[geos-commits] r3136 - in trunk: capi php php/test
svn_geos at osgeo.org
Mon Nov 29 05:51:13 EST 2010
Author: strk
Date: 2010-11-29 02:51:13 -0800 (Mon, 29 Nov 2010)
New Revision: 3136
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/php/geos.c
trunk/php/test/test.php
Merge branch 'rt'
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2010-11-29 09:43:32 UTC (rev 3135)
+++ trunk/capi/geos_c.cpp 2010-11-29 10:51:13 UTC (rev 3136)
@@ -1094,4 +1094,13 @@
return GEOSOrientationIndex_r(handle, Ax, Ay, Bx, By, Px, Py);
+GEOSGeometry *
+GEOSSharedPaths(const GEOSGeometry* g1, const GEOSGeometry* g2)
+ return GEOSSharedPaths_r(handle, g1, g2);
+extern GEOSGeometry GEOS_DLL *GEOSSharedPaths_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1, const GEOSGeometry* g2);
} /* extern "C" */
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2010-11-29 09:43:32 UTC (rev 3135)
+++ trunk/capi/geos_c.h.in 2010-11-29 10:51:13 UTC (rev 3136)
@@ -597,6 +597,22 @@
const GEOSGeometry* g);
+ * Find paths shared between the two given lineal geometries.
+ * Returns a GEOMETRYCOLLECTION having two elements:
+ * - first element is a MULTILINESTRING containing shared paths
+ * having the _same_ direction on both inputs
+ * - second element is a MULTILINESTRING containing shared paths
+ * having the _opposite_ direction on the two inputs
+ * Returns NULL on exception
+extern GEOSGeometry GEOS_DLL *GEOSSharedPaths(const GEOSGeometry* g1,
+ const GEOSGeometry* g2);
* Binary predicates - return 2 on exception, 1 on true, 0 on false
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2010-11-29 09:43:32 UTC (rev 3135)
+++ trunk/capi/geos_ts_c.cpp 2010-11-29 10:51:13 UTC (rev 3136)
@@ -53,6 +53,7 @@
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/buffer/BufferParameters.h>
#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/sharedpaths/SharedPathsOp.h>
#include <geos/linearref/LengthIndexedLine.h>
#include <geos/geom/BinaryOp.h>
#include <geos/util/IllegalArgumentException.h>
@@ -5327,6 +5328,79 @@
+GEOSGeometry *
+GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const GEOSGeometry* g2)
+ using namespace geos::operation::sharedpaths;
+ if ( 0 == extHandle ) return 0;
+ GEOSContextHandleInternal_t *handle =
+ reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( handle->initialized == 0 ) return 0;
+ SharedPathsOp::PathList forw, back;
+ try {
+ SharedPathsOp::sharedPathsOp(*g1, *g2, forw, back);
+ catch (const std::exception &e)
+ SharedPathsOp::clearEdges(forw);
+ SharedPathsOp::clearEdges(back);
+ handle->ERROR_MESSAGE("%s", e.what());
+ return 0;
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 0;
+ // Now forw and back have the geoms we want to use to construct
+ // our output GeometryCollections...
+ const GeometryFactory* factory = g1->getFactory();
+ size_t count;
+ std::auto_ptr< std::vector<Geometry*> > out1(
+ new std::vector<Geometry*>()
+ count = forw.size();
+ out1->reserve(count);
+ for (size_t i=0; i<count; ++i) {
+ out1->push_back(forw[i]);
+ std::auto_ptr<Geometry> out1g (
+ factory->createMultiLineString(out1.release())
+ std::auto_ptr< std::vector<Geometry*> > out2(
+ count = back.size();
+ out2->reserve(count);
+ out2->push_back(back[i]);
+ std::auto_ptr<Geometry> out2g (
+ factory->createMultiLineString(out2.release())
+ std::auto_ptr< std::vector<Geometry*> > out(
+ out->reserve(2);
+ out->push_back(out1g.release());
+ out->push_back(out2g.release());
+ std::auto_ptr<Geometry> outg (
+ factory->createGeometryCollection(out.release())
+ return outg.release();
} /* extern "C" */
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2010-11-29 09:43:32 UTC (rev 3135)
+++ trunk/php/geos.c 2010-11-29 10:51:13 UTC (rev 3136)
@@ -41,11 +41,13 @@
PHP_FUNCTION(GEOSVersion);
PHP_FUNCTION(GEOSPolygonize);
PHP_FUNCTION(GEOSLineMerge);
+PHP_FUNCTION(GEOSSharedPaths);
static function_entry geos_functions[] = {
PHP_FE(GEOSVersion, NULL)
PHP_FE(GEOSPolygonize, NULL)
PHP_FE(GEOSLineMerge, NULL)
+ PHP_FE(GEOSSharedPaths, NULL)
{NULL, NULL, NULL}
@@ -2309,6 +2311,32 @@
GEOSGeom_destroy(geom_out);
+ * GEOSGeometry GEOSSharedPaths(GEOSGeometry $geom1, GEOSGeometry *geom2)
+ GEOSGeometry *geom_in_1;
+ GEOSGeometry *geom_in_2;
+ GEOSGeometry *geom_out;
+ zval *zobj1, *zobj2;
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "oo", &zobj1, &zobj2)
+ == FAILURE)
+ RETURN_NULL();
+ geom_in_1 = getRelay(zobj1, Geometry_ce_ptr);
+ geom_in_2 = getRelay(zobj2, Geometry_ce_ptr);
+ geom_out = GEOSSharedPaths(geom_in_1, geom_in_2);
+ if ( ! geom_out ) RETURN_NULL(); /* should get an exception first */
+ /* return_value is a zval */
+ object_init_ex(return_value, Geometry_ce_ptr);
+ setRelay(return_value, geom_out);
/* ------ Initialization / Deinitialization / Meta ------------------ */
/* per-module initialization */
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2010-11-29 09:43:32 UTC (rev 3135)
+++ trunk/php/test/test.php 2010-11-29 10:51:13 UTC (rev 3136)
@@ -1055,6 +1055,21 @@
+ public function testGeometry_sharedPaths()
+ $reader = new GEOSWKTReader();
+ $writer = new GEOSWKTWriter();
+ $writer->setRoundingPrecision(0);
+ /* LINE - LINE */
+ $g1 = $reader->read('LINESTRING(0 0, 50 0)');
+ $g2 = $reader->read('MULTILINESTRING((5 0, 15 0),(40 0, 30 0))');
+ $gs = GEOSSharedPaths($g1, $g2);
+ $this->assertEquals(
+'GEOMETRYCOLLECTION (MULTILINESTRING ((5 0, 15 0)), MULTILINESTRING ((30 0, 40 0)))'
+ , $writer->write($gs));
public function testGeometry_simplify()
@@ -2011,4 +2026,5 @@
$this->assertEquals(53, $g->getSRID());
More information about the geos-commits
