[geos-commits] r3220 - in trunk/php: . test
svn_geos at osgeo.org
Tue Feb 15 10:15:15 EST 2011
Author: strk
Date: 2011-02-15 07:15:15 -0800 (Tue, 15 Feb 2011)
New Revision: 3220
trunk/php/geos.c
trunk/php/test/test.php
Adapt PHP binding to the new GEOSisValidDetail interface
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2011-02-15 15:15:09 UTC (rev 3219)
+++ trunk/php/geos.c 2011-02-15 15:15:15 UTC (rev 3220)
@@ -1157,10 +1157,16 @@
zend_bool retBool;
char *reasonVal = NULL;
zval *locationVal = NULL;
+ long int flags = 0;
this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
- ret = GEOSisValidDetail(this, &reason, &location);
+ if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "|l",
+ &flags) == FAILURE) {
+ RETURN_NULL();
+ ret = GEOSisValidDetail(this, flags, &reason, &location);
if ( ret == 2 ) RETURN_NULL(); /* should get an exception first */
if ( reason ) {
@@ -2474,6 +2480,10 @@
REGISTER_LONG_CONSTANT("GEOS_GEOMETRYCOLLECTION", GEOS_GEOMETRYCOLLECTION,
CONST_CS|CONST_PERSISTENT);
+ REGISTER_LONG_CONSTANT("GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE",
+ GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE,
+ CONST_CS|CONST_PERSISTENT);
return SUCCESS;
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2011-02-15 15:15:09 UTC (rev 3219)
+++ trunk/php/test/test.php 2011-02-15 15:15:15 UTC (rev 3220)
@@ -33,6 +33,8 @@
$this->assertEquals(5, GEOS_MULTILINESTRING);
$this->assertEquals(6, GEOS_MULTIPOLYGON);
$this->assertEquals(7, GEOS_GEOMETRYCOLLECTION);
+ $this->assertEquals(1, GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE);
public function testWKTReader__construct()
@@ -1328,6 +1330,26 @@
$this->assertEquals( 'Invalid Coordinate', $val['reason'] );
$this->assertEquals( 'POINT (0 nan)',
$writer->write($val['location']) );
+ $g = $reader->read(
+ 'POLYGON((0 0, -10 10, 10 10, 0 0, 4 5, -4 5, 0 0)))'
+ $val = $g->checkValidity();
+ $this->assertType( 'array', $val );
+ $this->assertFalse( $val['valid'] );
+ $this->assertEquals( 'Ring Self-intersection', $val['reason'] );
+ $this->assertEquals( 'POINT (0 0)',
+ $writer->write($val['location']) );
+ $flags = GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE;
+ $val = $g->checkValidity($flags);
+ $this->assertTrue( $val['valid'] );
+ $this->assertFalse( isset($val['reason']) );
+ $this->assertFalse( isset($val['location']) );
public function testGeometry_isSimple()
More information about the geos-commits
