[geos-commits] r3537 - in branches/3.3: . src/operation/buffer
tests/unit/operation/buffer tests/xmltester
tests/xmltester/tests/safe
svn_geos at osgeo.org
Fri Dec 9 05:12:04 EST 2011
Author: strk
Date: 2011-12-09 02:12:04 -0800 (Fri, 09 Dec 2011)
New Revision: 3537
Added:
branches/3.3/tests/xmltester/tests/safe/TestBufferJagged.xml
Removed:
branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
branches/3.3/NEWS
branches/3.3/src/operation/buffer/BufferOp.cpp
branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp
branches/3.3/tests/xmltester/Makefile.am
Improve buffer robustness by reverting to non snaprounding noder
This commit fixes all cases reported in
http://trac.osgeo.org/geos/wiki/BufferRobustness
They include #495 and #494
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2011-12-09 10:04:35 UTC (rev 3536)
+++ branches/3.3/NEWS 2011-12-09 10:12:04 UTC (rev 3537)
@@ -10,6 +10,7 @@
- Fix noding with reduced precision in Buffer operation (#473)
- Fix HotPixel original point invalidation (#498)
- Fix CascadedPolygonUnion to discard non-polygonal components (#499)
+ - Improve buffer robustness by reverting to non-snaprounding noder (#495)
Changes in 3.3.1
2011-09-27
Modified: branches/3.3/src/operation/buffer/BufferOp.cpp
--- branches/3.3/src/operation/buffer/BufferOp.cpp 2011-12-09 10:04:35 UTC (rev 3536)
+++ branches/3.3/src/operation/buffer/BufferOp.cpp 2011-12-09 10:12:04 UTC (rev 3537)
@@ -38,7 +38,6 @@
#include <geos/algorithm/LineIntersector.h>
#include <geos/noding/MCIndexNoder.h>
#include <geos/noding/IntersectionAdder.h>
-#include <geos/noding/snapround/SimpleSnapRounder.h>
@@ -60,11 +59,10 @@
static Profiler *profiler = Profiler::instance();
#endif
-/*private*/
-double
-BufferOp::precisionScaleFactor(const Geometry *g,
- double distance,
- int maxPrecisionDigits)
+namespace {
+double OLDprecisionScaleFactor(const Geometry *g,
+ double distance, int maxPrecisionDigits)
const Envelope *env=g->getEnvelopeInternal();
double envSize=(std::max)(env->getHeight(), env->getWidth());
@@ -78,6 +76,32 @@
return scaleFactor;
+} // anonymous namespace
+/*private*/
+double
+BufferOp::precisionScaleFactor(const Geometry *g,
+ double distance,
+ int maxPrecisionDigits)
+ const Envelope *env=g->getEnvelopeInternal();
+ double envMax = std::max(
+ std::max(fabs(env->getMaxX()), fabs(env->getMinX())),
+ std::max(fabs(env->getMaxY()), fabs(env->getMinY()))
+ double expandByDistance = distance > 0.0 ? distance : 0.0;
+ double bufEnvMax = envMax + 2 * expandByDistance;
+ // the smallest power of 10 greater than the buffer envelope
+ int bufEnvPrecisionDigits = (int) (std::log(bufEnvMax) / std::log(10) + 1.0);
+ int minUnitLog10 = maxPrecisionDigits - bufEnvPrecisionDigits;
+ double scaleFactor = std::pow(10.0, minUnitLog10);
+ return scaleFactor;
/*public static*/
Geometry*
BufferOp::bufferOp(const Geometry *g, double distance,
@@ -107,7 +131,6 @@
std::cerr<<"BufferOp::computeGeometry: trying with original precision"<<std::endl;
#endif
- //bufferReducedPrecision(); return; // FIXME: remove this code
bufferOriginalPrecision();
if (resultGeometry!=NULL) return;
@@ -197,8 +220,15 @@
PrecisionModel pm(1.0); // fixed as well
- snapround::MCIndexSnapRounder inoder(pm);
+#if 0 /* FIXME: MCIndexSnapRounder seems to be still bogus */
+ snapround::MCIndexSnapRounder inoder(pm);
+#else
+ algorithm::LineIntersector li(&fixedPM);
+ IntersectionAdder ia(li);
+ MCIndexNoder inoder(&ia);
+#endif
ScaledNoder noder(inoder, fixedPM.getScale());
BufferBuilder bufBuilder(bufParams);
@@ -214,19 +244,3 @@
} // namespace geos.operation
} // namespace geos
- * $Log$
- * Revision 1.52 2006/05/04 15:49:39 strk
- * updated all Geometry::getDimension() methods to return Dimension::DimensionType (closes bug#93)
- * Revision 1.51 2006/05/03 10:26:56 strk
- * Fixed misuse of precision model in noder (bufferFixedPrecision)
- * Revision 1.50 2006/03/23 09:17:19 strk
- * precision.h header split, minor optimizations
- * Revision 1.49 2006/03/15 18:56:30 strk
- * Temporary hack to avoid snapround:: Noders (still using ScaledNoder wrapper)
- * to allow for buffer_snapround.xml test to succeed
Modified: branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp
--- branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp 2011-12-09 10:04:35 UTC (rev 3536)
+++ branches/3.3/tests/unit/operation/buffer/BufferOpTest.cpp 2011-12-09 10:12:04 UTC (rev 3537)
@@ -310,7 +310,7 @@
// We're basically only interested an rough sense of a
// meaningful result.
- ensure_equals(gBuffer->getNumPoints(), std::size_t(46));
+ ensure_equals(gBuffer->getNumPoints(), std::size_t(47));
ensure_equals(int(gBuffer->getArea()), 3520);
Modified: branches/3.3/tests/xmltester/Makefile.am
--- branches/3.3/tests/xmltester/Makefile.am 2011-12-09 10:04:35 UTC (rev 3536)
+++ branches/3.3/tests/xmltester/Makefile.am 2011-12-09 10:12:04 UTC (rev 3537)
@@ -81,7 +81,7 @@
$(srcdir)/tests/hole_red.xml \
$(srcdir)/tests/safe/16595.xml \
$(srcdir)/tests/safe/16596.xml \
- $(srcdir)/tests/safe/buffer-1.01.xml
+ $(srcdir)/tests/safe/TestBufferJagged.xml
INVALID_OUTPUT_XMLTESTS =
Added: branches/3.3/tests/xmltester/tests/safe/TestBufferJagged.xml
--- branches/3.3/tests/xmltester/tests/safe/TestBufferJagged.xml (rev 0)
+++ branches/3.3/tests/xmltester/tests/safe/TestBufferJagged.xml 2011-12-09 10:12:04 UTC (rev 3537)
@@ -0,0 +1,75 @@
+<run>
+<precisionModel type="FLOATING"/>
+<resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
+<case>
+ <desc>
+Test case from Safe Software.
+See http://trac.osgeo.org/geos/wiki/BufferRobustness
+ </desc>
+ <a>
+ POLYGON ((99736.4572496327 -2239219.11305743, 99736.6573549178 -2239219.11305743, 99736.6573549178 -2239219.01300479, 99736.5573022753 -2239219.01300479, 99736.5573022753 -2239218.8128995, 99736.6573549178 -2239218.8128995, 99736.6573549178 -2239218.91295215, 99736.7574075604 -2239218.91295215, 99736.7574075604 -2239219.01300479, 99736.8574602029 -2239219.01300479, 99736.8574602029 -2239219.11305743, 99736.9575128455 -2239219.11305743, 99736.9575128455 -2239219.21311007, 99737.057565488 -2239219.21311007, 99737.057565488 -2239219.01300479, 99737.2576707731 -2239219.01300479, 99737.2576707731 -2239219.11305743, 99737.4577760582 -2239219.11305743, 99737.4577760582 -2239219.01300479, 99737.958039271 -2239219.01300479, 99737.958039271 -2239218.91295215, 99738.0580919136 -2239218.91295215, 99738.0580919136 -2239218.51274158, 99738.1581445561 -2239218.51274158, 99738.1581445561 -2239218.61279422, 99738.3582498412 -2239218.61279422, 99738.3582498412 -2239218.41268893, 99738.458
3024838 -2239218.41268893, 99738.4583024838 -2239218.61279422, 99738.5583551263 -2239218.61279422, 99738.5583551263 -2239218.41268893, 99738.6584077689 -2239218.41268893, 99738.6584077689 -2239218.31263629, 99738.4583024838 -2239218.31263629, 99738.4583024838 -2239218.11253101, 99738.5583551263 -2239218.11253101, 99738.5583551263 -2239218.21258365, 99738.6584077689 -2239218.21258365, 99738.6584077689 -2239218.11253101, 99738.7584604114 -2239218.11253101, 99738.7584604114 -2239218.41268893, 99738.858513054 -2239218.41268893, 99738.858513054 -2239218.31263629, 99738.9585656965 -2239218.31263629, 99738.9585656965 -2239218.21258365, 99738.858513054 -2239218.21258365, 99738.858513054 -2239217.91242572, 99738.9585656965 -2239217.91242572, 99738.9585656965 -2239218.01247836, 99739.1586709816 -2239218.01247836, 99739.1586709816 -2239217.91242572, 99739.2587236242 -2239217.91242572, 99739.2587236242 -2239218.01247836, 99739.3587762667 -2239218.01247836, 99739.3587762667 -2239218.1125
3101, 99739.4588289093 -2239218.11253101, 99739.4588289093 -2239217.91242572, 99739.5588815519 -2239217.91242572, 99739.5588815519 -2239218.01247836, 99739.6589341944 -2239218.01247836, 99739.6589341944 -2239217.81237308, 99739.8590394795 -2239217.81237308, 99739.8590394795 -2239217.71232044, 99740.0591447646 -2239217.71232044, 99740.0591447646 -2239217.61226779, 99740.1591974072 -2239217.61226779, 99740.1591974072 -2239217.71232044, 99740.2592500497 -2239217.71232044, 99740.2592500497 -2239217.51221515, 99740.0591447646 -2239217.51221515, 99740.0591447646 -2239217.41216251, 99740.2592500497 -2239217.41216251, 99740.2592500497 -2239217.21205722, 99740.3593026923 -2239217.21205722, 99740.3593026923 -2239217.01195194, 99740.2592500497 -2239217.01195194, 99740.2592500497 -2239217.11200458, 99740.1591974072 -2239217.11200458, 99740.1591974072 -2239217.01195194, 99740.0591447646 -2239217.01195194, 99740.0591447646 -2239217.31210987, 99739.8590394795 -2239217.31210987, 99739.85903
94795 -2239217.41216251, 99739.6589341944 -2239217.41216251, 99739.6589341944 -2239217.51221515, 99739.4588289093 -2239217.51221515, 99739.4588289093 -2239217.61226779, 99738.9585656965 -2239217.61226779, 99738.9585656965 -2239217.51221515, 99738.7584604114 -2239217.51221515, 99738.7584604114 -2239217.41216251, 99738.5583551263 -2239217.41216251, 99738.5583551263 -2239217.31210987, 99738.4583024838 -2239217.31210987, 99738.4583024838 -2239217.21205722, 99738.6584077689 -2239217.21205722, 99738.6584077689 -2239217.11200458, 99738.9585656965 -2239217.11200458, 99738.9585656965 -2239217.01195194, 99738.7584604114 -2239217.01195194, 99738.7584604114 -2239216.9118993, 99738.3582498412 -2239216.9118993, 99738.3582498412 -2239217.01195194, 99738.2581971987 -2239217.01195194, 99738.2581971987 -2239216.9118993, 99738.1581445561 -2239216.9118993, 99738.1581445561 -2239217.01195194, 99738.0580919136 -2239217.01195194, 99738.0580919136 -2239216.9118993, 99737.8579866284 -2239216.9118993
, 99737.8579866284 -2239216.61174137, 99737.6578813433 -2239216.61174137, 99737.6578813433 -2239216.41163608, 99737.4577760582 -2239216.41163608, 99737.4577760582 -2239216.2115308, 99737.2576707731 -2239216.2115308, 99737.2576707731 -2239215.81132023, 99737.057565488 -2239215.81132023, 99737.057565488 -2239215.41110966, 99736.9575128455 -2239215.41110966, 99736.9575128455 -2239215.31105701, 99736.8574602029 -2239215.31105701, 99736.8574602029 -2239215.01089909, 99736.9575128455 -2239215.01089909, 99736.9575128455 -2239214.91084644, 99737.057565488 -2239214.91084644, 99737.057565488 -2239214.8107938, 99737.1576181306 -2239214.8107938, 99737.1576181306 -2239214.71074116, 99737.3577234157 -2239214.71074116, 99737.3577234157 -2239214.61068852, 99737.6578813433 -2239214.61068852, 99737.6578813433 -2239214.41058323, 99737.8579866284 -2239214.41058323, 99737.8579866284 -2239214.31053059, 99737.958039271 -2239214.31053059, 99737.958039271 -2239214.1104253, 99737.5578287008 -2239214.
1104253, 99737.5578287008 -2239214.21047795, 99737.4577760582 -2239214.21047795, 99737.4577760582 -2239214.01037266, 99737.6578813433 -2239214.01037266, 99737.6578813433 -2239213.91032002, 99737.7579339859 -2239213.91032002, 99737.7579339859 -2239213.71021473, 99737.8579866284 -2239213.71021473, 99737.8579866284 -2239213.61016209, 99737.7579339859 -2239213.61016209, 99737.7579339859 -2239213.51010945, 99737.8579866284 -2239213.51010945, 99737.8579866284 -2239213.41005681, 99737.958039271 -2239213.41005681, 99737.958039271 -2239213.31000416, 99737.8579866284 -2239213.31000416, 99737.8579866284 -2239213.20995152, 99737.7579339859 -2239213.20995152, 99737.7579339859 -2239213.31000416, 99737.5578287008 -2239213.31000416, 99737.5578287008 -2239213.10989888, 99737.3577234157 -2239213.10989888, 99737.3577234157 -2239212.90979359, 99737.4577760582 -2239212.90979359, 99737.4577760582 -2239212.80974095, 99737.3577234157 -2239212.80974095, 99737.3577234157 -2239212.70968831, 99737.2576
707731 -2239212.70968831, 99737.2576707731 -2239212.30947774, 99737.057565488 -2239212.30947774, 99737.057565488 -2239212.2094251, 99736.9575128455 -2239212.2094251, 99736.9575128455 -2239212.10937245, 99737.057565488 -2239212.10937245, 99737.057565488 -2239212.00931981, 99737.1576181306 -2239212.00931981, 99737.1576181306 -2239212.10937245, 99737.2576707731 -2239212.10937245, 99737.2576707731 -2239212.2094251, 99737.3577234157 -2239212.2094251, 99737.3577234157 -2239212.40953038, 99737.4577760582 -2239212.40953038, 99737.4577760582 -2239212.30947774, 99737.5578287008 -2239212.30947774, 99737.5578287008 -2239212.2094251, 99737.6578813433 -2239212.2094251, 99737.6578813433 -2239212.10937245, 99737.5578287008 -2239212.10937245, 99737.5578287008 -2239212.00931981, 99737.4577760582 -2239212.00931981, 99737.4577760582 -2239211.90926717, 99737.2576707731 -2239211.90926717, 99737.2576707731 -2239211.80921452, 99737.1576181306 -2239211.80921452, 99737.1576181306 -2239211.70916188, 9
9737.057565488 -2239211.70916188, 99737.057565488 -2239211.60910924, 99736.9575128455 -2239211.60910924, 99736.9575128455 -2239211.5090566, 99736.7574075604 -2239211.5090566, 99736.7574075604 -2239211.40900395, 99736.5573022753 -2239211.40900395, 99736.5573022753 -2239211.00879338, 99736.4572496327 -2239211.00879338, 99736.4572496327 -2239210.90874074, 99736.157091705 -2239210.90874074, 99736.157091705 -2239210.8086881, 99736.2571443476 -2239210.8086881, 99736.2571443476 -2239210.60858281, 99736.3571969901 -2239210.60858281, 99736.3571969901 -2239210.40847753, 99736.2571443476 -2239210.40847753, 99736.2571443476 -2239210.50853017, 99736.0570390625 -2239210.50853017, 99736.0570390625 -2239210.40847753, 99736.157091705 -2239210.40847753, 99736.157091705 -2239210.30842489, 99735.9569864199 -2239210.30842489, 99735.9569864199 -2239210.20837224, 99736.0570390625 -2239210.20837224, 99736.0570390625 -2239209.90821432, 99735.8569337774 -2239209.90821432, 99735.8569337774 -2239209.80
816167, 99735.9569864199 -2239209.80816167, 99735.9569864199 -2239209.60805639, 99735.8569337774 -2239209.60805639, 99735.8569337774 -2239209.50800375, 99735.7568811348 -2239209.50800375, 99735.7568811348 -2239209.4079511, 99735.8569337774 -2239209.4079511, 99735.8569337774 -2239209.30789846, 99735.7568811348 -2239209.30789846, 99735.7568811348 -2239209.20784582, 99735.6568284923 -2239209.20784582, 99735.6568284923 -2239209.00774053, 99735.7568811348 -2239209.00774053, 99735.7568811348 -2239208.80763525, 99735.6568284923 -2239208.80763525, 99735.6568284923 -2239208.60752996, 99735.5567758497 -2239208.60752996, 99735.5567758497 -2239208.50747732, 99735.6568284923 -2239208.50747732, 99735.6568284923 -2239208.40742468, 99735.5567758497 -2239208.40742468, 99735.5567758497 -2239208.30737204, 99735.4567232072 -2239208.30737204, 99735.4567232072 -2239208.20731939, 99735.5567758497 -2239208.20731939, 99735.5567758497 -2239208.00721411, 99735.4567232072 -2239208.00721411, 99735.45672
32072 -2239207.90716147, 99735.3566705646 -2239207.90716147, 99735.3566705646 -2239207.70705618, 99735.4567232072 -2239207.70705618, 99735.4567232072 -2239207.50695089, 99735.3566705646 -2239207.50695089, 99735.3566705646 -2239207.40689825, 99735.4567232072 -2239207.40689825, 99735.4567232072 -2239207.30684561, 99735.2566179221 -2239207.30684561, 99735.2566179221 -2239207.20679297, 99735.3566705646 -2239207.20679297, 99735.3566705646 -2239207.10674032, 99735.1565652795 -2239207.10674032, 99735.1565652795 -2239207.30684561, 99735.0565126369 -2239207.30684561, 99735.0565126369 -2239207.00668768, 99734.9564599944 -2239207.00668768, 99734.9564599944 -2239207.40689825, 99734.8564073518 -2239207.40689825, 99734.8564073518 -2239207.00668768, 99734.7563547093 -2239207.00668768, 99734.7563547093 -2239206.90663504, 99734.6563020667 -2239206.90663504, 99734.6563020667 -2239206.8065824, 99734.5562494242 -2239206.8065824, 99734.5562494242 -2239206.70652975, 99734.2560914965 -2239206.7065
2975, 99734.2560914965 -2239206.60647711, 99734.3561441391 -2239206.60647711, 99734.3561441391 -2239206.30631918, 99734.156038854 -2239206.30631918, 99734.156038854 -2239206.20626654, 99734.0559862114 -2239206.20626654, 99734.0559862114 -2239206.1062139, 99734.2560914965 -2239206.1062139, 99734.2560914965 -2239205.90610861, 99734.3561441391 -2239205.90610861, 99734.3561441391 -2239205.80605597, 99734.4561967816 -2239205.80605597, 99734.4561967816 -2239205.70600333, 99734.6563020667 -2239205.70600333, 99734.6563020667 -2239205.80605597, 99734.8564073518 -2239205.80605597, 99734.8564073518 -2239205.30579276, 99734.3561441391 -2239205.30579276, 99734.3561441391 -2239205.10568747, 99734.0559862114 -2239205.10568747, 99734.0559862114 -2239205.00563483, 99733.8558809263 -2239205.00563483, 99733.8558809263 -2239204.90558219, 99733.6557756412 -2239204.90558219, 99733.6557756412 -2239204.80552955, 99733.4556703561 -2239204.80552955, 99733.4556703561 -2239204.7054769, 99733.3556177135
-2239204.7054769, 99733.3556177135 -2239204.60542426, 99733.1555124284 -2239204.60542426, 99733.1555124284 -2239204.50537162, 99732.8553545008 -2239204.50537162, 99732.8553545008 -2239204.60542426, 99732.7553018582 -2239204.60542426, 99732.7553018582 -2239204.90558219, 99732.5551965731 -2239204.90558219, 99732.5551965731 -2239205.00563483, 99732.4551439306 -2239205.00563483, 99732.4551439306 -2239205.10568747, 99732.355091288 -2239205.10568747, 99732.355091288 -2239205.20574012, 99732.1549860029 -2239205.20574012, 99732.1549860029 -2239205.30579276, 99731.9548807178 -2239205.30579276, 99731.9548807178 -2239205.4058454, 99731.454617505 -2239205.4058454, 99731.454617505 -2239205.50589804, 99731.0544069348 -2239205.50589804, 99731.0544069348 -2239205.60595069, 99730.8543016497 -2239205.60595069, 99730.8543016497 -2239205.70600333, 99730.7542490072 -2239205.70600333, 99730.7542490072 -2239205.80605597, 99730.554143722 -2239205.80605597, 99730.554143722 -2239205.90610861, 99730.
