[geos-commits] r3237 - in trunk: include/geos/noding/snapround
src/noding/snapround
svn_geos at osgeo.org
Wed Feb 23 09:37:05 EST 2011
Author: strk
Date: 2011-02-23 06:37:05 -0800 (Wed, 23 Feb 2011)
New Revision: 3237
trunk/include/geos/noding/snapround/HotPixel.h
trunk/include/geos/noding/snapround/HotPixel.inl
trunk/src/noding/snapround/HotPixel.cpp
Sync HotPixel to JTS-1.12 (doxygen + privatization of a method..)
Modified: trunk/include/geos/noding/snapround/HotPixel.h
--- trunk/include/geos/noding/snapround/HotPixel.h 2011-02-23 11:05:03 UTC (rev 3236)
+++ trunk/include/geos/noding/snapround/HotPixel.h 2011-02-23 14:37:05 UTC (rev 3237)
@@ -13,7 +13,7 @@
- * Last port: noding/snapround/HotPixel.java rev. 1.3 (JTS-1.9)
+ * Last port: noding/snapround/HotPixel.java r320 (JTS-1.12)
@@ -135,6 +135,9 @@
bool intersectsPixelClosure(const geom::Coordinate& p0,
const geom::Coordinate& p1);
+ bool intersectsScaled(const geom::Coordinate& p0,
+ const geom::Coordinate& p1) const;
// Declare type as noncopyable
HotPixel(const HotPixel& other);
@@ -142,6 +145,14 @@
public:
+ * Creates a new hot pixel.
+ * @param pt the coordinate at the centre of the pixel
+ * @param scaleFact the scaleFactor determining the pixel size
+ * @param li the intersector to use for testing intersection with
+ * line segments
HotPixel(const geom::Coordinate& pt,
double scaleFact,
algorithm::LineIntersector& li);
@@ -154,12 +165,19 @@
/** \brief
* Returns a "safe" envelope that is guaranteed to contain
* the hot pixel. Keeps ownership of it.
+ * The envelope returned will be larger than the exact envelope of the
+ * pixel.
const geom::Envelope& getSafeEnvelope() const;
- bool intersectsScaled(const geom::Coordinate& p0,
- const geom::Coordinate& p1) const;
+ * Tests whether the line segment (p0-p1) intersects this hot pixel.
+ * @param p0 the first coordinate of the line segment to test
+ * @param p1 the second coordinate of the line segment to test
+ * @return true if the line segment intersects this hot pixel
bool intersects(const geom::Coordinate& p0,
Modified: trunk/include/geos/noding/snapround/HotPixel.inl
--- trunk/include/geos/noding/snapround/HotPixel.inl 2011-02-23 11:05:03 UTC (rev 3236)
+++ trunk/include/geos/noding/snapround/HotPixel.inl 2011-02-23 14:37:05 UTC (rev 3237)
@@ -13,7 +13,7 @@
Modified: trunk/src/noding/snapround/HotPixel.cpp
--- trunk/src/noding/snapround/HotPixel.cpp 2011-02-23 11:05:03 UTC (rev 3236)
+++ trunk/src/noding/snapround/HotPixel.cpp 2011-02-23 14:37:05 UTC (rev 3237)
@@ -13,7 +13,7 @@
@@ -56,8 +56,10 @@
const Envelope&
HotPixel::getSafeEnvelope() const
+ static const double SAFE_ENV_EXPANSION_FACTOR = 0.75;
if (safeEnv.get() == NULL) {
- double safeTolerance = .75 / scaleFactor;
+ double safeTolerance = SAFE_ENV_EXPANSION_FACTOR / scaleFactor;
safeEnv = auto_ptr<Envelope>(new Envelope(originalPt.x - safeTolerance,
originalPt.x + safeTolerance,
originalPt.y - safeTolerance,
@@ -96,6 +98,7 @@
return intersectsScaled(p0Scaled, p1Scaled);
+/* private */
bool
HotPixel::intersectsScaled(const Coordinate& p0,
const Coordinate& p1) const
More information about the geos-commits
