[geos-commits] r3440 - in branches/3.3: . src/operation/buffer
tests/unit/capi
svn_geos at osgeo.org
Wed Jul 20 07:48:31 EDT 2011
Author: strk
Date: 2011-07-20 04:48:31 -0700 (Wed, 20 Jul 2011)
New Revision: 3440
branches/3.3/NEWS
branches/3.3/src/operation/buffer/BufferBuilder.cpp
branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp
Fix EMPTY result from GEOSOffsetCurve with distance 0 (#454)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2011-07-20 11:45:24 UTC (rev 3439)
+++ branches/3.3/NEWS 2011-07-20 11:48:31 UTC (rev 3440)
@@ -6,6 +6,7 @@
- Enable prepared intersects operation for points
- Fortify suspicious code found by static analisys tools
- Fix for SOLARIS build
+ - Fix EMPTY result from GEOSOffsetCurve with distance 0 (#454)
Changes in 3.3.0
2011-05-30
Modified: branches/3.3/src/operation/buffer/BufferBuilder.cpp
--- branches/3.3/src/operation/buffer/BufferBuilder.cpp 2011-07-20 11:45:24 UTC (rev 3439)
+++ branches/3.3/src/operation/buffer/BufferBuilder.cpp 2011-07-20 11:48:31 UTC (rev 3440)
@@ -141,6 +141,9 @@
const LineString* l = dynamic_cast< const LineString* >( g );
if ( !l ) throw util::IllegalArgumentException("BufferBuilder::bufferLineSingleSided only accept linestrings");
+ // Nothing to do for a distance of zero
+ if ( distance == 0 ) return g->clone();
// Get geometry factory and precision model.
const PrecisionModel* precisionModel = workingPrecisionModel;
if ( !precisionModel ) precisionModel = l->getPrecisionModel();
Modified: branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp
--- branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp 2011-07-20 11:45:24 UTC (rev 3439)
+++ branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp 2011-07-20 11:48:31 UTC (rev 3440)
@@ -168,6 +168,26 @@
+ // 0 distance
+ // See http://trac.osgeo.org/postgis/ticket/454
+ template<>
+ template<>
+ void object::test<6>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, 10 0)");
+ ensure( 0 != geom1_ );
+ geom2_ = GEOSOffsetCurve(geom1_, 0, 0, GEOSBUF_JOIN_ROUND, 2);
+ ensure( 0 != geom2_ );
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ ensure_equals(std::string(wkt_), std::string(
+ "LINESTRING (0 0, 10 0)"
} // namespace tut
More information about the geos-commits