4540910795 -2239205.90610861, 99730.4540910795 -2239206.00616126, 99730.3540384369 -2239206.00616126, 99730.3540384369 -2239206.50642447, 99730.2539857944 -2239206.50642447, 99730.2539857944 -2239206.70652975, 99730.1539331518 -2239206.70652975, 99730.1539331518 -2239206.8065824, 99729.9538278667 -2239206.8065824, 99729.9538278667 -2239206.90663504, 99729.5536172965 -2239206.90663504, 99729.5536172965 -2239207.00668768, 99729.3535120114 -2239207.00668768, 99729.3535120114 -2239207.10674032, 99729.2534593688 -2239207.10674032, 99729.2534593688 -2239207.20679297, 99729.0533540837 -2239207.20679297, 99729.0533540837 -2239207.30684561, 99728.9533014412 -2239207.30684561, 99728.9533014412 -2239207.40689825, 99728.8532487986 -2239207.40689825, 99728.8532487986 -2239207.50695089, 99728.7531961561 -2239207.50695089, 99728.7531961561 -2239207.60700354, 99728.6531435135 -2239207.60700354, 99728.6531435135 -2239208.10726675, 99728.553090871 -2239208.10726675, 99728.553090871 -2239208.3
0737204, 99728.4530382284 -2239208.30737204, 99728.4530382284 -2239208.50747732, 99728.6531435135 -2239208.50747732, 99728.6531435135 -2239208.60752996, 99728.2529329433 -2239208.60752996, 99728.2529329433 -2239208.70758261, 99727.8527223731 -2239208.70758261, 99727.8527223731 -2239208.60752996, 99727.5525644454 -2239208.60752996, 99727.5525644454 -2239208.70758261, 99727.4525118029 -2239208.70758261, 99727.4525118029 -2239208.60752996, 99726.4519853773 -2239208.60752996, 99726.4519853773 -2239208.70758261, 99726.2518800922 -2239208.70758261, 99726.2518800922 -2239208.80763525, 99726.1518274497 -2239208.80763525, 99726.1518274497 -2239208.90768789, 99726.0517748071 -2239208.90768789, 99726.0517748071 -2239209.00774053, 99725.9517221646 -2239209.00774053, 99725.9517221646 -2239209.10779318, 99725.851669522 -2239209.10779318, 99725.851669522 -2239209.20784582, 99725.7516168795 -2239209.20784582, 99725.7516168795 -2239209.4079511, 99725.6515642369 -2239209.4079511, 99725.651564
2369 -2239209.50800375, 99725.7516168795 -2239209.50800375, 99725.7516168795 -2239209.60805639, 99725.6515642369 -2239209.60805639, 99725.6515642369 -2239209.90821432, 99725.5515115944 -2239209.90821432, 99725.5515115944 -2239210.50853017, 99725.4514589518 -2239210.50853017, 99725.4514589518 -2239211.20889867, 99725.5515115944 -2239211.20889867, 99725.5515115944 -2239211.40900395, 99725.6515642369 -2239211.40900395, 99725.6515642369 -2239211.5090566, 99725.7516168795 -2239211.5090566, 99725.7516168795 -2239211.40900395, 99725.851669522 -2239211.40900395, 99725.851669522 -2239211.10884603, 99725.9517221646 -2239211.10884603, 99725.9517221646 -2239210.90874074, 99726.0517748071 -2239210.90874074, 99726.0517748071 -2239210.20837224, 99726.1518274497 -2239210.20837224, 99726.1518274497 -2239210.1083196, 99726.2518800922 -2239210.1083196, 99726.2518800922 -2239210.00826696, 99726.4519853773 -2239210.00826696, 99726.4519853773 -2239209.90821432, 99726.6520906625 -2239209.90821432,
99726.6520906625 -2239210.00826696, 99726.9522485901 -2239210.00826696, 99726.9522485901 -2239210.1083196, 99727.1523538752 -2239210.1083196, 99727.1523538752 -2239210.20837224, 99727.7526697305 -2239210.20837224, 99727.7526697305 -2239210.1083196, 99728.6531435135 -2239210.1083196, 99728.6531435135 -2239210.00826696, 99728.7531961561 -2239210.00826696, 99728.7531961561 -2239210.1083196, 99729.0533540837 -2239210.1083196, 99729.0533540837 -2239210.20837224, 99729.1534067263 -2239210.20837224, 99729.1534067263 -2239210.00826696, 99728.9533014412 -2239210.00826696, 99728.9533014412 -2239209.90821432, 99729.1534067263 -2239209.90821432, 99729.1534067263 -2239209.80816167, 99728.9533014412 -2239209.80816167, 99728.9533014412 -2239209.70810903, 99728.8532487986 -2239209.70810903, 99728.8532487986 -2239209.60805639, 99728.9533014412 -2239209.60805639, 99728.9533014412 -2239209.4079511, 99728.8532487986 -2239209.4079511, 99728.8532487986 -2239209.30789846, 99728.9533014412 -223920
9.30789846, 99728.9533014412 -2239209.00774053, 99729.0533540837 -2239209.00774053, 99729.0533540837 -2239208.90768789, 99729.5536172965 -2239208.90768789, 99729.5536172965 -2239208.80763525, 99729.7537225816 -2239208.80763525, 99729.7537225816 -2239208.90768789, 99729.8537752242 -2239208.90768789, 99729.8537752242 -2239209.00774053, 99729.9538278667 -2239209.00774053, 99729.9538278667 -2239209.10779318, 99730.1539331518 -2239209.10779318, 99730.1539331518 -2239209.30789846, 99730.0538805093 -2239209.30789846, 99730.0538805093 -2239209.4079511, 99730.1539331518 -2239209.4079511, 99730.1539331518 -2239209.50800375, 99730.0538805093 -2239209.50800375, 99730.0538805093 -2239209.80816167, 99729.9538278667 -2239209.80816167, 99729.9538278667 -2239210.00826696, 99729.8537752242 -2239210.00826696, 99729.8537752242 -2239210.1083196, 99729.7537225816 -2239210.1083196, 99729.7537225816 -2239210.20837224, 99729.5536172965 -2239210.20837224, 99729.5536172965 -2239210.1083196, 99729.3535
120114 -2239210.1083196, 99729.3535120114 -2239210.30842489, 99729.2534593688 -2239210.30842489, 99729.2534593688 -2239210.40847753, 99729.3535120114 -2239210.40847753, 99729.3535120114 -2239210.8086881, 99729.4535646539 -2239210.8086881, 99729.4535646539 -2239210.90874074, 99729.3535120114 -2239210.90874074, 99729.3535120114 -2239211.00879338, 99729.1534067263 -2239211.00879338, 99729.1534067263 -2239211.10884603, 99728.7531961561 -2239211.10884603, 99728.7531961561 -2239211.20889867, 99727.9527750156 -2239211.20889867, 99727.9527750156 -2239211.30895131, 99727.652617088 -2239211.30895131, 99727.652617088 -2239211.40900395, 99727.4525118029 -2239211.40900395, 99727.4525118029 -2239211.5090566, 99727.3524591603 -2239211.5090566, 99727.3524591603 -2239211.70916188, 99727.4525118029 -2239211.70916188, 99727.4525118029 -2239211.80921452, 99727.652617088 -2239211.80921452, 99727.652617088 -2239211.90926717, 99727.8527223731 -2239211.90926717, 99727.8527223731 -2239212.00931981,
99728.4530382284 -2239212.00931981, 99728.4530382284 -2239212.10937245, 99728.553090871 -2239212.10937245, 99728.553090871 -2239212.00931981, 99728.7531961561 -2239212.00931981, 99728.7531961561 -2239212.10937245, 99729.1534067263 -2239212.10937245, 99729.1534067263 -2239212.2094251, 99729.3535120114 -2239212.2094251, 99729.3535120114 -2239212.30947774, 99729.4535646539 -2239212.30947774, 99729.4535646539 -2239212.50958302, 99729.5536172965 -2239212.50958302, 99729.5536172965 -2239212.60963567, 99729.6536699391 -2239212.60963567, 99729.6536699391 -2239212.70968831, 99729.9538278667 -2239212.70968831, 99729.9538278667 -2239212.80974095, 99730.3540384369 -2239212.80974095, 99730.3540384369 -2239212.90979359, 99730.554143722 -2239212.90979359, 99730.554143722 -2239213.00984624, 99730.7542490072 -2239213.00984624, 99730.7542490072 -2239212.90979359, 99730.8543016497 -2239212.90979359, 99730.8543016497 -2239213.00984624, 99730.9543542922 -2239213.00984624, 99730.9543542922 -22392
13.20995152, 99731.0544069348 -2239213.20995152, 99731.0544069348 -2239213.10989888, 99731.1544595774 -2239213.10989888, 99731.1544595774 -2239213.31000416, 99731.3545648625 -2239213.31000416, 99731.3545648625 -2239213.41005681, 99731.454617505 -2239213.41005681, 99731.454617505 -2239213.51010945, 99731.5546701476 -2239213.51010945, 99731.5546701476 -2239213.61016209, 99731.6547227901 -2239213.61016209, 99731.6547227901 -2239213.81026738, 99731.7547754327 -2239213.81026738, 99731.7547754327 -2239213.91032002, 99731.8548280752 -2239213.91032002, 99731.8548280752 -2239214.1104253, 99731.9548807178 -2239214.1104253, 99731.9548807178 -2239214.31053059, 99732.0549333603 -2239214.31053059, 99732.0549333603 -2239214.41058323, 99731.9548807178 -2239214.41058323, 99731.9548807178 -2239214.51063587, 99732.0549333603 -2239214.51063587, 99732.0549333603 -2239214.71074116, 99732.1549860029 -2239214.71074116, 99732.1549860029 -2239214.91084644, 99732.2550386455 -2239214.91084644, 99732.25
50386455 -2239215.11095173, 99732.355091288 -2239215.11095173, 99732.355091288 -2239215.31105701, 99732.4551439306 -2239215.31105701, 99732.4551439306 -2239215.41110966, 99732.355091288 -2239215.41110966, 99732.355091288 -2239215.5111623, 99732.4551439306 -2239215.5111623, 99732.4551439306 -2239215.71126758, 99732.355091288 -2239215.71126758, 99732.355091288 -2239215.91137287, 99732.4551439306 -2239215.91137287, 99732.4551439306 -2239216.01142551, 99732.355091288 -2239216.01142551, 99732.355091288 -2239216.11147815, 99732.2550386455 -2239216.11147815, 99732.2550386455 -2239216.2115308, 99732.355091288 -2239216.2115308, 99732.355091288 -2239216.31158344, 99732.2550386455 -2239216.31158344, 99732.2550386455 -2239216.61174137, 99732.1549860029 -2239216.61174137, 99732.1549860029 -2239217.01195194, 99732.0549333603 -2239217.01195194, 99732.0549333603 -2239217.21205722, 99732.1549860029 -2239217.21205722, 99732.1549860029 -2239217.31210987, 99732.4551439306 -2239217.31210987, 997
32.4551439306 -2239217.41216251, 99732.5551965731 -2239217.41216251, 99732.5551965731 -2239217.31210987, 99732.7553018582 -2239217.31210987, 99732.7553018582 -2239217.41216251, 99732.8553545008 -2239217.41216251, 99732.8553545008 -2239217.51221515, 99732.9554071433 -2239217.51221515, 99732.9554071433 -2239217.31210987, 99733.1555124284 -2239217.31210987, 99733.1555124284 -2239217.41216251, 99733.255565071 -2239217.41216251, 99733.255565071 -2239217.31210987, 99733.4556703561 -2239217.31210987, 99733.4556703561 -2239217.41216251, 99733.5557229986 -2239217.41216251, 99733.5557229986 -2239217.31210987, 99733.6557756412 -2239217.31210987, 99733.6557756412 -2239217.21205722, 99733.8558809263 -2239217.21205722, 99733.8558809263 -2239217.11200458, 99733.9559335689 -2239217.11200458, 99733.9559335689 -2239217.01195194, 99734.0559862114 -2239217.01195194, 99734.0559862114 -2239217.21205722, 99734.156038854 -2239217.21205722, 99734.156038854 -2239217.11200458, 99734.2560914965 -223921
7.11200458, 99734.2560914965 -2239217.21205722, 99734.3561441391 -2239217.21205722, 99734.3561441391 -2239217.11200458, 99734.4561967816 -2239217.11200458, 99734.4561967816 -2239217.01195194, 99734.3561441391 -2239217.01195194, 99734.3561441391 -2239216.9118993, 99734.4561967816 -2239216.9118993, 99734.4561967816 -2239216.81184665, 99734.6563020667 -2239216.81184665, 99734.6563020667 -2239216.9118993, 99734.5562494242 -2239216.9118993, 99734.5562494242 -2239217.01195194, 99734.6563020667 -2239217.01195194, 99734.6563020667 -2239217.11200458, 99734.7563547093 -2239217.11200458, 99734.7563547093 -2239217.01195194, 99734.8564073518 -2239217.01195194, 99734.8564073518 -2239217.11200458, 99735.3566705646 -2239217.11200458, 99735.3566705646 -2239217.21205722, 99735.7568811348 -2239217.21205722, 99735.7568811348 -2239217.31210987, 99735.6568284923 -2239217.31210987, 99735.6568284923 -2239217.41216251, 99735.5567758497 -2239217.41216251, 99735.5567758497 -2239217.61226779, 99735.756
8811348 -2239217.61226779, 99735.7568811348 -2239217.71232044, 99735.9569864199 -2239217.71232044, 99735.9569864199 -2239218.01247836, 99735.8569337774 -2239218.01247836, 99735.8569337774 -2239218.11253101, 99735.9569864199 -2239218.11253101, 99735.9569864199 -2239218.21258365, 99736.0570390625 -2239218.21258365, 99736.0570390625 -2239218.41268893, 99735.9569864199 -2239218.41268893, 99735.9569864199 -2239218.61279422, 99736.0570390625 -2239218.61279422, 99736.0570390625 -2239218.71284686, 99735.9569864199 -2239218.71284686, 99735.9569864199 -2239218.8128995, 99736.0570390625 -2239218.8128995, 99736.0570390625 -2239218.91295215, 99736.3571969901 -2239218.91295215, 99736.3571969901 -2239219.01300479, 99736.4572496327 -2239219.01300479, 99736.4572496327 -2239219.11305743))
+ </a>
+ <test>
+ <desc>buffer-0.35: see http://trac.osgeo.org/geos/wiki/BufferRobustness</desc>
+ <op name="buffer" arg1="a" arg2="0.35">
+ POLYGON ((99725.2015115944 -2239210.264040296, 99725.2015115944 -2239209.90821432, 99725.20823674626 -2239209.839932707, 99725.22815375803 -2239209.7742751185, 99725.26049723009 -2239209.7137647383, 99725.3015642369 -2239209.663724446, 99725.3015642369 -2239209.60805639, 99725.30649139937 -2239209.5580300703, 99725.3015642369 -2239209.50800375, 99725.3015642369 -2239209.4079511, 99725.30828938876 -2239209.339669487, 99725.32820640053 -2239209.2740118983, 99725.3605498726 -2239209.213501518, 99725.40407686349 -2239209.1604637266, 99725.40647766467 -2239209.15849344, 99725.40834203135 -2239209.1395642073, 99725.42825904312 -2239209.0739066186, 99725.46060251519 -2239209.0133962384, 99725.50412950608 -2239208.960358447, 99725.55716729794 -2239208.9168314557, 99725.55944024482 -2239208.9156165402, 99725.5606551577 -2239208.913343598, 99725.60418214859 -2239208.8603058066, 99725.65721994045 -2239208.8167788154, 99725.65949288048 -2239208.8155639037, 99725.66070780029 -22392
08.8132909485, 99725.70423479118 -2239208.760253157, 99725.75727258304 -2239208.7167261657, 99725.75954552992 -2239208.7155112503, 99725.76076044279 -2239208.713238308, 99725.80428743368 -2239208.6602005167, 99725.85732522554 -2239208.6166735254, 99725.85959817292 -2239208.6154586095, 99725.8608130854 -2239208.6131856684, 99725.90434007629 -2239208.560147877, 99725.95737786815 -2239208.5166208856, 99725.95965081536 -2239208.51540597, 99725.96086572789 -2239208.5131330285, 99726.00439271878 -2239208.460095237, 99726.05743051064 -2239208.4165682457, 99726.11794089086 -2239208.384224774, 99726.18359847949 -2239208.364307762, 99726.2025277112 -2239208.3624433954, 99726.20449800388 -2239208.360042587, 99726.25753579574 -2239208.3165155957, 99726.31804617596 -2239208.2841721238, 99726.38370376459 -2239208.264255112, 99726.4519853773 -2239208.25752996, 99727.4525118029 -2239208.25752996, 99727.50253812416 -2239208.2624571226, 99727.5525644454 -2239208.25752996, 99727.8527223731 -22
39208.25752996, 99727.92100398582 -2239208.264255112, 99727.98666157444 -2239208.2841721238, 99728.04717195466 -2239208.3165155957, 99728.0528276582 -2239208.321157112, 99728.05848336175 -2239208.3165155957, 99728.10456354666 -2239208.2918852237, 99728.10976338026 -2239208.2390904273, 99728.12968039203 -2239208.1734328386, 99728.16202386409 -2239208.1129224584, 99728.20555085498 -2239208.059884667, 99728.20795165507 -2239208.0579143814, 99728.20981602286 -2239208.0389851374, 99728.22973303463 -2239207.9733275487, 99728.2620765067 -2239207.9128171685, 99728.30314351349 -2239207.8627768764, 99728.30314351349 -2239207.60700354, 99728.30986866535 -2239207.538721927, 99728.32978567712 -2239207.4730643383, 99728.36212914919 -2239207.412553958, 99728.40565614008 -2239207.3595161666, 99728.45869393194 -2239207.3159891753, 99728.460966872 -2239207.3147742637, 99728.4621817918 -2239207.3125013085, 99728.50570878269 -2239207.259463517, 99728.55874657455 -2239207.2159365257, 99728.56101
952141 -2239207.2147216103, 99728.56223443428 -2239207.212448668, 99728.60576142518 -2239207.1594108767, 99728.65879921704 -2239207.1158838854, 99728.66107216441 -2239207.1146689695, 99728.66228707689 -2239207.1123960284, 99728.70581406778 -2239207.059358237, 99728.75885185965 -2239207.0158312456, 99728.76112480687 -2239207.01461633, 99728.7623397194 -2239207.0123433885, 99728.80586671029 -2239206.959305597, 99728.85890450215 -2239206.9157786057, 99728.91941488237 -2239206.883435134, 99728.985072471 -2239206.863518122, 99729.0040017027 -2239206.8616537554, 99729.00597199539 -2239206.859252947, 99729.05900978725 -2239206.8157259556, 99729.06128273426 -2239206.81451104, 99729.06249764709 -2239206.812238098, 99729.10602463798 -2239206.7592003066, 99729.15906242984 -2239206.7156733153, 99729.21957281006 -2239206.6833298435, 99729.28523039869 -2239206.6634128317, 99729.30415963955 -2239206.661548464, 99729.30612992308 -2239206.659147667, 99729.35916771494 -2239206.6156206755, 997
29.41967809516 -2239206.5832772036, 99729.48533568378 -2239206.563360192, 99729.5536172965 -2239206.55663504, 99729.70933799617 -2239206.55663504, 99729.75937828515 -2239206.5155680357, 99729.81988866537 -2239206.4832245638, 99729.885546254 -2239206.463307552, 99729.9044754857 -2239206.4614431853, 99729.90644577838 -2239206.459042377, 99729.90884657952 -2239206.4570720904, 99729.91071094626 -2239206.438142857, 99729.93062795803 -2239206.3724852684, 99729.9629714301 -2239206.311974888, 99730.00403843689 -2239206.261934596, 99730.00403843689 -2239206.00616126, 99730.01076358875 -2239205.937879647, 99730.03068060052 -2239205.8722220585, 99730.06302407259 -2239205.8117116783, 99730.10655106348 -2239205.758673887, 99730.15958885534 -2239205.7151468955, 99730.16186179504 -2239205.713931984, 99730.1630767152 -2239205.711659028, 99730.20660370609 -2239205.6586212367, 99730.25964149795 -2239205.6150942454, 99730.26191444516 -2239205.61387933, 99730.26312935769 -2239205.6116063884, 99
730.30665634858 -2239205.558568597, 99730.35969414044 -2239205.5150416056, 99730.42020452066 -2239205.4826981337, 99730.48586210929 -2239205.462781122, 99730.50479135025 -2239205.4609167543, 99730.50676163378 -2239205.458515957, 99730.55979942564 -2239205.4149889657, 99730.56207237252 -2239205.4137740503, 99730.56328728539 -2239205.411501108, 99730.60681427628 -2239205.3584633167, 99730.65985206814 -2239205.3149363254, 99730.72036244837 -2239205.2825928535, 99730.78602003699 -2239205.262675842, 99730.8049492687 -2239205.260811475, 99730.80691956138 -2239205.2584106666, 99730.85995735324 -2239205.2148836753, 99730.92046773346 -2239205.1825402034, 99730.98612532209 -2239205.1626231917, 99731.0544069348 -2239205.1558980397, 99731.21012763448 -2239205.1558980397, 99731.26016792345 -2239205.1148310355, 99731.32067830367 -2239205.0824875636, 99731.3863358923 -2239205.062570552, 99731.454617505 -2239205.0558454, 99731.71039084728 -2239205.0558454, 99731.76043113625 -2239205.0147783
956, 99731.82094151647 -2239204.9824349238, 99731.8865991051 -2239204.962517912, 99731.90552834554 -2239204.9606535444, 99731.90749862949 -2239204.9582527466, 99731.96053642135 -2239204.9147257553, 99732.02104680157 -2239204.8823822835, 99732.0867043902 -2239204.8624652717, 99732.10563362233 -2239204.860600905, 99732.10760391458 -2239204.858200097, 99732.16064170645 -2239204.8146731057, 99732.16291465345 -2239204.8134581903, 99732.16412956628 -2239204.811185248, 99732.20765655718 -2239204.7581474567, 99732.26069434904 -2239204.7146204654, 99732.26296729626 -2239204.71340555, 99732.26418220879 -2239204.7111326084, 99732.30770919968 -2239204.658094817, 99732.36074699154 -2239204.6145678256, 99732.4068271754 -2239204.589937454, 99732.41202701005 -2239204.537142647, 99732.43194402182 -2239204.4714850583, 99732.46428749389 -2239204.410974678, 99732.50781448478 -2239204.3579368866, 99732.56085227664 -2239204.3144098953, 99732.56312522401 -2239204.3131949794, 99732.5643401365 -2239
204.3109220383, 99732.60786712739 -2239204.2578842468, 99732.66090491925 -2239204.2143572555, 99732.72141529947 -2239204.1820137836, 99732.7870728881 -2239204.162096772, 99732.8553545008 -2239204.15537162, 99733.1555124284 -2239204.15537162, 99733.22379404111 -2239204.162096772, 99733.28945162974 -2239204.1820137836, 99733.34996200996 -2239204.2143572555, 99733.40299980182 -2239204.2578842468, 99733.40497008535 -2239204.260285044, 99733.42389932621 -2239204.2621494117, 99733.48955691484 -2239204.2820664234, 99733.55006729506 -2239204.3144098953, 99733.60310508692 -2239204.3579368866, 99733.64663207781 -2239204.410974678, 99733.64784699064 -2239204.41324762, 99733.65011993765 -2239204.4144625356, 99733.70315772951 -2239204.457989527, 99733.7051280222 -2239204.4603903354, 99733.7240572539 -2239204.462254702, 99733.78971484253 -2239204.482171714, 99733.85022522275 -2239204.5145151857, 99733.90326301461 -2239204.558042177, 99733.90523329814 -2239204.5604429743, 99733.92416253901
-2239204.562307342, 99733.98982012764 -2239204.5822243537, 99734.05033050786 -2239204.6145678256, 99734.10336829972 -2239204.658094817, 99734.10533858325 -2239204.660495614, 99734.12426782411 -2239204.662359982, 99734.18992541273 -2239204.6822769935, 99734.25043579296 -2239204.7146204654, 99734.3004760825 -2239204.75568747, 99734.3561441391 -2239204.75568747, 99734.42442575181 -2239204.762412622, 99734.49008334044 -2239204.782329634, 99734.55059372066 -2239204.8146731057, 99734.60363151252 -2239204.858200097, 99734.64715850342 -2239204.9112378885, 99734.67097357841 -2239204.95579276, 99734.8564073518 -2239204.95579276, 99734.92468896451 -2239204.962517912, 99734.99034655314 -2239204.9824349238, 99735.05085693336 -2239205.0147783956, 99735.10389472522 -2239205.058305387, 99735.14742171612 -2239205.1113431784, 99735.17976518818 -2239205.1718535586, 99735.19968219995 -2239205.2375111473, 99735.20640735181 -2239205.30579276, 99735.20640735181 -2239205.80605597, 99735.1996821999
5 -2239205.874337583, 99735.17976518818 -2239205.9399951715, 99735.14742171612 -2239206.0005055517, 99735.10389472522 -2239206.053543343, 99735.05085693336 -2239206.0970703345, 99734.99034655314 -2239206.1294138064, 99734.92468896451 -2239206.149330818, 99734.8564073518 -2239206.15605597, 99734.67077661124 -2239206.15605597, 99734.67950197548 -2239206.1723799785, 99734.69941898725 -2239206.238037567, 99734.70614413911 -2239206.30631918, 99734.70614413911 -2239206.3917003134, 99734.75069900576 -2239206.4155153856, 99734.80373679762 -2239206.459042377, 99734.84726378851 -2239206.5120801684, 99734.8484787087 -2239206.514353124, 99734.85075164825 -2239206.5155680357, 99734.90378944011 -2239206.559095027, 99734.947316431 -2239206.6121328184, 99734.94853134349 -2239206.6144057596, 99734.95080429086 -2239206.6156206755, 99735.00084457983 -2239206.6566876797, 99735.0565126369 -2239206.6566876797, 99735.12479424961 -2239206.6634128317, 99735.19045183824 -2239206.6833298435, 99735.250
96221846 -2239206.7156733153, 99735.301002508 -2239206.75674032, 99735.3566705646 -2239206.75674032, 99735.4249521773 -2239206.763465472, 99735.49060976593 -2239206.7833824838, 99735.55112014615 -2239206.8157259556, 99735.60415793801 -2239206.859252947, 99735.6476849289 -2239206.9122907384, 99735.68002840097 -2239206.9728011186, 99735.69994541274 -2239207.0384587073, 99735.70180978053 -2239207.0573879513, 99735.70421058062 -2239207.059358237, 99735.74773757151 -2239207.1123960284, 99735.78008104357 -2239207.1729064086, 99735.79999805534 -2239207.238563997, 99735.8067232072 -2239207.30684561, 99735.8067232072 -2239207.40689825, 99735.80179604473 -2239207.4569245703, 99735.8067232072 -2239207.50695089, 99735.8067232072 -2239207.70705618, 99735.80173959458 -2239207.757655648, 99735.80426322312 -2239207.7597267367, 99735.84779021401 -2239207.812764528, 99735.88013368608 -2239207.8732749084, 99735.90005069785 -2239207.938932497, 99735.90677584971 -2239208.00721411, 99735.90677584
971 -2239208.1629348057, 99735.9478428566 -2239208.2129750983, 99735.98018632867 -2239208.2734854785, 99736.00010334044 -2239208.339143067, 99736.0068284923 -2239208.40742468, 99736.0068284923 -2239208.50747732, 99736.00190132983 -2239208.55750364, 99736.00196770823 -2239208.5581775913, 99736.00436850822 -2239208.560147877, 99736.04789549911 -2239208.6131856684, 99736.08023897118 -2239208.6736960486, 99736.10015598295 -2239208.739353637, 99736.10688113481 -2239208.80763525, 99736.10688113481 -2239209.00774053, 99736.1018975222 -2239209.058339998, 99736.10442115081 -2239209.060411087, 99736.1479481417 -2239209.1134488783, 99736.18029161377 -2239209.1739592585, 99736.20020862554 -2239209.239616847, 99736.2069337774 -2239209.30789846, 99736.2069337774 -2239209.3635665164, 99736.24800078421 -2239209.4136068085, 99736.28034425627 -2239209.4741171887, 99736.30026126804 -2239209.5397747774, 99736.3069864199 -2239209.60805639, 99736.3069864199 -2239209.6637244457, 99736.34805342682
-2239209.7137647383, 99736.38039689888 -2239209.7742751185, 99736.40031391065 -2239209.839932707, 99736.40703906251 -2239209.90821432, 99736.40703906251 -2239210.0633865455, 99736.4254786028 -2239210.065202682, 99736.49113619143 -2239210.0851196935, 99736.55164657165 -2239210.1174631654, 99736.60468436351 -2239210.1609901567, 99736.6482113544 -2239210.214027948, 99736.68055482647 -2239210.2745383284, 99736.70047183824 -2239210.340195917, 99736.7071969901 -2239210.40847753, 99736.7071969901 -2239210.60858281, 99736.70221337749 -2239210.659182278, 99736.70473700612 -2239210.6612533666, 99736.74826399701 -2239210.714291158, 99736.74947890984 -2239210.7165641002, 99736.75175185685 -2239210.7177790157, 99736.80478964871 -2239210.761306007, 99736.8483166396 -2239210.8143437984, 99736.88066011167 -2239210.8748541786, 99736.90057712344 -2239210.9405117673, 99736.9073022753 -2239211.00879338, 99736.9073022753 -2239211.0941745136, 99736.95185714196 -2239211.1179895857, 99737.004894933
82 -2239211.161516577, 99737.00686522608 -2239211.163917385, 99737.02579445821 -2239211.1657817517, 99737.09145204684 -2239211.1856987635, 99737.15196242706 -2239211.2180422354, 99737.20500021892 -2239211.2615692266, 99737.24852720981 -2239211.314607018, 99737.24974212269 -2239211.3168799602, 99737.25201506955 -2239211.3180948757, 99737.30505286141 -2239211.361621867, 99737.3485798523 -2239211.4146596584, 99737.34979476478 -2239211.4169325996, 99737.35206771216 -2239211.4181475155, 99737.40510550402 -2239211.461674507, 99737.44863249491 -2239211.5147122983, 99737.44984740744 -2239211.51698524, 99737.45212035466 -2239211.5182001553, 99737.50515814652 -2239211.5617271466, 99737.5071284392 -2239211.564127955, 99737.52605767091 -2239211.565992322, 99737.59171525954 -2239211.5859093335, 99737.65222563976 -2239211.6182528054, 99737.70526343162 -2239211.6617797967, 99737.74879042251 -2239211.714817588, 99737.75000533534 -2239211.7170905303, 99737.75227828235 -2239211.7183054457, 99
