[geos-commits] r3120 - in trunk: include/geos/operation
include/geos/operation/sharedpaths src/operation
src/operation/sharedpaths
svn_geos at osgeo.org
Mon Nov 29 04:32:34 EST 2010
Author: strk
Date: 2010-11-29 01:32:34 -0800 (Mon, 29 Nov 2010)
New Revision: 3120
Added:
trunk/include/geos/operation/sharedpaths/
trunk/include/geos/operation/sharedpaths/SharedPathsOp.h
trunk/src/operation/sharedpaths/
trunk/src/operation/sharedpaths/SharedPathsOp.cpp
Stub SharedPathsOp
Added: trunk/include/geos/operation/sharedpaths/SharedPathsOp.h
--- trunk/include/geos/operation/sharedpaths/SharedPathsOp.h (rev 0)
+++ trunk/include/geos/operation/sharedpaths/SharedPathsOp.h 2010-11-29 09:32:34 UTC (rev 3120)
@@ -0,0 +1,84 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2010 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: original work
+#ifndef GEOS_OPERATION_SHAREDPATHSOP_H
+#define GEOS_OPERATION_SHAREDPATHSOP_H
+#include <vector>
+// Forward declarations
+namespace geos {
+ namespace geom {
+ //class LineString;
+ class Geometry;
+namespace geos {
+namespace operation { // geos.operation
+namespace sharedpaths { // geos.operation.sharedpaths
+/** \brief
+ * Find shared paths among two linear Geometry objects
+ * For each shared path report if it direction is the same
+ * or opposite.
+class GEOS_DLL SharedPathsOp
+public:
+ /// Find paths shared between two linear geometries
+ /// @param g1
+ /// First geometry. Must be linear.
+ /// @param g2
+ /// Second geometry. Must be linear.
+ /// @param tol
+ /// Tolerance by which very close paths are considered shared.
+ /// TODO: specify more about the semantic, check SnapOp
+ /// @param sameDir
+ /// Shared edges having the same direction are pushed
+ /// onto this vector. They'll be of type LineString.
+ /// Ownership of the edges is tranferred.
+ /// @param oppositeDir
+ /// Shared edges having the opposite direction are pushed
+ static void SharedPathsOp(const Geometry& g1, const Geometry& g2,
+ double tol,
+ std::vector<Geometry*>& sameDirection,
+ std::vector<Geometry*>& oppositeDirection);
+} // namespace geos.operation.sharedpaths
+#endif
Added: trunk/src/operation/sharedpaths/SharedPathsOp.cpp
--- trunk/src/operation/sharedpaths/SharedPathsOp.cpp (rev 0)
+++ trunk/src/operation/sharedpaths/SharedPathsOp.cpp 2010-11-29 09:32:34 UTC (rev 3120)
@@ -0,0 +1,40 @@
+ * $Id$
+#include <geos/operation/sharedpahts/SharedPathsOp.h>
+#include <geos/util/IllegalArgumentException.h>
+namespace geos {
+/* public static */
+void
+SharedPathsOp::SharedPathsOp(const Geometry& g1, const Geometry& g2,
+ double tol,
+ throw geos::util::IllegalArgumentException("Not implemented yet");
+} // namespace geos::operation
More information about the geos-commits
