[geos-commits] r3309 - in trunk: include/geos/operation/linemerge
src/operation/linemerge
svn_geos at osgeo.org
Wed Apr 27 11:47:14 EDT 2011
Author: strk
Date: 2011-04-27 08:47:14 -0700 (Wed, 27 Apr 2011)
New Revision: 3309
trunk/include/geos/operation/linemerge/EdgeString.h
trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h
trunk/include/geos/operation/linemerge/LineMergeEdge.h
trunk/include/geos/operation/linemerge/LineMergeGraph.h
trunk/include/geos/operation/linemerge/LineMerger.h
trunk/include/geos/operation/linemerge/LineSequencer.h
trunk/src/operation/linemerge/EdgeString.cpp
trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp
trunk/src/operation/linemerge/LineMergeEdge.cpp
trunk/src/operation/linemerge/LineMergeGraph.cpp
trunk/src/operation/linemerge/LineMerger.cpp
trunk/src/operation/linemerge/LineSequencer.cpp
Sync linemerge package to JTS-1.12 (nothing changed)
Modified: trunk/include/geos/operation/linemerge/EdgeString.h
--- trunk/include/geos/operation/linemerge/EdgeString.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/EdgeString.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -15,7 +15,7 @@
- * Last port: operation/linemerge/EdgeString.java r320 (JTS-1.12)
+ * Last port: operation/linemerge/EdgeString.java r378 (JTS-1.12)
Modified: trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h
--- trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/LineMergeDirectedEdge.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -13,7 +13,7 @@
- * Last port: operation/linemerge/LineMergeDirectedEdge.java rev. 1.5 (JTS-1.10)
+ * Last port: operation/linemerge/LineMergeDirectedEdge.java r378 (JTS-1.12)
Modified: trunk/include/geos/operation/linemerge/LineMergeEdge.h
--- trunk/include/geos/operation/linemerge/LineMergeEdge.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/LineMergeEdge.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -4,7 +4,8 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -13,7 +14,7 @@
- * Last port: operation/linemerge/LineMergeEdge.java r320 (JTS-1.12)
+ * Last port: operation/linemerge/LineMergeEdge.java r378 (JTS-1.12)
Modified: trunk/include/geos/operation/linemerge/LineMergeGraph.h
--- trunk/include/geos/operation/linemerge/LineMergeGraph.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/LineMergeGraph.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -6,6 +6,7 @@
* Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
@@ -14,7 +15,7 @@
- * Last port: operation/linemerge/LineMergeGraph.java r320 (JTS-1.12)
+ * Last port: operation/linemerge/LineMergeGraph.java r378 (JTS-1.12)
@@ -75,6 +76,8 @@
* LineString representation of an edge.
* Empty lines or lines with all coordinates equal are not added.
+ * @param lineString the linestring to add to the graph
void addEdge(const geom::LineString *lineString);
Modified: trunk/include/geos/operation/linemerge/LineMerger.h
--- trunk/include/geos/operation/linemerge/LineMerger.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/LineMerger.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -13,7 +13,7 @@
- * Last port: operation/linemerge/LineMerger.java r320 (JTS-1.11)
+ * Last port: operation/linemerge/LineMerger.java r378 (JTS-1.12)
Modified: trunk/include/geos/operation/linemerge/LineSequencer.h
--- trunk/include/geos/operation/linemerge/LineSequencer.h 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/include/geos/operation/linemerge/LineSequencer.h 2011-04-27 15:47:14 UTC (rev 3309)
@@ -14,7 +14,7 @@
- * Last port: operation/linemerge/LineSequencer.java r320 (JTS-1.12)
+ * Last port: operation/linemerge/LineSequencer.java r378 (JTS-1.12)
@@ -63,6 +63,12 @@
* components of the input. Each linestring is oriented
* so that identical endpoints are adjacent in the list.
+ * A typical use case is to convert a set of
+ * unoriented geometric links
+ * from a linear network
+ * (e.g. such as block faces on a bus route)
+ * into a continuous oriented path through the network.
* The input linestrings may form one or more connected sets.
* The input linestrings should be correctly noded, or the results may
* not be what is expected.
@@ -82,10 +88,11 @@
* node of an linestring, use that node as the end of the sequence
* - If the sequence has no degree-1 nodes, use any node as the start
- * Not all arrangements of lines can be sequenced.
+ * Note that not all arrangements of lines can be sequenced.
* For a connected set of edges in a graph,
- * Euler's Theorem states that there is a sequence containing each edge once
- * if and only if there are no more than 2 nodes of odd degree.
+ * <i>Euler's Theorem</i> states that there is a sequence
+ * containing each edge once
+ * <b>if and only if</b> there are no more than 2 nodes of odd degree.
* If it is not possible to find a sequence, the isSequenceable method
* will return <code>false</code>.
Modified: trunk/src/operation/linemerge/EdgeString.cpp
--- trunk/src/operation/linemerge/EdgeString.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/EdgeString.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -15,7 +15,7 @@
Modified: trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp
--- trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/LineMergeDirectedEdge.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -14,7 +14,7 @@
Modified: trunk/src/operation/linemerge/LineMergeEdge.cpp
--- trunk/src/operation/linemerge/LineMergeEdge.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/LineMergeEdge.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -14,7 +14,7 @@
Modified: trunk/src/operation/linemerge/LineMergeGraph.cpp
--- trunk/src/operation/linemerge/LineMergeGraph.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/LineMergeGraph.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -15,7 +15,7 @@
Modified: trunk/src/operation/linemerge/LineMerger.cpp
--- trunk/src/operation/linemerge/LineMerger.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/LineMerger.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -14,7 +14,7 @@
Modified: trunk/src/operation/linemerge/LineSequencer.cpp
--- trunk/src/operation/linemerge/LineSequencer.cpp 2011-04-27 15:33:11 UTC (rev 3308)
+++ trunk/src/operation/linemerge/LineSequencer.cpp 2011-04-27 15:47:14 UTC (rev 3309)
@@ -14,7 +14,7 @@
More information about the geos-commits