737.80531607421 -2239211.761832437, 99737.8488430651 -2239211.8148702285, 99737.85005797763 -2239211.81714317, 99737.85233092486 -2239211.8183580856, 99737.90536871672 -2239211.861885077, 99737.94889570761 -2239211.9149228684, 99737.98123917967 -2239211.9754332486, 99738.00115619144 -2239212.041090837, 99738.0078813433 -2239212.10937245, 99738.0078813433 -2239212.2094251, 99738.00115619144 -2239212.277706713, 99737.98123917967 -2239212.3433643016, 99737.94889570761 -2239212.403874682, 99737.90536871672 -2239212.4569124733, 99737.85233092486 -2239212.5004394646, 99737.85005797763 -2239212.50165438, 99737.8488430651 -2239212.5039273216, 99737.80531607421 -2239212.556965113, 99737.75227828235 -2239212.6004921044, 99737.750005335 -2239212.6017070203, 99737.74879042251 -2239212.6039799615, 99737.74414890668 -2239212.609635665, 99737.74879042251 -2239212.615291368, 99737.78113389458 -2239212.6758017484, 99737.80105090635 -2239212.741459337, 99737.80777605821 -2239212.80974095, 997
37.80777605821 -2239212.85995152, 99737.8579866284 -2239212.85995152, 99737.9262682411 -2239212.866676672, 99737.99192582973 -2239212.8865936836, 99738.05243620995 -2239212.9189371555, 99738.10547400182 -2239212.962464147, 99738.14900099271 -2239213.0155019383, 99738.15021590519 -2239213.0177748795, 99738.15248885256 -2239213.0189897954, 99738.20552664442 -2239213.0625167866, 99738.24905363531 -2239213.115554578, 99738.28139710738 -2239213.1760649583, 99738.30131411915 -2239213.241722547, 99738.30803927101 -2239213.31000416, 99738.30803927101 -2239213.41005681, 99738.30131411915 -2239213.4783384227, 99738.28139710738 -2239213.5439960114, 99738.24905363531 -2239213.6045063916, 99738.2079866284 -2239213.654546684, 99738.2079866284 -2239213.71021473, 99738.20126147654 -2239213.7784963427, 99738.1816023578 -2239213.843303772, 99738.20552664442 -2239213.862937927, 99738.24905363531 -2239213.9159757183, 99738.28139710738 -2239213.9764860985, 99738.30131411915 -2239214.042143687, 9
9738.30803927101 -2239214.1104253, 99738.30803927101 -2239214.31053059, 99738.30131411915 -2239214.3788122027, 99738.28139710738 -2239214.4444697914, 99738.24905363531 -2239214.5049801716, 99738.20552664442 -2239214.558017963, 99738.15248885256 -2239214.6015449543, 99738.15021590554 -2239214.60275987, 99738.14900099271 -2239214.605032812, 99738.10547400182 -2239214.6580706034, 99738.05243620995 -2239214.7015975947, 99737.99192582973 -2239214.7339410665, 99737.98372643965 -2239214.736428324, 99737.98123917967 -2239214.7446277216, 99737.94889570761 -2239214.805138102, 99737.90536871672 -2239214.8581758933, 99737.85233092486 -2239214.9017028846, 99737.79182054463 -2239214.9340463565, 99737.72616295601 -2239214.953963368, 99737.6578813433 -2239214.96068852, 99737.60221328623 -2239214.96068852, 99737.55217299725 -2239215.0017555244, 99737.49166261703 -2239215.0340989963, 99737.4260050284 -2239215.054016008, 99737.40707578755 -2239215.0558803757, 99737.40510550402 -2239215.0582811
73, 99737.35206771216 -2239215.1018081643, 99737.34979476513 -2239215.1030230797, 99737.3485798523 -2239215.105296022, 99737.30505286141 -2239215.1583338133, 99737.30183084974 -2239215.16097805, 99737.30505286141 -2239215.1636222866, 99737.3485798523 -2239215.216660078, 99737.38092332437 -2239215.2771704583, 99737.40084033614 -2239215.342828047, 99737.407565488 -2239215.41110966, 99737.407565488 -2239215.4964907933, 99737.45212035466 -2239215.5203058654, 99737.50515814652 -2239215.5638328567, 99737.54868513742 -2239215.616870648, 99737.58102860948 -2239215.6773810284, 99737.60094562125 -2239215.743038617, 99737.60767077311 -2239215.81132023, 99737.60767077311 -2239215.8967013634, 99737.65222563976 -2239215.9205164355, 99737.70526343162 -2239215.964043427, 99737.74879042251 -2239216.0170812183, 99737.78113389458 -2239216.0775915985, 99737.78362115128 -2239216.085790985, 99737.79182054463 -2239216.088278244, 99737.85233092486 -2239216.1206217157, 99737.90536871672 -2239216.164
148707, 99737.94889570761 -2239216.2171864985, 99737.98123917967 -2239216.2776968786, 99737.98372643965 -2239216.285896276, 99737.99192582973 -2239216.2883835337, 99738.05243620995 -2239216.3207270056, 99738.10547400182 -2239216.364253997, 99738.14900099271 -2239216.4172917884, 99738.18134446477 -2239216.4778021686, 99738.20126147654 -2239216.543459757, 99738.20307761295 -2239216.5618992997, 99738.2581971987 -2239216.5618992997, 99738.30822351994 -2239216.5668264623, 99738.3582498412 -2239216.5618992997, 99738.7584604114 -2239216.5618992997, 99738.8267420241 -2239216.5686244518, 99738.89239961273 -2239216.5885414635, 99738.95290999295 -2239216.6208849354, 99739.00594778481 -2239216.6644119266, 99739.00791806876 -2239216.6668127244, 99739.02684730921 -2239216.668677092, 99739.09250489784 -2239216.688594104, 99739.15301527806 -2239216.7209375757, 99739.20605306992 -2239216.764464567, 99739.24958006082 -2239216.8175023585, 99739.28192353288 -2239216.8780127387, 99739.3018405446
5 -2239216.9436703273, 99739.30856569651 -2239217.01195194, 99739.30856569651 -2239217.11200458, 99739.30184054465 -2239217.180286193, 99739.2942768954 -2239217.205220203, 99739.32488970796 -2239217.1888573137, 99739.39054729659 -2239217.168940302, 99739.40947653746 -2239217.1670759344, 99739.41144682099 -2239217.164675137, 99739.46448461285 -2239217.1211481458, 99739.52499499307 -2239217.088804674, 99739.5906525817 -2239217.068887662, 99739.60958182214 -2239217.0670232945, 99739.61155210609 -2239217.0646224967, 99739.66458989795 -2239217.0210955054, 99739.71067008185 -2239216.996465134, 99739.71586991646 -2239216.9436703273, 99739.73578692823 -2239216.8780127387, 99739.76813040029 -2239216.8175023585, 99739.81165739118 -2239216.764464567, 99739.86469518305 -2239216.7209375757, 99739.92520556327 -2239216.688594104, 99739.99086315189 -2239216.668677092, 99740.0591447646 -2239216.66195194, 99740.1591974072 -2239216.66195194, 99740.20922372845 -2239216.6668791026, 99740.2592500
497 -2239216.66195194, 99740.3593026923 -2239216.66195194, 99740.42758430501 -2239216.668677092, 99740.49324189364 -2239216.688594104, 99740.55375227386 -2239216.7209375757, 99740.60679006572 -2239216.764464567, 99740.65031705661 -2239216.8175023585, 99740.68266052868 -2239216.8780127387, 99740.70257754045 -2239216.9436703273, 99740.70930269231 -2239217.01195194, 99740.70930269231 -2239217.21205722, 99740.70257754045 -2239217.2803388326, 99740.68266052868 -2239217.3459964213, 99740.65031705661 -2239217.4065068015, 99740.60679006572 -2239217.459544593, 99740.60438926567 -2239217.4615148786, 99740.60432288726 -2239217.46218883, 99740.6092500497 -2239217.51221515, 99740.6092500497 -2239217.71232044, 99740.60252489784 -2239217.780602053, 99740.58260788607 -2239217.8462596415, 99740.550264414 -2239217.9067700217, 99740.50673742311 -2239217.959807813, 99740.45369963125 -2239218.0033348044, 99740.39318925103 -2239218.0356782763, 99740.3275316624 -2239218.055595288, 99740.2592500497
-2239218.06232044, 99740.1591974072 -2239218.06232044, 99740.1091710859 -2239218.0573932775, 99740.10849713645 -2239218.0574596557, 99740.10652685292 -2239218.059860453, 99740.05348906106 -2239218.1033874443, 99739.99297868084 -2239218.135730916, 99739.98477928748 -2239218.138218175, 99739.98229203078 -2239218.1464175615, 99739.94994855871 -2239218.2069279416, 99739.90642156782 -2239218.259965733, 99739.85338377596 -2239218.3034927244, 99739.79287339574 -2239218.3358361963, 99739.72721580711 -2239218.355753208, 99739.70828657539 -2239218.3576175747, 99739.70631628271 -2239218.3600183832, 99739.65327849085 -2239218.4035453745, 99739.59276811063 -2239218.4358888464, 99739.527110522 -2239218.455805858, 99739.4588289093 -2239218.46253101, 99739.3587762667 -2239218.46253101, 99739.290494654 -2239218.455805858, 99739.27887399775 -2239218.4522807705, 99739.24958006082 -2239218.507085872, 99739.20605306992 -2239218.5601236634, 99739.15301527806 -2239218.6036506547, 99739.1507423308
4 -2239218.60486557, 99739.14952741831 -2239218.6071385117, 99739.10600042742 -2239218.6601763032, 99739.05296263556 -2239218.7037032945, 99738.99245225533 -2239218.7360467664, 99738.92679466671 -2239218.755963778, 99738.87399986494 -2239218.7611636124, 99738.8493694906 -2239218.8072438017, 99738.80584249971 -2239218.860281593, 99738.75280470785 -2239218.9038085844, 99738.69229432763 -2239218.9361520563, 99738.626636739 -2239218.956069068, 99738.5583551263 -2239218.96279422, 99738.4583024838 -2239218.96279422, 99738.4082761625 -2239218.9578670575, 99738.40362304353 -2239218.9583253497, 99738.40136676174 -2239218.981233763, 99738.38144974997 -2239219.0468913517, 99738.3491062779 -2239219.107401732, 99738.30557928701 -2239219.1604395234, 99738.25254149515 -2239219.2039665147, 99738.2502685478 -2239219.2051814306, 99738.24905363531 -2239219.2074543717, 99738.20552664442 -2239219.2604921632, 99738.15248885256 -2239219.3040191545, 99738.09197847234 -2239219.3363626264, 99738.0263
2088371 -2239219.356279638, 99737.958039271 -2239219.36300479, 99737.70226592873 -2239219.36300479, 99737.65222563976 -2239219.4040717944, 99737.59171525954 -2239219.4364152662, 99737.52605767091 -2239219.456332278, 99737.4577760582 -2239219.46305743, 99737.30205535909 -2239219.46305743, 99737.25201506955 -2239219.5041244347, 99737.19150468933 -2239219.5364679066, 99737.1258471007 -2239219.5563849183, 99737.057565488 -2239219.5631100703, 99736.9575128455 -2239219.5631100703, 99736.8892312328 -2239219.5563849183, 99736.82357364417 -2239219.5364679066, 99736.76306326395 -2239219.5041244347, 99736.71002547209 -2239219.4605974434, 99736.70795438564 -2239219.458073817, 99736.6573549178 -2239219.46305743, 99736.4572496327 -2239219.46305743, 99736.38896802 -2239219.456332278, 99736.32331043137 -2239219.4364152662, 99736.26280005115 -2239219.4040717944, 99736.20976225928 -2239219.360544803, 99736.16623526839 -2239219.3075070116, 99736.16502035591 -2239219.3052340704, 99736.162747408
54 -2239219.3040191545, 99736.11270711957 -2239219.2629521503, 99736.0570390625 -2239219.2629521503, 99735.9887574498 -2239219.2562269983, 99735.92309986117 -2239219.2363099866, 99735.86258948095 -2239219.2039665147, 99735.80955168909 -2239219.1604395234, 99735.7660246982 -2239219.107401732, 99735.76480977805 -2239219.1051287763, 99735.76253683835 -2239219.1039138646, 99735.70949904648 -2239219.0603868733, 99735.66597205559 -2239219.007349082, 99735.63362858353 -2239218.9468387016, 99735.61371157176 -2239218.881181113, 99735.6069864199 -2239218.8128995, 99735.6069864199 -2239218.71284686, 99735.61191358234 -2239218.66282054, 99735.6069864199 -2239218.61279422, 99735.6069864199 -2239218.41268893, 99735.61197003162 -2239218.362089471, 99735.60944640398 -2239218.3600183832, 99735.56591941309 -2239218.3069805917, 99735.53357594102 -2239218.2464702115, 99735.51365892925 -2239218.180812623, 99735.50693377739 -2239218.11253101, 99735.50693377739 -2239218.01247836, 99735.51191738911
-2239217.961878901, 99735.50939376139 -2239217.959807813, 99735.5074234687 -2239217.9574070047, 99735.488494237 -2239217.955542638, 99735.42283664837 -2239217.9356256262, 99735.36232626815 -2239217.9032821544, 99735.30928847629 -2239217.859755163, 99735.2657614854 -2239217.8067173716, 99735.23341801333 -2239217.7462069914, 99735.21350100156 -2239217.6805494027, 99735.2067758497 -2239217.61226779, 99735.2067758497 -2239217.5268866564, 99735.16222098304 -2239217.5030715843, 99735.11218069406 -2239217.46200458, 99734.8564073518 -2239217.46200458, 99734.80638103056 -2239217.4570774175, 99734.7563547093 -2239217.46200458, 99734.6563020667 -2239217.46200458, 99734.60570259861 -2239217.4570209673, 99734.60363151252 -2239217.459544593, 99734.55059372066 -2239217.5030715843, 99734.49008334044 -2239217.535415056, 99734.42442575181 -2239217.555332068, 99734.3561441391 -2239217.56205722, 99734.2560914965 -2239217.56205722, 99734.20606517524 -2239217.5571300574, 99734.156038854 -2239217
.56205722, 99734.0559862114 -2239217.56205722, 99733.9877045987 -2239217.555332068, 99733.95593356885 -2239217.5456944313, 99733.92416253901 -2239217.555332068, 99733.90523330729 -2239217.5571964346, 99733.90326301461 -2239217.559597243, 99733.85022522275 -2239217.6031242344, 99733.84795227574 -2239217.60433915, 99733.84673736291 -2239217.606612092, 99733.80321037202 -2239217.6596498834, 99733.75017258016 -2239217.7031768747, 99733.68966219993 -2239217.7355203466, 99733.62400461131 -2239217.7554373583, 99733.5557229986 -2239217.7621625103, 99733.4556703561 -2239217.7621625103, 99733.38738874339 -2239217.7554373583, 99733.35561771355 -2239217.7457997217, 99733.3238466837 -2239217.7554373583, 99733.255565071 -2239217.7621625103, 99733.19989701382 -2239217.7621625103, 99733.14985672485 -2239217.8032295145, 99733.08934634463 -2239217.8355729864, 99733.023688756 -2239217.855489998, 99732.9554071433 -2239217.86221515, 99732.8553545008 -2239217.86221515, 99732.7870728881 -2239217.8
55489998, 99732.72141529947 -2239217.8355729864, 99732.66090491925 -2239217.8032295145, 99732.60786712739 -2239217.7597025232, 99732.6057960413 -2239217.7571788975, 99732.5551965731 -2239217.7621625103, 99732.4551439306 -2239217.7621625103, 99732.38686231789 -2239217.7554373583, 99732.32120472926 -2239217.7355203466, 99732.26069434904 -2239217.7031768747, 99732.2106540595 -2239217.66210987, 99732.1549860029 -2239217.66210987, 99732.0867043902 -2239217.655384718, 99732.02104680157 -2239217.6354677062, 99731.96053642135 -2239217.6031242344, 99731.90749862949 -2239217.559597243, 99731.8639716386 -2239217.5065594516, 99731.86275671844 -2239217.504286496, 99731.86048377874 -2239217.5030715843, 99731.80744598688 -2239217.459544593, 99731.76391899599 -2239217.4065068015, 99731.73157552393 -2239217.3459964213, 99731.71165851215 -2239217.2803388326, 99731.70493336029 -2239217.21205722, 99731.70493336029 -2239217.01195194, 99731.71165851215 -2239216.9436703273, 99731.73157552393 -2239
216.8780127387, 99731.76391899599 -2239216.8175023585, 99731.8049860029 -2239216.767462066, 99731.8049860029 -2239216.61174137, 99731.81171115476 -2239216.543459757, 99731.83162816653 -2239216.4778021686, 99731.8639716386 -2239216.4172917884, 99731.90503864549 -2239216.367251496, 99731.90503864549 -2239216.31158344, 99731.90996580794 -2239216.26155712, 99731.90503864549 -2239216.2115308, 99731.90503864549 -2239216.11147815, 99731.91176379735 -2239216.043196537, 99731.93168080912 -2239215.9775389484, 99731.96402428119 -2239215.917028568, 99732.005091288 -2239215.866988276, 99732.005091288 -2239215.71126758, 99732.01181643986 -2239215.642985967, 99732.02145407554 -2239215.61121494, 99732.01181643986 -2239215.579443913, 99732.005091288 -2239215.5111623, 99732.005091288 -2239215.41110966, 99732.01001845092 -2239215.361083335, 99732.00995207312 -2239215.3604093897, 99732.00755127208 -2239215.3584391032, 99731.96402428119 -2239215.3054013117, 99731.93168080912 -2239215.2448909315,
99731.91176379735 -2239215.179233343, 99731.90989942956 -2239215.160304099, 99731.90749862949 -2239215.1583338133, 99731.8639716386 -2239215.105296022, 99731.83162816653 -2239215.0447856416, 99731.81171115476 -2239214.979128053, 99731.80984678802 -2239214.9601988196, 99731.80744598688 -2239214.958228533, 99731.76391899599 -2239214.9051907416, 99731.73157552393 -2239214.8446803614, 99731.71165851215 -2239214.779022773, 99731.70979414435 -2239214.760093529, 99731.70739334439 -2239214.758123243, 99731.6638663535 -2239214.7050854517, 99731.63152288143 -2239214.6445750715, 99731.61160586966 -2239214.578917483, 99731.6048807178 -2239214.51063587, 99731.6048807178 -2239214.41058323, 99731.60980788028 -2239214.36055691, 99731.60974150187 -2239214.3598829587, 99731.60734070178 -2239214.357912673, 99731.56381371089 -2239214.3048748816, 99731.53147023883 -2239214.2443645014, 99731.51155322706 -2239214.178706913, 99731.50968886031 -2239214.1597776795, 99731.50728805928 -2239214.1578073
93, 99731.46376106839 -2239214.1047696015, 99731.4625461559 -2239214.1024966603, 99731.46027320855 -2239214.1012817444, 99731.40723541669 -2239214.057754753, 99731.3637084258 -2239214.0047169616, 99731.33136495373 -2239213.9442065815, 99731.31144794196 -2239213.878548993, 99731.30958357417 -2239213.859619749, 99731.30718277418 -2239213.857649463, 99731.26365578329 -2239213.8046116717, 99731.2624408708 -2239213.8023387305, 99731.26016792345 -2239213.8011238147, 99731.20713013159 -2239213.7575968234, 99731.1636031407 -2239213.704559032, 99731.16238822782 -2239213.70228609, 99731.16011528095 -2239213.7010711743, 99731.10707748908 -2239213.657544183, 99731.1051071964 -2239213.6551433746, 99731.0861779647 -2239213.653279008, 99731.02052037607 -2239213.633361996, 99730.96000999585 -2239213.6010185243, 99730.90697220399 -2239213.557491533, 99730.90500192046 -2239213.5550907357, 99730.8860726795 -2239213.553226368, 99730.82041509087 -2239213.5333093563, 99730.75990471065 -2239213.50
09658844, 99730.70686691879 -2239213.457438893, 99730.6633399279 -2239213.4044011016, 99730.63952485814 -2239213.35984624, 99730.554143722 -2239213.35984624, 99730.48586210929 -2239213.353121088, 99730.42020452066 -2239213.333204076, 99730.35969414044 -2239213.3008606043, 99730.30665634858 -2239213.257333613, 99730.30468605632 -2239213.254932805, 99730.28575682419 -2239213.2530684383, 99730.22009923556 -2239213.2331514265, 99730.15958885534 -2239213.2008079547, 99730.1095485658 -2239213.15974095, 99729.9538278667 -2239213.15974095, 99729.885546254 -2239213.153015798, 99729.81988866537 -2239213.133098786, 99729.75937828515 -2239213.1007553143, 99729.70933799617 -2239213.05968831, 99729.6536699391 -2239213.05968831, 99729.58538832639 -2239213.052963158, 99729.51973073777 -2239213.0330461464, 99729.45922035754 -2239213.0007026745, 99729.40618256568 -2239212.957175683, 99729.36265557479 -2239212.9041378917, 99729.36144066231 -2239212.9018649505, 99729.35916771494 -2239212.900650
0347, 99729.30612992308 -2239212.8571230434, 99729.26260293218 -2239212.804085252, 99729.26138801203 -2239212.8018122963, 99729.25911507235 -2239212.8005973846, 99729.20607728048 -2239212.7570703933, 99729.16255028959 -2239212.704032602, 99729.13020681753 -2239212.6435222216, 99729.11028980576 -2239212.577864633, 99729.10842543902 -2239212.5589353996, 99729.10602463798 -2239212.556965113, 99729.10405435445 -2239212.554564316, 99729.08512511359 -2239212.552699948, 99729.01946752497 -2239212.5327829365, 99728.95895714474 -2239212.5004394646, 99728.90891684328 -2239212.45937245, 99728.7531961561 -2239212.45937245, 99728.6849145434 -2239212.452647298, 99728.65314351355 -2239212.4430096615, 99728.62137248371 -2239212.452647298, 99728.553090871 -2239212.45937245, 99728.4530382284 -2239212.45937245, 99728.38475661569 -2239212.452647298, 99728.31909902707 -2239212.4327302864, 99728.25858864684 -2239212.4003868145, 99728.20854835787 -2239212.3593198103, 99727.8527223731 -2239212.3593
198103, 99727.7844407604 -2239212.3525946583, 99727.71878317177 -2239212.3326776465, 99727.65827279155 -2239212.3003341747, 99727.60523499969 -2239212.2568071834, 99727.60326471574 -2239212.2544063856, 99727.58433547529 -2239212.252542018, 99727.51867788666 -2239212.232625006, 99727.45816750644 -2239212.2002815343, 99727.40512971458 -2239212.156754543, 99727.4031594219 -2239212.1543537346, 99727.38423019019 -2239212.152489368, 99727.31857260157 -2239212.132572356, 99727.25806222134 -2239212.1002288843, 99727.20502442948 -2239212.056701893, 99727.16149743859 -2239212.0036641015, 99727.1602825261 -2239212.0013911603, 99727.15800957875 -2239212.0001762444, 99727.10497178689 -2239211.956649253, 99727.061444796 -2239211.9036114616, 99727.02910132393 -2239211.8431010814, 99727.00918431216 -2239211.777443493, 99727.0024591603 -2239211.70916188, 99727.0024591603 -2239211.5090566, 99727.00918431216 -2239211.440774987, 99727.02910132393 -2239211.3751173983, 99727.061444796 -2239211.31
4607018, 99727.10497178689 -2239211.2615692266, 99727.15800957875 -2239211.2180422354, 99727.16028251879 -2239211.2168273237, 99727.16149743859 -2239211.2145543685, 99727.20502442948 -2239211.161516577, 99727.25806222134 -2239211.1179895857, 99727.31857260157 -2239211.085646114, 99727.38423019019 -2239211.065729102, 99727.40315943063 -2239211.0638647345, 99727.40512971458 -2239211.0614639367, 99727.45816750644 -2239211.0179369454, 99727.51867788666 -2239210.9855934735, 99727.58433547529 -2239210.965676462, 99727.652617088 -2239210.95895131, 99727.70828514507 -2239210.95895131, 99727.75832543404 -2239210.9178843056, 99727.81883581427 -2239210.8855408337, 99727.88449340289 -2239210.865623822, 99727.9527750156 -2239210.85889867, 99728.50870628557 -2239210.85889867, 99728.55874657455 -2239210.8178316657, 99728.61925695477 -2239210.785488194, 99728.6849145434 -2239210.765571182, 99728.7531961561 -2239210.75884603, 99728.90891684328 -2239210.75884603, 99728.95895714474 -2239210.71
77790157, 99729.00351201139 -2239210.6939639435, 99729.00351201139 -2239210.652967404, 99728.9624450045 -2239210.6029271116, 99728.93010153243 -2239210.5424167314, 99728.92761427246 -2239210.534217334, 99728.91941488237 -2239210.5317300763, 99728.85890450215 -2239210.4993866044, 99728.80886421318 -2239210.4583196, 99728.7531961561 -2239210.4583196, 99728.7031698348 -2239210.4533924377, 99728.6531435135 -2239210.4583196, 99727.99715960103 -2239210.4583196, 99727.94711931206 -2239210.4993866044, 99727.88660893183 -2239210.5317300763, 99727.82095134321 -2239210.551647088, 99727.7526697305 -2239210.55837224, 99727.1523538752 -2239210.55837224, 99727.08407226249 -2239210.551647088, 99727.01841467386 -2239210.5317300763, 99726.95790429364 -2239210.4993866044, 99726.90486650178 -2239210.455859613, 99726.90289621825 -2239210.453458816, 99726.88396697739 -2239210.451594448, 99726.81830938876 -2239210.4316774365, 99726.75779900854 -2239210.3993339646, 99726.707758719 -2239210.35826696
, 99726.6520906625 -2239210.35826696, 99726.58380904979 -2239210.351541808, 99726.5520380199 -2239210.3419041713, 99726.52026699 -2239210.351541808, 99726.50133774956 -2239210.3534061755, 99726.49936746561 -2239210.3558069733, 99726.44632967375 -2239210.3993339646, 99726.44405672654 -2239210.40054888, 99726.44284181402 -2239210.4028218216, 99726.4017748071 -2239210.452862114, 99726.4017748071 -2239210.90874074, 99726.39504965524 -2239210.9770223526, 99726.37513264347 -2239211.0426799413, 99726.34278917141 -2239211.1031903215, 99726.29926218052 -2239211.156228113, 99726.29686138059 -2239211.1581983985, 99726.29499701274 -2239211.177127643, 99726.27508000097 -2239211.2427852317, 99726.2427365289 -2239211.303295612, 99726.20166952201 -2239211.3533359044, 99726.20166952201 -2239211.40900395, 99726.19494437015 -2239211.477285563, 99726.17502735837 -2239211.5429431517, 99726.14268388631 -2239211.603453532, 99726.09915689542 -2239211.6564913234, 99726.04611910356 -2239211.700018314
6, 99726.04384616365 -2239211.7012332263, 99726.0426312438 -2239211.7035061815, 99725.99910425291 -2239211.756543973, 99725.94606646105 -2239211.8000709643, 99725.88555608083 -2239211.832414436, 99725.8198984922 -2239211.852331448, 99725.7516168795 -2239211.8590566, 99725.6515642369 -2239211.8590566, 99725.5832826242 -2239211.852331448, 99725.51762503557 -2239211.832414436, 99725.45711465535 -2239211.8000709643, 99725.40407686349 -2239211.756543973, 99725.3605498726 -2239211.7035061815, 99725.35933495275 -2239211.7012332263, 99725.35706201284 -2239211.7000183146, 99725.30402422098 -2239211.6564913234, 99725.26049723009 -2239211.603453532, 99725.22815375803 -2239211.5429431517, 99725.20823674626 -2239211.477285563, 99725.20637237951 -2239211.4583563297, 99725.20397157838 -2239211.456386043, 99725.16044458748 -2239211.4033482517, 99725.12810111542 -2239211.3428378715, 99725.10818410365 -2239211.277180283, 99725.10145895179 -2239211.20889867, 99725.10145895179 -2239210.50853017
, 99725.10818410365 -2239210.4402485574, 99725.12810111542 -2239210.3745909687, 99725.16044458748 -2239210.3140805885, 99725.2015115944 -2239210.264040296),
+ (99729.4984977109 -2239209.7583196, 99729.5536172965 -2239209.7583196, 99729.60421676433 -2239209.763303213, 99729.60628785078 -2239209.7607795866, 99729.60868865077 -2239209.758809301, 99729.61055301856 -2239209.739880057, 99729.63047003033 -2239209.6742224684, 99729.6628135024 -2239209.613712088, 99729.70388050929 -2239209.5636717957, 99729.70388050929 -2239209.50800375, 99729.70880767224 -2239209.457977425, 99729.70388050929 -2239209.4079511, 99729.70388050929 -2239209.352283054, 99729.6628135024 -2239209.3022427615, 99729.66159858255 -2239209.2999698063, 99729.65932564264 -2239209.2987548946, 99729.60628785078 -2239209.2552279034, 99729.60421676433 -2239209.252704277, 99729.5536172965 -2239209.25768789, 99729.3033014412 -2239209.25768789, 99729.3033014412 -2239209.30789846, 99729.29837427876 -2239209.35792478, 99729.3033014412 -2239209.4079511, 99729.3033014412 -2239209.4933322333, 99729.34785630785 -2239209.5171473054, 99729.40089409972 -2239209.5606742967, 99729.4444
2109061 -2239209.613712088, 99729.47676456267 -2239209.6742224684, 99729.49668157444 -2239209.739880057, 99729.4984977109 -2239209.7583196))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-0.75: see http://trac.osgeo.org/geos/wiki/BufferRobustness</desc>
+ <op name="buffer" arg1="a" arg2="0.75">
+ POLYGON((99724.80151159 -2239210.14114081,99724.80151159 -2239209.90821432,99724.81592263 -2239209.76189657,99724.85860194 -2239209.62120174,99724.9042938714 -2239209.53571816,99724.90156424 -2239209.50800375,99724.90156424 -2239209.4079511,99724.91597528 -2239209.26163336,99724.95865459 -2239209.12093853,99725.02796203 -2239208.99127343,99725.0428380369 -2239208.97314696,99725.05870723 -2239208.92083324,99725.12801467 -2239208.79116814,99725.22128679 -2239208.67751573,99725.2762402889 -2239208.63241656,99725.32133944 -2239208.57746309,99725.3762929231 -2239208.53236393,99725.42139208 -2239208.47741045,99725.4763455623 -2239208.43231129,99725.52144472 -2239208.3773578,99725.5763982031 -2239208.33225864,99725.62149736 -2239208.27730516,99725.6764508589 -2239208.23220599,99725.72155001 -2239208.17725252,99725.83520242 -2239208.0839804,99725.96486752 -2239208.01467296,99726.0171812128 -2239207.99880377,99726.0353077 -2239207.98392775,99726.1649728 -2239207.91462031,99726.
