[geos-commits] r3196 - in trunk: include/geos/operation/union
tests/unit tests/unit/operation/union
svn_geos at osgeo.org
Thu Feb 10 10:51:16 EST 2011
Author: strk
Date: 2011-02-10 07:51:16 -0800 (Thu, 10 Feb 2011)
New Revision: 3196
Added:
trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
trunk/include/geos/operation/union/UnaryUnionOp.h
trunk/tests/unit/Makefile.am
trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
Add unit test for UnaryUnionOp (and fix interface bug)
Modified: trunk/include/geos/operation/union/UnaryUnionOp.h
--- trunk/include/geos/operation/union/UnaryUnionOp.h 2011-02-10 14:14:30 UTC (rev 3195)
+++ trunk/include/geos/operation/union/UnaryUnionOp.h 2011-02-10 15:51:16 UTC (rev 3196)
@@ -106,7 +106,7 @@
geomFact(&geomFactIn)
- extractAll(geoms);
+ extractGeoms(geoms);
template <class T>
@@ -114,7 +114,7 @@
geomFact(0)
UnaryUnionOp(const geom::Geometry& geom)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2011-02-10 14:14:30 UTC (rev 3195)
+++ trunk/tests/unit/Makefile.am 2011-02-10 15:51:16 UTC (rev 3196)
@@ -81,6 +81,7 @@
operation/overlay/snap/LineStringSnapperTest.cpp \
operation/sharedpaths/SharedPathsOpTest.cpp \
operation/union/CascadedPolygonUnionTest.cpp \
+ operation/union/UnaryUnionOpTest.cpp \
operation/valid/IsValidTest.cpp \
operation/valid/ValidClosedRingTest.cpp \
operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp \
Modified: trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
--- trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2011-02-10 14:14:30 UTC (rev 3195)
+++ trunk/tests/unit/operation/union/CascadedPolygonUnionTest.cpp 2011-02-10 15:51:16 UTC (rev 3196)
@@ -24,7 +24,7 @@
// Common data used by tests
- struct test_unaryuniontest_data
+ struct test_cascadedpolygonuniontest_data
geos::geom::GeometryFactory gf;
geos::io::WKTReader wktreader;
@@ -32,16 +32,16 @@
typedef geos::geom::Geometry::AutoPtr GeomPtr;
- test_unaryuniontest_data()
+ test_cascadedpolygonuniontest_data()
: gf(),
wktreader(&gf)
- typedef test_group<test_unaryuniontest_data> group;
+ typedef test_group<test_cascadedpolygonuniontest_data> group;
typedef group::object object;
- group test_unaryuniontest_group("geos::operation::geounion::CascadedPolygonUnion");
+ group test_cascadedpolygonuniontest_group("geos::operation::geounion::CascadedPolygonUnion");
// test runner
geos::geom::Geometry* unionIterated(
@@ -72,7 +72,7 @@
return CascadedPolygonUnion::Union(geoms);
- void test_runner(test_unaryuniontest_data& t,
+ void test_runner(test_cascadedpolygonuniontest_data& t,
std::vector<geos::geom::Polygon*>* geoms)
std::auto_ptr<geos::geom::Geometry> union1(unionIterated(geoms));
Added: trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp
--- trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp (rev 0)
+++ trunk/tests/unit/operation/union/UnaryUnionOpTest.cpp 2011-02-10 15:51:16 UTC (rev 3196)
@@ -0,0 +1,155 @@
+// $Id$
+// Test Suite for geos::operation::geounion::CascadedPolygonUnion class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/operation/union/UnaryUnionOp.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+#include <iostream>
