[geos-commits] r3214 - trunk/tests/unit/operation/distance
svn_geos at osgeo.org svn_geos at osgeo.org
Sun Feb 13 15:14:49 EST 2011
Author: mloskot
Date: 2011-02-13 12:14:49 -0800 (Sun, 13 Feb 2011)
New Revision: 3214
   trunk/tests/unit/operation/distance/DistanceOpTest.cpp
CRLF to LF
Modified: trunk/tests/unit/operation/distance/DistanceOpTest.cpp
--- trunk/tests/unit/operation/distance/DistanceOpTest.cpp	2011-02-13 20:14:07 UTC (rev 3213)
+++ trunk/tests/unit/operation/distance/DistanceOpTest.cpp	2011-02-13 20:14:49 UTC (rev 3214)
@@ -462,19 +462,19 @@
 	template<>
 	template<>
 	void object::test<19>()
-        const char* wkb_geom1 = "01060000000100000001030000000100000000000000";
-        const char* wkb_geom2 = "010100000000000000000000000000000000000000";
-        geos::geom::PrecisionModel precision(geos::geom::PrecisionModel::FLOATING);
-        geos::geom::GeometryFactory f(&precision);
-        std::istringstream istr1(wkb_geom1);
-        std::istringstream istr2(wkb_geom2);
-        geos::io::WKBReader wkb(f);
-        GeomPtr g1(wkb.readHEX(istr1));
-        GeomPtr g2(wkb.readHEX(istr2));
-        ensure(g1->isValid());
-        ensure(g2->isValid());
+        const char* wkb_geom1 = "01060000000100000001030000000100000000000000";
+        const char* wkb_geom2 = "010100000000000000000000000000000000000000";
+        geos::geom::PrecisionModel precision(geos::geom::PrecisionModel::FLOATING);
+        geos::geom::GeometryFactory f(&precision);
+        std::istringstream istr1(wkb_geom1);
+        std::istringstream istr2(wkb_geom2);
+        geos::io::WKBReader wkb(f);
+        GeomPtr g1(wkb.readHEX(istr1));
+        GeomPtr g2(wkb.readHEX(istr2));
+        ensure(g1->isValid());
+        ensure(g2->isValid());
 	// TODO: finish the tests by adding:
More information about the geos-commits mailing list
