[geos-commits] r3181 - in trunk: src/geom src/geom/util src/io
src/operation/linemerge tests/unit/geom
svn_geos at osgeo.org
Fri Feb 4 03:50:42 EST 2011
Author: strk
Date: 2011-02-04 00:50:42 -0800 (Fri, 04 Feb 2011)
New Revision: 3181
trunk/src/geom/GeometryFactory.cpp
trunk/src/geom/LineString.cpp
trunk/src/geom/Polygon.cpp
trunk/src/geom/util/GeometryEditor.cpp
trunk/src/geom/util/GeometryTransformer.cpp
trunk/src/io/WKTWriter.cpp
trunk/src/operation/linemerge/LineSequencer.cpp
trunk/tests/unit/geom/GeometryFactoryTest.cpp
trunk/tests/unit/geom/LineStringTest.cpp
trunk/tests/unit/geom/LinearRingTest.cpp
trunk/tests/unit/geom/PolygonTest.cpp
Drop more static casts
Modified: trunk/src/geom/GeometryFactory.cpp
--- trunk/src/geom/GeometryFactory.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/geom/GeometryFactory.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -520,7 +520,7 @@
GeometryFactory::createPolygon(const LinearRing &shell, const vector<Geometry *> &holes)
const
- LinearRing *newRing = (LinearRing *)shell.clone();
+ LinearRing *newRing = dynamic_cast<LinearRing *>(shell.clone());
vector<Geometry *>*newHoles = new vector<Geometry *>(holes.size());
for (size_t i=0; i<holes.size(); i++)
Modified: trunk/src/geom/LineString.cpp
--- trunk/src/geom/LineString.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/geom/LineString.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -347,8 +347,8 @@
int
LineString::compareToSameClass(const Geometry *ls) const
- assert(dynamic_cast<const LineString*>(ls));
- const LineString *line=static_cast<const LineString*>(ls);
+ const LineString *line=dynamic_cast<const LineString*>(ls);
+ assert(line);
// MD - optimized implementation
int mynpts=points->getSize();
int othnpts=line->points->getSize();
Modified: trunk/src/geom/Polygon.cpp
--- trunk/src/geom/Polygon.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/geom/Polygon.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -60,7 +60,11 @@
holes=new vector<Geometry *>(nholes);
for(size_t i=0; i<nholes; ++i)
- LinearRing *h=new LinearRing(* (LinearRing*)(*p.holes)[i]);
+ // TODO: holes is a vector of Geometry, anyway
+ // so there's no point in casting here,
+ // just use ->clone instead !
+ const LinearRing* lr = dynamic_cast<const LinearRing *>((*p.holes)[i]);
+ LinearRing *h=new LinearRing(*lr);
(*holes)[i]=h;
@@ -117,7 +121,8 @@
size_t nholes=holes->size();
for (size_t i=0; i<nholes; ++i)
- const CoordinateSequence* childCoords=((LinearRing *)(*holes)[i])->getCoordinatesRO();
+ const LinearRing* lr = dynamic_cast<const LinearRing *>((*holes)[i]);
+ const CoordinateSequence* childCoords = lr->getCoordinatesRO();
childCoords->toVector(*cl);
@@ -130,7 +135,8 @@
size_t numPoints = shell->getNumPoints();
for(size_t i=0, n=holes->size(); i<n; ++i)
- numPoints += ((LinearRing *)(*holes)[i])->getNumPoints();
+ numPoints += lr->getNumPoints();
return numPoints;
@@ -191,7 +197,8 @@
const LineString*
Polygon::getInteriorRingN(size_t n) const
- return (LineString *) (*holes)[n];
+ const LinearRing* lr = dynamic_cast<const LinearRing *>((*holes)[n]);
+ return lr;
string
@@ -224,14 +231,11 @@
vector<Geometry *> *rings = new vector<Geometry *>(holes->size()+1);
- //(*rings)[0]=shell->clone(); // new LineString(*shell);
(*rings)[0] = gf->createLineString(*shell).release();
- //(*rings)[i + 1] = new LineString((const LineString &)*(*holes)[i]);
- assert( dynamic_cast<LineString *>( (*holes)[i] ) );
- LineString* hole = static_cast<LineString *>( (*holes)[i] );
- assert(hole);
+ const LinearRing* hole = dynamic_cast<const LinearRing *>((*holes)[i]);
+ assert( hole );
LineString* ls = gf->createLineString( *hole ).release();
(*rings)[i + 1] = ls;
@@ -280,7 +284,8 @@
shell->apply_ro(filter);
- ((LinearRing *)(*holes)[i])->apply_ro(filter);