+namespace tut
+ // Test Group
+ // Common data used by tests
+ struct test_unaryuniontest_data
+ geos::geom::GeometryFactory gf;
+ geos::io::WKTReader wktreader;
+ geos::io::WKTWriter wktwriter;
+ typedef geos::geom::Geometry::AutoPtr GeomPtr;
+ typedef geos::geom::Geometry Geom;
+ typedef geos::operation::geounion::UnaryUnionOp UnaryUnionOp;
+ test_unaryuniontest_data()
+ : gf(),
+ wktreader(&gf)
+ wktwriter.setTrim(true);
+ void delAll(std::vector<Geom*>& geoms)
+ for (size_t i=0; i<geoms.size(); ++i) delete geoms[i];
+ GeomPtr readWKT(const std::string& inputWKT)
+ return GeomPtr(wktreader.read(inputWKT));
+ void readWKT(const char* const* inputWKT, std::vector<Geom*>& geoms)
+ for (const char* const* ptr=inputWKT; *ptr; ++ptr) {
+ geoms.push_back(readWKT(*ptr).release());
+ static GeomPtr normalize(const Geom& g)
+ GeomPtr g2 ( g.clone() );
+ g2->normalize();
+ return g2;
+ bool isEqual(const Geom& a, const Geom& b)
+ using std::cout;
+ using std::endl;
+ GeomPtr a2 = normalize(a);
+ GeomPtr b2 = normalize(b);
+ bool eq = a2->equalsExact(b2.get());
+ if ( ! eq ) {
+ cout << "OBTAINED: " << wktwriter.write(b2.get()) << endl;
+ return eq;
+ void doTest(const char* const* inputWKT, const std::string& expectedWKT)
+ std::vector<Geom*> geoms;
+ readWKT(inputWKT, geoms);
+ GeomPtr result;
+ if ( geoms.empty() )
+ result = UnaryUnionOp::Union(geoms, gf);
+ else
+ result = UnaryUnionOp::Union(geoms);
+ bool ok = isEqual(*readWKT(expectedWKT), *result);
+ delAll(geoms);
+ ensure(ok);
+ typedef test_group<test_unaryuniontest_data> group;
+ typedef group::object object;
+ group test_unaryuniontest_group("geos::operation::geounion::UnaryUnionOp");
+ template<>
+ template<>
+ void object::test<1>()
+ static char const* const geoms[] = { NULL };
+ doTest(geoms, "GEOMETRYCOLLECTION EMPTY");
+ template<>
+ template<>
+ void object::test<2>()
+ "POINT (1 1)", "POINT (2 2)",
+ NULL
+ doTest(geoms, "MULTIPOINT ((1 1), (2 2))");
+ template<>
+ template<>
+ void object::test<3>()
+ "GEOMETRYCOLLECTION (POLYGON ((0 0, 0 90, 90 90, 90 0, 0 0)), POLYGON ((120 0, 120 90, 210 90, 210 0, 120 0)), LINESTRING (40 50, 40 140), LINESTRING (160 50, 160 140), POINT (60 50), POINT (60 140), POINT (40 140))",
+ NULL
+ doTest(geoms, "GEOMETRYCOLLECTION (POINT (60 140), LINESTRING (40 90, 40 140), LINESTRING (160 90, 160 140), POLYGON ((0 0, 0 90, 40 90, 90 90, 90 0, 0 0)), POLYGON ((120 0, 120 90, 160 90, 210 90, 210 0, 120 0)))");
+ template<>
+ template<>
+ void object::test<4>()
+ "POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))",
+ "MULTIPOLYGON (((20 0, 20 10, 40 10, 40 0, 20 0)),((5 5, 5 8, 8 8, 8 5, 5 5)))",
+ "POINT (5 5)",
+ "POINT (-5 5)",
+ "LINESTRING (-10 -10, -10 0, -10 20)",
+ "LINESTRING (-10 2, 10 2)",
+ NULL
+ doTest(geoms, "GEOMETRYCOLLECTION (POLYGON ((0 0, 0 2, 0 10, 10 10, 10 2, 10 0, 0 0)), POLYGON ((20 0, 20 10, 40 10, 40 0, 20 0)), LINESTRING (-10 -10, -10 0, -10 2), LINESTRING (-10 2, 0 2), LINESTRING (-10 2, -10 20), POINT (-5 5))");
+} // namespace tut
More information about the geos-commits
