[geos-commits] r3227 - in trunk: include/geos/operation/linemerge
src/operation/linemerge
svn_geos at osgeo.org
Mon Feb 21 11:14:18 EST 2011
Author: strk
Date: 2011-02-21 08:14:18 -0800 (Mon, 21 Feb 2011)
New Revision: 3227
trunk/include/geos/operation/linemerge/LineSequencer.h
trunk/src/operation/linemerge/LineSequencer.cpp
Sync linemerge::LineSequencer to JTS-1.12
Modified: trunk/include/geos/operation/linemerge/LineSequencer.h
--- trunk/include/geos/operation/linemerge/LineSequencer.h 2011-02-21 14:02:42 UTC (rev 3226)
+++ trunk/include/geos/operation/linemerge/LineSequencer.h 2011-02-21 16:14:18 UTC (rev 3227)
@@ -13,7 +13,7 @@
- * Last port: operation/linemerge/LineSequencer.java rev. 1.6 (JTS-1.10)
+ * Last port: operation/linemerge/LineSequencer.java r320 (JTS-1.12)
@@ -60,7 +60,7 @@
* The input linestrings may form one or more connected sets.
* The input linestrings should be correctly noded, or the results may
* not be what is expected.
- * The output of this method is a single MultiLineString containing the ordered
+ * The computed output is a single MultiLineString containing the ordered
* linestrings in the sequence.
* The sequencing employs the classic <b>Eulerian path</b> graph algorithm.
@@ -176,6 +176,13 @@
public:
+ static geom::Geometry* sequence(const geom::Geometry& geom)
+ LineSequencer sequencer;
+ sequencer.add(geom);
+ return sequencer.getSequencedLineStrings();
LineSequencer()
factory(0),
Modified: trunk/src/operation/linemerge/LineSequencer.cpp
--- trunk/src/operation/linemerge/LineSequencer.cpp 2011-02-21 14:02:42 UTC (rev 3226)
+++ trunk/src/operation/linemerge/LineSequencer.cpp 2011-02-21 16:14:18 UTC (rev 3227)
@@ -13,7 +13,7 @@
More information about the geos-commits