30566764 -2239207.871941,99726.45198538 -2239207.85752996,99727.4525118 -2239207.85752996,99727.5025381233 -2239207.86245712,99727.55256445 -2239207.85752996,99727.8488737358 -2239207.85752996,99727.86018122 -2239207.82025418,99727.90314351 -2239207.73987739,99727.90314351 -2239207.60700354,99727.91755455 -2239207.4606858,99727.96023386 -2239207.31999096,99728.0295413 -2239207.19032586,99728.12281343 -2239207.07667345,99728.1777669131 -2239207.03157429,99728.22286607 -2239206.97662081,99728.2778195531 -2239206.93152165,99728.32291871 -2239206.87656817,99728.3778722081 -2239206.831469,99728.42297136 -2239206.77651552,99728.4779248283 -2239206.73141638,99728.523024 -2239206.67646288,99728.63667641 -2239206.58319076,99728.76634151 -2239206.51388332,99728.8010181124 -2239206.50336429,99728.82318193 -2239206.4763576,99728.93683434 -2239206.38308547,99729.06649944 -2239206.31377803,99729.118813149 -2239206.29790884,99729.13693962 -2239206.28303283,99729.26660472 -2239206.21372539,
99729.40729956 -2239206.17104608,99729.5536173 -2239206.15663504,99729.5864384989 -2239206.15663504,99729.5979079113 -2239206.15050451,99729.60403844 -2239206.1390351,99729.60403844 -2239206.00616126,99729.61844948 -2239205.85984352,99729.66112879 -2239205.71914868,99729.73043623 -2239205.58948358,99729.82370835 -2239205.47583117,99729.8786618331 -2239205.43073201,99729.92376099 -2239205.37577853,99729.9787145011 -2239205.33067935,99730.02381364 -2239205.27572589,99730.13746605 -2239205.18245376,99730.26713115 -2239205.11314632,99730.3018077423 -2239205.10262729,99730.32397156 -2239205.0756206,99730.43762397 -2239204.98234848,99730.56728908 -2239204.91304104,99730.6196027728 -2239204.89717186,99730.63772926 -2239204.88229583,99730.76739436 -2239204.81298839,99730.90808919 -2239204.77030908,99731.05440693 -2239204.75589804,99731.0872281389 -2239204.75589804,99731.16760493 -2239204.71293575,99731.30829976 -2239204.67025644,99731.45461751 -2239204.6558454,99731.5874913489 -2239
204.6558454,99731.66786814 -2239204.61288311,99731.7201818627 -2239204.59701392,99731.73830833 -2239204.58213791,99731.86797343 -2239204.51283047,99731.9026500223 -2239204.50231144,99731.92481384 -2239204.47530475,99731.979767316 -2239204.4302056,99732.02486649 -2239204.3752521,99732.0518731808 -2239204.35308828,99732.06239221 -2239204.31841169,99732.13169965 -2239204.18874659,99732.22497177 -2239204.07509417,99732.2799252531 -2239204.02999501,99732.32502441 -2239203.97504153,99732.43867683 -2239203.88176941,99732.56834193 -2239203.81246197,99732.70903676 -2239203.76978266,99732.8553545 -2239203.75537162,99733.15551243 -2239203.75537162,99733.30183017 -2239203.76978266,99733.442525 -2239203.81246197,99733.5721901 -2239203.88176941,99733.5903165651 -2239203.89664542,99733.64263029 -2239203.91251461,99733.77229539 -2239203.98182205,99733.8859478 -2239204.07509417,99733.9081116236 -2239204.10210087,99733.94278822 -2239204.1126199,99734.07245332 -2239204.18192734,99734.090579791
-2239204.19680335,99734.1428935 -2239204.21267254,99734.2725586 -2239204.28197998,99734.2906850673 -2239204.29685599,99734.34299879 -2239204.31272518,99734.4385623232 -2239204.36380495,99734.50246188 -2239204.37009851,99734.64315671 -2239204.41277782,99734.77282181 -2239204.48208526,99734.8634839262 -2239204.55648974,99735.00272509 -2239204.5702038,99735.14341993 -2239204.61288311,99735.27308503 -2239204.68219055,99735.38673744 -2239204.77546267,99735.48000956 -2239204.88911508,99735.549317 -2239205.01878018,99735.59199631 -2239205.15947502,99735.60640735 -2239205.30579276,99735.60640735 -2239205.80605597,99735.59199631 -2239205.95237371,99735.549317 -2239206.09306855,99735.48000956 -2239206.22273365,99735.38673744 -2239206.33638606,99735.3863763185 -2239206.33668242,99735.439088742 -2239206.3648578,99735.50298831 -2239206.37115136,99735.64368314 -2239206.41383068,99735.77334824 -2239206.48313812,99735.88700065 -2239206.57641024,99735.98027277 -2239206.69006265,99736.049580
21 -2239206.81972775,99736.0654493992 -2239206.87204146,99736.08032542 -2239206.89016794,99736.14963286 -2239207.01983304,99736.19231217 -2239207.16052787,99736.20672321 -2239207.30684561,99736.20672321 -2239207.40689825,99736.2017960474 -2239207.45692457,99736.20672321 -2239207.50695089,99736.20672321 -2239207.63982474,99736.2496855 -2239207.72020153,99736.29236481 -2239207.86089637,99736.30677585 -2239208.00721411,99736.30677585 -2239208.04003531,99736.34973814 -2239208.1204121,99736.39241745 -2239208.26110694,99736.40682849 -2239208.40742468,99736.40682849 -2239208.44024588,99736.44979078 -2239208.52062267,99736.4924701 -2239208.66131751,99736.50688113 -2239208.80763525,99736.50688113 -2239208.94050908,99736.54984343 -2239209.02088589,99736.59252274 -2239209.16158072,99736.5988162972 -2239209.22548028,99736.64989607 -2239209.32104381,99736.69257538 -2239209.46173865,99736.6988689372 -2239209.52563821,99736.74994871 -2239209.62120174,99736.79262802 -2239209.76189657,99736.
7967393798 -2239209.80363991,99736.88752708 -2239209.87814744,99736.9807992 -2239209.99179985,99737.05010664 -2239210.12146495,99737.09278595 -2239210.26215979,99737.10719699 -2239210.40847753,99737.10719699 -2239210.50230287,99737.18090448 -2239210.59211571,99737.25021192 -2239210.72178081,99737.2854776711 -2239210.83803638,99737.37419052 -2239210.88545439,99737.48784293 -2239210.97872651,99737.5329420869 -2239211.03367999,99737.58789557 -2239211.07877915,99737.6329947341 -2239211.13373264,99737.68794822 -2239211.1788318,99737.7101120377 -2239211.20583849,99737.74478863 -2239211.21635752,99737.87445373 -2239211.28566496,99737.98810614 -2239211.37893708,99738.0332052911 -2239211.43389055,99738.08815879 -2239211.47898972,99738.1332579599 -2239211.53394322,99738.18821143 -2239211.57904237,99738.28148355 -2239211.69269478,99738.35079099 -2239211.82235988,99738.3934703 -2239211.96305471,99738.40788134 -2239212.10937245,99738.40788134 -2239212.20942509,99738.3934703 -2239212.3557
4284,99738.35079099 -2239212.49643767,99738.2941740377 -2239212.60236054,99738.38831671 -2239212.67962143,99738.4334158619 -2239212.73457491,99738.48836936 -2239212.77967408,99738.58164148 -2239212.89332649,99738.65094892 -2239213.02299159,99738.69362823 -2239213.16368642,99738.70803927 -2239213.31000416,99738.70803927 -2239213.41005681,99738.69362823 -2239213.55637455,99738.65094892 -2239213.69706938,99738.6171829562 -2239213.76024105,99738.65094892 -2239213.82341273,99738.69362823 -2239213.96410756,99738.70803927 -2239214.1104253,99738.70803927 -2239214.31053059,99738.69362823 -2239214.45684833,99738.65094892 -2239214.59754316,99738.58164148 -2239214.72720826,99738.48836936 -2239214.84086067,99738.4334158741 -2239214.88595983,99738.38831671 -2239214.94091332,99738.2784097438 -2239215.03111163,99738.18821143 -2239215.1410186,99738.07455902 -2239215.23429073,99737.94489392 -2239215.30359817,99737.8341295888 -2239215.33719816,99737.88127298 -2239215.39464255,99737.95058042 -2
239215.52430765,99737.99325973 -2239215.66500249,99737.9957755359 -2239215.6905459,99738.0783044636 -2239215.79110768,99738.18821143 -2239215.881306,99738.2784097438 -2239215.99121297,99738.38831671 -2239216.08141128,99738.4543715263 -2239216.1618993,99738.75846041 -2239216.1618993,99738.90477815 -2239216.17631033,99739.04547299 -2239216.21898965,99739.17513809 -2239216.28829709,99739.193264561 -2239216.3031731,99739.24557827 -2239216.31904229,99739.37524337 -2239216.38834973,99739.48889578 -2239216.48162185,99739.5088552311 -2239216.50594251,99739.52881468 -2239216.48162185,99739.64246709 -2239216.38834973,99739.77213219 -2239216.31904229,99739.91282702 -2239216.27636298,99740.05914476 -2239216.26195194,99740.15919741 -2239216.26195194,99740.20922373 -2239216.2668791,99740.25925005 -2239216.26195194,99740.35930269 -2239216.26195194,99740.50562043 -2239216.27636298,99740.64631527 -2239216.31904229,99740.77598037 -2239216.38834973,99740.88963278 -2239216.48162185,99740.982904
9 -2239216.59527426,99741.05221234 -2239216.72493936,99741.09489165 -2239216.8656342,99741.10930269 -2239217.01195194,99741.10930269 -2239217.21205722,99741.09489165 -2239217.35837496,99741.05221234 -2239217.4990698,99741.00925005 -2239217.57944659,99741.00925005 -2239217.71232044,99740.99483901 -2239217.85863818,99740.9521597 -2239217.99933301,99740.88285226 -2239218.12899811,99740.78958014 -2239218.24265052,99740.67592772 -2239218.33592264,99740.54626262 -2239218.40523008,99740.40556779 -2239218.4479094,99740.25925005 -2239218.46232044,99740.255319081 -2239218.46232044,99740.18926428 -2239218.54280845,99740.07561187 -2239218.63608057,99739.94594677 -2239218.70538801,99739.8936330476 -2239218.7212572,99739.87550658 -2239218.73613321,99739.74584148 -2239218.80544066,99739.60514665 -2239218.84811997,99739.4659054834 -2239218.86183403,99739.4339422969 -2239218.88806554,99739.38884314 -2239218.94301902,99739.27519073 -2239219.03629114,99739.14552563 -2239219.10559858,99739.1108
490276 -2239219.11611761,99739.08868521 -2239219.1431243,99738.9750328 -2239219.23639643,99738.8453677 -2239219.30570387,99738.70467287 -2239219.34838318,99738.6629295295 -2239219.35249454,99738.588422 -2239219.44328223,99738.5334685047 -2239219.4883814,99738.48836936 -2239219.54333487,99738.37471695 -2239219.636607,99738.24505185 -2239219.70591444,99738.10435701 -2239219.74859375,99737.95803927 -2239219.76300479,99737.8251654211 -2239219.76300479,99737.74478863 -2239219.80596708,99737.6040938 -2239219.84864639,99737.45777606 -2239219.86305743,99737.4249548511 -2239219.86305743,99737.34457806 -2239219.90601972,99737.20388323 -2239219.94869903,99737.05756549 -2239219.96311007,99736.95751285 -2239219.96311007,99736.8111951 -2239219.94869903,99736.67050027 -2239219.90601972,99736.5901234789 -2239219.86305743,99736.45724963 -2239219.86305743,99736.31093189 -2239219.84864639,99736.17023706 -2239219.80596708,99736.04057196 -2239219.73665964,99735.9362647377 -2239219.65105692,99735
.91072132 -2239219.64854111,99735.77002649 -2239219.6058618,99735.64036139 -2239219.53655436,99735.52670898 -2239219.44328223,99735.4816098189 -2239219.38832875,99735.42665633 -2239219.34322959,99735.33338421 -2239219.22957718,99735.26407677 -2239219.09991208,99735.22139746 -2239218.95921724,99735.20698642 -2239218.8128995,99735.20698642 -2239218.71284686,99735.2119135826 -2239218.66282054,99735.20698642 -2239218.61279422,99735.20698642 -2239218.47992037,99735.16402413 -2239218.39954358,99735.12134482 -2239218.25884875,99735.1172334606 -2239218.21710542,99735.02644576 -2239218.14259788,99734.93317364 -2239218.02894547,99734.8638662 -2239217.89928037,99734.8524401864 -2239217.86161385,99734.80638103 -2239217.85707742,99734.75635471 -2239217.86200458,99734.7235335011 -2239217.86200458,99734.64315671 -2239217.90496687,99734.50246188 -2239217.94764618,99734.35614414 -2239217.96205722,99734.2560915 -2239217.96205722,99734.2060651767 -2239217.95713006,99734.15603885 -2239217.96205
722,99734.0622135113 -2239217.96205722,99733.97240067 -2239218.03576472,99733.84273557 -2239218.10507216,99733.70204074 -2239218.14775147,99733.555723 -2239218.16216251,99733.45567036 -2239218.16216251,99733.3556177116 -2239218.15230819,99733.3379832532 -2239218.15404503,99733.24241972 -2239218.2051248,99733.10172488 -2239218.24780411,99732.95540714 -2239218.26221515,99732.8553545 -2239218.26221515,99732.70903676 -2239218.24780411,99732.56834193 -2239218.2051248,99732.4879651389 -2239218.16216251,99732.45514393 -2239218.16216251,99732.30882619 -2239218.14775147,99732.16813136 -2239218.10507216,99732.072567829 -2239218.05399239,99732.00866826 -2239218.04769883,99731.86797343 -2239218.00501951,99731.73830833 -2239217.93571207,99731.62465592 -2239217.84243995,99731.579556759 -2239217.78748647,99731.52460327 -2239217.74238731,99731.43133115 -2239217.6287349,99731.36202371 -2239217.4990698,99731.3193444 -2239217.35837496,99731.30493336 -2239217.21205722,99731.30493336 -2239217.01
195194,99731.3193444 -2239216.8656342,99731.36202371 -2239216.72493936,99731.404986 -2239216.64456257,99731.404986 -2239216.61174137,99731.41939704 -2239216.46542363,99731.46207635 -2239216.32472879,99731.5077682803 -2239216.2392452,99731.50503865 -2239216.2115308,99731.50503865 -2239216.11147815,99731.51944969 -2239215.96516041,99731.562129 -2239215.82446558,99731.60509129 -2239215.74408879,99731.60509129 -2239215.71126758,99731.6149456152 -2239215.61121494,99731.60509129 -2239215.5111623,99731.60509129 -2239215.47834109,99731.562129 -2239215.3979643,99731.5462598148 -2239215.34565061,99731.53138379 -2239215.32752412,99731.46207635 -2239215.19785902,99731.4462071551 -2239215.1455453,99731.43133115 -2239215.12741883,99731.36202371 -2239214.99775373,99731.3461545199 -2239214.94544002,99731.33127851 -2239214.92731355,99731.26197107 -2239214.79764845,99731.21929176 -2239214.65695361,99731.20488072 -2239214.51063587,99731.20488072 -2239214.47781467,99731.16191843 -2239214.397437
88,99731.151399397 -2239214.36276128,99731.1243927 -2239214.34059746,99731.03112058 -2239214.22694505,99730.96181314 -2239214.09727995,99730.9512941077 -2239214.06260335,99730.92428742 -2239214.04043953,99730.9021236047 -2239214.01343284,99730.867447 -2239214.00291381,99730.7377819 -2239213.93360637,99730.719655429 -2239213.91873036,99730.66734172 -2239213.90286117,99730.53767662 -2239213.83355373,99730.4333693977 -2239213.74795101,99730.40782598 -2239213.7454352,99730.26713115 -2239213.70275589,99730.13746605 -2239213.63344844,99730.1193395827 -2239213.61857243,99730.06702586 -2239213.60270324,99729.9866490689 -2239213.55974095,99729.95382787 -2239213.55974095,99729.80751013 -2239213.54532991,99729.66681529 -2239213.5026506,99729.5712517568 -2239213.45157083,99729.5073522 -2239213.44527727,99729.36665736 -2239213.40259796,99729.23699226 -2239213.33329052,99729.12333985 -2239213.24001839,99729.0782406931 -2239213.18506491,99729.02328721 -2239213.13996575,99728.9781880531 -22
39213.08501227,99728.92323457 -2239213.03991311,99728.82996244 -2239212.9262607,99728.7974867573 -2239212.86550297,99728.7860173589 -2239212.85937245,99728.75319616 -2239212.85937245,99728.6531435116 -2239212.84951812,99728.55309087 -2239212.85937245,99728.45303823 -2239212.85937245,99728.30672049 -2239212.84496141,99728.16602565 -2239212.8022821,99728.0856488589 -2239212.75931981,99727.85272237 -2239212.75931981,99727.70640463 -2239212.74490877,99727.5657098 -2239212.70222946,99727.4360447 -2239212.63292202,99727.4179182327 -2239212.61804601,99727.36560451 -2239212.60217682,99727.23593941 -2239212.53286938,99727.21781293 -2239212.51799336,99727.16549923 -2239212.50212417,99727.03583413 -2239212.43281673,99726.92218172 -2239212.33954461,99726.8770825589 -2239212.28459113,99726.82212907 -2239212.23949197,99726.72885695 -2239212.12583956,99726.65954951 -2239211.99617446,99726.6168702 -2239211.85547962,99726.60245916 -2239211.70916188,99726.60245916 -2239211.5090566,99726.60660
03423 -2239211.46701047,99726.5935520379 -2239211.49142213,99726.58725848 -2239211.5553217,99726.54457917 -2239211.69601653,99726.47527173 -2239211.82568163,99726.38199961 -2239211.93933404,99726.3270461269 -2239211.9844332,99726.28194697 -2239212.03938668,99726.16829455 -2239212.13265881,99726.03862945 -2239212.20196625,99725.89793462 -2239212.24464556,99725.75161688 -2239212.2590566,99725.65156424 -2239212.2590566,99725.5052465 -2239212.24464556,99725.36455166 -2239212.20196625,99725.23488656 -2239212.13265881,99725.12123415 -2239212.03938668,99725.0761349931 -2239211.9844332,99725.02118151 -2239211.93933404,99724.92790939 -2239211.82568163,99724.85860194 -2239211.69601653,99724.8427327449 -2239211.6437028,99724.82785674 -2239211.62557634,99724.7585493 -2239211.49591124,99724.71586999 -2239211.35521641,99724.70145895 -2239211.20889867,99724.70145895 -2239210.50853017,99724.71586999 -2239210.36221243,99724.7585493 -2239210.2215176,99724.80151159 -2239210.14114081),(99726.87
70825589 -2239210.93362735,99726.8959962418 -2239210.91058097,99726.8653413 -2239210.90128189,99726.80177481 -2239210.86730489,99726.80177481 -2239210.90874074,99726.7911658513 -2239211.0164553,99726.82212907 -2239210.97872651,99726.8770825589 -2239210.93362735))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-1.01 (#494)</desc>
+ <op name="buffer" arg1="a" arg2="1.01">
+ POLYGON ((99724.5415116 -2239210.07866999,99724.5415116 -2239209.9082143,99724.5609185 -2239209.7111731,99724.6183933 -2239209.521704,99724.6415642 -2239209.4783543,99724.6415642 -2239209.4079511,99724.6609711 -2239209.2109099,99724.7184459 -2239209.0214408,99724.8094364244 -2239208.85120953,99724.8184986 -2239208.8213356,99724.9118326 -2239208.6467199,99725.037439 -2239208.493668,99725.0923925052 -2239208.44856881,99725.1374917 -2239208.3936153,99725.19244517 -2239208.34851617,99725.2375443 -2239208.2935627,99725.2924978955 -2239208.24846343,99725.337597 -2239208.19351,99725.39255036 -2239208.14841096,99725.4376496 -2239208.0934574,99725.4926031603 -2239208.04835816,99725.5377022 -2239207.9934048,99725.6907542 -2239207.8677983,99725.8653698 -2239207.7744643,99725.8952440723 -2239207.76540204,99726.0654751 -2239207.6744116,99726.2549442 -2239207.6169368,99726.4519854 -2239207.59753,99727.4525118 -2239207.59753,99727.5025381 -2239207.60245714,99727.5525644 -2239207.5975
3,99727.64407656 -2239207.59753,99727.6625504 -2239207.4099623,99727.7200252 -2239207.2204933,99727.8133592 -2239207.0458776,99727.9389657 -2239206.8928257,99727.9939189892 -2239206.84772668,99728.0390183 -2239206.792773,99728.09397177 -2239206.74767387,99728.1390709 -2239206.6927204,99728.1940245825 -2239206.64762109,99728.2391236 -2239206.5926678,99728.2940769089 -2239206.54756877,99728.3391762 -2239206.4926151,99728.4922281 -2239206.3670087,99728.6537698364 -2239206.28066278,99728.7923861 -2239206.1669034,99728.9670017 -2239206.0735694,99728.9968758442 -2239206.06450717,99729.167107 -2239205.9735167,99729.3528016278 -2239205.91718687,99729.3634453 -2239205.80912,99729.4209201 -2239205.619651,99729.5142541 -2239205.4450353,99729.6398606 -2239205.2919834,99729.6948141603 -2239205.24688416,99729.7399132 -2239205.1919308,99729.7948667052 -2239205.14683161,99729.8399659 -2239205.0918781,99729.9930178 -2239204.9662717,99730.1545592497 -2239204.87992594,99730.2931757 -2239204.76
61664,99730.4677914 -2239204.6728324,99730.4976652713 -2239204.66377026,99730.6678967 -2239204.5727797,99730.8573657 -2239204.5153049,99731.0180600617 -2239204.49947786,99731.0681072 -2239204.4727271,99731.2575763 -2239204.4152523,99731.4546175 -2239204.3958454,99731.5250206377 -2239204.3958454,99731.5683705 -2239204.3726744,99731.5982447981 -2239204.36361213,99731.7554017157 -2239204.27960999,99731.7959194991 -2239204.24635789,99731.8291718013 -2239204.2058398,99731.9155175 -2239204.0442983,99732.041124 -2239203.8912464,99732.0960776663 -2239203.84614711,99732.1411767 -2239203.7911938,99732.2942286 -2239203.6655873,99732.4688442 -2239203.5722533,99732.6583133 -2239203.5147785,99732.8553545 -2239203.4953716,99733.1555124 -2239203.4953716,99733.3525537 -2239203.5147785,99733.5420227 -2239203.5722533,99733.7122537168 -2239203.66324364,99733.742128 -2239203.6723059,99733.9167436 -2239203.76564,99734.0553600971 -2239203.8793995,99734.2125173287 -2239203.96340176,99734.2423912 -2
239203.9724639,99734.4126222168 -2239204.06345424,99734.4424965 -2239204.0725165,99734.5151443635 -2239204.1113476,99734.5531854 -2239204.1150943,99734.7426544 -2239204.1725691,99734.9172701 -2239204.2659032,99734.9669580798 -2239204.30668106,99735.0534486 -2239204.3151996,99735.2429176 -2239204.3726744,99735.4175333 -2239204.4660085,99735.5705852 -2239204.5916149,99735.6961917 -2239204.7446668,99735.7895257 -2239204.9192825,99735.8470005 -2239205.1087515,99735.8664074 -2239205.3057928,99735.8664074 -2239205.806056,99735.8470005 -2239206.0030972,99735.7895257 -2239206.1925662,99735.7871029413 -2239206.19709886,99735.9177965 -2239206.266956,99736.0708484 -2239206.3925625,99736.1964549 -2239206.5456144,99736.2897889 -2239206.7202301,99736.2988511704 -2239206.7501044,99736.3898415 -2239206.9203353,99736.4473163 -2239207.1098044,99736.4667232 -2239207.3068456,99736.4667232 -2239207.4068983,99736.4617960304 -2239207.4569246,99736.4667232 -2239207.5069509,99736.4667232 -2239207.57
735392,99736.4898942 -2239207.6207038,99736.547369 -2239207.8101729,99736.5631959389 -2239207.97086704,99736.5899468 -2239208.0209144,99736.6474216 -2239208.2103835,99736.6632486227 -2239208.37107766,99736.6899995 -2239208.421125,99736.7474743 -2239208.610594,99736.7668811 -2239208.8076352,99736.7668811 -2239208.87803829,99736.7900521 -2239208.9213882,99736.8475269 -2239209.1108572,99736.8512736244 -2239209.14889828,99736.8901047 -2239209.2215461,99736.9475796 -2239209.4110152,99736.951326291 -2239209.44905612,99736.9901574 -2239209.521704,99737.0329471384 -2239209.66276292,99737.0713748 -2239209.6942997,99737.1969813 -2239209.8473516,99737.2903153 -2239210.0219673,99737.3477901 -2239210.2114363,99737.367197 -2239210.4084775,99737.367197 -2239210.41124683,99737.3970866 -2239210.4476674,99737.4904206 -2239210.6222831,99737.5019722663 -2239210.66036386,99737.5186388 -2239210.6692723,99737.6716907 -2239210.7948787,99737.7167900108 -2239210.84983238,99737.7717433 -2239210.894931
4,99737.8168423337 -2239210.94988471,99737.8573605503 -2239210.98313714,99738.018902 -2239211.0694829,99738.1719539 -2239211.1950893,99738.2170533011 -2239211.25004306,99738.2720065 -2239211.295142,99738.3171054434 -2239211.3500952,99738.3720592 -2239211.3951946,99738.4976657 -2239211.5482465,99738.5909997 -2239211.7228622,99738.6484745 -2239211.9123312,99738.6678813 -2239212.1093725,99738.6678813 -2239212.2094251,99738.6484745 -2239212.4064663,99738.6081004414 -2239212.53956179,99738.61726363 -2239212.55072717,99738.6722171 -2239212.5958263,99738.7978236 -2239212.7488782,99738.8911576 -2239212.9234939,99738.9486324 -2239213.1129629,99738.9680393 -2239213.3100042,99738.9680393 -2239213.4100568,99738.9486324 -2239213.607098,99738.9021769824 -2239213.76024105,99738.9486324 -2239213.9133841,99738.9680393 -2239214.1104253,99738.9680393 -2239214.3105306,99738.9486324 -2239214.5075718,99738.8911576 -2239214.6970409,99738.7978236 -2239214.8716565,99738.6722171 -2239215.0247084,9973
8.6172637911 -2239215.06980743,99738.5721645 -2239215.1247611,99738.462257725 -2239215.21495922,99738.3720592 -2239215.3248664,99738.2190073 -2239215.4504728,99738.2014247057 -2239215.45987089,99738.2367425085 -2239215.57629807,99738.2621522445 -2239215.60725993,99738.3720592 -2239215.6974582,99738.462257725 -2239215.80736538,99738.5721645 -2239215.8975635,99738.5757227977 -2239215.9018993,99738.7584604 -2239215.9018993,99738.9555016 -2239215.9213062,99739.1449707 -2239215.978781,99739.3152014914 -2239216.06977127,99739.345076 -2239216.0788336,99739.5088552031 -2239216.16637542,99739.6726345 -2239216.0788336,99739.8621035 -2239216.0213588,99740.0591448 -2239216.0019519,99740.1591974 -2239216.0019519,99740.2092237 -2239216.00687907,99740.25925 -2239216.0019519,99740.3593027 -2239216.0019519,99740.5563439 -2239216.0213588,99740.745813 -2239216.0788336,99740.9204286 -2239216.1721676,99741.0734805 -2239216.2977741,99741.199087 -2239216.450826,99741.292421 -2239216.6254417,99741.
