[geos-commits] r3208 - trunk/include/geos/geom/util
svn_geos at osgeo.org
Sun Feb 13 14:25:25 EST 2011
Author: mloskot
Date: 2011-02-13 11:25:25 -0800 (Sun, 13 Feb 2011)
New Revision: 3208
trunk/include/geos/geom/util/GeometryExtracter.h
Renamed template parameters to more readable CamelCase and self-descriptive form. Declare Extracter type as non-copyable. Do not use names starting with underscore - they are reserved for C++ implementations.
Modified: trunk/include/geos/geom/util/GeometryExtracter.h
--- trunk/include/geos/geom/util/GeometryExtracter.h 2011-02-13 19:22:24 UTC (rev 3207)
+++ trunk/include/geos/geom/util/GeometryExtracter.h 2011-02-13 19:25:25 UTC (rev 3208)
@@ -46,24 +46,24 @@
* @param geom the geometry from which to extract
* @param list the list to add the extracted elements to
- template <class to, class container>
- static void extract(const Geometry& geom, container& lst)
+ template <class ComponentType, class TargetContainer>
+ static void extract(const Geometry& geom, TargetContainer& lst)
- if ( const to* c = dynamic_cast<const to*>(&geom) )
+ if ( const ComponentType* c = dynamic_cast<const ComponentType*>(&geom) )
lst.push_back(c);
else if ( const GeometryCollection* c =
dynamic_cast<const GeometryCollection*>(&geom) )
- GeometryExtracter::Extracter<to, container> extracter(lst);
+ GeometryExtracter::Extracter<ComponentType, TargetContainer> extracter(lst);
c->apply_ro(&extracter);
private:
- template <class TO, class CO>
struct Extracter: public GeometryFilter {
@@ -71,17 +71,20 @@
* @param comps the container to extract into (will push_back to it)
- Extracter(CO& comps) : _comps(comps) {}
+ Extracter(TargetContainer& comps) : comps_(comps) {}
- CO& _comps;
+ TargetContainer& comps_;
void filter_ro(const Geometry* geom)
- if ( const TO* c = dynamic_cast<const TO*>(geom) ) {
- _comps.push_back(c);
+ if ( const ComponentType* c = dynamic_cast<const ComponentType*>(geom) ) {
+ comps_.push_back(c);
+ // Declare type as noncopyable
+ Extracter(const Extracter& other);
+ Extracter& operator=(const Extracter& rhs);
More information about the geos-commits