+ lr->apply_ro(filter);
@@ -290,7 +295,8 @@
shell->apply_rw(filter);
- ((LinearRing *)(*holes)[i])->apply_rw(filter);
+ LinearRing* lr = dynamic_cast<LinearRing *>((*holes)[i]);
+ lr->apply_rw(filter);
@@ -318,7 +324,8 @@
normalize(shell, true);
- normalize((LinearRing *)(*holes)[i], false);
+ normalize(lr, false);
sort(holes->begin(), holes->end(), GeometryGreaterThen());
@@ -369,7 +376,7 @@
area+=fabs(algorithm::CGAlgorithms::signedArea(shell->getCoordinatesRO()));
- LinearRing *lr = static_cast<LinearRing *>((*holes)[i]);
+ const LinearRing *lr = dynamic_cast<const LinearRing *>((*holes)[i]);
const CoordinateSequence *h=lr->getCoordinatesRO();
area-=fabs(algorithm::CGAlgorithms::signedArea(h));
Modified: trunk/src/geom/util/GeometryEditor.cpp
--- trunk/src/geom/util/GeometryEditor.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/geom/util/GeometryEditor.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -115,7 +115,7 @@
Geometry* editResult = edit(newPolygon->getExteriorRing(),operation);
- LinearRing* shell = static_cast<LinearRing*>(editResult);
+ LinearRing* shell = dynamic_cast<LinearRing*>(editResult);
if (shell->isEmpty()) {
//RemoveSelectedPlugIn relies on this behaviour. [Jon Aquino]
delete shell;
@@ -130,8 +130,8 @@
Geometry *hole_geom = edit(newPolygon->getInteriorRingN(i),
operation);
- assert(dynamic_cast<LinearRing*>(hole_geom));
- LinearRing *hole = static_cast<LinearRing*>(hole_geom);
+ LinearRing *hole = dynamic_cast<LinearRing*>(hole_geom);
+ assert(hole);
if (hole->isEmpty())
Modified: trunk/src/geom/util/GeometryTransformer.cpp
--- trunk/src/geom/util/GeometryTransformer.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/geom/util/GeometryTransformer.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -228,9 +228,9 @@
for (unsigned int i=0, n=geom->getNumGeometries(); i<n; i++)
- assert(dynamic_cast<const LineString*>(geom->getGeometryN(i)));
- const LineString* l = static_cast<const LineString*>(
+ const LineString* l = dynamic_cast<const LineString*>(
geom->getGeometryN(i));
+ assert(l);
Geometry::AutoPtr transformGeom = transformLineString(l, geom);
if ( transformGeom.get() == NULL ) continue;
@@ -257,9 +257,9 @@
bool isAllValidLinearRings = true;
- assert(dynamic_cast<const LinearRing*>(geom->getExteriorRing()));
- const LinearRing* lr = static_cast<const LinearRing*>(
+ const LinearRing* lr = dynamic_cast<const LinearRing*>(
geom->getExteriorRing());
+ assert(lr);
Geometry::AutoPtr shell = transformLinearRing(lr, geom);
if ( shell.get() == NULL
@@ -272,10 +272,9 @@
vector<Geometry*>* holes = new vector<Geometry*>();
for (unsigned int i=0, n=geom->getNumInteriorRing(); i<n; i++)
- geom->getInteriorRingN(i)));
geom->getInteriorRingN(i));
+ assert(lr);
Geometry::AutoPtr hole(transformLinearRing(lr, geom));
@@ -294,10 +293,9 @@
if ( isAllValidLinearRings)
Geometry* sh = shell.release();
- assert(dynamic_cast<LinearRing*>(sh));
- return Geometry::AutoPtr(factory->createPolygon(
- static_cast<LinearRing*>(sh),
- holes));
+ LinearRing* lr = dynamic_cast<LinearRing*>(sh);
+ assert(lr);
+ return Geometry::AutoPtr(factory->createPolygon(lr, holes));
else
@@ -332,9 +330,9 @@
- assert(dynamic_cast<const Polygon*>(geom->getGeometryN(i)));
- const Polygon* p = static_cast<const Polygon*>(
+ const Polygon* p = dynamic_cast<const Polygon*>(
+ assert(p);
Geometry::AutoPtr transformGeom = transformPolygon(p, geom);
Modified: trunk/src/io/WKTWriter.cpp
--- trunk/src/io/WKTWriter.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/io/WKTWriter.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -510,7 +510,10 @@
level2=level+1;
doIndent=true;
- appendLineStringText((LineString *) multiLineString->getGeometryN(i), level2, doIndent, writer);
+ const LineString* ls = dynamic_cast<const LineString *>(
