[geos-commits] r3448 - in trunk: include/geos/geomgraph
src/geomgraph
svn_geos at osgeo.org
Thu Jul 21 05:54:02 EDT 2011
Author: strk
Date: 2011-07-21 02:54:02 -0700 (Thu, 21 Jul 2011)
New Revision: 3448
trunk/include/geos/geomgraph/TopologyLocation.h
trunk/src/geomgraph/TopologyLocation.cpp
Add assignment operator to TopologyLocation, drop old logs, sync port info
Modified: trunk/include/geos/geomgraph/TopologyLocation.h
--- trunk/include/geos/geomgraph/TopologyLocation.h 2011-07-20 21:12:02 UTC (rev 3447)
+++ trunk/include/geos/geomgraph/TopologyLocation.h 2011-07-21 09:54:02 UTC (rev 3448)
@@ -1,5 +1,4 @@
- * $Id$
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
@@ -14,7 +13,7 @@
- * Last port: geomgraph/TopologyLocation.java rev. 1.6 (JTS-1.10)
+ * Last port: geomgraph/TopologyLocation.java r428 (JTS-1.12+)
@@ -85,6 +84,8 @@
TopologyLocation(const TopologyLocation &gl);
+ TopologyLocation& operator= (const TopologyLocation &gl);
int get(std::size_t posIndex) const;
@@ -148,19 +149,3 @@
#endif // ifndef GEOS_GEOMGRAPH_TOPOLOGYLOCATION_H
- * $Log$
- * Revision 1.4 2006/06/12 11:29:23 strk
- * unsigned int => size_t
- * Revision 1.3 2006/04/06 09:01:11 strk
- * Doxygen comments, port info, operator<<, assertion checking
- * Revision 1.2 2006/03/24 09:52:41 strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.1 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/src/geomgraph/TopologyLocation.cpp
--- trunk/src/geomgraph/TopologyLocation.cpp 2011-07-20 21:12:02 UTC (rev 3447)
+++ trunk/src/geomgraph/TopologyLocation.cpp 2011-07-21 09:54:02 UTC (rev 3448)
@@ -1,5 +1,4 @@
- * $Id$
@@ -14,7 +13,7 @@
@@ -66,13 +65,21 @@
/*public*/
-TopologyLocation::TopologyLocation(const TopologyLocation &gl):
+TopologyLocation::TopologyLocation(const TopologyLocation &gl)
location(gl.location)
- //location=new vector<int>(gl->location->begin(),gl->location->end());
/*public*/
+TopologyLocation&
+TopologyLocation::operator= (const TopologyLocation &gl)
+ location = gl.location;
+ return *this;
+/*public*/
int
TopologyLocation::get(size_t posIndex) const
@@ -228,45 +235,4 @@
} // namespace geos.geomgraph
} // namespace geos
- * $Log$
- * Revision 1.10 2006/06/12 11:29:23 strk
- * Revision 1.9 2006/04/06 09:01:10 strk
- * Revision 1.8 2006/03/15 17:16:29 strk
- * streamlined headers inclusion
- * Revision 1.7 2006/03/03 10:46:21 strk
- * Removed 'using namespace' from headers, added missing headers in .cpp files, removed useless includes in headers (bug#46)
- * Revision 1.6 2006/02/19 19:46:49 strk
- * Packages <-> namespaces mapping for most GEOS internal code (uncomplete, but working). Dir-level libs for index/ subdirs.
- * Revision 1.5 2005/11/29 15:45:39 strk
- * Fixed signedness of TopologyLocation methods, cleanups.
- * Revision 1.4 2005/11/15 18:30:59 strk
- * Removed dead code
- * Revision 1.3 2005/11/14 18:14:04 strk
- * Reduced heap allocations made by TopologyLocation and Label objects.
- * Enforced const-correctness on GraphComponent.
- * Cleanups.
- * Revision 1.2 2004/07/02 13:28:26 strk
- * Fixed all #include lines to reflect headers layout change.
- * Added client application build tips in README.
- * Revision 1.1 2004/03/19 09:48:45 ybychkov
- * "geomgraph" and "geomgraph/indexl" upgraded to JTS 1.4
- * Revision 1.8 2003/11/07 01:23:42 pramsey
- * Add standard CVS headers licence notices and copyrights to all cpp and h
- * files.
More information about the geos-commits