3498958 -2239216.8149107,99741.3693027 -2239217.0119519,99741.3693027 -2239217.2120572,99741.3498958 -2239217.4090984,99741.292421 -2239217.5985675,99741.26925 -2239217.64191741,99741.26925 -2239217.7123204,99741.2498432 -2239217.9093617,99741.1923684 -2239218.0988307,99741.0990344 -2239218.2734464,99740.9734279 -2239218.4264983,99740.820376 -2239218.5521047,99740.6457603 -2239218.6454388,99740.4562913 -2239218.7029136,99740.3869959453 -2239218.70973857,99740.373112 -2239218.7266562,99740.2200601 -2239218.8522627,99740.0454445 -2239218.9455967,99740.0155699914 -2239218.95465903,99739.8453392 -2239219.0456493,99739.6558701 -2239219.1031241,99739.5865749089 -2239219.10994909,99739.5726909 -2239219.1268668,99739.419639 -2239219.2524732,99739.2580975504 -2239219.33881896,99739.1194811 -2239219.4525785,99738.9448654 -2239219.5459125,99738.8038065828 -2239219.5887023,99738.7722698 -2239219.62713,99738.7173161175 -2239219.67222931,99738.6722171 -2239219.7271826,99738.5191652 -22392
19.8527891,99738.3445495 -2239219.9461231,99738.1550805 -2239220.0035979,99737.9580393 -2239220.0230048,99737.8876361623 -2239220.0230048,99737.8442863 -2239220.0461758,99737.6548173 -2239220.1036506,99737.4941231253 -2239220.11947754,99737.4440758 -2239220.1462284,99737.2546067 -2239220.2037032,99737.0575655 -2239220.2231101,99736.9575128 -2239220.2231101,99736.7604716 -2239220.2037032,99736.5710026 -2239220.1462284,99736.5276526912 -2239220.1230574,99736.4572496 -2239220.1230574,99736.2602084 -2239220.1036506,99736.0707394 -2239220.0461758,99735.8961237 -2239219.9528417,99735.8220170434 -2239219.89202396,99735.6705288 -2239219.8460705,99735.4959131 -2239219.7527365,99735.3428612 -2239219.62713,99735.29776207 -2239219.57217653,99735.2428086 -2239219.5270774,99735.1172021 -2239219.3740254,99735.0238681 -2239219.1994098,99734.9663933 -2239219.0099407,99734.9469864 -2239218.8128995,99734.9469864 -2239218.7128469,99734.9519135732 -2239218.66282054,99734.9469864 -2239218.6127942
,99734.9469864 -2239218.54239114,99734.9238154 -2239218.4990413,99734.8810256616 -2239218.35798238,99734.842598 -2239218.3264456,99734.7169915 -2239218.1733937,99734.7075934665 -2239218.15581122,99734.5531854 -2239218.2026504,99734.3561441 -2239218.2220572,99734.2560915 -2239218.2220572,99734.2060652 -2239218.21713006,99734.1560389 -2239218.2220572,99734.153269497 -2239218.2220572,99734.1168489 -2239218.2519468,99733.9422333 -2239218.3452808,99733.7527642 -2239218.4027556,99733.555723 -2239218.4221625,99733.4556704 -2239218.4221625,99733.3962216239 -2239218.4163073,99733.3419174 -2239218.4453335,99733.1524484 -2239218.5028083,99732.9554071 -2239218.5222152,99732.8553545 -2239218.5222152,99732.6583133 -2239218.5028083,99732.4688442 -2239218.4453335,99732.4187968324 -2239218.41858262,99732.2581027 -2239218.4027556,99732.0686337 -2239218.3452808,99731.9959858341 -2239218.30644972,99731.9579448 -2239218.302703,99731.7684757 -2239218.2452282,99731.5938601 -2239218.1518942,99731.4
408082 -2239218.0262877,99731.3957091663 -2239217.97133439,99731.3407555 -2239217.9262351,99731.2151491 -2239217.7731832,99731.121815 -2239217.5985675,99731.0643402 -2239217.4090984,99731.0449334 -2239217.2120572,99731.0449334 -2239217.0119519,99731.0643402 -2239216.8149107,99731.121815 -2239216.6254417,99731.1485658751 -2239216.57539437,99731.1643929 -2239216.4147001,99731.2218677 -2239216.2252311,99731.2450386 -2239216.18188138,99731.2450386 -2239216.1114782,99731.2644455 -2239215.9144369,99731.3219203 -2239215.7249679,99731.3486711837 -2239215.6749205,99731.354945644 -2239215.61121495,99731.3486711837 -2239215.5475094,99731.3219203 -2239215.497462,99731.3128580278 -2239215.4675877,99731.2218677 -2239215.2973567,99731.2128054311 -2239215.26748241,99731.121815 -2239215.0972514,99731.1127527279 -2239215.0673771,99731.0217624 -2239214.8971461,99730.9642876 -2239214.7076771,99730.9484605738 -2239214.5469829,99730.9286978954 -2239214.51000958,99730.8149385 -2239214.3713933,9973
0.7377477001 -2239214.22697941,99730.5977179188 -2239214.15213197,99730.567844 -2239214.1430698,99730.3932284 -2239214.0497358,99730.3191216666 -2239213.98891804,99730.1676335 -2239213.9429646,99729.997402493 -2239213.85197417,99729.9675282 -2239213.8429119,99729.9174808437 -2239213.81616104,99729.7567866 -2239213.8003341,99729.5673176 -2239213.7428593,99729.4946695048 -2239213.7040281,99729.4566287 -2239213.7002814,99729.2671597 -2239213.6428066,99729.092544 -2239213.5494726,99728.9394921 -2239213.4238662,99728.8943929214 -2239213.36891268,99728.8394394 -2239213.3238135,99728.79434027 -2239213.26886003,99728.7393868 -2239213.2237609,99728.6461920537 -2239213.11020282,99728.5530909 -2239213.1193725,99728.4530382 -2239213.1193725,99728.255997 -2239213.0999656,99728.066528 -2239213.0424908,99728.0231780912 -2239213.0193198,99727.8527224 -2239213.0193198,99727.6556811 -2239212.9999129,99727.4662121 -2239212.9424381,99727.2959810832 -2239212.85144776,99727.2661068 -2239212.84238
55,99727.0958760086 -2239212.75139523,99727.0660015 -2239212.7423329,99726.8913859 -2239212.6489988,99726.738334 -2239212.5233924,99726.6932348052 -2239212.4684389,99726.6382813 -2239212.4233397,99726.5126749 -2239212.2702878,99726.4789537659 -2239212.20720004,99726.4657947 -2239212.2232344,99726.3127428 -2239212.3488409,99726.1381271 -2239212.4421749,99725.9486581 -2239212.4996497,99725.7516169 -2239212.5190566,99725.6515642 -2239212.5190566,99725.454523 -2239212.4996497,99725.265054 -2239212.4421749,99725.0904383 -2239212.3488409,99724.9373864 -2239212.2232344,99724.8922873825 -2239212.16828111,99724.8373337 -2239212.1231818,99724.7117273 -2239211.9701299,99724.6183933 -2239211.7955142,99724.6093311591 -2239211.76564033,99724.5183406 -2239211.5954089,99724.4608658 -2239211.4059399,99724.441459 -2239211.2088987,99724.441459 -2239210.5085302,99724.4608658 -2239210.3114889,99724.5183406 -2239210.1220199,99724.5415116 -2239210.07866999))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-1.1</desc>
+ <op name="buffer" arg1="a" arg2="1.1">
+ POLYGON ((99724.45151159 -2239210.0570456,99724.45151159 -2239209.90821432,99724.47264779 -2239209.69361496,99724.53524411 -2239209.48726254,99724.55156424 -2239209.45672972,99724.55156424 -2239209.4079511,99724.57270043 -2239209.19335175,99724.63529675 -2239208.98699933,99724.7262871367 -2239208.81676829,99724.73534939 -2239208.78689404,99724.83700031 -2239208.59671856,99724.97379942 -2239208.43002836,99725.0287529111 -2239208.38492919,99725.07385206 -2239208.32997572,99725.128805548 -2239208.28487656,99725.17390471 -2239208.22992307,99725.2288581827 -2239208.18482392,99725.27395735 -2239208.12987043,99725.3289108328 -2239208.08477127,99725.37400999 -2239208.02981779,99725.4289634811 -2239207.98471862,99725.47406263 -2239207.92976515,99725.64075284 -2239207.79296603,99725.83092832 -2239207.69131512,99725.8608025436 -2239207.68225287,99726.0310336 -2239207.59126248,99726.23738602 -2239207.52866615,99726.45198538 -2239207.50752996,99727.4525118 -2239207.50752996,99727.5
02538125 -2239207.51245712,99727.55256445 -2239207.50752996,99727.5629408061 -2239207.50752996,99727.57427971 -2239207.39240418,99727.63687603 -2239207.18605176,99727.73852694 -2239206.99587628,99727.87532605 -2239206.82918608,99727.9302795548 -2239206.7840869,99727.9753787 -2239206.72913344,99728.0303321742 -2239206.68403429,99728.07543134 -2239206.62908079,99728.1303848228 -2239206.58398163,99728.17548398 -2239206.52902815,99728.2304374628 -2239206.48392899,99728.27553662 -2239206.42897551,99728.44222683 -2239206.29217639,99728.6037683473 -2239206.20583065,99728.74238476 -2239206.09207111,99728.93256024 -2239205.9904202,99728.9624344654 -2239205.98135795,99729.13266552 -2239205.89036755,99729.2695322976 -2239205.84884947,99729.27517463 -2239205.7915619,99729.33777095 -2239205.58520948,99729.43942186 -2239205.395034,99729.57622098 -2239205.2283438,99729.6311744542 -2239205.18324465,99729.67627362 -2239205.12829115,99729.7312271028 -2239205.08319199,99729.77632626 -2239205.0
2823851,99729.94301647 -2239204.8914394,99730.1045579766 -2239204.80509367,99730.24317439 -2239204.69133411,99730.43334987 -2239204.5896832,99730.4632241149 -2239204.58062095,99730.63345516 -2239204.48963056,99730.83980758 -2239204.42703424,99730.9915507716 -2239204.41208883,99731.03366573 -2239204.38957792,99731.24001815 -2239204.32698159,99731.45461751 -2239204.3058454,99731.5033961238 -2239204.3058454,99731.53392894 -2239204.28952527,99731.5638031868 -2239204.28046302,99731.7054002625 -2239204.2047778,99731.7322799528 -2239204.18271821,99731.7543395289 -2239204.15583854,99731.84068528 -2239203.994297,99731.9774844 -2239203.8276068,99732.0324378828 -2239203.78250764,99732.07753704 -2239203.72755416,99732.24422724 -2239203.59075504,99732.43440273 -2239203.48910413,99732.64075515 -2239203.42650781,99732.8553545 -2239203.40537162,99733.15551243 -2239203.40537162,99733.37011178 -2239203.42650781,99733.5764642 -2239203.48910413,99733.7466952432 -2239203.58009452,99733.77656949
-2239203.58915677,99733.96674497 -2239203.69080769,99734.1053613588 -2239203.80456722,99734.2469584764 -2239203.88025245,99734.2768327 -2239203.8893147,99734.4470637803 -2239203.98030511,99734.47693799 -2239203.98936735,99734.5416536026 -2239204.02395857,99734.57074349 -2239204.02682367,99734.77709591 -2239204.08941999,99734.9672714 -2239204.1910709,99735.002776056 -2239204.22020882,99735.07100671 -2239204.22692895,99735.27735913 -2239204.28952527,99735.46753461 -2239204.39117618,99735.63422481 -2239204.5279753,99735.77102393 -2239204.6946655,99735.87267484 -2239204.88484098,99735.93527116 -2239205.0911934,99735.95640735 -2239205.30579276,99735.95640735 -2239205.80605597,99735.93527116 -2239206.02065533,99735.8950519575 -2239206.15324028,99735.96779782 -2239206.19212375,99736.13448802 -2239206.32892287,99736.27128714 -2239206.49561307,99736.37293805 -2239206.68578855,99736.3820002963 -2239206.71566277,99736.47299069 -2239206.88589383,99736.53558702 -2239207.09224626,99736.55
672321 -2239207.30684561,99736.55672321 -2239207.40689825,99736.5517960479 -2239207.45692457,99736.55672321 -2239207.50695089,99736.55672321 -2239207.55572952,99736.57304334 -2239207.58626233,99736.63563966 -2239207.79261475,99736.6505850566 -2239207.94435792,99736.67309598 -2239207.9864729,99736.7356923 -2239208.19282532,99736.7506376966 -2239208.34456849,99736.77314862 -2239208.38668347,99736.83574494 -2239208.59303589,99736.85688113 -2239208.80763525,99736.85688113 -2239208.85641386,99736.87320126 -2239208.88694668,99736.93579759 -2239209.09329911,99736.9386626941 -2239209.122389,99736.97325391 -2239209.18710461,99737.03585023 -2239209.39345703,99737.0387153344 -2239209.42254693,99737.07330655 -2239209.48726254,99737.1107700712 -2239209.61076322,99737.13501445 -2239209.63066007,99737.27181356 -2239209.79735027,99737.37346448 -2239209.98752575,99737.4360608 -2239210.19387817,99737.4539791828 -2239210.37580658,99737.47191885 -2239210.39766613,99737.57356976 -2239210.5878416
1,99737.5778688697 -2239210.60201388,99737.7353303 -2239210.73123914,99737.7804294535 -2239210.78619261,99737.83538295 -2239210.83129178,99737.8804821072 -2239210.88624526,99737.9073617975 -2239210.90830485,99738.06890331 -2239210.99465059,99738.23559352 -2239211.13144971,99738.2806926772 -2239211.18640319,99738.33564616 -2239211.23150235,99738.3807453172 -2239211.28645583,99738.4356988 -2239211.33155499,99738.57249792 -2239211.4982452,99738.67414883 -2239211.68842068,99738.73674515 -2239211.8947731,99738.75788134 -2239212.10937245,99738.75788134 -2239212.20942509,99738.73674515 -2239212.42402445,99738.7102974729 -2239212.51121076,99738.73585673 -2239212.5321867,99738.87265584 -2239212.69887691,99738.97430676 -2239212.88905239,99739.03690308 -2239213.09540481,99739.05803927 -2239213.31000416,99739.05803927 -2239213.41005681,99739.03690308 -2239213.62465616,99738.9957738532 -2239213.76024105,99739.03690308 -2239213.89582595,99739.05803927 -2239214.1104253,99739.05803927 -2239
214.31053059,99739.03690308 -2239214.52512994,99738.97430676 -2239214.73148236,99738.87265584 -2239214.92165784,99738.73585673 -2239215.08834805,99738.6809032472 -2239215.13344721,99738.63580409 -2239215.18840069,99738.5258971362 -2239215.27859899,99738.4356988 -2239215.38850598,99738.3057292327 -2239215.49516925,99738.3172807609 -2239215.53324953,99738.3257918344 -2239215.54362031,99738.4356988 -2239215.63381862,99738.5258971196 -2239215.74372559,99738.6089670129 -2239215.81189929,99738.75846041 -2239215.81189929,99738.97305977 -2239215.83303549,99739.17941219 -2239215.89563181,99739.3496432464 -2239215.9866222,99739.37951747 -2239215.99568445,99739.50885523 -2239216.06481692,99739.63819299 -2239215.99568445,99739.84454541 -2239215.93308813,99740.05914476 -2239215.91195194,99740.15919741 -2239215.91195194,99740.20922373 -2239215.9168791,99740.25925005 -2239215.91195194,99740.35930269 -2239215.91195194,99740.57390205 -2239215.93308813,99740.78025447 -2239215.99568445,99740.9
7042995 -2239216.09733536,99741.13712015 -2239216.23413448,99741.27391927 -2239216.40082468,99741.37557018 -2239216.59100016,99741.4381665 -2239216.79735258,99741.45930269 -2239217.01195194,99741.45930269 -2239217.21205722,99741.4381665 -2239217.42665658,99741.37557018 -2239217.633009,99741.35925005 -2239217.66354182,99741.35925005 -2239217.71232044,99741.33811386 -2239217.92691979,99741.27551754 -2239218.13327221,99741.17386662 -2239218.32344769,99741.03706751 -2239218.49013789,99740.87037731 -2239218.62693701,99740.68020183 -2239218.72858792,99740.4738494 -2239218.79118424,99740.4304621038 -2239218.79545752,99740.27006145 -2239218.92709494,99740.07988597 -2239219.02874585,99740.050011744 -2239219.0378081,99739.87978068 -2239219.12879849,99739.67342826 -2239219.19139481,99739.6300409638 -2239219.19566809,99739.46964031 -2239219.32730551,99739.3080987927 -2239219.41365125,99739.16948238 -2239219.52741079,99738.9793069 -2239219.6290617,99738.855806222 -2239219.66652523,99738.