+ multiLineString->getGeometryN(i)
+ appendLineStringText(ls, level2, doIndent, writer);
writer->write(")");
Modified: trunk/src/operation/linemerge/LineSequencer.cpp
--- trunk/src/operation/linemerge/LineSequencer.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/src/operation/linemerge/LineSequencer.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -67,10 +67,11 @@
for (unsigned int i=0, n=mls->getNumGeometries(); i<n; ++i)
- assert(dynamic_cast<const LineString*>(mls->getGeometryN(i)));
+ const LineString* lineptr = \
+ dynamic_cast<const LineString*>(mls->getGeometryN(i));
+ assert(lineptr);
+ const LineString& line = *lineptr;
- const LineString& line = \
- static_cast<const LineString&>(*(mls->getGeometryN(i)));
const Coordinate* startNode = &(line.getCoordinateN(0));
const Coordinate* endNode = &(line.getCoordinateN(line.getNumPoints() - 1));
@@ -208,8 +209,8 @@
lineToAdd = reverse(line);
} else {
Geometry* lineClone = line->clone();
- assert(dynamic_cast<LineString *>(lineClone));
- lineToAdd = static_cast<LineString *>(lineClone);
+ lineToAdd = dynamic_cast<LineString *>(lineClone);
+ assert(lineToAdd);
lines->push_back(lineToAdd);
Modified: trunk/tests/unit/geom/GeometryFactoryTest.cpp
--- trunk/tests/unit/geom/GeometryFactoryTest.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/tests/unit/geom/GeometryFactoryTest.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -760,7 +760,8 @@
GeometryPtr geo = reader_.read(("LINEARRING(7 7, 12 7, 12 12, 7 12, 7 7)"));
ensure( geo != 0 );
- LinearRingPtr hole = static_cast<LinearRingPtr>(geo);
+ LinearRingPtr hole = dynamic_cast<LinearRingPtr>(geo);
+ ensure( hole );
ensure( hole->isRing() );
ensure_equals( hole->getNumPoints(), interiorSize );
Modified: trunk/tests/unit/geom/LineStringTest.cpp
--- trunk/tests/unit/geom/LineStringTest.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/tests/unit/geom/LineStringTest.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -343,7 +343,7 @@
GeometryPtr geo = reader_.read("LINESTRING (0 0, 5 5, 10 5, 10 10)");
ensure( geo != 0 );
- LineStringPtr line = static_cast<LineStringPtr>(geo);
+ LineStringPtr line = dynamic_cast<LineStringPtr>(geo);
ensure(line != 0);
GeometryPtr envelope = line->getEnvelope();
@@ -365,7 +365,7 @@
ensure( geo != 0 );
ensure(line != 0);
GeometryPtr boundary = line->getBoundary();
@@ -387,7 +387,7 @@
ensure( geo != 0 );
ensure(line != 0);
GeometryPtr hull = line->convexHull();
Modified: trunk/tests/unit/geom/LinearRingTest.cpp
--- trunk/tests/unit/geom/LinearRingTest.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/tests/unit/geom/LinearRingTest.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -56,7 +56,7 @@
// Create non-empty LinearRing
GeometryPtr geo = 0;
geo = reader_.read("LINEARRING(0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10)");
- ring_ = static_cast<LinearRingPtr>(geo);
+ ring_ = dynamic_cast<LinearRingPtr>(geo);
~test_linearring_data()
@@ -411,7 +411,7 @@
GeometryPtr geo = reader_.read("LINEARRING(0 0, 5 5, 10 10, 15 5, 5 5, 0 10)");
ensure(geo != 0);
- LinearRingPtr ring = static_cast<LinearRingPtr>(geo);
+ LinearRingPtr ring = dynamic_cast<LinearRingPtr>(geo);
ensure(ring != 0);
ensure( !ring->isValid() );
Modified: trunk/tests/unit/geom/PolygonTest.cpp
--- trunk/tests/unit/geom/PolygonTest.cpp 2011-02-03 21:50:17 UTC (rev 3180)
+++ trunk/tests/unit/geom/PolygonTest.cpp 2011-02-04 08:50:42 UTC (rev 3181)
@@ -107,7 +107,7 @@
// Exterior (clone is required here because Polygon takes ownership)
GeometryPtr geo = ring.clone();
- LinearRingPtr exterior = static_cast<LinearRingPtr>(geo);
+ LinearRingPtr exterior = dynamic_cast<LinearRingPtr>(geo);
// Create non-empty Polygon
//geos::geom::Polygon poly(exterior, 0, &factory_);
More information about the geos-commits
