[geos-commits] r3304 - in trunk/tests/unit: . capi
svn_geos at osgeo.org
Wed Apr 27 09:06:31 EDT 2011
Author: strk
Date: 2011-04-27 06:06:31 -0700 (Wed, 27 Apr 2011)
New Revision: 3304
Added:
trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
trunk/tests/unit/Makefile.am
trunk/tests/unit/capi/GEOSBufferTest.cpp
Put OffsetCurveTest in its own file (old singleside test + a couple more tests)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2011-04-27 13:06:22 UTC (rev 3303)
+++ trunk/tests/unit/Makefile.am 2011-04-27 13:06:31 UTC (rev 3304)
@@ -101,6 +101,7 @@
capi/GEOSPreparedGeometryTest.cpp \
capi/GEOSPolygonizer_getCutEdgesTest.cpp \
capi/GEOSBufferTest.cpp \
+ capi/GEOSOffsetCurveTest.cpp \
capi/GEOSGeom_create.cpp \
capi/GEOSGeom_extractUniquePointsTest.cpp \
capi/GEOSOrientationIndex.cpp \
Modified: trunk/tests/unit/capi/GEOSBufferTest.cpp
--- trunk/tests/unit/capi/GEOSBufferTest.cpp 2011-04-27 13:06:22 UTC (rev 3303)
+++ trunk/tests/unit/capi/GEOSBufferTest.cpp 2011-04-27 13:06:31 UTC (rev 3304)
@@ -444,48 +444,5 @@
- // Single-sided buffer (1)
- template<>
- template<>
- void object::test<17>()
- geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0)");
- ensure( 0 != geom1_ );
- geom2_ = GEOSSingleSidedBuffer(geom1_, 2, 2, GEOSBUF_JOIN_ROUND, 2, 1);
- ensure( 0 != geom2_ );
- wkt_ = GEOSGeomToWKT(geom2_);
- ensure_equals(std::string(wkt_), std::string(
-"LINESTRING (0.0000000000000000 2.0000000000000000, 10.0000000000000000 2.0000000000000000)"
- // Single-sided buffer (2)
- template<>
- template<>
- void object::test<18>()
- geom2_ = GEOSSingleSidedBuffer(geom1_, 2, 2, GEOSBUF_JOIN_ROUND, 2, 0);
-"LINESTRING (10.0000000000000000 -2.0000000000000000, 0.0000000000000000 -2.0000000000000000)"
} // namespace tut
Added: trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
--- trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp 2011-04-27 13:06:31 UTC (rev 3304)
@@ -0,0 +1,153 @@
+// $Id$
+// Test Suite for C-API GEOSOffsetCurve
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capioffsetcurve_data
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ GEOSWKTWriter* wktw_;
+ char* wkt_;
+ double area_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capioffsetcurve_data()
+ : geom1_(0), geom2_(0), wkt_(0)
+ initGEOS(notice, notice);
+ wktw_ = GEOSWKTWriter_create();
+ GEOSWKTWriter_setTrim(wktw_, 1);
+ ~test_capioffsetcurve_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ GEOSWKTWriter_destroy(wktw_);
+ GEOSFree(wkt_);
+ geom1_ = 0;
+ geom2_ = 0;
+ wkt_ = 0;
+ finishGEOS();
+ typedef test_group<test_capioffsetcurve_data> group;
+ typedef group::object object;
+ group test_capioffsetcurve_group("capi::GEOSOffsetCurve");
+ // Test Cases
+ // Straight, left
+ template<>
+ template<>
+ void object::test<1>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0)");
+ ensure( 0 != geom1_ );
+ geom2_ = GEOSOffsetCurve(geom1_, 2, 2, GEOSBUF_JOIN_ROUND, 2, 1);
+ ensure( 0 != geom2_ );
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ ensure_equals(std::string(wkt_), std::string( "LINESTRING (0 2, 10 2)"));
+ // Straight, right
+ template<>
+ template<>
+ void object::test<2>()
+ geom2_ = GEOSOffsetCurve(geom1_, 2, 2, GEOSBUF_JOIN_ROUND, 2, 0);
+"LINESTRING (10 -2, 0 -2)"
+ // Outside curve
+ template<>
+ template<>
+ void object::test<3>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0, 10 10)");
+ geom2_ = GEOSOffsetCurve(geom1_, 2, 1, GEOSBUF_JOIN_ROUND, 2, 0);
+"LINESTRING (12 10, 12 0, 10 -2, 0 -2)"
+ // Inside curve
+ template<>
+ template<>
+ void object::test<4>()
+ geom2_ = GEOSOffsetCurve(geom1_, 2, 1, GEOSBUF_JOIN_ROUND, 2, 1);
+"LINESTRING (0 2, 8 2, 8 10)"
+} // namespace tut
More information about the geos-commits