83590937 -2239219.69076961,99738.7809558789 -2239219.73586877,99738.73585673 -2239219.79082225,99738.56916653 -2239219.92762136,99738.37899105 -2239220.02927227,99738.17263863 -2239220.0918686,99737.95803927 -2239220.11300479,99737.9092606432 -2239220.11300479,99737.87872783 -2239220.12932492,99737.67237541 -2239220.19192124,99737.5206322346 -2239220.20686664,99737.47851726 -2239220.22937756,99737.27216484 -2239220.29197388,99737.05756549 -2239220.31311007,99736.95751285 -2239220.31311007,99736.74291349 -2239220.29197388,99736.53656107 -2239220.22937756,99736.5060282537 -2239220.21305743,99736.45724963 -2239220.21305743,99736.24265028 -2239220.19192124,99736.03629786 -2239220.12932492,99735.84612238 -2239220.027674,99735.778968366 -2239219.97256213,99735.63608729 -2239219.92921963,99735.44591181 -2239219.82756872,99735.2792216 -2239219.69076961,99735.2341224342 -2239219.63581611,99735.17916896 -2239219.59071696,99735.04236985 -2239219.42402676,99734.94071893 -2239219.2338512
8,99734.87812261 -2239219.02749886,99734.85698642 -2239218.8128995,99734.85698642 -2239218.71284686,99734.8619135822 -2239218.66282054,99734.85698642 -2239218.61279422,99734.85698642 -2239218.5640156,99734.84066629 -2239218.53348278,99734.8032027694 -2239218.4099821,99734.77895839 -2239218.39008525,99734.6722951221 -2239218.26011568,99734.57074349 -2239218.29092103,99734.35614414 -2239218.31205722,99734.2560915 -2239218.31205722,99734.206065175 -2239218.30713006,99734.1887097995 -2239218.30883941,99734.16685025 -2239218.32677908,99733.97667477 -2239218.42842999,99733.77032235 -2239218.49102632,99733.555723 -2239218.51216251,99733.45567036 -2239218.51216251,99733.4144813942 -2239218.50810575,99733.37635892 -2239218.52848264,99733.1700065 -2239218.59107896,99732.95540714 -2239218.61221515,99732.8553545 -2239218.61221515,99732.64075515 -2239218.59107896,99732.43440273 -2239218.52848264,99732.3922877578 -2239218.50597172,99732.24054458 -2239218.49102632,99732.03419215 -2239218.4
2842999,99731.9694765374 -2239218.39383877,99731.94038665 -2239218.39097367,99731.73403423 -2239218.32837735,99731.54385875 -2239218.22672644,99731.37716854 -2239218.08992732,99731.3320693911 -2239218.03497385,99731.2771159 -2239217.98987468,99731.14031679 -2239217.82318448,99731.03866587 -2239217.633009,99730.97606955 -2239217.42665658,99730.95493336 -2239217.21205722,99730.95493336 -2239217.01195194,99730.97606955 -2239216.79735258,99731.03866587 -2239216.59100016,99731.0611767929 -2239216.54888519,99731.07612219 -2239216.39714201,99731.13871852 -2239216.19078959,99731.15503865 -2239216.16025677,99731.15503865 -2239216.11147815,99731.17617484 -2239215.8968788,99731.23877116 -2239215.69052638,99731.2612820825 -2239215.64841141,99731.2649456144 -2239215.61121494,99731.2612820828 -2239215.57401848,99731.23877116 -2239215.5319035,99731.2297089137 -2239215.50202928,99731.13871852 -2239215.33179822,99731.129656271 -2239215.30192399,99731.03866587 -2239215.13169293,99731.02960362
37 -2239215.10181871,99730.93861323 -2239214.93158765,99730.87601691 -2239214.72523523,99730.8610715134 -2239214.57349206,99730.8538657489 -2239214.56001102,99730.74010622 -2239214.42139463,99730.6715646238 -2239214.29316233,99730.5632767436 -2239214.23528126,99730.53340252 -2239214.22621901,99730.34322704 -2239214.12456809,99730.276073026 -2239214.06945622,99730.13319195 -2239214.02611372,99729.9629609068 -2239213.93512333,99729.93308666 -2239213.92606108,99729.8909716838 -2239213.90355016,99729.73922851 -2239213.88860476,99729.53287609 -2239213.82600844,99729.4681604841 -2239213.79141723,99729.43907058 -2239213.78855212,99729.23271816 -2239213.72595579,99729.04254268 -2239213.62430488,99728.87585248 -2239213.48750577,99728.8307533142 -2239213.43255227,99728.77579984 -2239213.38745312,99728.7307006948 -2239213.33249966,99728.67574719 -2239213.28740048,99728.6073273203 -2239213.20403063,99728.55309087 -2239213.20937245,99728.45303823 -2239213.20937245,99728.23843887 -2239213
.18823626,99728.03208645 -2239213.12563994,99728.0015536337 -2239213.10931981,99727.85272237 -2239213.10931981,99727.63812302 -2239213.08818362,99727.4317706 -2239213.0255873,99727.2615395585 -2239212.93459691,99727.23166531 -2239212.92553465,99727.0614342536 -2239212.83454426,99727.03156003 -2239212.82548201,99726.84138455 -2239212.7238311,99726.67469434 -2239212.58703198,99726.6295951911 -2239212.53207851,99726.5746417 -2239212.48697934,99726.4583176232 -2239212.34523804,99726.36274414 -2239212.42367317,99726.17256866 -2239212.52532408,99725.96621623 -2239212.58792041,99725.75161688 -2239212.6090566,99725.65156424 -2239212.6090566,99725.43696488 -2239212.58792041,99725.23061246 -2239212.52532408,99725.04043698 -2239212.42367317,99724.87374678 -2239212.28687406,99724.8286476041 -2239212.23192056,99724.77369414 -2239212.18682141,99724.63689502 -2239212.02013121,99724.53524411 -2239211.82995573,99724.5261818637 -2239211.80008151,99724.43519147 -2239211.62985045,99724.37259514
-2239211.42349802,99724.35145895 -2239211.20889867,99724.35145895 -2239210.50853017,99724.37259514 -2239210.29393082,99724.43519147 -2239210.0875784,99724.45151159 -2239210.0570456))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-1.5</desc>
+ <op name="buffer" arg1="a" arg2="1.5">
+POLYGON ((99723.95146 -2239211.2089, 99723.95146 -2239210.50853, 99723.98028 -2239210.21589, 99724.05151 -2239209.98109, 99724.05151 -2239209.90821, 99724.08033 -2239209.61558, 99724.15553 -2239209.3677, 99724.18039 -2239209.11532, 99724.26574 -2239208.83393, 99724.35674 -2239208.66369, 99724.3658 -2239208.63382, 99724.50441 -2239208.37449, 99724.69096 -2239208.14719, 99724.7459 -2239208.1021, 99724.79101 -2239208.04713, 99724.84597 -2239208.00203, 99724.89106 -2239207.94708, 99724.94601 -2239207.90199, 99724.99111 -2239207.84703, 99725.04609 -2239207.80191, 99725.09117 -2239207.74698, 99725.14611 -2239207.70189, 99725.19122 -2239207.64692, 99725.41852 -2239207.46038, 99725.67785 -2239207.32176, 99725.70776 -2239207.31269, 99725.87796 -2239207.22171, 99726.15935 -2239207.13635, 99726.45199 -2239207.10753, 99727.24471 -2239207.10753, 99727.26732 -2239207.03298, 99727.40594 -2239206.77365, 99727.59248 -2239206.54634, 99727.64746 -2239206.50122, 99727.69254 -2239206.44629, 9972
7.74748 -2239206.4012, 99727.79259 -2239206.34624, 99727.84755 -2239206.30113, 99727.89264 -2239206.24619, 99727.94757 -2239206.20111, 99727.99269 -2239206.14613, 99728.22 -2239205.95959, 99728.38155 -2239205.87324, 99728.52016 -2239205.75948, 99728.77949 -2239205.62087, 99728.80935 -2239205.61181, 99728.93391 -2239205.54523, 99728.96822 -2239205.43214, 99729.10683 -2239205.17281, 99729.29338 -2239204.9455, 99729.34833 -2239204.9004, 99729.39343 -2239204.84545, 99729.44838 -2239204.80035, 99729.49348 -2239204.7454, 99729.72079 -2239204.55885, 99729.88233 -2239204.47251, 99730.02095 -2239204.35875, 99730.28028 -2239204.22013, 99730.31014 -2239204.21107, 99730.48038 -2239204.12008, 99730.76177 -2239204.03472, 99730.87374 -2239204.02369, 99730.88059 -2239204.02003, 99731.16198 -2239203.93467, 99731.41243 -2239203.91001, 99731.44315 -2239203.89359, 99731.5081 -2239203.77207, 99731.69464 -2239203.54476, 99731.74959 -2239203.49966, 99731.79469 -2239203.44471, 99732.022 -2239203.25
817, 99732.28133 -2239203.11955, 99732.56272 -2239203.03419, 99732.85535 -2239203.00537, 99733.15551 -2239203.00537, 99733.44815 -2239203.03419, 99733.72954 -2239203.11955, 99733.89976 -2239203.21054, 99733.92964 -2239203.2196, 99734.18897 -2239203.35822, 99734.32761 -2239203.47199, 99734.4 -2239203.51069, 99734.42991 -2239203.51976, 99734.60016 -2239203.61077, 99734.63001 -2239203.61982, 99734.66893 -2239203.64062, 99734.93017 -2239203.71987, 99735.14389 -2239203.8341, 99735.14904 -2239203.83461, 99735.43043 -2239203.91997, 99735.68976 -2239204.05859, 99735.91707 -2239204.24513, 99736.10361 -2239204.47244, 99736.24223 -2239204.73177, 99736.32759 -2239205.01316, 99736.35641 -2239205.30579, 99736.35641 -2239205.80606, 99736.33909 -2239205.98187, 99736.41733 -2239206.04608, 99736.60387 -2239206.27338, 99736.74249 -2239206.53272, 99736.75155 -2239206.56258, 99736.84254 -2239206.73282, 99736.9279 -2239207.01421, 99736.95672 -2239207.30685, 99736.95672 -2239207.4069, 99736.95179
-2239207.45692, 99736.95275 -2239207.46666, 99737.02795 -2239207.71458, 99737.03898 -2239207.82653, 99737.04265 -2239207.8334, 99737.12801 -2239208.11479, 99737.13904 -2239208.22676, 99737.1427 -2239208.23361, 99737.22806 -2239208.515, 99737.25291 -2239208.76738, 99737.32199 -2239208.99507, 99737.34281 -2239209.03403, 99737.42204 -2239209.29524, 99737.44286 -2239209.33419, 99737.46408 -2239209.40414, 99737.6044 -2239209.57512, 99737.74302 -2239209.83445, 99737.82837 -2239210.11584, 99737.84096 -2239210.24364, 99737.89745 -2239210.34932, 99738.01817 -2239210.4484, 99738.06325 -2239210.50333, 99738.11823 -2239210.54845, 99738.14922 -2239210.58621, 99738.29113 -2239210.66206, 99738.51844 -2239210.84861, 99738.56354 -2239210.90357, 99738.61849 -2239210.94866, 99738.66359 -2239211.00361, 99738.71854 -2239211.04871, 99738.90509 -2239211.27602, 99739.0437 -2239211.53535, 99739.12906 -2239211.81674, 99739.15788 -2239212.10937, 99739.15788 -2239212.20943, 99739.13946 -2239212.39649,
99739.20524 -2239212.47665, 99739.34386 -2239212.73598, 99739.42922 -2239213.01737, 99739.45804 -2239213.31, 99739.45804 -2239213.41006, 99739.42922 -2239213.70269, 99739.41176 -2239213.76024, 99739.42922 -2239213.81779, 99739.45804 -2239214.11043, 99739.45804 -2239214.31053, 99739.42922 -2239214.60317, 99739.34386 -2239214.88456, 99739.20524 -2239215.14389, 99739.0187 -2239215.37119, 99738.96375 -2239215.41629, 99738.95173 -2239215.43093, 99739.0511 -2239215.44072, 99739.33249 -2239215.52608, 99739.50273 -2239215.61707, 99739.50886 -2239215.61893, 99739.76651 -2239215.54077, 99740.05914 -2239215.51195, 99740.1592 -2239215.51195, 99740.20922 -2239215.51688, 99740.25925 -2239215.51195, 99740.3593 -2239215.51195, 99740.65194 -2239215.54077, 99740.93333 -2239215.62613, 99741.19266 -2239215.76475, 99741.41996 -2239215.95129, 99741.60651 -2239216.1786, 99741.74512 -2239216.43793, 99741.83048 -2239216.71932, 99741.8593 -2239217.01195, 99741.8593 -2239217.21206, 99741.83048 -223921
7.50469, 99741.75529 -2239217.75257, 99741.73043 -2239218.00496, 99741.64507 -2239218.28635, 99741.50645 -2239218.54568, 99741.31991 -2239218.77298, 99741.09261 -2239218.95952, 99740.83328 -2239219.09814, 99740.6046 -2239219.16751, 99740.49229 -2239219.25968, 99740.23296 -2239219.3983, 99740.20308 -2239219.40737, 99740.03285 -2239219.49835, 99739.80418 -2239219.56772, 99739.69187 -2239219.65989, 99739.53032 -2239219.74624, 99739.39171 -2239219.86, 99739.13238 -2239219.99861, 99739.06303 -2239220.01965, 99739.0187 -2239220.07366, 99738.79139 -2239220.26021, 99738.53206 -2239220.39882, 99738.25067 -2239220.48418, 99737.99834 -2239220.50903, 99737.75041 -2239220.58424, 99737.63844 -2239220.59527, 99737.63159 -2239220.59893, 99737.3502 -2239220.68429, 99737.05757 -2239220.71311, 99736.95751 -2239220.71311, 99736.66488 -2239220.68429, 99736.417 -2239220.6091, 99736.16461 -2239220.58424, 99735.88322 -2239220.49888, 99735.62389 -2239220.36026, 99735.58764 -2239220.33051, 99735.4830
1 -2239220.29877, 99735.22368 -2239220.16016, 99734.99638 -2239219.97361, 99734.95127 -2239219.91865, 99734.89633 -2239219.87356, 99734.70978 -2239219.64625, 99734.57117 -2239219.38692, 99734.48581 -2239219.10553, 99734.45699 -2239218.8129, 99734.45699 -2239218.71285, 99734.45806 -2239218.70202, 99734.35614 -2239218.71206, 99734.2905 -2239218.71206, 99734.12975 -2239218.79798, 99733.84836 -2239218.88334, 99733.55572 -2239218.91216, 99733.48285 -2239218.91216, 99733.24804 -2239218.98339, 99732.95541 -2239219.01222, 99732.85535 -2239219.01222, 99732.56272 -2239218.98339, 99732.28133 -2239218.89803, 99732.27448 -2239218.89437, 99732.16251 -2239218.88334, 99731.88112 -2239218.79798, 99731.8422 -2239218.77718, 99731.58096 -2239218.69793, 99731.32163 -2239218.55931, 99731.09433 -2239218.37277, 99731.04924 -2239218.31783, 99730.99427 -2239218.27272, 99730.80773 -2239218.04541, 99730.66911 -2239217.78608, 99730.58376 -2239217.50469, 99730.55493 -2239217.21206, 99730.55493 -2239217.0
1195, 99730.58376 -2239216.71932, 99730.66911 -2239216.43793, 99730.67278 -2239216.43105, 99730.68381 -2239216.31911, 99730.759 -2239216.07123, 99730.78386 -2239215.81884, 99730.84317 -2239215.62332, 99730.76917 -2239215.48487, 99730.76012 -2239215.45502, 99730.66911 -2239215.28477, 99730.66004 -2239215.25486, 99730.56906 -2239215.08466, 99730.4837 -2239214.80327, 99730.47622 -2239214.72734, 99730.40752 -2239214.64362, 99730.38225 -2239214.59635, 99730.38033 -2239214.59577, 99730.121 -2239214.45716, 99730.08474 -2239214.4274, 99729.98012 -2239214.39567, 99729.80988 -2239214.30467, 99729.78001 -2239214.29561, 99729.77316 -2239214.29195, 99729.66119 -2239214.28092, 99729.3798 -2239214.19556, 99729.34088 -2239214.17476, 99729.07964 -2239214.09551, 99728.82031 -2239213.95689, 99728.59301 -2239213.77035, 99728.54792 -2239213.7154, 99728.49296 -2239213.6703, 99728.44786 -2239213.61534, 99728.43888 -2239213.60798, 99728.1604 -2239213.58055, 99727.92559 -2239213.50932, 99727.85272 -
2239213.50932, 99727.56009 -2239213.4805, 99727.2787 -2239213.39514, 99727.1085 -2239213.30416, 99727.07859 -2239213.29509, 99726.90834 -2239213.20408, 99726.87849 -2239213.19503, 99726.61916 -2239213.05642, 99726.39185 -2239212.86987, 99726.38593 -2239212.86265, 99726.32564 -2239212.89488, 99726.04425 -2239212.98023, 99725.75162 -2239213.00906, 99725.65156 -2239213.00906, 99725.35893 -2239212.98023, 99725.07754 -2239212.89488, 99724.81821 -2239212.75626, 99724.5909 -2239212.56972, 99724.54578 -2239212.51474, 99724.49085 -2239212.46966, 99724.30431 -2239212.24236, 99724.16569 -2239211.98303, 99724.15662 -2239211.95315, 99724.06564 -2239211.78292, 99723.98028 -2239211.50153, 99723.95146 -2239211.2089))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-2</desc>
+ <op name="buffer" arg1="a" arg2="2">
+POLYGON ((99723.45146 -2239211.2089, 99723.45146 -2239210.50853, 99723.48989 -2239210.11835, 99723.55151 -2239209.91521, 99723.55151 -2239209.90821, 99723.58994 -2239209.51803, 99723.66513 -2239209.27016, 99723.68999 -2239209.01777, 99723.80381 -2239208.64258, 99723.8948 -2239208.47236, 99723.90386 -2239208.44248, 99724.08868 -2239208.09671, 99724.3374 -2239207.79363, 99724.39237 -2239207.74852, 99724.43746 -2239207.69358, 99724.49241 -2239207.64848, 99724.53751 -2239207.59353, 99724.59245 -2239207.54844, 99724.63756 -2239207.49347, 99724.69251 -2239207.44837, 99724.73761 -2239207.39342, 99724.79258 -2239207.34831, 99724.83767 -2239207.29337, 99725.14074 -2239207.04464, 99725.48651 -2239206.85982, 99725.5164 -2239206.85075, 99725.68662 -2239206.75977, 99726.0618 -2239206.64596, 99726.45199 -2239206.60753, 99726.93051 -2239206.60753, 99726.9902 -2239206.49586, 99727.23893 -2239206.19279, 99727.29389 -2239206.14769, 99727.33898 -2239206.09274, 99727.39394 -2239206.04764, 99727
.43904 -2239205.99268, 99727.49399 -2239205.94758, 99727.53909 -2239205.89263, 99727.59404 -2239205.84754, 99727.63914 -2239205.79258, 99727.94221 -2239205.54385, 99728.10377 -2239205.4575, 99728.24237 -2239205.34375, 99728.53479 -2239205.18745, 99728.6911 -2239204.89502, 99728.93982 -2239204.59195, 99728.9948 -2239204.54683, 99729.03988 -2239204.4919, 99729.09481 -2239204.44682, 99729.13993 -2239204.39184, 99729.443 -2239204.14312, 99729.60454 -2239204.05678, 99729.74316 -2239203.94301, 99730.08893 -2239203.75819, 99730.11883 -2239203.74912, 99730.28904 -2239203.65814, 99730.66423 -2239203.54433, 99730.76844 -2239203.53407, 99731.06444 -2239203.44427, 99731.13947 -2239203.43688, 99731.34109 -2239203.19121, 99731.39604 -2239203.14611, 99731.44114 -2239203.09116, 99731.74421 -2239202.84243, 99732.08999 -2239202.65761, 99732.46517 -2239202.5438, 99732.85535 -2239202.50537, 99733.15551 -2239202.50537, 99733.54569 -2239202.5438, 99733.92088 -2239202.65761, 99734.09114 -2239202.7
4862, 99734.12098 -2239202.75767, 99734.46676 -2239202.94249, 99734.59911 -2239203.0511, 99734.62125 -2239203.05782, 99734.79151 -2239203.14883, 99734.82135 -2239203.15788, 99734.86028 -2239203.17869, 99735.12151 -2239203.25793, 99735.33065 -2239203.36972, 99735.62177 -2239203.45803, 99735.96755 -2239203.64285, 99736.27062 -2239203.89158, 99736.51935 -2239204.19465, 99736.70417 -2239204.54043, 99736.81798 -2239204.91561, 99736.85641 -2239205.30579, 99736.85641 -2239205.79675, 99737.01961 -2239205.9956, 99737.20443 -2239206.34137, 99737.2135 -2239206.37127, 99737.30448 -2239206.54148, 99737.41829 -2239206.91666, 99737.45672 -2239207.30685, 99737.45672 -2239207.4069, 99737.4562 -2239207.41217, 99737.51835 -2239207.61703, 99737.52862 -2239207.72126, 99737.6184 -2239208.01724, 99737.62867 -2239208.12147, 99737.71845 -2239208.41745, 99737.74331 -2239208.66984, 99737.78392 -2239208.80372, 99737.80475 -2239208.84269, 99737.88399 -2239209.10392, 99737.9048 -2239209.14285, 99737.9115
1 -2239209.16498, 99738.02014 -2239209.29734, 99738.20496 -2239209.64311, 99738.31877 -2239210.0183, 99738.32231 -2239210.05429, 99738.37173 -2239210.09484, 99738.41684 -2239210.14981, 99738.47006 -2239210.19349, 99738.56892 -2239210.24633, 99738.87199 -2239210.49505, 99738.91711 -2239210.55003, 99738.97204 -2239210.59511, 99739.01714 -2239210.65006, 99739.07209 -2239210.69516, 99739.32082 -2239210.99823, 99739.50564 -2239211.34401, 99739.61945 -2239211.71919, 99739.65788 -2239212.10937, 99739.65788 -2239212.20943, 99739.65302 -2239212.2588, 99739.8058 -2239212.54464, 99739.91961 -2239212.91982, 99739.95804 -2239213.31, 99739.95804 -2239213.41006, 99739.92355 -2239213.76024, 99739.95804 -2239214.11043, 99739.95804 -2239214.31053, 99739.91961 -2239214.70071, 99739.81799 -2239215.0357, 99740.05914 -2239215.01195, 99740.1592 -2239215.01195, 99740.20923 -2239215.01688, 99740.25925 -2239215.01195, 99740.3593 -2239215.01195, 99740.74948 -2239215.05038, 99741.12467 -2239215.16419,
99741.47044 -2239215.34901, 99741.77352 -2239215.59774, 99742.02224 -2239215.90081, 99742.20706 -2239216.24659, 99742.32087 -2239216.62177, 99742.3593 -2239217.01195, 99742.3593 -2239217.21206, 99742.32087 -2239217.60224, 99742.24568 -2239217.85011, 99742.22082 -2239218.1025, 99742.10701 -2239218.47769, 99741.92219 -2239218.82346, 99741.67346 -2239219.12653, 99741.37039 -2239219.37526, 99741.02462 -2239219.56008, 99740.84376 -2239219.61494, 99740.77007 -2239219.67542, 99740.4243 -2239219.86024, 99740.39442 -2239219.8693, 99740.2242 -2239219.96029, 99740.04334 -2239220.01515, 99739.96965 -2239220.07563, 99739.80811 -2239220.16197, 99739.6695 -2239220.27573, 99739.34642 -2239220.44841, 99739.06918 -2239220.67594, 99738.72341 -2239220.86076, 99738.34822 -2239220.97458, 99738.09586 -2239220.99943, 99737.84796 -2239221.07463, 99737.74373 -2239221.0849, 99737.44775 -2239221.17468, 99737.05757 -2239221.21311, 99736.95751 -2239221.21311, 99736.56733 -2239221.17468, 99736.31946 -2239
221.09949, 99736.06707 -2239221.07463, 99735.69188 -2239220.96082, 99735.3514 -2239220.77883, 99735.29167 -2239220.76071, 99734.9459 -2239220.57589, 99734.64283 -2239220.32717, 99734.59773 -2239220.27221, 99734.54277 -2239220.22711, 99734.29405 -2239219.92404, 99734.10923 -2239219.57827, 99734.03865 -2239219.3456, 99733.9459 -2239219.37373, 99733.55572 -2239219.41216, 99733.54874 -2239219.41216, 99733.34559 -2239219.47379, 99732.95541 -2239219.51222, 99732.85535 -2239219.51222, 99732.46517 -2239219.47379, 99732.16918 -2239219.384, 99732.06496 -2239219.37373, 99731.68978 -2239219.25992, 99731.65085 -2239219.23911, 99731.38962 -2239219.15987, 99731.04385 -2239218.97505, 99730.74077 -2239218.72632, 99730.69568 -2239218.67137, 99730.64072 -2239218.62627, 99730.39199 -2239218.3232, 99730.20717 -2239217.97742, 99730.09336 -2239217.60224, 99730.05493 -2239217.21206, 99730.05493 -2239217.01195, 99730.09336 -2239216.62177, 99730.18316 -2239216.32575, 99730.19342 -2239216.22156, 99730
.26861 -2239215.97368, 99730.29347 -2239215.7213, 99730.30719 -2239215.67607, 99730.29818 -2239215.64638, 99730.20717 -2239215.47611, 99730.1981 -2239215.44622, 99730.10712 -2239215.276, 99730.01224 -2239214.96324, 99729.84854 -2239214.87574, 99729.78878 -2239214.85761, 99729.6417 -2239214.779, 99729.56365 -2239214.77131, 99729.18846 -2239214.6575, 99729.14953 -2239214.63669, 99728.8883 -2239214.55745, 99728.54253 -2239214.37263, 99728.23946 -2239214.1239, 99728.2077 -2239214.08521, 99728.06286 -2239214.07094, 99727.85972 -2239214.00932, 99727.85272 -2239214.00932, 99727.46254 -2239213.97089, 99727.08736 -2239213.85708, 99726.91714 -2239213.7661, 99726.88725 -2239213.75703, 99726.717 -2239213.66603, 99726.68714 -2239213.65697, 99726.34137 -2239213.47215, 99726.28616 -2239213.42684, 99726.1418 -2239213.47063, 99725.75162 -2239213.50906, 99725.65156 -2239213.50906, 99725.26138 -2239213.47063, 99724.8862 -2239213.35682, 99724.54042 -2239213.172, 99724.23735 -2239212.92327, 9972
