[geos-commits] r3266 - in trunk/php: . test
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Mar 4 12:05:45 EST 2011
Author: strk
Date: 2011-03-04 09:05:44 -0800 (Fri, 04 Mar 2011)
New Revision: 3266
   trunk/php/geos.c
   trunk/php/test/test.php
PHP: add relateBoundaryNodeRule method to GEOSGeometry object
Modified: trunk/php/geos.c
--- trunk/php/geos.c	2011-03-04 16:38:16 UTC (rev 3265)
+++ trunk/php/geos.c	2011-03-04 17:05:44 UTC (rev 3266)
@@ -188,6 +188,7 @@
 PHP_METHOD(Geometry, pointOnSurface);
 PHP_METHOD(Geometry, centroid);
 PHP_METHOD(Geometry, relate);
+PHP_METHOD(Geometry, relateBoundaryNodeRule);
 PHP_METHOD(Geometry, simplify); /* also does topology-preserving */
 PHP_METHOD(Geometry, extractUniquePoints);
 PHP_METHOD(Geometry, disjoint);
@@ -247,6 +248,7 @@
     PHP_ME(Geometry, pointOnSurface, NULL, 0)
     PHP_ME(Geometry, centroid, NULL, 0)
     PHP_ME(Geometry, relate, NULL, 0)
+    PHP_ME(Geometry, relateBoundaryNodeRule, NULL, 0)
     PHP_ME(Geometry, simplify, NULL, 0)
     PHP_ME(Geometry, extractUniquePoints, NULL, 0)
     PHP_ME(Geometry, disjoint, NULL, 0)
@@ -837,6 +839,36 @@
+ * GEOSGeometry::relateBoundaryNodeRule(otherGeom, rule)
+    GEOSGeometry *this;
+    GEOSGeometry *other;
+    zval *zobj;
+    char* pat;
+    long int bnr = GEOSRELATE_BNR_OGC;
+    char* retStr;
+    this = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+    if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "ol",
+        &zobj, &bnr) == FAILURE)
+        RETURN_NULL();
+    other = getRelay(zobj, Geometry_ce_ptr);
+    /* we'll compute it */
+    pat = GEOSRelateBoundaryNodeRule(this, other, bnr);
+    if ( ! pat ) RETURN_NULL(); /* should get an exception first */
+    retStr = estrdup(pat);
+    GEOSFree(pat);
+    RETURN_STRING(retStr, 0);
  * GEOSGeometry GEOSGeometry::simplify(tolerance)
  * GEOSGeometry GEOSGeometry::simplify(tolerance, preserveTopology)
@@ -2542,6 +2574,19 @@
         GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE,
         CONST_CS|CONST_PERSISTENT);
+    REGISTER_LONG_CONSTANT("GEOSRELATE_BNR_MOD2", GEOSRELATE_BNR_MOD2,
+        CONST_CS|CONST_PERSISTENT);
+    REGISTER_LONG_CONSTANT("GEOSRELATE_BNR_OGC", GEOSRELATE_BNR_OGC,
+    REGISTER_LONG_CONSTANT("GEOSRELATE_BNR_ENDPOINT", GEOSRELATE_BNR_ENDPOINT,
+    REGISTER_LONG_CONSTANT("GEOSRELATE_BNR_MULTIVALENT_ENDPOINT",
+        GEOSRELATE_BNR_MULTIVALENT_ENDPOINT,
+    REGISTER_LONG_CONSTANT("GEOSRELATE_BNR_MONOVALENT_ENDPOINT",
+        GEOSRELATE_BNR_MONOVALENT_ENDPOINT,
     return SUCCESS;
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php	2011-03-04 16:38:16 UTC (rev 3265)
+++ trunk/php/test/test.php	2011-03-04 17:05:44 UTC (rev 3266)
@@ -35,6 +35,12 @@
         $this->assertEquals(7, GEOS_GEOMETRYCOLLECTION);
         $this->assertEquals(1, GEOSVALID_ALLOW_SELFTOUCHING_RING_FORMING_HOLE);
+        $this->assertEquals(1, GEOSRELATE_BNR_MOD2);
+        $this->assertEquals(1, GEOSRELATE_BNR_OGC);
+        $this->assertEquals(2, GEOSRELATE_BNR_ENDPOINT);
+        $this->assertEquals(3, GEOSRELATE_BNR_MULTIVALENT_ENDPOINT);
+        $this->assertEquals(4, GEOSRELATE_BNR_MONOVALENT_ENDPOINT);
     public function testWKTReader__construct()
@@ -1007,6 +1013,23 @@
+    public function testGeometry_relateBoundaryNodeRule()
+        $reader = new GEOSWKTReader();
+        $writer = new GEOSWKTWriter();
+        $writer->setRoundingPrecision(0);
+        $g = $reader->read('LINESTRING(0 0, 2 4, 5 5, 0 0)');
+        $g2 = $reader->read('POINT(0 0)');
+        $ret = $g->relateBoundaryNodeRule($g2, GEOSRELATE_BNR_OGC);
+        $this->assertEquals('0F1FFFFF2', $ret);
+        $ret = $g->relateBoundaryNodeRule($g2, GEOSRELATE_BNR_ENDPOINT);
+        $this->assertEquals('FF10FFFF2', $ret);
     public function testGeometry_polygonize()
@@ -2157,5 +2180,4 @@
         $this->assertFalse(GEOSRelateMatch('0FFFFFFF2', '0FFFFFFFF'));
More information about the geos-commits mailing list
