[geos-commits] r3252 - in trunk: src/operation/buffer
tests/xmltester
svn_geos at osgeo.org
Mon Feb 28 09:36:07 EST 2011
Author: strk
Date: 2011-02-28 06:36:07 -0800 (Mon, 28 Feb 2011)
New Revision: 3252
trunk/src/operation/buffer/BufferOp.cpp
trunk/tests/xmltester/Makefile.am
Fix BufferOp::bufferFixedPrecision to use snap-rounding noder. Fixes bug #356.
Modified: trunk/src/operation/buffer/BufferOp.cpp
--- trunk/src/operation/buffer/BufferOp.cpp 2011-02-28 12:19:22 UTC (rev 3251)
+++ trunk/src/operation/buffer/BufferOp.cpp 2011-02-28 14:36:07 UTC (rev 3252)
@@ -193,21 +193,8 @@
PrecisionModel pm(1.0); // fixed as well
+ snapround::MCIndexSnapRounder inoder(pm);
-// FIXME: both MCIndexSnapRounder and SimpleSnapRounder
-// makes buffer_snapround.xml test fail.
-#if 0
- snapround::MCIndexSnapRounder inoder(pm); // fail
- snapround::SimpleSnapRounder inoder(pm); // fail
-#else
- algorithm::LineIntersector li(&fixedPM);
- IntersectionAdder ia(li);
- MCIndexNoder inoder(&ia); // This works fine (but does not snapround)
-#endif
ScaledNoder noder(inoder, fixedPM.getScale());
BufferBuilder bufBuilder(bufParams);
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2011-02-28 12:19:22 UTC (rev 3251)
+++ trunk/tests/xmltester/Makefile.am 2011-02-28 14:36:07 UTC (rev 3252)
@@ -25,6 +25,7 @@
$(srcdir)/tests/bug188.xml \
$(srcdir)/tests/bug244.xml \
$(srcdir)/tests/bug275.xml \
+ $(srcdir)/tests/bug356.xml \
$(srcdir)/tests/bug358.xml \
$(srcdir)/tests/bug360.xml \
$(srcdir)/tests/bug366.xml \
More information about the geos-commits
