[geos-commits] r3422 - in trunk: src/operation/valid
tests/xmltester tests/xmltester/tests/ticket
svn_geos at osgeo.org
Tue Jul 5 06:56:39 EDT 2011
Author: strk
Date: 2011-07-05 03:56:39 -0700 (Tue, 05 Jul 2011)
New Revision: 3422
Removed:
trunk/tests/xmltester/tests/ticket/bug449.xml
trunk/src/operation/valid/IndexedNestedRingTester.cpp
trunk/tests/xmltester/Makefile.am
Revert "When checking for validity, do not abort if every vertex of an hole is also a vertex of another one. Fixes bug #449, including regress testing." (will redo the JTS way)
This reverts commit 7d2306c8dca2f0f1c5722640758578c1d59c7295.
Modified: trunk/src/operation/valid/IndexedNestedRingTester.cpp
--- trunk/src/operation/valid/IndexedNestedRingTester.cpp 2011-07-05 10:53:48 UTC (rev 3421)
+++ trunk/src/operation/valid/IndexedNestedRingTester.cpp 2011-07-05 10:56:39 UTC (rev 3422)
@@ -50,6 +50,7 @@
for (size_t j=0, jn=results.size(); j<jn; ++j)
const geom::LinearRing* searchRing = static_cast<const geom::LinearRing*>(results[j]);
+ const geom::CoordinateSequence *searchRingPts=searchRing->getCoordinatesRO();
if (innerRing==searchRing)
continue;
@@ -60,20 +61,15 @@
continue;
- const geom::Coordinate *innerRingPt =
+ const geom::Coordinate *innerRingPt =
IsValidOp::findPtNotNode(innerRingPts,
searchRing,
graph);
- // Unable to find a ring point not a node of
- // the search ring. Can happen, see
- // http://trac.osgeo.org/geos/ticket/449
- // for examples.
- if ( ! innerRingPt ) {
- continue;
+ // Unable to find a ring point not a node of
+ // the search ring
+ assert(innerRingPt!=NULL);
- const geom::CoordinateSequence *searchRingPts=searchRing->getCoordinatesRO();
bool isInside = algorithm::CGAlgorithms::isPointInRing(
*innerRingPt, searchRingPts);
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2011-07-05 10:53:48 UTC (rev 3421)
+++ trunk/tests/xmltester/Makefile.am 2011-07-05 10:56:39 UTC (rev 3422)
@@ -33,7 +33,6 @@
$(srcdir)/tests/ticket/bug392.xml \
$(srcdir)/tests/ticket/bug398.xml \
$(srcdir)/tests/ticket/bug434.xml \
- $(srcdir)/tests/ticket/bug449.xml \
$(srcdir)/tests/general/TestBoundary.xml \
$(srcdir)/tests/general/TestBuffer.xml \
$(srcdir)/tests/general/TestBufferMitredJoin.xml \
Deleted: trunk/tests/xmltester/tests/ticket/bug449.xml
--- trunk/tests/xmltester/tests/ticket/bug449.xml 2011-07-05 10:53:48 UTC (rev 3421)
+++ trunk/tests/xmltester/tests/ticket/bug449.xml 2011-07-05 10:56:39 UTC (rev 3422)
@@ -1,21 +0,0 @@
-<run>
- <precisionModel type="FLOATING" />
-<case>
- <desc>
-http://trac.osgeo.org/geos/ticket/449
- </desc>
- <a>
- POLYGON(
- (0 0, 0 5, 6 5, 6 0, 0 0),
- (2 1, 4 1, 3 2, 2 1),
- (2 1, 1 4, 5 4, 4 1, 4 3, 3 2, 2 3, 2 1)
- </a>
-<test>
- <op name="isValid" arg1="A">false</op>
-</test>
-</case>
-</run>
More information about the geos-commits
