[geos-commits] r3525 - trunk/tests/xmltester/tests/safe
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Dec 2 04:42:02 EST 2011
Author: strk
Date: 2011-12-02 01:42:02 -0800 (Fri, 02 Dec 2011)
New Revision: 3525
   trunk/tests/xmltester/tests/safe/buffer-1.01.xml
Add <resultMatcher> tag to make the test runnable with JTS
Modified: trunk/tests/xmltester/tests/safe/buffer-1.01.xml
--- trunk/tests/xmltester/tests/safe/buffer-1.01.xml	2011-11-30 09:49:58 UTC (rev 3524)
+++ trunk/tests/xmltester/tests/safe/buffer-1.01.xml	2011-12-02 09:42:02 UTC (rev 3525)
@@ -1,5 +1,6 @@
 <run>
 <precisionModel type="FLOATING"/>
+<resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
 <case>
   <desc>GEOS 3.3.1 produces rectangle buffer, GEOS 3.2.0 fine (#494)</desc>
More information about the geos-commits mailing list
