[geos-commits] r3200 - in trunk/tests/xmltester: . tests/general
svn_geos at osgeo.org
Thu Feb 10 16:05:32 EST 2011
Author: strk
Date: 2011-02-10 13:05:32 -0800 (Thu, 10 Feb 2011)
New Revision: 3200
Added:
trunk/tests/xmltester/tests/general/TestUnaryUnion.xml
trunk/tests/xmltester/Makefile.am
trunk/tests/xmltester/XMLTester.cpp
Add support for UnaryUnion testing in XML format, import the JTS xml test for it
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2011-02-10 21:05:23 UTC (rev 3199)
+++ trunk/tests/xmltester/Makefile.am 2011-02-10 21:05:32 UTC (rev 3200)
@@ -53,6 +53,7 @@
$(srcdir)/tests/general/TestRelatePA.xml \
$(srcdir)/tests/general/TestRelatePP.xml \
$(srcdir)/tests/general/TestSimple.xml \
+ $(srcdir)/tests/general/TestUnaryUnion.xml \
$(srcdir)/tests/general/TestValid.xml \
$(srcdir)/tests/general/TestValid2.xml \
$(srcdir)/tests/general/TestValid2-big.xml \
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2011-02-10 21:05:23 UTC (rev 3199)
+++ trunk/tests/xmltester/XMLTester.cpp 2011-02-10 21:05:32 UTC (rev 3200)
@@ -806,11 +806,16 @@
GeomAutoPtr gRes(parseGeometry(opRes, "expected"));
gRes->normalize();
+ GeomAutoPtr gRealRes;
+ if ( gB ) {
#ifndef USE_BINARYOP
- GeomAutoPtr gRealRes(gA->Union(gB));
+ gRealRes.reset(gA->Union(gB));
#else
- GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opUNION));
+ gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opUNION));
#endif
+ } else {
+ gRealRes = gA->Union();
gRealRes->normalize();
Added: trunk/tests/xmltester/tests/general/TestUnaryUnion.xml
--- trunk/tests/xmltester/tests/general/TestUnaryUnion.xml (rev 0)
+++ trunk/tests/xmltester/tests/general/TestUnaryUnion.xml 2011-02-10 21:05:32 UTC (rev 3200)
@@ -0,0 +1,150 @@
+<run>
+ <desc>Tests for Geometry.union() method (unary union)</desc>
+ <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/>
+<case>
+ <desc>P - point (showing merging of identical points)</desc>
+ <a>
+ MULTIPOINT((10 10), (0 0), (10 10))
+ </a>
+<test>
+ <op name="union" arg1="A">
+ MULTIPOINT((10 10), (0 0))
+ </op>
+</test>
+</case>
+<case>
+ <a>
+ MULTIPOINT((10 10), (0 0), (10 10), (10 10), (10 10), (5 5), (5 5))
+ </a>
+<test>
+ MULTIPOINT((10 10), (5 5), (0 0))
+ </op>
+</test>
+</case>
+<case>
+ <desc>mL - multiLineString (showing noding)</desc>
+ <a>
+ MULTILINESTRING((0 0, 10 10), (0 10, 10 0))
+ </a>
+<test>
+ MULTILINESTRING ((0 0, 5 5), (5 5, 10 10), (0 10, 5 5), (5 5, 10 0))
+ </op>
+</test>
+</case>
+<case>
+ <desc>GC - shows handling linear rings and linestrings</desc>
+ <a> GEOMETRYCOLLECTION (LINEARRING (0 0, 0 70, 80 70, 80 0, 0 0),
+ LINESTRING (30 110, 30 30, 100 30))
+ </a>
+ <test>
+ MULTILINESTRING ((0 0, 0 70, 30 70),
+ (30 70, 80 70, 80 30),
+ (80 30, 80 0, 0 0),
+ (30 110, 30 70),
+ (30 70, 30 30, 80 30),
+ (80 30, 100 30))
+ </op>
+ </test>
+</case>
+<case>
+ <desc>mL - multiLineString (showing noding and dissolving)</desc>
+ <a> MULTILINESTRING((0 0, 10 10), (5 5, 15 15))
+ </a>
+ <test>
+ MULTILINESTRING ((0 0, 5 5), (5 5, 10 10), (10 10, 15 15))
+ </op>
+ </test>
+</case>
+<case>
+ <desc>mP - multiPolygon (invalid)</desc>
+ <a> MULTIPOLYGON (((0 0, 0 100, 100 100, 100 0, 0 0)),
+ ((70 160, 70 70, 160 70, 160 160, 70 160)))
+ </a>
+ <test>
+ POLYGON ((0 0, 0 100, 70 100, 70 160, 160 160, 160 70, 100 70, 100 0, 0 0))
+ </op>
+ </test>
+</case>
+<case>
+ <desc>GC - geometry collection (homo)</desc>
+ <a> GEOMETRYCOLLECTION (POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0)),
+ POLYGON ((70 160, 70 70, 160 70, 160 160, 70 160)))
+ </a>
+ <test>
+ </op>
+ </test>
+</case>
+<case>
+ <desc>GC - geometry collection (hetero LA)</desc>
+ POLYGON ((70 160, 70 70, 160 70, 160 160, 70 160)),
+ LINESTRING (40 70, 40 160))
+ </a>
+ <test>
+ GEOMETRYCOLLECTION (LINESTRING (40 100, 40 160),
+ POLYGON ((0 0, 0 100, 40 100, 70 100, 70 160, 160 160, 160 70, 100 70, 100 0, 0 0)))
+ </op>
+ </test>
+</case>
+<case>
+ <desc>GC - geometry collection (hetero PL)</desc>
+ <a> GEOMETRYCOLLECTION (LINESTRING (40 60, 120 110),
+ POINT (120 110),
+ POINT (40 60))
+ </a>
+ <test>
+ LINESTRING (40 60, 120 110)
+ </op>
+ </test>
+</case>
+<case>
+ POINT (120 110),
+ POINT (40 60),
+ POINT (100 70),
+ POINT (80 50))
+ </a>
+ <test>
+ GEOMETRYCOLLECTION (POINT (80 50), POINT (100 70), LINESTRING (40 60, 120 110))
+ </op>
+ </test>
+</case>
+<case>
+ <desc>mP - multipolygon (invalid) with topology collapse</desc>
+ <a> MULTIPOLYGON (((0 0, 150 0, 150 1, 0 0)),
+ ((180 0, 20 0, 20 100, 180 100, 180 0)))
+ </a>
+ <test>
+ GEOMETRYCOLLECTION (LINESTRING (0 0, 20 0),
+ POLYGON ((150 0, 20 0, 20 100, 180 100, 180 0, 150 0)))
+ </op>
+ </test>
+</case>
+</run>
More information about the geos-commits
