();
+int
 Point::getBoundaryDimension() const
 	return Dimension::False;
Modified: trunk/src/geom/Polygon.cpp
--- trunk/src/geom/Polygon.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/geom/Polygon.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -145,6 +145,23 @@
 int
+Polygon::getCoordinateDimension() const
+	int dimension=2;
+    if( shell != NULL )
+        dimension = max(dimension,shell->getCoordinateDimension());
+	size_t nholes=holes->size();
+	for (size_t i=0; i<nholes; ++i)
+        dimension = max(dimension,(*holes)[i]->getCoordinateDimension());
+	return dimension;
+int
 Polygon::getBoundaryDimension() const
 	return 1;
Modified: trunk/src/io/WKBWriter.cpp
--- trunk/src/io/WKBWriter.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/io/WKBWriter.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -46,10 +46,11 @@
 	namespace io { // geos.io
 WKBWriter::WKBWriter(int dims, int bo, bool srid):
-		outputDimension(dims), byteOrder(bo), includeSRID(srid), outStream(NULL)
+		defaultOutputDimension(dims), byteOrder(bo), includeSRID(srid), outStream(NULL)
 	if ( dims < 2 || dims > 3 )
 		throw util::IllegalArgumentException("WKB output dimension must be 2 or 3");
+    outputDimension = defaultOutputDimension;
 WKBWriter::~WKBWriter()
@@ -72,6 +73,10 @@
 void
 WKBWriter::write(const Geometry &g, ostream &os)
+    if( outputDimension > g.getCoordinateDimension() )
+        outputDimension = g.getCoordinateDimension();
 	outStream = &os;
 	switch (g.getGeometryTypeId()) {
@@ -204,20 +209,19 @@
 WKBWriter::writeGeometryType(int typeId, int SRID)
 	int flag3D = (outputDimension == 3) ? 0x80000000 : 0;
-        int typeInt = typeId | flag3D;
+    int typeInt = typeId | flag3D;
-        if (includeSRID && SRID != 0)
-          typeInt = typeInt | 0x20000000;
+    if (includeSRID && SRID != 0)
+        typeInt = typeInt | 0x20000000;
-	//writeInt(typeId);
 	writeInt(typeInt);
 void
 WKBWriter::writeSRID(int SRID)
-          writeInt(SRID);
+        writeInt(SRID);
 void
@@ -234,7 +238,7 @@
 	int size = cs.getSize();
 	bool is3d=false;
-	if ( cs.getDimension() > 2 && outputDimension > 2) is3d = true;
+	if ( outputDimension > 2) is3d = true;
 	if (sized) writeInt(size);
 	for (int i=0; i<size; i++) writeCoordinate(cs, i, is3d);
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/src/io/WKTWriter.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -38,8 +38,6 @@
 #include <sstream>
 #include <cassert>
-#define PRINT_Z 0
 using namespace std;
 using namespace geos::geom;
@@ -52,6 +50,8 @@
 	trim = false;
 	level=0;
 	formatter="%f";
+    defaultOutputDimension = 2;
+    old3D = false;
 WKTWriter::~WKTWriter() {}
@@ -194,6 +194,8 @@
 WKTWriter::appendGeometryTaggedText(const Geometry *geometry, int level,
 		Writer *writer)
+    outputDimension = min(defaultOutputDimension,geometry->getCoordinateDimension());
 	indent(level, writer);
 	if (typeid(*geometry)==typeid(Point)) {
 		Point* point=(Point*)geometry;
@@ -225,6 +227,9 @@
 		Writer *writer)
 	writer->write("POINT ");
+    if( outputDimension == 3 && !old3D )
+        writer->write( "Z " );
 	appendPointText(coordinate, level, writer);
@@ -233,6 +238,9 @@
 		Writer *writer)
 	writer->write("LINESTRING ");
 	appendLineStringText(lineString, level, false, writer);
@@ -245,31 +253,43 @@
 void WKTWriter::appendLinearRingTaggedText(const LinearRing* linearRing, int level, Writer *writer) {
 	writer->write("LINEARRING ");
 	appendLineStringText((LineString*)linearRing, level, false, writer);
 void WKTWriter::appendPolygonTaggedText(const Polygon *polygon, int level, Writer *writer) {
 	writer->write("POLYGON ");
 	appendPolygonText(polygon, level, false, writer);
 void WKTWriter::appendMultiPointTaggedText(const MultiPoint *multipoint, int level, Writer *writer) {
 	writer->write("MULTIPOINT ");
 	appendMultiPointText(multipoint, level, writer);
 void WKTWriter::appendMultiLineStringTaggedText(const MultiLineString *multiLineString, int level,Writer *writer) {
 	writer->write("MULTILINESTRING ");
 	appendMultiLineStringText(multiLineString, level, false, writer);
 void WKTWriter::appendMultiPolygonTaggedText(const MultiPolygon *multiPolygon, int level, Writer *writer) {
 	writer->write("MULTIPOLYGON ");
 	appendMultiPolygonText(multiPolygon, level, writer);
 void WKTWriter::appendGeometryCollectionTaggedText(const GeometryCollection *geometryCollection, int level,Writer *writer) {
 	writer->write("GEOMETRYCOLLECTION ");
+    if( outputDimension == 3 && !old3D ) // ? do we really do this?
