[geos-commits] r3451 - in trunk: . include/geos/noding
src/geom/prep src/noding src/operation/buffer tests/unit/noding
svn_geos at osgeo.org
Tue Jul 26 12:23:31 EDT 2011
Author: strk
Date: 2011-07-26 09:23:30 -0700 (Tue, 26 Jul 2011)
New Revision: 3451
trunk/NEWS
trunk/include/geos/noding/NodedSegmentString.h
trunk/include/geos/noding/SegmentNodeList.h
trunk/include/geos/noding/SegmentStringUtil.h
trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp
trunk/src/geom/prep/PreparedLineString.cpp
trunk/src/geom/prep/PreparedLineStringIntersects.cpp
trunk/src/geom/prep/PreparedPolygon.cpp
trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp
trunk/src/geom/prep/PreparedPolygonIntersects.cpp
trunk/src/noding/SegmentNodeList.cpp
trunk/src/operation/buffer/BufferBuilder.cpp
trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
trunk/tests/unit/noding/NodedSegmentStringTest.cpp
trunk/tests/unit/noding/SegmentNodeTest.cpp
Have NodedSegmentString take ownership of CoordinateSequence
Modified: trunk/NEWS
--- trunk/NEWS 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/NEWS 2011-07-26 16:23:30 UTC (rev 3451)
@@ -8,6 +8,7 @@
- Signature of most functions taking an IntersectionMatrix changed
to take it by reference rather than pointer.
- GraphComponent::label is now a Label value (from a pointer)
+ - NodedSegmentString takes ownership of CoordinateSequence now
Changes in 3.3.0
2011-05-30
Modified: trunk/include/geos/noding/NodedSegmentString.h
--- trunk/include/geos/noding/NodedSegmentString.h 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/include/geos/noding/NodedSegmentString.h 2011-07-26 16:23:30 UTC (rev 3451)
@@ -83,7 +83,7 @@
* Creates a new segment string from a list of vertices.
* @param newPts CoordinateSequence representing the string,
- * externally owned
+ * ownership transferred.
* @param data the user-defined data of this segment string
* (may be null)
@@ -95,7 +95,9 @@
~NodedSegmentString()
+ delete pts;
* Adds an intersection node for a given point and segment to this segment string.
Modified: trunk/include/geos/noding/SegmentNodeList.h
--- trunk/include/geos/noding/SegmentNodeList.h 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/include/geos/noding/SegmentNodeList.h 2011-07-26 16:23:30 UTC (rev 3451)
@@ -64,9 +64,6 @@
// This vector is here to keep track of created splitEdges
std::vector<SegmentString*> splitEdges;
- // This vector is here to keep track of created Coordinates
- std::vector<geom::CoordinateSequence*> splitCoordLists;
* Checks the correctness of the set of split edges corresponding
* to this edge
Modified: trunk/include/geos/noding/SegmentStringUtil.h
--- trunk/include/geos/noding/SegmentStringUtil.h 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/include/geos/noding/SegmentStringUtil.h 2011-07-26 16:23:30 UTC (rev 3451)
@@ -47,14 +47,7 @@
* @param geom the geometry to extract from
* @param segStr a List of SegmentStrings (output parameter).
* Ownership of elements pushed to the vector
- * is transferred to caller. Note that the
- * CoordinateSequence associated with the
- * returned SegmentString elements are allocated
- * by this function, so must also be destroyed
- * by caller.
- * TODO: check if this can be optimized by leaving
- * ownership of actual CoordinateSequence
- * to the passed Geometry.
+ * is transferred to caller.
