[geos-commits] r3167 - trunk/tests/xmltester
svn_geos at osgeo.org
Tue Jan 25 18:08:35 EST 2011
Author: mloskot
Date: 2011-01-25 15:08:35 -0800 (Tue, 25 Jan 2011)
New Revision: 3167
trunk/tests/xmltester/CMakeLists.txt
Updated CMake configuration to call xmltester from runtime output directory.
Modified: trunk/tests/xmltester/CMakeLists.txt
--- trunk/tests/xmltester/CMakeLists.txt 2010-12-26 21:20:33 UTC (rev 3166)
+++ trunk/tests/xmltester/CMakeLists.txt 2011-01-25 23:08:35 UTC (rev 3167)
@@ -98,7 +98,7 @@
${XMLTESTS_DIR}/safe/16595.xml
${XMLTESTS_DIR}/safe/16596.xml)
- add_test(xmltester ${CMAKE_CURRENT_BINARY_DIR}/xmltester ${SAVE_XMLTESTS})
+ add_test(xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/xmltester ${SAVE_XMLTESTS})
set(STATUS_RESULT "ON")
endif()
More information about the geos-commits