4.19225 -2239212.86832, 99724.1373 -2239212.82322, 99723.88857 -2239212.52014, 99723.70375 -2239212.17437, 99723.69469 -2239212.14449, 99723.6037 -2239211.97427, 99723.48989 -2239211.59908, 99723.45146 -2239211.2089))
+</op>
+ </test>
+ <test>
+ <desc>buffer-5</desc>
+ <op name="buffer" arg1="a" arg2="5">
+POLYGON ((99720.45146 -2239211.2089, 99720.45146 -2239210.50853, 99720.54753 -2239209.53308, 99720.60814 -2239209.33328, 99720.64759 -2239208.93276, 99720.72278 -2239208.68488, 99720.74764 -2239208.4325, 99721.03217 -2239207.49453, 99721.12316 -2239207.32431, 99721.13222 -2239207.29443, 99721.59427 -2239206.42999, 99722.21608 -2239205.67231, 99722.27106 -2239205.62719, 99722.31614 -2239205.57226, 99722.37109 -2239205.52716, 99722.41619 -2239205.47221, 99722.47112 -2239205.42713, 99722.51624 -2239205.37215, 99722.57119 -2239205.32705, 99722.61629 -2239205.2721, 99722.67127 -2239205.22698, 99722.71635 -2239205.17205, 99723.47403 -2239204.55023, 99724.33846 -2239204.08818, 99724.36835 -2239204.07911, 99724.53857 -2239203.98813, 99725.47653 -2239203.7036, 99725.49258 -2239203.70202, 99725.51782 -2239203.67126, 99726.2755 -2239203.04944, 99726.39661 -2239202.98471, 99726.8185 -2239202.47063, 99726.87346 -2239202.42553, 99726.91856 -2239202.37057, 99726.97351 -2239202.32547, 99727
.01861 -2239202.27052, 99727.77629 -2239201.64871, 99727.93782 -2239201.56237, 99728.07645 -2239201.4486, 99728.94088 -2239200.98655, 99728.97078 -2239200.97748, 99729.14099 -2239200.8865, 99729.58577 -2239200.75158, 99730.0775 -2239200.34802, 99730.94194 -2239199.88597, 99731.8799 -2239199.60145, 99732.85535 -2239199.50537, 99733.15551 -2239199.50537, 99734.13096 -2239199.60145, 99735.06893 -2239199.88597, 99735.2392 -2239199.97698, 99735.26903 -2239199.98603, 99736.12018 -2239200.44097, 99736.26956 -2239200.48629, 99736.47875 -2239200.5981, 99736.76982 -2239200.6864, 99737.63426 -2239201.14844, 99738.39194 -2239201.77026, 99739.01376 -2239202.52794, 99739.47581 -2239203.39238, 99739.76033 -2239204.33034, 99739.8158 -2239204.89347, 99739.97607 -2239205.19332, 99739.98514 -2239205.22321, 99740.07612 -2239205.39343, 99740.36065 -2239206.33139, 99740.41469 -2239206.88008, 99740.4607 -2239207.03176, 99740.47097 -2239207.13598, 99740.56075 -2239207.43197, 99740.57101 -2239207.53
616, 99740.66081 -2239207.83218, 99740.66951 -2239207.92055, 99740.848 -2239208.25447, 99740.99331 -2239208.37373, 99741.03843 -2239208.42871, 99741.09336 -2239208.47379, 99741.13844 -2239208.52872, 99741.19342 -2239208.57384, 99741.81523 -2239209.33152, 99742.27728 -2239210.19596, 99742.56181 -2239211.13392, 99742.5926 -2239211.44657, 99742.86197 -2239212.33455, 99742.90074 -2239212.72824, 99743.13715 -2239212.8546, 99743.89484 -2239213.47642, 99744.51665 -2239214.2341, 99744.9787 -2239215.09853, 99745.26323 -2239216.0365, 99745.3593 -2239217.01195, 99745.3593 -2239217.21206, 99745.26323 -2239218.18751, 99745.18804 -2239218.43539, 99745.16318 -2239218.68777, 99744.87865 -2239219.62574, 99744.4166 -2239220.49017, 99743.79478 -2239221.24785, 99743.0371 -2239221.86967, 99742.17267 -2239222.33172, 99742.08305 -2239222.3589, 99741.57235 -2239222.63188, 99741.54248 -2239222.64094, 99741.40242 -2239222.7158, 99741.33621 -2239222.77014, 99741.01312 -2239222.94283, 99740.73589 -2239
223.17035, 99739.87146 -2239223.6324, 99738.93349 -2239223.91693, 99738.68112 -2239223.94179, 99738.43323 -2239224.01698, 99738.32904 -2239224.02724, 99738.03302 -2239224.11704, 99737.05757 -2239224.21311, 99736.95751 -2239224.21311, 99735.98206 -2239224.11704, 99735.73415 -2239224.04184, 99735.4818 -2239224.01698, 99734.54383 -2239223.73246, 99734.20335 -2239223.55047, 99734.14362 -2239223.53235, 99733.27919 -2239223.0703, 99732.56422 -2239222.48354, 99731.8799 -2239222.41614, 99731.58392 -2239222.32636, 99731.47969 -2239222.31609, 99730.54173 -2239222.03156, 99730.50281 -2239222.01076, 99730.24157 -2239221.93151, 99729.37713 -2239221.46946, 99728.61945 -2239220.84764, 99728.57435 -2239220.79269, 99728.5194 -2239220.74759, 99727.89759 -2239219.98991, 99727.43554 -2239219.12547, 99727.15101 -2239218.18751, 99727.05493 -2239217.21206, 99727.05493 -2239217.01195, 99727.05953 -2239216.96524, 99726.98147 -2239216.92351, 99726.87727 -2239216.91325, 99725.93931 -2239216.62872, 997
25.76905 -2239216.53772, 99725.7392 -2239216.52866, 99725.70253 -2239216.50906, 99725.65156 -2239216.50906, 99724.67611 -2239216.41298, 99723.73815 -2239216.12845, 99722.87371 -2239215.6664, 99722.11603 -2239215.04459, 99722.07093 -2239214.98964, 99722.01598 -2239214.94454, 99721.39416 -2239214.18686, 99720.93211 -2239213.32242, 99720.92305 -2239213.29255, 99720.83206 -2239213.12232, 99720.54753 -2239212.18435, 99720.45146 -2239211.2089))
+ </op>
+ </test>
+ <test>
+ <desc>buffer-10</desc>
+ <op name="buffer" arg1="a" arg2="10">
+ POLYGON((99739.3044617493 -2239228.93117449,99739.008469 -2239229.020963,99737.057565 -2239229.21311,99736.957513 -2239229.21311,99735.00661 -2239229.020963,99734.7587215452 -2239228.94576679,99734.506346 -2239228.92091,99732.630415 -2239228.351853,99732.2899489618 -2239228.16987015,99732.230205 -2239228.151747,99730.501337 -2239227.227648,99730.4848796373 -2239227.2141418,99728.62831 -2239226.650958,99728.5893723796 -2239226.63014541,99728.328152 -2239226.550905,99726.599284 -2239225.626806,99725.083918 -2239224.383178,99725.0388167068 -2239224.32822188,99724.983866 -2239224.283125,99723.740237 -2239222.76776,99722.8223261684 -2239221.05046925,99721.82473 -2239220.747852,99720.095862 -2239219.823753,99718.580496 -2239218.580124,99718.5353971293 -2239218.52517087,99718.480444 -2239218.480072,99717.236815 -2239216.964706,99716.312716 -2239215.235838,99716.3036531494 -2239215.20596176,99716.212664 -2239215.035733,99715.643606 -2239213.159802,99715.451459 -2239211.208899,
99715.451459 -2239210.50853,99715.643606 -2239208.557627,99715.7042101752 -2239208.357842,99715.743659 -2239207.957311,99715.8188539234 -2239207.70942636,99715.843711 -2239207.457048,99716.412769 -2239205.581117,99716.5037597346 -2239205.41088527,99716.512822 -2239205.381011,99717.436921 -2239203.652143,99718.680549 -2239202.136778,99718.7355025838 -2239202.09167879,99718.780602 -2239202.036725,99718.8355551293 -2239201.99162613,99718.880654 -2239201.936673,99718.935607786 -2239201.89157358,99718.980707 -2239201.83662,99719.0356606586 -2239201.79152069,99719.08076 -2239201.736567,99719.1357131293 -2239201.69146813,99719.180812 -2239201.636515,99720.696178 -2239200.392886,99722.425046 -2239199.468787,99722.4549222379 -2239199.45972415,99722.625151 -2239199.368735,99723.0271739372 -2239199.24678256,99723.282971 -2239198.935093,99723.3379241293 -2239198.88999413,99723.383023 -2239198.835041,99723.437976786 -2239198.78994158,99723.483076 -2239198.734988,99724.998441 -2239197.491
36,99725.1599836931 -2239197.40501365,99725.298599 -2239197.291255,99727.027467 -2239196.367155,99727.0573455502 -2239196.35809145,99727.1672091138 -2239196.29936816,99727.299652 -2239196.190675,99729.02852 -2239195.266576,99730.904451 -2239194.697519,99732.855355 -2239194.505372,99733.155512 -2239194.505372,99735.106416 -2239194.697519,99736.982347 -2239195.266576,99737.1525800191 -2239195.35756742,99737.182452 -2239195.366629,99738.0336074759 -2239195.82158098,99738.182978 -2239195.866892,99738.3921436726 -2239195.97869336,99738.683242 -2239196.066997,99740.41211 -2239196.991097,99741.927475 -2239198.234725,99743.171103 -2239199.75009,99744.095203 -2239201.478958,99744.66426 -2239203.35489,99744.6723060104 -2239203.43658259,99744.695519 -2239203.480011,99745.264576 -2239205.355942,99745.3020732906 -2239205.73665892,99745.972577 -2239206.55367,99746.896677 -2239208.282538,99747.3895739426 -2239209.90740274,99747.430371 -2239209.940884,99748.673999 -2239211.45625,99749.59809
8 -2239213.185118,99750.167155 -2239215.061049,99750.359303 -2239217.011952,99750.359303 -2239217.212057,99750.167155 -2239219.16296,99750.0919601843 -2239219.41084441,99750.067103 -2239219.663224,99749.498045 -2239221.539155,99748.573946 -2239223.268023,99747.330318 -2239224.783388,99745.814952 -2239226.027017,99744.086084 -2239226.951116,99744.0485605807 -2239226.9624986,99743.7909773231 -2239227.10017983,99743.513742 -2239227.327701,99741.784874 -2239228.2518,99739.908942 -2239228.820858,99739.6565636369 -2239228.84571508,99739.408679 -2239228.92091,99739.3044617493 -2239228.93117449))
+ </op>
+ </test>
+</case>
+</run>
Deleted: branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
--- branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml 2011-12-09 10:04:35 UTC (rev 3536)
+++ branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml 2011-12-09 10:12:04 UTC (rev 3537)
@@ -1,19 +0,0 @@
-<run>
-<precisionModel type="FLOATING"/>
-<resultMatcher>com.vividsolutions.jtstest.testrunner.BufferResultMatcher</resultMatcher>
-<case>
- <desc>GEOS 3.3.1 produces rectangle buffer, GEOS 3.2.0 fine (#494)</desc>
- <a>
- POLYGON ((99736.4572496327 -2239219.11305743, 99736.6573549178 -2239219.11305743, 99736.6573549178 -2239219.01300479, 99736.5573022753 -2239219.01300479, 99736.5573022753 -2239218.8128995, 99736.6573549178 -2239218.8128995, 99736.6573549178 -2239218.91295215, 99736.7574075604 -2239218.91295215, 99736.7574075604 -2239219.01300479, 99736.8574602029 -2239219.01300479, 99736.8574602029 -2239219.11305743, 99736.9575128455 -2239219.11305743, 99736.9575128455 -2239219.21311007, 99737.057565488 -2239219.21311007, 99737.057565488 -2239219.01300479, 99737.2576707731 -2239219.01300479, 99737.2576707731 -2239219.11305743, 99737.4577760582 -2239219.11305743, 99737.4577760582 -2239219.01300479, 99737.958039271 -2239219.01300479, 99737.958039271 -2239218.91295215, 99738.0580919136 -2239218.91295215, 99738.0580919136 -2239218.51274158, 99738.1581445561 -2239218.51274158, 99738.1581445561 -2239218.61279422, 99738.3582498412 -2239218.61279422, 99738.3582498412 -2239218.41268893, 99738.458
3024838 -2239218.41268893, 99738.4583024838 -2239218.61279422, 99738.5583551263 -2239218.61279422, 99738.5583551263 -2239218.41268893, 99738.6584077689 -2239218.41268893, 99738.6584077689 -2239218.31263629, 99738.4583024838 -2239218.31263629, 99738.4583024838 -2239218.11253101, 99738.5583551263 -2239218.11253101, 99738.5583551263 -2239218.21258365, 99738.6584077689 -2239218.21258365, 99738.6584077689 -2239218.11253101, 99738.7584604114 -2239218.11253101, 99738.7584604114 -2239218.41268893, 99738.858513054 -2239218.41268893, 99738.858513054 -2239218.31263629, 99738.9585656965 -2239218.31263629, 99738.9585656965 -2239218.21258365, 99738.858513054 -2239218.21258365, 99738.858513054 -2239217.91242572, 99738.9585656965 -2239217.91242572, 99738.9585656965 -2239218.01247836, 99739.1586709816 -2239218.01247836, 99739.1586709816 -2239217.91242572, 99739.2587236242 -2239217.91242572, 99739.2587236242 -2239218.01247836, 99739.3587762667 -2239218.01247836, 99739.3587762667 -2239218.1125
3101, 99739.4588289093 -2239218.11253101, 99739.4588289093 -2239217.91242572, 99739.5588815519 -2239217.91242572, 99739.5588815519 -2239218.01247836, 99739.6589341944 -2239218.01247836, 99739.6589341944 -2239217.81237308, 99739.8590394795 -2239217.81237308, 99739.8590394795 -2239217.71232044, 99740.0591447646 -2239217.71232044, 99740.0591447646 -2239217.61226779, 99740.1591974072 -2239217.61226779, 99740.1591974072 -2239217.71232044, 99740.2592500497 -2239217.71232044, 99740.2592500497 -2239217.51221515, 99740.0591447646 -2239217.51221515, 99740.0591447646 -2239217.41216251, 99740.2592500497 -2239217.41216251, 99740.2592500497 -2239217.21205722, 99740.3593026923 -2239217.21205722, 99740.3593026923 -2239217.01195194, 99740.2592500497 -2239217.01195194, 99740.2592500497 -2239217.11200458, 99740.1591974072 -2239217.11200458, 99740.1591974072 -2239217.01195194, 99740.0591447646 -2239217.01195194, 99740.0591447646 -2239217.31210987, 99739.8590394795 -2239217.31210987, 99739.85903
94795 -2239217.41216251, 99739.6589341944 -2239217.41216251, 99739.6589341944 -2239217.51221515, 99739.4588289093 -2239217.51221515, 99739.4588289093 -2239217.61226779, 99738.9585656965 -2239217.61226779, 99738.9585656965 -2239217.51221515, 99738.7584604114 -2239217.51221515, 99738.7584604114 -2239217.41216251, 99738.5583551263 -2239217.41216251, 99738.5583551263 -2239217.31210987, 99738.4583024838 -2239217.31210987, 99738.4583024838 -2239217.21205722, 99738.6584077689 -2239217.21205722, 99738.6584077689 -2239217.11200458, 99738.9585656965 -2239217.11200458, 99738.9585656965 -2239217.01195194, 99738.7584604114 -2239217.01195194, 99738.7584604114 -2239216.9118993, 99738.3582498412 -2239216.9118993, 99738.3582498412 -2239217.01195194, 99738.2581971987 -2239217.01195194, 99738.2581971987 -2239216.9118993, 99738.1581445561 -2239216.9118993, 99738.1581445561 -2239217.01195194, 99738.0580919136 -2239217.01195194, 99738.0580919136 -2239216.9118993, 99737.8579866284 -2239216.9118993
, 99737.8579866284 -2239216.61174137, 99737.6578813433 -2239216.61174137, 99737.6578813433 -2239216.41163608, 99737.4577760582 -2239216.41163608, 99737.4577760582 -2239216.2115308, 99737.2576707731 -2239216.2115308, 99737.2576707731 -2239215.81132023, 99737.057565488 -2239215.81132023, 99737.057565488 -2239215.41110966, 99736.9575128455 -2239215.41110966, 99736.9575128455 -2239215.31105701, 99736.8574602029 -2239215.31105701, 99736.8574602029 -2239215.01089909, 99736.9575128455 -2239215.01089909, 99736.9575128455 -2239214.91084644, 99737.057565488 -2239214.91084644, 99737.057565488 -2239214.8107938, 99737.1576181306 -2239214.8107938, 99737.1576181306 -2239214.71074116, 99737.3577234157 -2239214.71074116, 99737.3577234157 -2239214.61068852, 99737.6578813433 -2239214.61068852, 99737.6578813433 -2239214.41058323, 99737.8579866284 -2239214.41058323, 99737.8579866284 -2239214.31053059, 99737.958039271 -2239214.31053059, 99737.958039271 -2239214.1104253, 99737.5578287008 -2239214.
1104253, 99737.5578287008 -2239214.21047795, 99737.4577760582 -2239214.21047795, 99737.4577760582 -2239214.01037266, 99737.6578813433 -2239214.01037266, 99737.6578813433 -2239213.91032002, 99737.7579339859 -2239213.91032002, 99737.7579339859 -2239213.71021473, 99737.8579866284 -2239213.71021473, 99737.8579866284 -2239213.61016209, 99737.7579339859 -2239213.61016209, 99737.7579339859 -2239213.51010945, 99737.8579866284 -2239213.51010945, 99737.8579866284 -2239213.41005681, 99737.958039271 -2239213.41005681, 99737.958039271 -2239213.31000416, 99737.8579866284 -2239213.31000416, 99737.8579866284 -2239213.20995152, 99737.7579339859 -2239213.20995152, 99737.7579339859 -2239213.31000416, 99737.5578287008 -2239213.31000416, 99737.5578287008 -2239213.10989888, 99737.3577234157 -2239213.10989888, 99737.3577234157 -2239212.90979359, 99737.4577760582 -2239212.90979359, 99737.4577760582 -2239212.80974095, 99737.3577234157 -2239212.80974095, 99737.3577234157 -2239212.70968831, 99737.2576
707731 -2239212.70968831, 99737.2576707731 -2239212.30947774, 99737.057565488 -2239212.30947774, 99737.057565488 -2239212.2094251, 99736.9575128455 -2239212.2094251, 99736.9575128455 -2239212.10937245, 99737.057565488 -2239212.10937245, 99737.057565488 -2239212.00931981, 99737.1576181306 -2239212.00931981, 99737.1576181306 -2239212.10937245, 99737.2576707731 -2239212.10937245, 99737.2576707731 -2239212.2094251, 99737.3577234157 -2239212.2094251, 99737.3577234157 -2239212.40953038, 99737.4577760582 -2239212.40953038, 99737.4577760582 -2239212.30947774, 99737.5578287008 -2239212.30947774, 99737.5578287008 -2239212.2094251, 99737.6578813433 -2239212.2094251, 99737.6578813433 -2239212.10937245, 99737.5578287008 -2239212.10937245, 99737.5578287008 -2239212.00931981, 99737.4577760582 -2239212.00931981, 99737.4577760582 -2239211.90926717, 99737.2576707731 -2239211.90926717, 99737.2576707731 -2239211.80921452, 99737.1576181306 -2239211.80921452, 99737.1576181306 -2239211.70916188, 9
9737.057565488 -2239211.70916188, 99737.057565488 -2239211.60910924, 99736.9575128455 -2239211.60910924, 99736.9575128455 -2239211.5090566, 99736.7574075604 -2239211.5090566, 99736.7574075604 -2239211.40900395, 99736.5573022753 -2239211.40900395, 99736.5573022753 -2239211.00879338, 99736.4572496327 -2239211.00879338, 99736.4572496327 -2239210.90874074, 99736.157091705 -2239210.90874074, 99736.157091705 -2239210.8086881, 99736.2571443476 -2239210.8086881, 99736.2571443476 -2239210.60858281, 99736.3571969901 -2239210.60858281, 99736.3571969901 -2239210.40847753, 99736.2571443476 -2239210.40847753, 99736.2571443476 -2239210.50853017, 99736.0570390625 -2239210.50853017, 99736.0570390625 -2239210.40847753, 99736.157091705 -2239210.40847753, 99736.157091705 -2239210.30842489, 99735.9569864199 -2239210.30842489, 99735.9569864199 -2239210.20837224, 99736.0570390625 -2239210.20837224, 99736.0570390625 -2239209.90821432, 99735.8569337774 -2239209.90821432, 99735.8569337774 -2239209.80
816167, 99735.9569864199 -2239209.80816167, 99735.9569864199 -2239209.60805639, 99735.8569337774 -2239209.60805639, 99735.8569337774 -2239209.50800375, 99735.7568811348 -2239209.50800375, 99735.7568811348 -2239209.4079511, 99735.8569337774 -2239209.4079511, 99735.8569337774 -2239209.30789846, 99735.7568811348 -2239209.30789846, 99735.7568811348 -2239209.20784582, 99735.6568284923 -2239209.20784582, 99735.6568284923 -2239209.00774053, 99735.7568811348 -2239209.00774053, 99735.7568811348 -2239208.80763525, 99735.6568284923 -2239208.80763525, 99735.6568284923 -2239208.60752996, 99735.5567758497 -2239208.60752996, 99735.5567758497 -2239208.50747732, 99735.6568284923 -2239208.50747732, 99735.6568284923 -2239208.40742468, 99735.5567758497 -2239208.40742468, 99735.5567758497 -2239208.30737204, 99735.4567232072 -2239208.30737204, 99735.4567232072 -2239208.20731939, 99735.5567758497 -2239208.20731939, 99735.5567758497 -2239208.00721411, 99735.4567232072 -2239208.00721411, 99735.45672
32072 -2239207.90716147, 99735.3566705646 -2239207.90716147, 99735.3566705646 -2239207.70705618, 99735.4567232072 -2239207.70705618, 99735.4567232072 -2239207.50695089, 99735.3566705646 -2239207.50695089, 99735.3566705646 -2239207.40689825, 99735.4567232072 -2239207.40689825, 99735.4567232072 -2239207.30684561, 99735.2566179221 -2239207.30684561, 99735.2566179221 -2239207.20679297, 99735.3566705646 -2239207.20679297, 99735.3566705646 -2239207.10674032, 99735.1565652795 -2239207.10674032, 99735.1565652795 -2239207.30684561, 99735.0565126369 -2239207.30684561, 99735.0565126369 -2239207.00668768, 99734.9564599944 -2239207.00668768, 99734.9564599944 -2239207.40689825, 99734.8564073518 -2239207.40689825, 99734.8564073518 -2239207.00668768, 99734.7563547093 -2239207.00668768, 99734.7563547093 -2239206.90663504, 99734.6563020667 -2239206.90663504, 99734.6563020667 -2239206.8065824, 99734.5562494242 -2239206.8065824, 99734.5562494242 -2239206.70652975, 99734.2560914965 -2239206.7065
2975, 99734.2560914965 -2239206.60647711, 99734.3561441391 -2239206.60647711, 99734.3561441391 -2239206.30631918, 99734.156038854 -2239206.30631918, 99734.156038854 -2239206.20626654, 99734.0559862114 -2239206.20626654, 99734.0559862114 -2239206.1062139, 99734.2560914965 -2239206.1062139, 99734.2560914965 -2239205.90610861, 99734.3561441391 -2239205.90610861, 99734.3561441391 -2239205.80605597, 99734.4561967816 -2239205.80605597, 99734.4561967816 -2239205.70600333, 99734.6563020667 -2239205.70600333, 99734.6563020667 -2239205.80605597, 99734.8564073518 -2239205.80605597, 99734.8564073518 -2239205.30579276, 99734.3561441391 -2239205.30579276, 99734.3561441391 -2239205.10568747, 99734.0559862114 -2239205.10568747, 99734.0559862114 -2239205.00563483, 99733.8558809263 -2239205.00563483, 99733.8558809263 -2239204.90558219, 99733.6557756412 -2239204.90558219, 99733.6557756412 -2239204.80552955, 99733.4556703561 -2239204.80552955, 99733.4556703561 -2239204.7054769, 99733.3556177135
-2239204.7054769, 99733.3556177135 -2239204.60542426, 99733.1555124284 -2239204.60542426, 99733.1555124284 -2239204.50537162, 99732.8553545008 -2239204.50537162, 99732.8553545008 -2239204.60542426, 99732.7553018582 -2239204.60542426, 99732.7553018582 -2239204.90558219, 99732.5551965731 -2239204.90558219, 99732.5551965731 -2239205.00563483, 99732.4551439306 -2239205.00563483, 99732.4551439306 -2239205.10568747, 99732.355091288 -2239205.10568747, 99732.355091288 -2239205.20574012, 99732.1549860029 -2239205.20574012, 99732.1549860029 -2239205.30579276, 99731.9548807178 -2239205.30579276, 99731.9548807178 -2239205.4058454, 99731.454617505 -2239205.4058454, 99731.454617505 -2239205.50589804, 99731.0544069348 -2239205.50589804, 99731.0544069348 -2239205.60595069, 99730.8543016497 -2239205.60595069, 99730.8543016497 -2239205.70600333, 99730.7542490072 -2239205.70600333, 99730.7542490072 -2239205.80605597, 99730.554143722 -2239205.80605597, 99730.554143722 -2239205.90610861, 99730.
