[geos-commits] r3187 - in trunk: include/geos/operation/union
src/operation/union
svn_geos at osgeo.org
Mon Feb 7 10:41:33 EST 2011
Author: strk
Date: 2011-02-07 07:41:32 -0800 (Mon, 07 Feb 2011)
New Revision: 3187
Added:
trunk/include/geos/operation/union/PointGeometryUnion.h
trunk/src/operation/union/PointGeometryUnion.cpp
trunk/include/geos/operation/union/Makefile.am
trunk/src/operation/union/Makefile.am
PointGeometryUnion port
Modified: trunk/include/geos/operation/union/Makefile.am
--- trunk/include/geos/operation/union/Makefile.am 2011-02-07 15:39:36 UTC (rev 3186)
+++ trunk/include/geos/operation/union/Makefile.am 2011-02-07 15:41:32 UTC (rev 3187)
@@ -9,4 +9,5 @@
geosdir = $(includedir)/geos/operation/union
geos_HEADERS = \
- CascadedPolygonUnion.h
+ CascadedPolygonUnion.h \
+ PointGeometryUnion.h
Added: trunk/include/geos/operation/union/PointGeometryUnion.h
--- trunk/include/geos/operation/union/PointGeometryUnion.h (rev 0)
+++ trunk/include/geos/operation/union/PointGeometryUnion.h 2011-02-07 15:41:32 UTC (rev 3187)
@@ -0,0 +1,72 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: operation/union/PointGeometryUnion.java r320 (JTS-1.12)
+#ifndef GEOS_OP_UNION_POINTGEOMETRYUNION_H
+#define GEOS_OP_UNION_POINTGEOMETRYUNION_H
+#include <geos/export.h>
+#include <vector>
+#include <algorithm>
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class GeometryFactory;
+ class Geometry;
+ class Puntal;
+namespace geos {
+namespace operation { // geos::operation
+namespace geounion { // geos::operation::geounion
+ * \brief
+ * Computes the union of a {@link Puntal} geometry with
+ * another arbitrary {@link Geometry}.
+ * Does not copy any component geometries.
+class GEOS_DLL PointGeometryUnion
+public:
+ static std::auto_ptr<geom::Geometry> Union(
+ const geom::Puntal& pointGeom,
+ const geom::Geometry& otherGeom);
+ PointGeometryUnion(const geom::Puntal& pointGeom,
+ std::auto_ptr<geom::Geometry> Union() const;
+private:
+ const geom::Geometry& pointGeom;
+ const geom::Geometry& otherGeom;
+ const geom::GeometryFactory* geomFact;
+} // namespace geos::operation::union
+#endif
Modified: trunk/src/operation/union/Makefile.am
--- trunk/src/operation/union/Makefile.am 2011-02-07 15:39:36 UTC (rev 3186)
+++ trunk/src/operation/union/Makefile.am 2011-02-07 15:41:32 UTC (rev 3187)
@@ -9,6 +9,7 @@
INCLUDES = -I$(top_srcdir)/include
libopunion_la_SOURCES = \
- CascadedPolygonUnion.cpp
+ CascadedPolygonUnion.cpp \
+ PointGeometryUnion.cpp
libopunion_la_LIBADD =
Added: trunk/src/operation/union/PointGeometryUnion.cpp
--- trunk/src/operation/union/PointGeometryUnion.cpp (rev 0)
+++ trunk/src/operation/union/PointGeometryUnion.cpp 2011-02-07 15:41:32 UTC (rev 3187)
@@ -0,0 +1,102 @@
+ * $Id$
+#include <memory> // for auto_ptr
+#include <algorithm> // for copy
+#include <geos/operation/union/PointGeometryUnion.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Puntal.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/MultiPoint.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Location.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/util/GeometryCombiner.h>
+#include <geos/algorithm/PointLocator.h>
+namespace geos {
+/* public */
+std::auto_ptr<geom::Geometry>
+PointGeometryUnion::Union() const
+ using namespace geom;
+ using algorithm::PointLocator;
+ using geom::util::GeometryCombiner;
+ PointLocator locater;
+ // use a set to eliminate duplicates, as required for union
+ std::set<Coordinate> exteriorCoords;
+ for (std::size_t i=0, n=pointGeom.getNumGeometries(); i<n; ++i) {
+ assert(dynamic_cast<const Point*>(pointGeom.getGeometryN(i)));
+ const Point& point = *(static_cast<const Point*>(pointGeom.getGeometryN(i)));
+ const Coordinate* coord = point.getCoordinate();
+ int loc = locater.locate(*coord, &otherGeom);
+ if (loc == Location::EXTERIOR)
+ exteriorCoords.insert(*coord);
+ // if no points are in exterior, return the other geom
+ if (exteriorCoords.empty())
+ return std::auto_ptr<Geometry>(otherGeom.clone());
+ // make a puntal geometry of appropriate size
+ std::auto_ptr<Geometry> ptComp;
+ if (exteriorCoords.size() == 1) {
+ ptComp.reset( geomFact->createPoint(*(exteriorCoords.begin())) );
+ else
+ std::vector<Coordinate> coords;
+ std::copy(exteriorCoords.begin(), exteriorCoords.end(), coords.begin());
+ ptComp.reset( geomFact->createMultiPoint(coords) );
+ // add point component to the other geometry
+ return std::auto_ptr<Geometry> (
+ GeometryCombiner::combine(ptComp.get(), &otherGeom)
+/* public static */
+PointGeometryUnion::Union(const geom::Puntal& pointGeom,
+ PointGeometryUnion unioner(pointGeom, otherGeom);
+ return unioner.Union();
+/* public */
+PointGeometryUnion::PointGeometryUnion(const geom::Puntal& pointGeom_,
+ const geom::Geometry& otherGeom_)
+ pointGeom ( pointGeom_ ),
+ otherGeom ( otherGeom_ )
+ geomFact = otherGeom.getFactory();
More information about the geos-commits