static void extractSegmentStrings(const geom::Geometry * g,
SegmentString::ConstVect& segStr)
Modified: trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp
--- trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/AbstractPreparedPolygonContains.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -96,7 +96,6 @@
for (std::size_t i = 0, ni = lineSegStr.size(); i < ni; i++ )
- delete lineSegStr[i]->getCoordinates();
delete lineSegStr[i];
Modified: trunk/src/geom/prep/PreparedLineString.cpp
--- trunk/src/geom/prep/PreparedLineString.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/PreparedLineString.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -37,7 +37,6 @@
for ( noding::SegmentString::ConstVect::size_type i = 0,
ni = segStrings.size(); i < ni; ++i )
- delete segStrings[ i ]->getCoordinates();
delete segStrings[ i ];
Modified: trunk/src/geom/prep/PreparedLineStringIntersects.cpp
--- trunk/src/geom/prep/PreparedLineStringIntersects.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/PreparedLineStringIntersects.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -61,7 +61,6 @@
bool segsIntersect = fssif->intersects( &lineSegStr);// prepLine.getIntersectionFinder()->intersects(lineSegStr);
for ( size_t i = 0, ni = lineSegStr.size(); i < ni; i++ ) {
- delete lineSegStr[ i ]->getCoordinates();
delete lineSegStr[ i ];
Modified: trunk/src/geom/prep/PreparedPolygon.cpp
--- trunk/src/geom/prep/PreparedPolygon.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/PreparedPolygon.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -52,7 +52,6 @@
for ( std::size_t i = 0, ni = segStrings.size(); i < ni; i++ )
Modified: trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp
--- trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/PreparedPolygonContainsProperly.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -60,7 +60,6 @@
bool segsIntersect = prepPoly->getIntersectionFinder()->intersects( &lineSegStr);
Modified: trunk/src/geom/prep/PreparedPolygonIntersects.cpp
--- trunk/src/geom/prep/PreparedPolygonIntersects.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/geom/prep/PreparedPolygonIntersects.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -60,7 +60,6 @@
Modified: trunk/src/noding/SegmentNodeList.cpp
--- trunk/src/noding/SegmentNodeList.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/noding/SegmentNodeList.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -61,11 +61,6 @@
delete splitEdges[i];
- for(size_t i=0, n=splitCoordLists.size(); i<n; ++i)
- delete splitCoordLists[i];
SegmentNode*
@@ -285,16 +280,14 @@
if (useIntPt1) pts->setAt(ei1->coord, ipt++);
+ // SegmentString takes ownership of CoordinateList 'pts'
SegmentString *ret = new NodedSegmentString(pts, edge.getData());
#if GEOS_DEBUG
std::cerr<<" SegmentString created"<<std::endl;
#endif
splitEdges.push_back(ret);
- // Keep track of created CoordinateSequence to release
- // it at this SegmentNodeList destruction time
- splitCoordLists.push_back(pts);
return ret;
Modified: trunk/src/operation/buffer/BufferBuilder.cpp
--- trunk/src/operation/buffer/BufferBuilder.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/operation/buffer/BufferBuilder.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -87,7 +87,7 @@
std::vector<Geometry*> lines;
while(it != et) {
const SegmentString* ss = *it;
- LineString* line = fact->createLineString(ss->getCoordinates());
+ LineString* line = fact->createLineString(ss->getCoordinates()->clone());
lines.push_back(line);
++it;
@@ -184,10 +184,13 @@
CoordinateSequence* seq = lineList[i];
+ // SegmentString takes ownership of CoordinateSequence
SegmentString* ss = new NodedSegmentString(seq, NULL);
curveList.push_back( ss );
+ lineList.clear();
// Node these SegmentStrings.
Noder* noder = getNoder( precisionModel );
noder->computeNodes( &curveList );
@@ -211,10 +214,6 @@
for (size_t i=0, n=curveList.size(); i<n; ++i) delete curveList[i];
curveList.clear();
- for (size_t i=0, n=lineList.size(); i<n; ++i) delete lineList[i];
- lineList.clear();
Geometry* singleSided = geomFact->createMultiLineString(
singleSidedNodedEdges );
Modified: trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/src/operation/buffer/OffsetCurveSetBuilder.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -72,7 +72,6 @@
SegmentString* ss = curveList[i];
- delete ss->getCoordinates();
delete ss;
for (size_t i=0, n=newLabels.size(); i<n; ++i)
@@ -119,6 +118,7 @@
// add the edge for a coordinate list which is a raw offset curve
Label *newlabel = new Label(0, Location::BOUNDARY, leftLoc, rightLoc);
+ // coord ownership transferred to SegmentString
SegmentString *e=new NodedSegmentString(coord, newlabel);
// SegmentString doesnt own the sequence, so we need to delete in
Modified: trunk/tests/unit/noding/NodedSegmentStringTest.cpp
--- trunk/tests/unit/noding/NodedSegmentStringTest.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/tests/unit/noding/NodedSegmentStringTest.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -76,15 +76,13 @@
ensure_equals(cs->size(), 2u);
- SegmentStringAutoPtr ss(makeSegmentString(cs.get()));
+ SegmentStringAutoPtr ss(makeSegmentString(cs.release()));
ensure(0 != ss.get());
ensure_equals(ss->size(), 2u);
ensure_equals(ss->getData(), (void*)0);
- ensure_equals(ss->getCoordinates(), cs.get());
ensure_equals(ss->getCoordinate(0), c0);
ensure_equals(ss->getCoordinate(1), c1);
@@ -113,15 +111,13 @@
@@ -153,15 +149,13 @@
ensure_equals(cs->size(), 4u);
ensure_equals(ss->size(), 4u);
@@ -215,7 +209,7 @@
cs->add(p0);
cs->add(p1);
ensure_equals(ss->getNodeList().size(), 0u);
Modified: trunk/tests/unit/noding/SegmentNodeTest.cpp
--- trunk/tests/unit/noding/SegmentNodeTest.cpp 2011-07-26 15:09:35 UTC (rev 3450)
+++ trunk/tests/unit/noding/SegmentNodeTest.cpp 2011-07-26 16:23:30 UTC (rev 3451)
@@ -68,7 +68,7 @@
// Create SegmentString instance
- NodedSegmentString segment(cs.get(), 0);
+ NodedSegmentString segment(cs.release(), 0);
ensure_equals( segment.size(), coords_size );
@@ -116,7 +116,7 @@
@@ -158,7 +158,7 @@
@@ -200,7 +200,7 @@
More information about the geos-commits
