[geos-commits] r3453 - in trunk: include/geos/noding src/noding
src/operation/buffer
svn_geos at osgeo.org
Wed Jul 27 04:12:56 EDT 2011
Author: strk
Date: 2011-07-27 01:12:56 -0700 (Wed, 27 Jul 2011)
New Revision: 3453
trunk/include/geos/noding/Noder.h
trunk/include/geos/noding/SegmentNodeList.h
trunk/src/noding/SegmentNodeList.cpp
trunk/src/operation/buffer/BufferBuilder.cpp
Change Noder interface to transfer ownership of noded segment strings to caller. Delete them as soon as converted to Edges in BufferOp.
Modified: trunk/include/geos/noding/Noder.h
--- trunk/include/geos/noding/Noder.h 2011-07-26 16:36:42 UTC (rev 3452)
+++ trunk/include/geos/noding/Noder.h 2011-07-27 08:12:56 UTC (rev 3453)
@@ -1,5 +1,4 @@
- * $Id$
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
@@ -64,7 +63,7 @@
* The SegmentStrings have the same context as their parent.
* @return a newly allocated std::vector of const SegmentStrings.
- * Caller is responsible to delete it
+ * Caller is responsible to delete container and elements.
virtual std::vector<SegmentString*>* getNodedSubstrings() const=0;
@@ -83,13 +82,3 @@
#endif // GEOS_NODING_NODER_H
- * $Log$
- * Revision 1.2 2006/03/24 09:52:41 strk
- * USE_INLINE => GEOS_INLINE
- * Revision 1.1 2006/03/09 16:46:49 strk
- * geos::geom namespace definition, first pass at headers split
Modified: trunk/include/geos/noding/SegmentNodeList.h
--- trunk/include/geos/noding/SegmentNodeList.h 2011-07-26 16:36:42 UTC (rev 3452)
+++ trunk/include/geos/noding/SegmentNodeList.h 2011-07-27 08:12:56 UTC (rev 3453)
@@ -61,9 +61,6 @@
// the parent edge
const NodedSegmentString& edge;
- // This vector is here to keep track of created splitEdges
- std::vector<SegmentString*> splitEdges;
* Checks the correctness of the set of split edges corresponding
* to this edge
@@ -77,6 +74,8 @@
* (and including) the two intersections.
* The label for the new edge is the same as the label for the
* parent edge.
+ * ownership of return value is transferred
SegmentString* createSplitEdge(SegmentNode *ei0, SegmentNode *ei1);
Modified: trunk/src/noding/SegmentNodeList.cpp
--- trunk/src/noding/SegmentNodeList.cpp 2011-07-26 16:36:42 UTC (rev 3452)
+++ trunk/src/noding/SegmentNodeList.cpp 2011-07-27 08:12:56 UTC (rev 3453)
@@ -56,11 +56,6 @@
delete *it;
- for(size_t i=0, n=splitEdges.size(); i<n; ++i)
- delete splitEdges[i];
SegmentNode*
@@ -217,6 +212,7 @@
#endif
+/*private*/
void
SegmentNodeList::checkSplitEdgesCorrectness(std::vector<SegmentString*>& splitEdges)
@@ -286,7 +282,6 @@
#if GEOS_DEBUG
std::cerr<<" SegmentString created"<<std::endl;
#endif
- splitEdges.push_back(ret);
return ret;
Modified: trunk/src/operation/buffer/BufferBuilder.cpp
--- trunk/src/operation/buffer/BufferBuilder.cpp 2011-07-26 16:36:42 UTC (rev 3452)
+++ trunk/src/operation/buffer/BufferBuilder.cpp 2011-07-27 08:12:56 UTC (rev 3453)
@@ -194,11 +194,13 @@
// Node these SegmentStrings.
Noder* noder = getNoder( precisionModel );
noder->computeNodes( &curveList );
SegmentString::NonConstVect* nodedEdges = noder->getNodedSubstrings();
// Create a geometry out of the noded substrings.
std::vector< Geometry* >* singleSidedNodedEdges =
new std::vector< Geometry * >();
+ singleSidedNodedEdges->reserve(nodedEdges->size());
for ( unsigned int i = 0, n = nodedEdges->size(); i < n; ++i )
SegmentString* ss = ( *nodedEdges )[i];
@@ -206,10 +208,12 @@
Geometry* tmp = geomFact->createLineString(
ss->getCoordinates()->clone()
+ delete ss;
singleSidedNodedEdges->push_back( tmp );
- if ( nodedEdges != &curveList ) delete nodedEdges;
+ delete nodedEdges;
for (size_t i=0, n=curveList.size(); i<n; ++i) delete curveList[i];
curveList.clear();
@@ -526,25 +530,22 @@
const Label* oldLabel = static_cast<const Label*>(segStr->getData());
CoordinateSequence* cs = CoordinateSequence::removeRepeatedPoints(segStr->getCoordinates());
+ delete segStr;
if ( cs->size() < 2 )
- delete cs; // we need to take care of the memory here as cs is a new sequence
- return; // don't insert collapsed edges
+ // don't insert collapsed edges
+ delete cs;
+ return;
- // we need to clone SegmentString coordinates
- // as Edge will take ownership of them
- // TODO: find a way to transfer ownership instead
- // Who will own the edge ? FIXME: find out and handle that!
+ // Edge takes ownership of the CoordinateSequence
Edge* edge = new Edge(cs, *oldLabel);
// will take care of the Edge ownership
insertUniqueEdge(edge);
- if ( nodedSegStrings != &bufferSegStrList )
- delete nodedSegStrings;
+ delete nodedSegStrings;
if ( noder != workingNoder ) delete noder;
More information about the geos-commits