 	appendGeometryCollectionText(geometryCollection, level, writer);
@@ -294,10 +314,11 @@
 	out+=writeNumber(coordinate->x);
 	out+=" ";
 	out+=writeNumber(coordinate->y);
-#if PRINT_Z
-	out+=" ";
-	out+=writeNumber(coordinate->z);
-#endif
+    if( outputDimension == 3 )
+        out+=" ";
+        out+=writeNumber(coordinate->z);
 	writer->write(out);
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/tests/unit/Makefile.am	2010-05-28 20:38:40 UTC (rev 2995)
@@ -62,6 +62,7 @@
 	index/quadtree/DoubleBitsTest.cpp \
 	io/ByteOrderValuesTest.cpp \
 	io/WKBReaderTest.cpp \
+	io/WKBWriterTest.cpp \
 	io/WKTReaderTest.cpp \
 	io/WKTWriterTest.cpp \
 	linearref/LengthIndexedLineTest.cpp \
Modified: trunk/tests/unit/geom/LineStringTest.cpp
--- trunk/tests/unit/geom/LineStringTest.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/tests/unit/geom/LineStringTest.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -129,6 +129,7 @@
 		ensure_equals( ls->getGeometryTypeId(), geos::geom::GEOS_LINESTRING );
 		ensure_equals( ls->getDimension(), geos::geom::Dimension::L );
 		ensure_equals( ls->getBoundaryDimension(), geos::geom::Dimension::P );
+        ensure_equals( ls->getCoordinateDimension(), 3 );
 		ensure_equals( ls->getNumPoints(), size3 );
 		ensure_equals( ls->getArea(), 0.0 );
 		ensure( ls->getLength() != 0.0 );
@@ -328,6 +329,7 @@
 		ensure( !line->isEmpty() );
 		ensure( !line->isClosed() );
 		ensure( !line->isRing() );
+        ensure( line->getCoordinateDimension() == 2 );
 		// FREE TESTED LINESTRING
 		factory_.destroyGeometry(line);
Modified: trunk/tests/unit/geom/PointTest.cpp
--- trunk/tests/unit/geom/PointTest.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/tests/unit/geom/PointTest.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -91,6 +91,10 @@
 		PointAutoPtr point(factory_.createPoint(coords));
 		ensure( !point->isEmpty() );
+        // currently the empty CoordinateArraySequence constructor
+        // produces a dimension 3 sequence.
+        ensure( point->getCoordinateDimension() == 3 );
     // Test of user's constructor throwing IllegalArgumentException
@@ -510,5 +514,19 @@
 		factory_.destroyGeometry(p3);
+	// Test of getCoordinateDimension() for 2d/3d.
+	template<>
+	template<>
+	void object::test<40>()
+		GeometryPtr p = reader_.read("POINT(-1.233 5.678 1.0)");
+        ensure( p->getCoordinateDimension() == 3 );
+		p = reader_.read("POINT(-1.233 5.678)");
+        ensure( p->getCoordinateDimension() == 2 );
 } // namespace tut
Modified: trunk/tests/unit/io/WKTWriterTest.cpp
--- trunk/tests/unit/io/WKTWriterTest.cpp	2010-05-28 20:32:14 UTC (rev 2994)
+++ trunk/tests/unit/io/WKTWriterTest.cpp	2010-05-28 20:38:40 UTC (rev 2995)
@@ -30,11 +30,11 @@
 		geos::io::WKTWriter wktwriter;
 		test_wktwriter_data()
-			pm(1000.0),
-			gf(&pm),
-			wktreader(&gf)
+                pm(1000.0),
+                gf(&pm),
+                wktreader(&gf)
@@ -53,42 +53,85 @@
 	template<>
 	void object::test<1>()
-            geos::geom::Geometry *geom = wktreader.read("POINT(-117 33)");
-            std::string  result;
+        geos::geom::Geometry *geom = wktreader.read("POINT(-117 33)");
+        std::string  result;
-            wktwriter.setTrim(false);
-            result = wktwriter.write( geom );
+        wktwriter.setTrim(false);
+        result = wktwriter.write( geom );
-            ensure( result == "POINT (-117.0000 33.0000)" );
+        ensure( result == "POINT (-117.0000 33.0000)" );
-            wktwriter.setTrim(true);
+        wktwriter.setTrim(true);
-            ensure( result == "POINT (-117 33)" );
+        ensure( result == "POINT (-117 33)" );
-            delete geom;
+        delete geom;
 	// 2 - Test the output precision capability
 	template<>
 	template<>
 	void object::test<2>()
-            geos::geom::Geometry *geom = wktreader.read("POINT(-117.1234567 33.1234567)");
+        geos::geom::Geometry *geom = wktreader.read("POINT(-117.1234567 33.1234567)");
-            ensure( result == "POINT (-117.1230 33.1230)" );
+        ensure( result == "POINT (-117.1230 33.1230)" );
-            wktwriter.setRoundingPrecision(2);
+        wktwriter.setRoundingPrecision(2);
-            ensure( result == "POINT (-117.12 33.12)" );
+        ensure( result == "POINT (-117.12 33.12)" );
-            delete geom;
+        delete geom;
+	// 3 - Test 3D generation from a 3D geometry.
+	template<>
+	template<>
+	void object::test<3>()
+        geos::geom::Geometry *geom = wktreader.read("POINT Z (-117 33 120)");
+        wktwriter.setOutputDimension(3);
+        wktwriter.setTrim( true );
+        wktwriter.setOld3D( false );
+        ensure_equals( result, std::string("POINT Z (-117 33 120)") );
+        wktwriter.setOld3D( true );
+        ensure_equals( result, std::string("POINT (-117 33 120)") );
+        delete geom;
+	// 4 - Test 2D generation from a 3D geometry.
+	template<>
+	template<>
+	void object::test<4>()
+        geos::geom::Geometry *geom = wktreader.read("POINT(-117 33 120)");
+        wktwriter.setOutputDimension(2);
+        ensure_equals( result, std::string("POINT (-117 33)") );
+        delete geom;
 } // namespace tut
More information about the geos-commits mailing list
