[geos-commits] r3235 - trunk/tests/unit/noding
svn_geos at osgeo.org
Wed Feb 23 05:25:28 EST 2011
Author: strk
Date: 2011-02-23 02:25:28 -0800 (Wed, 23 Feb 2011)
New Revision: 3235
trunk/tests/unit/noding/SegmentPointComparatorTest.cpp
Port JTS unit tests for SegmentPointComparator
Modified: trunk/tests/unit/noding/SegmentPointComparatorTest.cpp
--- trunk/tests/unit/noding/SegmentPointComparatorTest.cpp 2011-02-23 10:25:20 UTC (rev 3234)
+++ trunk/tests/unit/noding/SegmentPointComparatorTest.cpp 2011-02-23 10:25:28 UTC (rev 3235)
@@ -1,11 +1,18 @@
// $Id$
// Test Suite for geos::noding::SegmentPointComparator class.
+// Ports tests found in jts/junit/noding/SegmentPointComparatorTest.java
+// and jts/junit/noding/SegmentPointComparatorFullTest.java
#include <tut.hpp>
// geos
#include <geos/noding/SegmentNode.h>
+#include <geos/noding/SegmentPointComparator.h>
#include <geos/noding/SegmentString.h>
+#include <geos/noding/Octant.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/LineSegment.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/CoordinateArraySequenceFactory.h>
@@ -22,17 +29,91 @@
struct test_segmentpointcomparator_data
- typedef std::auto_ptr<geos::geom::CoordinateSequence>
+ typedef std::auto_ptr<geos::geom::CoordinateSequence>
CoordinateSequenceAutoPtr;
- typedef std::auto_ptr<geos::noding::SegmentString>
+ typedef std::auto_ptr<geos::noding::SegmentString>
SegmentStringAutoPtr;
+ typedef geos::geom::Coordinate Coordinate;
+ typedef geos::geom::LineSegment LineSegment;
+ typedef geos::geom::PrecisionModel PrecisionModel;
- const geos::geom::CoordinateSequenceFactory* csFactory;
+ PrecisionModel pm;
test_segmentpointcomparator_data()
- : csFactory(geos::geom::CoordinateArraySequenceFactory::instance())
+ : pm(1.0)
+ void checkNodePosition(int octant, double x0, double y0,
+ double x1, double y1, int
+ expectedPositionValue)
+ using geos::noding::SegmentPointComparator;
+ int posValue = SegmentPointComparator::compare(octant,
+ Coordinate(x0, y0),
+ Coordinate(x1, y1)
+ ensure( posValue == expectedPositionValue );
+ void checkNodePosition(const LineSegment& seg, const Coordinate& p0,
+ const Coordinate& p1, int expectedPositionValue)
+ using geos::noding::Octant;
+ int octant = Octant::octant(seg.p0, seg.p1);
+ int posValue = SegmentPointComparator::compare(octant, p0, p1);
+ Coordinate computePoint(const LineSegment& seg, double dist)
+ double dx = seg.p1.x - seg.p0.x;
+ double dy = seg.p1.y - seg.p0.y;
+ double len = seg.getLength();
+ Coordinate pt(dist * dx / len, dist * dy / len);
+ pm.makePrecise(pt);
+ return pt;
+ void checkPointsAtDistance(const LineSegment& seg,
+ double dist0, double dist1)
+ using geos::geom::Coordinate;
+ Coordinate p0 = computePoint(seg, dist0);
+ Coordinate p1 = computePoint(seg, dist1);
+ if (p0.equals(p1)) {
+ checkNodePosition(seg, p0, p1, 0);
+ else {
+ checkNodePosition(seg, p0, p1, -1);
+ checkNodePosition(seg, p1, p0, 1);
+ void checkSegment(double x, double y)
+ Coordinate seg0(0, 0);
+ Coordinate seg1(x, y);
+ LineSegment seg(seg0, seg1);
+ for (int i = 0; i < 4; i++) {
+ double dist = i;
+ double gridSize = 1 / pm.getScale();
+ checkPointsAtDistance(seg, dist, dist + 1.0 * gridSize);
+ checkPointsAtDistance(seg, dist, dist + 2.0 * gridSize);
+ checkPointsAtDistance(seg, dist, dist + 3.0 * gridSize);
+ checkPointsAtDistance(seg, dist, dist + 4.0 * gridSize);
typedef test_group<test_segmentpointcomparator_data> group;
@@ -44,14 +125,58 @@
// Test Cases
- // TODO
+ // testOctant0 (from simple unit test)
template<>
template<>
void object::test<1>()
+ checkNodePosition(0, 1, 1, 2, 2, -1);
+ checkNodePosition(0, 1, 0, 1, 1, -1);
- // TODO - mloskot add test cases
+ // testQuadrant0
+ template<>
+ template<>
+ void object::test<2>()
+ checkSegment(100, 0);
+ checkSegment(100, 50);
+ checkSegment(100, 100);
+ checkSegment(100, 150);
+ checkSegment(0, 100);
+ // testQuadrant4
+ template<>
+ template<>
+ void object::test<3>()
+ checkSegment(100, -50);
+ checkSegment(100, -100);
+ checkSegment(100, -150);
+ checkSegment(0, -100);
+ // testQuadrant1
+ template<>
+ template<>
+ void object::test<4>()
+ checkSegment(-100, 0);
+ checkSegment(-100, 50);
+ checkSegment(-100, 100);
+ checkSegment(-100, 150);
+ // testQuadrant2
+ template<>
+ template<>
+ void object::test<5>()
+ checkSegment(-100, -50);
+ checkSegment(-100, -100);
+ checkSegment(-100, -150);
} // namespace tut
More information about the geos-commits