4540910795 -2239205.90610861, 99730.4540910795 -2239206.00616126, 99730.3540384369 -2239206.00616126, 99730.3540384369 -2239206.50642447, 99730.2539857944 -2239206.50642447, 99730.2539857944 -2239206.70652975, 99730.1539331518 -2239206.70652975, 99730.1539331518 -2239206.8065824, 99729.9538278667 -2239206.8065824, 99729.9538278667 -2239206.90663504, 99729.5536172965 -2239206.90663504, 99729.5536172965 -2239207.00668768, 99729.3535120114 -2239207.00668768, 99729.3535120114 -2239207.10674032, 99729.2534593688 -2239207.10674032, 99729.2534593688 -2239207.20679297, 99729.0533540837 -2239207.20679297, 99729.0533540837 -2239207.30684561, 99728.9533014412 -2239207.30684561, 99728.9533014412 -2239207.40689825, 99728.8532487986 -2239207.40689825, 99728.8532487986 -2239207.50695089, 99728.7531961561 -2239207.50695089, 99728.7531961561 -2239207.60700354, 99728.6531435135 -2239207.60700354, 99728.6531435135 -2239208.10726675, 99728.553090871 -2239208.10726675, 99728.553090871 -2239208.3
0737204, 99728.4530382284 -2239208.30737204, 99728.4530382284 -2239208.50747732, 99728.6531435135 -2239208.50747732, 99728.6531435135 -2239208.60752996, 99728.2529329433 -2239208.60752996, 99728.2529329433 -2239208.70758261, 99727.8527223731 -2239208.70758261, 99727.8527223731 -2239208.60752996, 99727.5525644454 -2239208.60752996, 99727.5525644454 -2239208.70758261, 99727.4525118029 -2239208.70758261, 99727.4525118029 -2239208.60752996, 99726.4519853773 -2239208.60752996, 99726.4519853773 -2239208.70758261, 99726.2518800922 -2239208.70758261, 99726.2518800922 -2239208.80763525, 99726.1518274497 -2239208.80763525, 99726.1518274497 -2239208.90768789, 99726.0517748071 -2239208.90768789, 99726.0517748071 -2239209.00774053, 99725.9517221646 -2239209.00774053, 99725.9517221646 -2239209.10779318, 99725.851669522 -2239209.10779318, 99725.851669522 -2239209.20784582, 99725.7516168795 -2239209.20784582, 99725.7516168795 -2239209.4079511, 99725.6515642369 -2239209.4079511, 99725.651564
2369 -2239209.50800375, 99725.7516168795 -2239209.50800375, 99725.7516168795 -2239209.60805639, 99725.6515642369 -2239209.60805639, 99725.6515642369 -2239209.90821432, 99725.5515115944 -2239209.90821432, 99725.5515115944 -2239210.50853017, 99725.4514589518 -2239210.50853017, 99725.4514589518 -2239211.20889867, 99725.5515115944 -2239211.20889867, 99725.5515115944 -2239211.40900395, 99725.6515642369 -2239211.40900395, 99725.6515642369 -2239211.5090566, 99725.7516168795 -2239211.5090566, 99725.7516168795 -2239211.40900395, 99725.851669522 -2239211.40900395, 99725.851669522 -2239211.10884603, 99725.9517221646 -2239211.10884603, 99725.9517221646 -2239210.90874074, 99726.0517748071 -2239210.90874074, 99726.0517748071 -2239210.20837224, 99726.1518274497 -2239210.20837224, 99726.1518274497 -2239210.1083196, 99726.2518800922 -2239210.1083196, 99726.2518800922 -2239210.00826696, 99726.4519853773 -2239210.00826696, 99726.4519853773 -2239209.90821432, 99726.6520906625 -2239209.90821432,
99726.6520906625 -2239210.00826696, 99726.9522485901 -2239210.00826696, 99726.9522485901 -2239210.1083196, 99727.1523538752 -2239210.1083196, 99727.1523538752 -2239210.20837224, 99727.7526697305 -2239210.20837224, 99727.7526697305 -2239210.1083196, 99728.6531435135 -2239210.1083196, 99728.6531435135 -2239210.00826696, 99728.7531961561 -2239210.00826696, 99728.7531961561 -2239210.1083196, 99729.0533540837 -2239210.1083196, 99729.0533540837 -2239210.20837224, 99729.1534067263 -2239210.20837224, 99729.1534067263 -2239210.00826696, 99728.9533014412 -2239210.00826696, 99728.9533014412 -2239209.90821432, 99729.1534067263 -2239209.90821432, 99729.1534067263 -2239209.80816167, 99728.9533014412 -2239209.80816167, 99728.9533014412 -2239209.70810903, 99728.8532487986 -2239209.70810903, 99728.8532487986 -2239209.60805639, 99728.9533014412 -2239209.60805639, 99728.9533014412 -2239209.4079511, 99728.8532487986 -2239209.4079511, 99728.8532487986 -2239209.30789846, 99728.9533014412 -223920
9.30789846, 99728.9533014412 -2239209.00774053, 99729.0533540837 -2239209.00774053, 99729.0533540837 -2239208.90768789, 99729.5536172965 -2239208.90768789, 99729.5536172965 -2239208.80763525, 99729.7537225816 -2239208.80763525, 99729.7537225816 -2239208.90768789, 99729.8537752242 -2239208.90768789, 99729.8537752242 -2239209.00774053, 99729.9538278667 -2239209.00774053, 99729.9538278667 -2239209.10779318, 99730.1539331518 -2239209.10779318, 99730.1539331518 -2239209.30789846, 99730.0538805093 -2239209.30789846, 99730.0538805093 -2239209.4079511, 99730.1539331518 -2239209.4079511, 99730.1539331518 -2239209.50800375, 99730.0538805093 -2239209.50800375, 99730.0538805093 -2239209.80816167, 99729.9538278667 -2239209.80816167, 99729.9538278667 -2239210.00826696, 99729.8537752242 -2239210.00826696, 99729.8537752242 -2239210.1083196, 99729.7537225816 -2239210.1083196, 99729.7537225816 -2239210.20837224, 99729.5536172965 -2239210.20837224, 99729.5536172965 -2239210.1083196, 99729.3535
120114 -2239210.1083196, 99729.3535120114 -2239210.30842489, 99729.2534593688 -2239210.30842489, 99729.2534593688 -2239210.40847753, 99729.3535120114 -2239210.40847753, 99729.3535120114 -2239210.8086881, 99729.4535646539 -2239210.8086881, 99729.4535646539 -2239210.90874074, 99729.3535120114 -2239210.90874074, 99729.3535120114 -2239211.00879338, 99729.1534067263 -2239211.00879338, 99729.1534067263 -2239211.10884603, 99728.7531961561 -2239211.10884603, 99728.7531961561 -2239211.20889867, 99727.9527750156 -2239211.20889867, 99727.9527750156 -2239211.30895131, 99727.652617088 -2239211.30895131, 99727.652617088 -2239211.40900395, 99727.4525118029 -2239211.40900395, 99727.4525118029 -2239211.5090566, 99727.3524591603 -2239211.5090566, 99727.3524591603 -2239211.70916188, 99727.4525118029 -2239211.70916188, 99727.4525118029 -2239211.80921452, 99727.652617088 -2239211.80921452, 99727.652617088 -2239211.90926717, 99727.8527223731 -2239211.90926717, 99727.8527223731 -2239212.00931981,
99728.4530382284 -2239212.00931981, 99728.4530382284 -2239212.10937245, 99728.553090871 -2239212.10937245, 99728.553090871 -2239212.00931981, 99728.7531961561 -2239212.00931981, 99728.7531961561 -2239212.10937245, 99729.1534067263 -2239212.10937245, 99729.1534067263 -2239212.2094251, 99729.3535120114 -2239212.2094251, 99729.3535120114 -2239212.30947774, 99729.4535646539 -2239212.30947774, 99729.4535646539 -2239212.50958302, 99729.5536172965 -2239212.50958302, 99729.5536172965 -2239212.60963567, 99729.6536699391 -2239212.60963567, 99729.6536699391 -2239212.70968831, 99729.9538278667 -2239212.70968831, 99729.9538278667 -2239212.80974095, 99730.3540384369 -2239212.80974095, 99730.3540384369 -2239212.90979359, 99730.554143722 -2239212.90979359, 99730.554143722 -2239213.00984624, 99730.7542490072 -2239213.00984624, 99730.7542490072 -2239212.90979359, 99730.8543016497 -2239212.90979359, 99730.8543016497 -2239213.00984624, 99730.9543542922 -2239213.00984624, 99730.9543542922 -22392
13.20995152, 99731.0544069348 -2239213.20995152, 99731.0544069348 -2239213.10989888, 99731.1544595774 -2239213.10989888, 99731.1544595774 -2239213.31000416, 99731.3545648625 -2239213.31000416, 99731.3545648625 -2239213.41005681, 99731.454617505 -2239213.41005681, 99731.454617505 -2239213.51010945, 99731.5546701476 -2239213.51010945, 99731.5546701476 -2239213.61016209, 99731.6547227901 -2239213.61016209, 99731.6547227901 -2239213.81026738, 99731.7547754327 -2239213.81026738, 99731.7547754327 -2239213.91032002, 99731.8548280752 -2239213.91032002, 99731.8548280752 -2239214.1104253, 99731.9548807178 -2239214.1104253, 99731.9548807178 -2239214.31053059, 99732.0549333603 -2239214.31053059, 99732.0549333603 -2239214.41058323, 99731.9548807178 -2239214.41058323, 99731.9548807178 -2239214.51063587, 99732.0549333603 -2239214.51063587, 99732.0549333603 -2239214.71074116, 99732.1549860029 -2239214.71074116, 99732.1549860029 -2239214.91084644, 99732.2550386455 -2239214.91084644, 99732.25
50386455 -2239215.11095173, 99732.355091288 -2239215.11095173, 99732.355091288 -2239215.31105701, 99732.4551439306 -2239215.31105701, 99732.4551439306 -2239215.41110966, 99732.355091288 -2239215.41110966, 99732.355091288 -2239215.5111623, 99732.4551439306 -2239215.5111623, 99732.4551439306 -2239215.71126758, 99732.355091288 -2239215.71126758, 99732.355091288 -2239215.91137287, 99732.4551439306 -2239215.91137287, 99732.4551439306 -2239216.01142551, 99732.355091288 -2239216.01142551, 99732.355091288 -2239216.11147815, 99732.2550386455 -2239216.11147815, 99732.2550386455 -2239216.2115308, 99732.355091288 -2239216.2115308, 99732.355091288 -2239216.31158344, 99732.2550386455 -2239216.31158344, 99732.2550386455 -2239216.61174137, 99732.1549860029 -2239216.61174137, 99732.1549860029 -2239217.01195194, 99732.0549333603 -2239217.01195194, 99732.0549333603 -2239217.21205722, 99732.1549860029 -2239217.21205722, 99732.1549860029 -2239217.31210987, 99732.4551439306 -2239217.31210987, 997
32.4551439306 -2239217.41216251, 99732.5551965731 -2239217.41216251, 99732.5551965731 -2239217.31210987, 99732.7553018582 -2239217.31210987, 99732.7553018582 -2239217.41216251, 99732.8553545008 -2239217.41216251, 99732.8553545008 -2239217.51221515, 99732.9554071433 -2239217.51221515, 99732.9554071433 -2239217.31210987, 99733.1555124284 -2239217.31210987, 99733.1555124284 -2239217.41216251, 99733.255565071 -2239217.41216251, 99733.255565071 -2239217.31210987, 99733.4556703561 -2239217.31210987, 99733.4556703561 -2239217.41216251, 99733.5557229986 -2239217.41216251, 99733.5557229986 -2239217.31210987, 99733.6557756412 -2239217.31210987, 99733.6557756412 -2239217.21205722, 99733.8558809263 -2239217.21205722, 99733.8558809263 -2239217.11200458, 99733.9559335689 -2239217.11200458, 99733.9559335689 -2239217.01195194, 99734.0559862114 -2239217.01195194, 99734.0559862114 -2239217.21205722, 99734.156038854 -2239217.21205722, 99734.156038854 -2239217.11200458, 99734.2560914965 -223921
7.11200458, 99734.2560914965 -2239217.21205722, 99734.3561441391 -2239217.21205722, 99734.3561441391 -2239217.11200458, 99734.4561967816 -2239217.11200458, 99734.4561967816 -2239217.01195194, 99734.3561441391 -2239217.01195194, 99734.3561441391 -2239216.9118993, 99734.4561967816 -2239216.9118993, 99734.4561967816 -2239216.81184665, 99734.6563020667 -2239216.81184665, 99734.6563020667 -2239216.9118993, 99734.5562494242 -2239216.9118993, 99734.5562494242 -2239217.01195194, 99734.6563020667 -2239217.01195194, 99734.6563020667 -2239217.11200458, 99734.7563547093 -2239217.11200458, 99734.7563547093 -2239217.01195194, 99734.8564073518 -2239217.01195194, 99734.8564073518 -2239217.11200458, 99735.3566705646 -2239217.11200458, 99735.3566705646 -2239217.21205722, 99735.7568811348 -2239217.21205722, 99735.7568811348 -2239217.31210987, 99735.6568284923 -2239217.31210987, 99735.6568284923 -2239217.41216251, 99735.5567758497 -2239217.41216251, 99735.5567758497 -2239217.61226779, 99735.756
8811348 -2239217.61226779, 99735.7568811348 -2239217.71232044, 99735.9569864199 -2239217.71232044, 99735.9569864199 -2239218.01247836, 99735.8569337774 -2239218.01247836, 99735.8569337774 -2239218.11253101, 99735.9569864199 -2239218.11253101, 99735.9569864199 -2239218.21258365, 99736.0570390625 -2239218.21258365, 99736.0570390625 -2239218.41268893, 99735.9569864199 -2239218.41268893, 99735.9569864199 -2239218.61279422, 99736.0570390625 -2239218.61279422, 99736.0570390625 -2239218.71284686, 99735.9569864199 -2239218.71284686, 99735.9569864199 -2239218.8128995, 99736.0570390625 -2239218.8128995, 99736.0570390625 -2239218.91295215, 99736.3571969901 -2239218.91295215, 99736.3571969901 -2239219.01300479, 99736.4572496327 -2239219.01300479, 99736.4572496327 -2239219.11305743))
- </a>
- <test>
- <op name="buffer" arg1="a" arg2="1.01">
- POLYGON ((99724.5415116 -2239210.07866999,99724.5415116 -2239209.9082143,99724.5609185 -2239209.7111731,99724.6183933 -2239209.521704,99724.6415642 -2239209.4783543,99724.6415642 -2239209.4079511,99724.6609711 -2239209.2109099,99724.7184459 -2239209.0214408,99724.8094364244 -2239208.85120953,99724.8184986 -2239208.8213356,99724.9118326 -2239208.6467199,99725.037439 -2239208.493668,99725.0923925052 -2239208.44856881,99725.1374917 -2239208.3936153,99725.19244517 -2239208.34851617,99725.2375443 -2239208.2935627,99725.2924978955 -2239208.24846343,99725.337597 -2239208.19351,99725.39255036 -2239208.14841096,99725.4376496 -2239208.0934574,99725.4926031603 -2239208.04835816,99725.5377022 -2239207.9934048,99725.6907542 -2239207.8677983,99725.8653698 -2239207.7744643,99725.8952440723 -2239207.76540204,99726.0654751 -2239207.6744116,99726.2549442 -2239207.6169368,99726.4519854 -2239207.59753,99727.4525118 -2239207.59753,99727.5025381 -2239207.60245714,99727.5525644 -2239207.5975
3,99727.64407656 -2239207.59753,99727.6625504 -2239207.4099623,99727.7200252 -2239207.2204933,99727.8133592 -2239207.0458776,99727.9389657 -2239206.8928257,99727.9939189892 -2239206.84772668,99728.0390183 -2239206.792773,99728.09397177 -2239206.74767387,99728.1390709 -2239206.6927204,99728.1940245825 -2239206.64762109,99728.2391236 -2239206.5926678,99728.2940769089 -2239206.54756877,99728.3391762 -2239206.4926151,99728.4922281 -2239206.3670087,99728.6537698364 -2239206.28066278,99728.7923861 -2239206.1669034,99728.9670017 -2239206.0735694,99728.9968758442 -2239206.06450717,99729.167107 -2239205.9735167,99729.3528016278 -2239205.91718687,99729.3634453 -2239205.80912,99729.4209201 -2239205.619651,99729.5142541 -2239205.4450353,99729.6398606 -2239205.2919834,99729.6948141603 -2239205.24688416,99729.7399132 -2239205.1919308,99729.7948667052 -2239205.14683161,99729.8399659 -2239205.0918781,99729.9930178 -2239204.9662717,99730.1545592497 -2239204.87992594,99730.2931757 -2239204.76
61664,99730.4677914 -2239204.6728324,99730.4976652713 -2239204.66377026,99730.6678967 -2239204.5727797,99730.8573657 -2239204.5153049,99731.0180600617 -2239204.49947786,99731.0681072 -2239204.4727271,99731.2575763 -2239204.4152523,99731.4546175 -2239204.3958454,99731.5250206377 -2239204.3958454,99731.5683705 -2239204.3726744,99731.5982447981 -2239204.36361213,99731.7554017157 -2239204.27960999,99731.7959194991 -2239204.24635789,99731.8291718013 -2239204.2058398,99731.9155175 -2239204.0442983,99732.041124 -2239203.8912464,99732.0960776663 -2239203.84614711,99732.1411767 -2239203.7911938,99732.2942286 -2239203.6655873,99732.4688442 -2239203.5722533,99732.6583133 -2239203.5147785,99732.8553545 -2239203.4953716,99733.1555124 -2239203.4953716,99733.3525537 -2239203.5147785,99733.5420227 -2239203.5722533,99733.7122537168 -2239203.66324364,99733.742128 -2239203.6723059,99733.9167436 -2239203.76564,99734.0553600971 -2239203.8793995,99734.2125173287 -2239203.96340176,99734.2423912 -2
239203.9724639,99734.4126222168 -2239204.06345424,99734.4424965 -2239204.0725165,99734.5151443635 -2239204.1113476,99734.5531854 -2239204.1150943,99734.7426544 -2239204.1725691,99734.9172701 -2239204.2659032,99734.9669580798 -2239204.30668106,99735.0534486 -2239204.3151996,99735.2429176 -2239204.3726744,99735.4175333 -2239204.4660085,99735.5705852 -2239204.5916149,99735.6961917 -2239204.7446668,99735.7895257 -2239204.9192825,99735.8470005 -2239205.1087515,99735.8664074 -2239205.3057928,99735.8664074 -2239205.806056,99735.8470005 -2239206.0030972,99735.7895257 -2239206.1925662,99735.7871029413 -2239206.19709886,99735.9177965 -2239206.266956,99736.0708484 -2239206.3925625,99736.1964549 -2239206.5456144,99736.2897889 -2239206.7202301,99736.2988511704 -2239206.7501044,99736.3898415 -2239206.9203353,99736.4473163 -2239207.1098044,99736.4667232 -2239207.3068456,99736.4667232 -2239207.4068983,99736.4617960304 -2239207.4569246,99736.4667232 -2239207.5069509,99736.4667232 -2239207.57
735392,99736.4898942 -2239207.6207038,99736.547369 -2239207.8101729,99736.5631959389 -2239207.97086704,99736.5899468 -2239208.0209144,99736.6474216 -2239208.2103835,99736.6632486227 -2239208.37107766,99736.6899995 -2239208.421125,99736.7474743 -2239208.610594,99736.7668811 -2239208.8076352,99736.7668811 -2239208.87803829,99736.7900521 -2239208.9213882,99736.8475269 -2239209.1108572,99736.8512736244 -2239209.14889828,99736.8901047 -2239209.2215461,99736.9475796 -2239209.4110152,99736.951326291 -2239209.44905612,99736.9901574 -2239209.521704,99737.0329471384 -2239209.66276292,99737.0713748 -2239209.6942997,99737.1969813 -2239209.8473516,99737.2903153 -2239210.0219673,99737.3477901 -2239210.2114363,99737.367197 -2239210.4084775,99737.367197 -2239210.41124683,99737.3970866 -2239210.4476674,99737.4904206 -2239210.6222831,99737.5019722663 -2239210.66036386,99737.5186388 -2239210.6692723,99737.6716907 -2239210.7948787,99737.7167900108 -2239210.84983238,99737.7717433 -2239210.894931
4,99737.8168423337 -2239210.94988471,99737.8573605503 -2239210.98313714,99738.018902 -2239211.0694829,99738.1719539 -2239211.1950893,99738.2170533011 -2239211.25004306,99738.2720065 -2239211.295142,99738.3171054434 -2239211.3500952,99738.3720592 -2239211.3951946,99738.4976657 -2239211.5482465,99738.5909997 -2239211.7228622,99738.6484745 -2239211.9123312,99738.6678813 -2239212.1093725,99738.6678813 -2239212.2094251,99738.6484745 -2239212.4064663,99738.6081004414 -2239212.53956179,99738.61726363 -2239212.55072717,99738.6722171 -2239212.5958263,99738.7978236 -2239212.7488782,99738.8911576 -2239212.9234939,99738.9486324 -2239213.1129629,99738.9680393 -2239213.3100042,99738.9680393 -2239213.4100568,99738.9486324 -2239213.607098,99738.9021769824 -2239213.76024105,99738.9486324 -2239213.9133841,99738.9680393 -2239214.1104253,99738.9680393 -2239214.3105306,99738.9486324 -2239214.5075718,99738.8911576 -2239214.6970409,99738.7978236 -2239214.8716565,99738.6722171 -2239215.0247084,9973
8.6172637911 -2239215.06980743,99738.5721645 -2239215.1247611,99738.462257725 -2239215.21495922,99738.3720592 -2239215.3248664,99738.2190073 -2239215.4504728,99738.2014247057 -2239215.45987089,99738.2367425085 -2239215.57629807,99738.2621522445 -2239215.60725993,99738.3720592 -2239215.6974582,99738.462257725 -2239215.80736538,99738.5721645 -2239215.8975635,99738.5757227977 -2239215.9018993,99738.7584604 -2239215.9018993,99738.9555016 -2239215.9213062,99739.1449707 -2239215.978781,99739.3152014914 -2239216.06977127,99739.345076 -2239216.0788336,99739.5088552031 -2239216.16637542,99739.6726345 -2239216.0788336,99739.8621035 -2239216.0213588,99740.0591448 -2239216.0019519,99740.1591974 -2239216.0019519,99740.2092237 -2239216.00687907,99740.25925 -2239216.0019519,99740.3593027 -2239216.0019519,99740.5563439 -2239216.0213588,99740.745813 -2239216.0788336,99740.9204286 -2239216.1721676,99741.0734805 -2239216.2977741,99741.199087 -2239216.450826,99741.292421 -2239216.6254417,99741.
3498958 -2239216.8149107,99741.3693027 -2239217.0119519,99741.3693027 -2239217.2120572,99741.3498958 -2239217.4090984,99741.292421 -2239217.5985675,99741.26925 -2239217.64191741,99741.26925 -2239217.7123204,99741.2498432 -2239217.9093617,99741.1923684 -2239218.0988307,99741.0990344 -2239218.2734464,99740.9734279 -2239218.4264983,99740.820376 -2239218.5521047,99740.6457603 -2239218.6454388,99740.4562913 -2239218.7029136,99740.3869959453 -2239218.70973857,99740.373112 -2239218.7266562,99740.2200601 -2239218.8522627,99740.0454445 -2239218.9455967,99740.0155699914 -2239218.95465903,99739.8453392 -2239219.0456493,99739.6558701 -2239219.1031241,99739.5865749089 -2239219.10994909,99739.5726909 -2239219.1268668,99739.419639 -2239219.2524732,99739.2580975504 -2239219.33881896,99739.1194811 -2239219.4525785,99738.9448654 -2239219.5459125,99738.8038065828 -2239219.5887023,99738.7722698 -2239219.62713,99738.7173161175 -2239219.67222931,99738.6722171 -2239219.7271826,99738.5191652 -22392
19.8527891,99738.3445495 -2239219.9461231,99738.1550805 -2239220.0035979,99737.9580393 -2239220.0230048,99737.8876361623 -2239220.0230048,99737.8442863 -2239220.0461758,99737.6548173 -2239220.1036506,99737.4941231253 -2239220.11947754,99737.4440758 -2239220.1462284,99737.2546067 -2239220.2037032,99737.0575655 -2239220.2231101,99736.9575128 -2239220.2231101,99736.7604716 -2239220.2037032,99736.5710026 -2239220.1462284,99736.5276526912 -2239220.1230574,99736.4572496 -2239220.1230574,99736.2602084 -2239220.1036506,99736.0707394 -2239220.0461758,99735.8961237 -2239219.9528417,99735.8220170434 -2239219.89202396,99735.6705288 -2239219.8460705,99735.4959131 -2239219.7527365,99735.3428612 -2239219.62713,99735.29776207 -2239219.57217653,99735.2428086 -2239219.5270774,99735.1172021 -2239219.3740254,99735.0238681 -2239219.1994098,99734.9663933 -2239219.0099407,99734.9469864 -2239218.8128995,99734.9469864 -2239218.7128469,99734.9519135732 -2239218.66282054,99734.9469864 -2239218.6127942
,99734.9469864 -2239218.54239114,99734.9238154 -2239218.4990413,99734.8810256616 -2239218.35798238,99734.842598 -2239218.3264456,99734.7169915 -2239218.1733937,99734.7075934665 -2239218.15581122,99734.5531854 -2239218.2026504,99734.3561441 -2239218.2220572,99734.2560915 -2239218.2220572,99734.2060652 -2239218.21713006,99734.1560389 -2239218.2220572,99734.153269497 -2239218.2220572,99734.1168489 -2239218.2519468,99733.9422333 -2239218.3452808,99733.7527642 -2239218.4027556,99733.555723 -2239218.4221625,99733.4556704 -2239218.4221625,99733.3962216239 -2239218.4163073,99733.3419174 -2239218.4453335,99733.1524484 -2239218.5028083,99732.9554071 -2239218.5222152,99732.8553545 -2239218.5222152,99732.6583133 -2239218.5028083,99732.4688442 -2239218.4453335,99732.4187968324 -2239218.41858262,99732.2581027 -2239218.4027556,99732.0686337 -2239218.3452808,99731.9959858341 -2239218.30644972,99731.9579448 -2239218.302703,99731.7684757 -2239218.2452282,99731.5938601 -2239218.1518942,99731.4
408082 -2239218.0262877,99731.3957091663 -2239217.97133439,99731.3407555 -2239217.9262351,99731.2151491 -2239217.7731832,99731.121815 -2239217.5985675,99731.0643402 -2239217.4090984,99731.0449334 -2239217.2120572,99731.0449334 -2239217.0119519,99731.0643402 -2239216.8149107,99731.121815 -2239216.6254417,99731.1485658751 -2239216.57539437,99731.1643929 -2239216.4147001,99731.2218677 -2239216.2252311,99731.2450386 -2239216.18188138,99731.2450386 -2239216.1114782,99731.2644455 -2239215.9144369,99731.3219203 -2239215.7249679,99731.3486711837 -2239215.6749205,99731.354945644 -2239215.61121495,99731.3486711837 -2239215.5475094,99731.3219203 -2239215.497462,99731.3128580278 -2239215.4675877,99731.2218677 -2239215.2973567,99731.2128054311 -2239215.26748241,99731.121815 -2239215.0972514,99731.1127527279 -2239215.0673771,99731.0217624 -2239214.8971461,99730.9642876 -2239214.7076771,99730.9484605738 -2239214.5469829,99730.9286978954 -2239214.51000958,99730.8149385 -2239214.3713933,9973
0.7377477001 -2239214.22697941,99730.5977179188 -2239214.15213197,99730.567844 -2239214.1430698,99730.3932284 -2239214.0497358,99730.3191216666 -2239213.98891804,99730.1676335 -2239213.9429646,99729.997402493 -2239213.85197417,99729.9675282 -2239213.8429119,99729.9174808437 -2239213.81616104,99729.7567866 -2239213.8003341,99729.5673176 -2239213.7428593,99729.4946695048 -2239213.7040281,99729.4566287 -2239213.7002814,99729.2671597 -2239213.6428066,99729.092544 -2239213.5494726,99728.9394921 -2239213.4238662,99728.8943929214 -2239213.36891268,99728.8394394 -2239213.3238135,99728.79434027 -2239213.26886003,99728.7393868 -2239213.2237609,99728.6461920537 -2239213.11020282,99728.5530909 -2239213.1193725,99728.4530382 -2239213.1193725,99728.255997 -2239213.0999656,99728.066528 -2239213.0424908,99728.0231780912 -2239213.0193198,99727.8527224 -2239213.0193198,99727.6556811 -2239212.9999129,99727.4662121 -2239212.9424381,99727.2959810832 -2239212.85144776,99727.2661068 -2239212.84238
55,99727.0958760086 -2239212.75139523,99727.0660015 -2239212.7423329,99726.8913859 -2239212.6489988,99726.738334 -2239212.5233924,99726.6932348052 -2239212.4684389,99726.6382813 -2239212.4233397,99726.5126749 -2239212.2702878,99726.4789537659 -2239212.20720004,99726.4657947 -2239212.2232344,99726.3127428 -2239212.3488409,99726.1381271 -2239212.4421749,99725.9486581 -2239212.4996497,99725.7516169 -2239212.5190566,99725.6515642 -2239212.5190566,99725.454523 -2239212.4996497,99725.265054 -2239212.4421749,99725.0904383 -2239212.3488409,99724.9373864 -2239212.2232344,99724.8922873825 -2239212.16828111,99724.8373337 -2239212.1231818,99724.7117273 -2239211.9701299,99724.6183933 -2239211.7955142,99724.6093311591 -2239211.76564033,99724.5183406 -2239211.5954089,99724.4608658 -2239211.4059399,99724.441459 -2239211.2088987,99724.441459 -2239210.5085302,99724.4608658 -2239210.3114889,99724.5183406 -2239210.1220199,99724.5415116 -2239210.07866999))
- </op>
- </test>
-</case>
-</run>
More information about the geos-commits
